Try over a search engine a doc about liquid zink such a physical parameter cannot be calculated it has to be measured. If you do not find the only way is to build a system to generate a flow of liquid zink and via the physical model measure parameters which could give you a value for the viscosity. For instance a laminar flow where the flow is depending on viscosity.
