Previous in Forum: Power Frequency Around the Globe   Next in Forum: Current Carrying Capacity of 795 MCM ACSR MALLARD
19 comments
Transformer Leakage
05/10/2012 10:26 PM
hello friends recently we installed a transformer we made all necessary connection next day when we went to the inspection of transformer oil is leaking from breather transformer has been not charged yet if anyone can tell the reason share with me
Good Answers: 1693
Re: transformer leakage
05/10/2012 10:40 PM
The transformer manufacturer would be the best source of advice.
Because they:
1. Have seen the transformer before
2. Built it and know how much oil they put in it when built
3. Won't have to make wild guesses based on absolutely no credible information provided by you.
4. May have some incentive to help you, which we don't
CALL THE MANUFACTURER OF THE TRANSFORMER!!!!!!!!!!!!!!
05/11/2012 1:55 AM
05/11/2012 3:14 AM
#1↑ +
5. Will have experience elsewhere of other transformer issues pertaining to their equipment that they can bring to the party.
Good Answers: 59
Re: Transformer Leakage
05/11/2012 10:33 PM
Oh pleaase! Leaky vessel IS a question to this community?!?
05/11/2012 11:47 PM
You are not making sense. Try some punctuation to define where one sentence ends and another one starts.
05/12/2012 4:03 AM
Is this an oil filled transformer? Does it have a sign on it saying 'This Way Up'? Please check and report back for further instructions.
Good Answers: 982
05/12/2012 7:56 AM
I think you have something here. Any fluid filled vessel with a breather vent should have the vent above the fluid line so that air can breathe in and out of the vessel. For fluid to leak out of a breather vent fluid must be at the breather vent elevation. Either the transformer is overfilled, the transformer is not level or in the general case the transformer is oriented wrong.
Great! Now how do we claim our consultancy fee from someone that cannot fix a leak?
05/12/2012 6:39 AM
the problem is that it might have been over filled from the manufacturer, the second reason is that may in the transportation it have been tilted thus making the oil from the main to find its way to the breather, and also check if your oil bath in the breather is not leaking
Good Answers: 181
05/12/2012 10:15 AM
Every transformer I've fitted has been delivered with the breather blanked off to prevent oil getting in to the breather in transit.
05/12/2012 10:11 AM
Assuming that this an oil filled transformer it should have a means of checking the oil level, eg Sight glass. Is the level correct for temperature? Is the transformer on a level base? If it is a plain breather it may have a bung fitted for transport. When removing this you sometimes get oil leaking that has been sloshed about during transport. If the transformer has a tank on the top, the sight glass will be on that, otherwise on the transformer. If oil continues to come from the breather the transformer is over filled. A silica gel filter might be fitted, if so empty any oil from this. If this filter has been filled with oil empty the container, clean out and fit a new filter element.
Some sort of response from you would be in order. Perhaps even thank you to all forum members who have taken the time to respond to your question.
05/12/2012 3:56 PM
This is an assumption!!!
Transformer was located or stored cold.
Transformer was moved into hot sun.
Transformer oil warmed up and expanded.
Maybe?
Good Answers: 1693
05/12/2012 4:08 PM
Wouldn't you assume that the manufacturer filled the transformer to the level corresponding to the volume of oil with the transformer at operating temperature?
Good Answers: 982
05/12/2012 5:19 PM
I think this is a reasonable, plausible assumption considering that once again we know absolutely nothing about the transformer environment. The OP hasn't even given us their location let alone anything about this transformer. As far as we know this transformer is built in Russia to "normal" parameters but has been installed in the sun of the Thar desert. Remember we only have the information from somebody that cannot figure out how to diagnose a brand new vessel that leaks.
05/12/2012 6:08 PM
For all we know it might have been installed upside down.
Good Answers: 1693
05/12/2012 6:13 PM
Doubt it. They wouldn't have been able to read the nameplate.
Good Answers: 982
05/12/2012 6:22 PM
If they could read the nameplate they'd know who manufactured it and could contact them!
05/13/2012 4:35 AM
yes the couse of oil leaking in your trasformer is to much load he obsurved thats is why oil is leaking you need to change a bigger TR to prevnt damaging your TR and also you need to be carefully calculte the community load so you will be totally install a correct TR,
hope this will be help to guys !
i want ot helf piple need assistance and to share my knowleged in technical
Good Answers: 1693
05/13/2012 10:28 AM
toink,
Perhaps it would help if you read the original post before blundering into the discussion without any facts.
04/19/2014 4:28 AM
checking the position of the breather.and the oil level from the oil sight glass.Generally the oil leaking do not happen.
Maybe the breather is lower the oil level.
Generally the breather is on the top of the transformer.
Register to Reply 19 comments
GopelT (1); grandmfg (1); leveles (1); lyn (4); martin882 (1); nobodysomebody47 (1); PWSlack (1); Rainmain (2); redfred (3); StandardsGuy (2); toink (1); TonyS (1)
