Previous in Forum: Inductor Coil Design   Next in Forum: Computer with Elctrical
Battries
08/01/2012 1:25 PM
how many types engine battries... engine battries cells are designed in series or parallal
Re: battries
08/01/2012 1:41 PM
"engine battries cells are designed in series or parallal"
Well, lets see. If the cells of a typical lead acid battery were connected in parallel the battery would measure somewhere around 2 volt. Right? What is the actual voltage measured, and why is that?
Re: battries
08/01/2012 2:08 PM
max volotage 12 volts. total 4 battries are connected in engine.... is starting purpose....how to start the engine.. what exitation....
Re: battries
08/01/2012 2:12 PM
Well, that is an entirely different question, or I wildly misunderstood your original post.
Please slow down a little bit and explain, as completely as you can, just what we can help you to do. What engine? Is this a diesel powered generator?
Re: battries
08/01/2012 2:20 PM
I see you are a student, so you are not involved an getting something to function.
Can you tell us: Has your money for textbooks been repurposed?
Re: battries
08/02/2012 3:14 AM
Engine manufacturer's manual?
Read it?
Re: battries
08/14/2012 2:20 AM
24 v battary .... 6 cells are there..
Re: battries
08/14/2012 9:34 AM
Good morning.
You started off with "how many types engine battries... engine battries cells are designed in series or parallal"
Then you told us "max volotage 12 volts. total 4 battries are connected in engine...."
And now you tell us "24 v battary .... 6 cells are there.."
If you wish to have some advice, you really do need to tell us what is going on.
Doorman (4); PWSlack (1); rambabugopisetti (2)
