Previous in Forum: Software for Hydraulic and Electrical Systems   Next in Forum: Sharp Print Software
Panasonic Touch Screen Connect with MCU Using Serial Port
01/03/2013 6:37 AM
Dear All,
I am doing a project using Panasonic TC with Renases MCU to control input & Output pins.I already written a code for MCU for communicating with hyperterminal to control I/O operation, using STX command.But the problem is TC command is starting with '?' for ex: TC one Switch command is ?01SRR0001016D,when I send this command no response,when I send a command with STX like STX?01SRR0003006E then i am getting output ,bec I already mentioned in the mcu program .
But I want the actual output when I send the ?01SRR0001016D this command bec the TC sending this command without having STX. so what shall I do.
What is the use of STX, if STX is not present what will be the result.Plz help me.
Regards
Jeffy
Pathfinder Tags: serial port
Re: Panasonic Touch Screen Connect with MCU Using Serial Port
01/03/2013 8:38 AM
What is a "bec"?
01/03/2013 9:31 AM
The question must be answered, is it true?
01/04/2013 5:15 AM
Read compiler manual.
01/21/2013 5:49 AM
now i can successfully send command from TC to mcu, but another problem is sending commands from mcu to tc, ie,i want to send a command like "?01SRW000615F"from mcu to TC for that I wrote a code, when testing in hyperterminal its working,but when connecting to TC its not working means no response from TC,but the same code in hyperterminal when pressing enter its passing to TC, its works.I dont know why MCU not sending to TC,
I found out one thing is when pressing enter in hyperterminal then only this command send to TC so add a'\r' in my program then also not working.
Normally MCU transmit one charater at a time,may be this is the issue,anyone have idea how to send a bunch of charaters at a time. Plz help me to find a solution.
All the commands I used in the program are right.
04/23/2019 2:43 AM
I also encountered the same problem, how did you finally solve it?
VICAPS HMI Parts Center: Touchscreen-Keypad-LCD Displya-Protective Film
Anonymous Poster (1); jeffy (1); lyn (1); SolarEagle (1); VICAPS HMI Parts (1)
