Previous in Forum: Wind Turbine Generator   Next in Forum: REF Protection for Transformer
12 comments
What is a Transformer?
05/25/2012 10:48 PM
What is a transformer?
Good Answers: 982
Re: What is a trnsformer
05/25/2012 10:54 PM
It probably is just a misspelled transformer.
It is amazing what one little vowel can do.
05/25/2012 11:46 PM
The one you are interested in is an electrical device having n1 primary and n2 secondary turns of wire around a common magnetic core. If v1 volts are applied to the primary winding, then the secondary winding produces v2 = v1n2/n1 volts.
Good Answers: 181
05/26/2012 12:24 AM
Here's one I made earlier
Canada - Member - New Member
05/26/2012 1:31 AM
The good ones are Autobots, but the bad ones are Deceptocons.
Knowledge makes what was impossible, seem easy.
05/26/2012 2:18 AM
A transformer is an electrical device for reducing or increasing voltage generally speaking, where line voltage is is run through a coil in close proximity to another coil, the secondary coil then picks up part of the voltage according to the number of coils contained in each coil...more specifically...
"A transformer is a device that transfers electrical energy from one circuit to another through inductively coupled conductors-the transformer's coils. A varying current in the first or primary winding creates a varying magnetic flux in the transformer's core and thus a varying magnetic field through the secondary winding. This varying magnetic field induces a varying electromotive force (EMF), or "voltage", in the secondary winding. This effect is called inductive coupling.
If a load is connected to the secondary, current will flow in the secondary winding, and electrical energy will be transferred from the primary circuit through the transformer to the load. In an ideal transformer, the induced voltage in the secondary winding (Vs) is in proportion to the primary voltage (Vp) and is given by the ratio of the number of turns in the secondary (Ns) to the number of turns in the primary (Np) as follows:
By appropriate selection of the ratio of turns, a transformer thus enables an alternating current (AC) voltage to be "stepped up" by making Ns greater than Np, or "stepped down" by making Ns less than Np. The windings are coils wound around a ferromagnetic core, air-core transformers being a notable exception.
Transformers range in size from a thumbnail-sized coupling transformer hidden inside a stage microphone to huge units weighing hundreds of tons used to interconnect portions of power grids. All operate on the same basic principles, although the range of designs is wide. While new technologies have eliminated the need for transformers in some electronic circuits, transformers are still found in nearly all electronic devices designed for household ("mains") voltage. Transformers are essential for high-voltage electric power transmission, which makes long-distance transmission economically practical."
http://en.wikipedia.org/wiki/Transformer
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
05/26/2012 6:12 AM
Great!!!
I wonder nobody replied as "Dont ask homework questions", "This is not homework section", "google is there"!!!!
you need to go, to get something
Good Answers: 42
05/26/2012 9:18 AM
Because this is a long week end and every one is in good mood.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
07/26/2013 8:09 AM
Your information about tranformer is very nice. But I want to ask you one question! In tranformer's, the primary voltage is high but current is less whereas the secondary voltage is less but the current value is much higher! I want to know the reason. Please explain me.
All is well !!! All is well !!
Good Answers: 982
07/26/2013 10:11 AM
The conservation of energy is the root of your answer. Now how this universal law gets applied in a transformer takes a lot of schooling. Electromagnetism is a sophomore or junior level class in college.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: What Is a Transformer?
05/28/2012 8:34 PM
More than meets the eyes!!
It's all about the Boom! - MythBusters
06/07/2012 1:53 PM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Good Answers: 804
06/07/2012 9:34 PM
"A transformer is a little bird tweeting in meadow; a transformer is a wreath of pretty flowers which ... smell bad..."
Register to Reply 12 comments
amnakhan1245 (1); bharath boss (1); Elroy (1); JRaef (1); redfred (2); Sapper (1); sharath4 (1); SolarEagle (1); TonyS (1); Tornado (1); V.I.Abraham (1)
