Previous in Forum: Are Polyethylene and DEET Compatible   Next in Forum: Remove Aluminum but Leave Copper
Chemical Reacton in Electrolyte Cell
08/30/2012 5:56 AM
Hi to all,
I'm an Automotive Engineer.
Currently I'm working in a industry of making automoblie parts
As I've only 1 yr industrial experience i need ur experties to do better job in my industry
Recently i got a project to calculate a Hard chrome plating Time on the piston rod of shock absorber
For this purpose i need to know following things
1-Current density -- Actual Current divided by surface area of piston exposed for plating -this is the right way to calculate?
2-Current Efficency
for the current efficency i need to know what the chemical reaction is going in the Electroplating cell
As for hard chrome plalting we used setup similar electrolytic cell having
anode= Lead metal & Cathode = Mild steel (Base metal for plating)
we used Electroyte solution CrO3 with catalyst H2SO4 and SiF6-2
can u guys tell me chemical reaction is going on at anode & cathode
plus u also suggest me how much amount of catalyst should be used & also suggest best positive radicals for Silicon Hexa fluoride (valency=-2) for the desire chrome plating
For your information
Plating thickness requires 25micron meter in the length of 236mm having a diameter of 21.943~21.973mm
I m looking forward the experties response
Thaking you
Regards
Haris Aslam
Re: Chemical Reacton in Electrolyte cell
08/30/2012 7:07 AM
Re: Chemical Reacton in Electrolyte Cell
08/30/2012 8:33 PM
Haris,
You're just a mess.
Did you ever get that "1KW gnerator through which i want to connect a DC motor which transmit the elcetrical power to the axle through the belt or chain mechanism" with no input power to the generator to work????
08/31/2012 3:59 AM
This was the initial questions i asked when i went for design of hybrid vehicle
But now i already made a hybrid prototype vehicle with a DC motor + ICE & where i used to charge the battery from the alternator.
www.youtube.com/watch?v=n7N9z4HoCSM
u can see this link..
Register to Reply 3 comments
Anonymous Poster (1); Haris (1); lyn (1)
