Previous in Forum: In Which Case the Friction is Higher?   Next in Forum: PIR Sensor
Selection of a Distribution Transformer
03/30/2012 2:39 AM
Dear Friends,
what are the points to be considered in selection of a Distribution Transformer
for the factory load
having connected load of 3000 KW,
expected maximum demand 2625 KVA and
aload factor of 1900 KVA
regards
Subhash
Re: Selection of a Distribution Transformer
03/30/2012 3:26 AM
Make sure you have enough juice....
03/31/2012 11:35 AM
Dear Solar Eagle,
I think you are very poor in making Juice!!!!!!!!!!!
Are you found of Juice?
which one ?
we will send from CR4 to you..................
03/30/2012 4:03 PM
what do you mean by "aload factor" 1900 kVA. If you mean "load factor" it is always less than one.
03/31/2012 11:28 AM
I am sorry, it is average load, and yes load factor will be alway less, and idle load factor is 0.6, if i am not wrong
04/01/2012 2:20 PM
Do not worry about the load what it is but you need to follow the correct rule how to select transformer whether it is 1 kVA or 1000kVA. Here is a link for you, it is showing how to select a transformer
Steps for Selecting the Proper Transformer
nobodysomebody47 (2); SolarEagle (1); SUBH_ASHD (2)
