Previous in Forum: Vessel-Bottom Cone-Stiffeners   Next in Forum: Evaporative Air Cooler
Proper Electrode for Welding of HK40 Material
02/29/2012 1:52 AM
hi!what would be the proper electrode (with its MOC) to use to weld the cracked HK40 materials
Anonymous Poster #2
Re: proper electrode for welding of HK40 material
02/29/2012 3:10 AM
HK40?
02/29/2012 4:11 AM
New HK-40 material (under A297 or A351 or A567) has very good weldability but Cracked HK-40 may not be easy material to be weld repaired. You may have to work out the procedure for its anealing before welding. However you can try A 5.4: E 310-16 weld elecrods, which matches very closely the composition of HK 40.( 25Cr, 20 Ni, 0.4C etc.)
