Previous in Forum: Easily How to Convert MKV to AVI on Mac   Next in Forum: Shaft Coupling Material Selection
Thickness Tolerance in Plate
12/26/2012 5:22 AM
What will be the WALL thickness tolerance (reduction or increase ) in PLATE of any type, grade and material???Please also give the code reference of this tolerance.I will appreciate if some one will tell.
Re: Thickness tolerance in plate
12/26/2012 7:57 AM
Where have you looked, so far?
Have you asked the plate supplier?
Have you consulted any specifications?
What have you done in the past, or is this your first time working with plate?
How about ASTM?
Group of ASTM standards for steel plate, sheet, strip and wire :: KEY ...
12/31/2012 7:18 AM
YES FIRST TIME I AM WORKING WITH PLATE BUT I GOT MY ANSWER IN ASME SEC-II PART A.
BUT THANK YOU VERY MUCH FOR YOUR ANSWER AND GUIDANCE.
01/02/2013 8:59 AM
Do turn off Caps Lock before posting. Many thanks.
Register to Reply 3 comments
lyn (1); mohammad jawad (1); PWSlack (1)
