Previous in Forum: Insulation Piercing Connector   Next in Forum: Electrical Problem With Toyota Avensis.
Motor Generator Frequency Converters Manufacturers
03/06/2013 4:16 AM
Hi Friends, I have a requirement for a Motor Generator Frequency Converter with direct 6.6 kV 50 Hz input to the motor and output 460V 60 Hz, 2 MVA for a marine application.
Please can someone who has expertise in these converters recommend me any reputed manufacturers.
Thanks in advance for your valued recommendation.
Re: Motor Generator Frequency Converters Manufacturers
03/06/2013 9:43 AM
Go here and search: Search GlobalSpec
05/20/2013 11:36 AM
Not quite right. You can take a stupid man and with a bit of patience, knowing what you are doing you can change him into a quite intelligent being.
Intelligence defined as: The ability to perceive, pose and resolve problems relating to survival.
03/07/2013 10:42 AM
We have a Horlick unit 150KW and it's running non-stop since 7 years save for some maintenance. Very sturdy build and reliable.
Try that.
03/07/2013 11:09 AM
Welcome.
03/07/2013 11:29 AM
Good point. Thanks.
