Previous in Forum: Creepage Distance   Next in Forum: T5 28W/54W Tube
14 comments
Low Powered Ceilling Fan
09/27/2012 1:27 PM
Is it possible to build a low powered ceilling fan? Is it possible to convert the fan into a generator? If converted, how much power will I get?
Re: low powered ceilling fan
09/27/2012 1:29 PM
watch in you tube as ggcamie
Reply Off Topic (Score 6)
Re: low powered ceiling fan
09/27/2012 1:35 PM
You can build anything your heart desires, your skills allow and that do not violate the laws of nature. You can even convert a fan into a generator. However, unless the draft in your room is strong enough to spin the fan without any electric power applied then you cannot produce any electric power with your fan.
09/27/2012 2:01 PM
thanks, thanks alot for your kind information . recently i modified 60 watt coventional ceilling fan into dc fan. which run on least power as 5 watts to spin the hub above the rated speed .at this case is it possible to generate more more then the input . plg help me ............
Good Answers: 34
09/27/2012 2:50 PM
In this universe, out put is always less than input. No body can ever change that.
09/27/2012 3:01 PM
Is this you and your devices?
There are a lot of members here who will be very happy to expose these. I fear you have very little time to thoroughly explain these, otherwise this thread will likely be removed.
09/27/2012 3:05 PM
watch this link http://www.youtube.com/watch?v=Bk5GOvgAgv8&feature=g-upl
09/27/2012 3:16 PM
Okay, I did. Now what?
What are you asking of us?
Do you need investors? Lots of luck with that.
Do you need peer review? I have a feeling that is coming shortly.
Or, do you need a review of the laws of thermodynamics?
09/27/2012 3:12 PM
thanks for your reply.
Good Answers: 34
Re: Low Powered Ceiling Fan
09/27/2012 1:45 PM
Q1. Yes
Q2. YES
Q3. The power receivable is proportional, to the size of your low powered ceiling fan, now converted into a generator.
09/27/2012 1:52 PM
thanks for commenting .i build a fan of of 15 times lower powered fan in india plg check the video search
as ggcamie
Good Answers: 92
Re: Low Powered Ceilling Fan
09/27/2012 10:52 PM
Don't believe these guys. All you have do is install this in the right place in your local government building where high level discussions take place between opposing political parties & run it off the ensuing hot air- oh yeah, you wanted a low power device, not a megawatt generator. Outa luck then.
09/27/2012 11:58 PM
a dc motor's speed can be regulated with a reostat. it can generate power too, but it's not practical. there's better ways to generate power.
09/28/2012 12:45 PM
"at this case is it possible to generate more more then the input "
NO!
09/28/2012 1:55 PM
It's done all the time. Don't believe the nay sayers here.
Take a look here:OVERUNITYBUILDER - HOME OF FREE ENERGY KNOWLEDGE
After you have looked over this site, I hope that you will realize that you can only get more energy out of a system that you put in, in your dreams.
Look at perpetual motion. Tesla.
Doorman (2); durtieduck (1); ggcamie (5); JNB (1); Joshi (2); lyn (2); redfred (1)
