Previous in Forum: Level Gauge and DP Level   Next in Forum: Sun Shields for Transmitters
Level Transmitter -Radioactive
06/11/2012 6:43 AM
Dear All,
For specifying a Level transmitter radioactive type is ther any Guidelines or Standards which we can follow like the Source type or Strength , container material .
Or should we consider like Vendor to Advise ( VTA )
Regards
Jose
Re: Level Transmitter -Radioactive
06/11/2012 7:46 AM
Surely there are some discussions taking place with vendors?
06/11/2012 8:52 AM
Go here: Search GlobalSpec.
Type "level transmitter" into the search box.
Press enter.
Good Answers: 21
06/12/2012 3:02 PM
Choose big...eg Endress & Hauser manufactures such level sensors, and are familiar with the proper requirements. You need best vendor advice..
In almost all countries, you require a government authority/ licence to own a radioactive source.
Note that the transmitter itself is not radioactive.
Typically, there is a radiation source (isotope) for which strength/ activity you require very professional advice...A radiation sensor continuously detects radiation passing through a vessel from this source. The process medium resists/ inhibits the radiation stream, but at the point where there is no resisitance to the stream , the sensor / receiver will be exposed to a higher activity of radiation.
eg in a horizontal drum/ vessel, the process medium's resistance to the radiation stream will be highest at the widest point of the drum, if the process level is above that height .
This signal is converted (typically) into a 4-20mA signal and your 'level' value is transmitted as an electronic signal by an independent transmitter. Other configurations are possible, but this is the most common.
Register to Reply 3 comments
Hilton (1); lyn (1); PWSlack (1)
