Previous in Forum: Sine Wave to Square Wave Converter Power by 12-18 Volt   Next in Forum: HID (Na) Light Fixture Works Intermittently
10 comments
DC to DC Step-up Transformer
07/01/2012 8:46 AM
Hi, just would like to ask a favor for a little help. How do I make a circuit to step-up voltage from DC to DC?
Re: DC to DC Step-up Transformer
07/01/2012 9:00 AM
Good Answers: 982
07/01/2012 10:21 AM
You cannot do this with just a transformer. DC does not conduct from the primary to the secondary of a transformer. Since what you ask for cannot be done with what you are looking for, the question now is what do you need?
If you are trying to take the power from one DC power source (AA battery) and convert this power to a different DC voltage power source then a DC to DC switching supply is what you need. To choose the correct supply you will need to know the voltage and maximum current will be needed at the output. You will also have to know the power available from your original DC power source. The drawback of this approach is that the output power will always be less than the power taken from the sole power source. You should also clarify if the output is isolated from the input. One also should know if the output is supposed to be regulated (constant voltage or current) as the input DC voltage changes.
If instead you are trying to track a small changing DC signal to a larger signal then what you are looking for is a DC amplifier. The gain desired must be specified for a circuit to be crafted. Usually a DC amplifier has at least two power sources available, the DC voltage to be measured and a voltage source slightly larger than the maximum output desired. The advantage of this approach is that very little power must be taken from the original DC signal. So the output power can easily exceed the power taken from the measured DC voltage.
07/01/2012 10:40 AM
Hi,
You can imagine the DC batteries in series.
Same way, You can configure the same, by rectifiers in series, with capacitors in load side of each rectifiers, connected in series.
Of course, you have to design the power ratings of each components, as per your needs. PRV & current rating of each rectifier diodes should be taken care.
Exploring the Science of Electricity
07/01/2012 11:21 AM
What you seem to be describing is a voltage mulitiplier which works on a square waveform or pulses, not DC.
07/01/2012 11:51 AM
Basically, you convert DC to AC through a multi-vibrator circuit; step up the AC through a transformer and convert the AC back down to DC through a rectifier circuit. The power out will always be less than the power in.
Mr.Ron from South Ms.
Good Answers: 58
07/01/2012 6:42 PM
So an old auto ignition coil is not a DC step up?
mike k
Good Answers: 982
07/01/2012 7:14 PM
It does step up but it does not produce DC.
07/01/2012 7:26 PM
If connected to a 12VDC supply, an ignition coil would produce no output (after some initial wobbles following the connection). The high voltage which produces the spark only occurs after the current is interrupted by the contacts opening.
Also (as redfred pointed out) when the primary current is interrupted, the secondary produces AC.
So - correct. It is not a DC step up.
07/02/2012 2:42 AM
No.
It works on interrupting the current and produces a pulse.
Good Answers: 11
07/12/2012 10:59 AM
interesting, must be like that of flash of a camera works
harry potter (1); JohnDG (2); mike k (1); Noudge79 (1); redfred (2); ronseto (1); user-deleted-1105 (2)
