Hello All -
Our maintenance crew recently discovered that a newly installed compressor was causing oil to get into our shop air - showing up in pneumatic valves in our production equipment and dripping from a few joints in our feed lines. Although the install problem that caused the oil problem has been fixed, it's clear that there now is oil in the lines and there is oil in some (most/all?) of our equipment.
This is a new shop. There were no traps installed in the "air drops" and only one-third of the equipment has coalesing filters.
Will the oil damage pneumatic valves and cylinders? If so, what's the best method to prevent oil (from the lines) from getting into equipment?
Thanks for the help.
