Previous in Forum: Oil Handling and Properties at Low Temperatures.   Next in Forum: Reverse Osmosis Energy Recovery
31 comments
Lathe Oil?
01/26/2013 11:06 AM
I just bought a tiny little lathe of E-Bay (other aution sates are also available). It seems to be missing a topslide and was sloppy as hell. I've stripped, cleaned and adjusted it. It's a 'Super Adept' , great name eh?
I've tested it on wood and brass. It works ok.
I'm a bit scared of overtightening the headstock plain bearings as I've read the casting can break. What grade oil should I use? I used 3 in1 on everything as I rbuilt it, but I wonder if engine oil may help the headstock bearings (you can see the little oil cups above the bearings).
These were made about 1933- 1950. It's a cute little thing and will probably do me for turning arrow heads etc.
If you want some extra fun, you can guess what I paid for it .
There's a £2 coin in the pics for scale (for those, not in the Uk... it's still a £2 coin)
User-tagged by 1 user
Re: Lathe Oil?
01/26/2013 11:27 AM
£134.54 -ish?
Re: Lathe Oil?
01/26/2013 11:54 AM
C'mon... it's me, cheapskate Del... you cannot be serious....lower, lower.
(Bear in mind it disn't look that pretty when I got it)
Oh and BTW it sounds better with some lawnmower engine oil in the lube cups (well some of it went in the cups) and I adjusted the headstock bearings for minimum noise.
Re: Lathe Oil?
01/26/2013 12:04 PM
That was the only one I found on e-bay :-D
Re: Lathe Oil?
01/26/2013 12:20 PM
Oh, you cheat monkey... I'd have expected that of the squig, but you?
Oh dear I think I may have to tell teacher of you.
£51.01 gotta be a bargain
Re: Lathe Oil?
01/26/2013 2:10 PM
Definite bargain! And it ain't cheatin' - it's bein' smart. Mebee a bit too smart, but oh, well.
Re: Lathe Oil?
01/26/2013 11:30 AM
Cheers Lyn, ta for the quick reponse. (My searches didn't seem to find much... maybe too specific?)
Looks like I can use something thicker.
This is all a bit out of my comfort zone hence the Q.
Re: Lathe Oil?
01/26/2013 12:09 PM
Cute little pencil sharpener you got there but are you sure you dont need to step up to a bigger motor though?
For oiling my Smithy 1340i I prefer SAE 40 full synthetic engine oil. Seems to hang on real well and so far has yet to ever cause any lubrication dry out related issues I can see.
(Other than forgetting to put it on when I should.)
Re: Lathe Oil?
01/26/2013 1:51 PM
I do have a bigger motor, but I prob' need to find out WTF I'm doing before unleashing more power.
I've found a topslide for a Unimat 3-4 £36, I've E-maile the company to ask about the fixing arrangement, hoping that it might fit without too much trouble.
then I'll be able to turn tapers for arrow heads etc.
Re: Lathe Oil?
01/26/2013 2:08 PM
I think that you have plenty of motor for that rubber sewing machine drive.
You will find that proper tool grinding is the secret of a successful machinist.
Re: Lathe Oil?
01/26/2013 2:35 PM
Well form personal experience I can assure you that sharpening a common pencil at 15,000+ RPM will leave you a point like no other!
A little experiment a few of us naughty kids did back in college machining class one unsupervised evening with the high speed precision micro lathe thing.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: Lathe Oil?
01/26/2013 1:23 PM
What you need is a bigger motor...
Or something with a PTO..
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Re: Lathe Oil?
01/26/2013 3:18 PM
If it's cheap you want, this is hard to beat....$46
Re: Lathe Oil?
01/26/2013 3:20 PM
You ain't gonna turn brass on that.
Re: Lathe Oil?
01/26/2013 5:42 PM
You could substitute an angle grinder for the drill, might work....I myself am a big believer in quality tools though, and would probably go with something like this....
That being said it looks like you got a good deal.., but the proof is in the pudding as they say....good luck with it in any case...will be curious to see some arrow head designs....
Re: Lathe Oil?
01/26/2013 10:47 PM
I use 30 W non detergent in my lathe spindle, Vactra way lube for the ways and it's held up fine. I also have a couple of milling machines and a surface grinder that I use Vactra way lubricant on. You might check with a petroleum sales company for specifics. The selection and brands are endless. It's around $8/gallon. if you can find that small of a container, usually sells in 5 gallon pails.You might be able to talk a machine shop out of a quart for a couple of brewski's!!!
Re: Lathe Oil?
01/26/2013 11:50 PM
I find that on full-loss oiling systems like on your lathe spindle, 10-40 Mobil-1 works very well. Full-loss means that the oil leaks out and detergents in the oil will take contaminants with it as it leaks out. Synthetics will keep the bearings cool. I use 10-30 Mobil-1 on my Bridgeport and the spindle bearings stay nice and cool even after hours of high-speed running.
Do not use detergent oil on the slides, the aforementioned Vactra is much better and won't stain the slide metal (ask me how I know). Mobil's Vactra is a synthetic but I don't think it has detergents in it.
Vactra is about $9 on e-bay (http://compare.ebay.com/like/290783791844?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar) and $20 at Enco (http://www.use-enco.com/CGI/INPAGE?PMPAGE=/specials/893-2096)
It was burning when I put it down!
Re: Lathe Oil?
01/27/2013 4:03 AM
Cheers, good idea on the brewski... I might pop down to the place I used to work, they had a great modelshop and machine shop.
Re: Lathe Oil?
01/27/2013 5:06 AM
Well done, I am green with envy!!!
Good Answers: 25
Re: Lathe Oil?
01/27/2013 5:45 AM
Hi Del, so you have installed arrow making factory?,
Re: Lathe Oil?
01/27/2013 7:44 AM
Well, it would do for miniature arrows.
Re: Lathe Oil?
01/27/2013 8:54 PM
Tsk, Tsk, are those inches I see? I thought UK was metric, but I recall you weren't happy with that.
Good Answers: 94
Re: Lathe Oil?
01/28/2013 4:34 AM
We are (sort of) metricated but may not have been in the 1930s-60s when the lathe was made.
Re: Lathe Oil?
01/27/2013 1:04 PM
The bearings on my lathe (Sheldon 11") used to heat up when I was using a non-detergent 30 weight oil. I switched to a high detergent 10-30 oil and the bearings now run cool. Each machine manufacturer had their own oil recommendation, so it is difficult to tell you what oil to use. As another respondent stated, try to get some "way" oil from a machine shop and use an oil for the bearings that results in cool running.
Mr.Ron from South Ms.
Good Answers: 94
Re: Lathe Oil?
01/27/2013 5:35 PM
There's a history of the make here if you're interested.
Re: Lathe Oil?
01/27/2013 6:55 PM
Nice find.
Re: Lathe Oil?
01/28/2013 2:26 AM
Yup, seen it already ta, as part of my online pre-purchase program which was submitted in triplicate to the committee before entering into the online auction process.
Or maybe I was just smurfing at work
Good Answers: 19
Re: Lathe Oil?
01/28/2013 9:39 AM
If no-one else has said I would recommend reducing the spindle rpm via a layshaft, those lathes weren't meant to spin that fast.
http://www.lathes.co.uk/adept/index.html
Also in case no one else has said, the link above is pretty informative. Enjoy.
Re: Lathe Oil?
01/28/2013 10:09 AM
Ah! It did have a lay shaft, but I thought fast was good.
Mind, it was a pretty naff arrangement of lay shaft and the final drive was string!
(There was a broken belt in with the odds n ends).
While we're discussing it, is the round rubber belt ok or should I try to find a small V belt.
I can reinstate the layshaft. (Maybe I could use a pair of stockings from a Barbie doll... Kris made me say that)
I've just ordered a topslide for a Unimat 3 of the interweb, I think it will fit, with maybe a little work. (£36, but it still keeps me under a £100 total, so I reckon that's ok)
All the advice and help is greatly appreciated.
Re: Lathe Oil?
01/28/2013 11:59 AM
My Dad used a good quality 10w30 motor oil in an old South Bend 21" lathe. 1920's.
This lathe had worn out bronze bushings in the headstock when he purchased it so he bored them out and made a special setup to pour lead/babbit bushings. This worked great for many years with the motor oil. The bushings never seemed to wear as long as we kept it lubed.
I would think a good V-belt would slip less if you needed more torque to drive a bigger project.
Re: Lathe Oil?
01/28/2013 12:08 PM
You paid £10, (five of those silly looking coins). And I am extremely envious of you. Know where I can get one?
Re: Lathe Oil?
01/28/2013 12:55 PM
Nope £51 but still a bargain.
Register to Reply 31 comments
Andy Germany (1); Bricktop (1); evaluator (1); HUX (1); James Stewart (1); JohnDG (4); JustCurious (1); lyn (1); mrehmus (1); Nigh (2); ronseto (1); SolarEagle (2); StandardsGuy (1); suresh sharma (1); tcmtech (2); user-deleted-1105 (10)
