Previous in Forum: Gas Compression & Combustion Efficiency   Next in Forum: Fittings for a Stainless Steel Pipe
Contra Rotating Axial Fans
02/23/2012 11:21 AM
Cant seem to find an answer to this.
knowing that a contra-rotating axial fan provides 2-3 times the static as a single stage axial fan for a given air volume, in what application would you use a contra-rotating fan as opposed to a muti-stage axial fan for this purpose.
Any help appreciated, cheers
Re: Contra Rotating Axial Fans
02/23/2012 3:38 PM
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
02/23/2012 7:20 PM
Several Aircarft manufactures (fixed wing and rotorcraft) use contra-rotating propellors as they eliminate rotational torque and increase power.
Helicopters with this system can lift heavier loads and fly faster, they also have the benefit of not requiring the additional complexity of having the tail rotor.
The V22 - Osprey uses this capability to mix the VTOL functionality of a Helo with the speed and range of a fixed wing aircraft.
V-22 OSPRAY Formidable Aircraft - YouTube
Chinooks use this to lift massive loads.
And Fixed wing aircraft have used them at various times to increase speed and manuverability.
In some processes, Ducted fans use contra-rotating fans to produce a laminar air flow. i.e. wind tunnels.
Regards,
Sapper
It's all about the Boom! - MythBusters
03/09/2012 2:37 AM
Expensive to run and operate… Still not very safe. It is the only craft that is not insulated in order to reduce weight..it cannot be used in place of multi-stage axial fans to boost up air only where a variable balance between the static and dynamic displacement of air is required such as in the case of Osprey.
Register to Reply 3 comments
mazhur (1); Sapper (1); SolarEagle (1)
