Previous in Forum: Battery Lifetime Affected by Temperature   Next in Forum: Ring Main Unit
9 comments
Short Circuit Rating of Cable
12/06/2012 4:29 AM
Hi guys, just need your professional opinion, if the short circuit rating of 22 kV Switchgear busbar is 40 kA for 1 sec, should I size the outgoing cables for Short circuit 40 kA/1sec too? Thanks in advance.
Re: Short circuit rating of cable
12/06/2012 4:45 AM
What does the characteristic curve of the circuit overload protective device look like?
12/06/2012 5:06 AM
Only if you want every wire in the facility to be as large as the bus bar....
Re: Short Circuit Rating of Cable
12/06/2012 1:22 PM
You should size based on the upstream and downstream protective settings which should hopefully be lower, if not then yes unless you want to do a study to calculate fault currents at various points upstream and downstream of the switchgear to get the actual maximum expected fault current.
Remember, the switchgear may be rated for 40kA/1sec but the supply never has infinite capacity and the cabling is never a perfect conductor.
Good Answers: 42
12/07/2012 12:35 AM
I agree, of course, with jack.
You have to recalculate the short-circuit current at the end of the cable. The resistance and the reactance of the cable could reduce the current dramatically.
Second, usually 0.1 sec it is enough time to clear the short circuit.
If the cable is XLPE or EPR insulated the maximum temperature it is 250 deg.C.
If you need to take into consideration a reserve protection 0.15-0.2 sec still will be fair.
For 0.15 sec [for adiabatic phenomenon] 250 MCM at 40 KA [rms] will be the minimum copper cross section.
Julius
France - Member - New Member
12/10/2012 8:07 AM
Beware, 0,1 sec seems a bit short . It depends on your protection scheme, this time may be mich longer specially in MV where you have time discrimination.
Good Answers: 42
12/11/2012 12:51 AM
I agree with you, obouill, it is very short, but 5 cycles [total] clearing fault it is still possible.
Julius
12/07/2012 8:51 AM
It is depend on your design philosophy.
1. primary protection tripping time (relay 50/51 of outgoing feeder)
2. secondary protection tripping time (relay 50/51 of main breaker)
If you are a good engineer with money to invest, choose cable to tolerate SC time in 2.
If you are on budget, choose cable rating of SC time in 1.
Now you know what I mean.
12/08/2012 6:05 AM
"Now you know what I mean." No?
06/18/2013 1:29 PM
I agree with Jack.
But also the cable manufacturer catalog shall give to you a curve showing the maximum admisible sc againt time in sec., ask for this information.
Bye ( now definitive becouse tomorro I lose the computer and internet, Chaoooo Dear friends)
Register to Reply 9 comments
7anoter4 (2); Anonymous Poster (1); Drton (1); jack of all trades (1); juan J. Isdray (1); obouill (1); PWSlack (1); Tornado (1)
