Previous in Forum: Response of Over Voltage & Over Frequency Relay   Next in Forum: Motor Contactors
Electrical and Instrument Cable
05/11/2013 9:18 AM
Dear All
Is it possible to run the electrical cable parallel with instrument 100 apart.
both cable are armoured any interference.
Regards
Good Answers: 1693
Re: Electrical and Instrument cable
05/11/2013 10:09 AM
Yes.
Yes.
Good Answers: 804
05/11/2013 11:13 AM
100 what? Mm? Cm? Meters? kM? Inches? Feet? Cubits? What do you mean by armored? Does that mean shielded?
Do you feel that you are qualified to be making these kinds of decisions if you must ask those kinds of basic questions? I'm not trying to be rude, but it appears as though you are not an electrical engineer and are trying to set up something rather complex (instrumentation) without even the most rudimentary knowledge necessary. That means that if we help to facilitate this, someone may get hurt. Hire a qualified electrical engineer please.
Good Answers: 181
Re: Electrical and Instrument Cable
05/11/2013 10:32 PM
Good Answers: 42
05/13/2013 12:17 AM
If I well interpreted these sentences no distance is required from power cable[low voltage] if the ITC cable is armored. However the armor has to be well grounded[see NEC Art.250].
According to NEC Art.727.2 Definition.
Type ITC Instrumentation Tray Cable. A factory assembly of two or more insulated conductors, with or without a grounding conductor(s), enclosed in a nonmetallic sheath.
Art.727.4 Uses Permitted.
(7) Direct buried where identified for the use.
Art.727.5 Uses Not Permitted
Type ITC cable shall not be installed with power, lighting, Class 1 circuits that are not power limited, or non-power-limited circuits.
Exception No. 2: Where a metallic sheath or armor is applied over the nonmetallic sheath of the Type ITC cable.
Julius
Good Answers: 169
05/13/2013 8:08 AM
As per IS 1255, the minimum clearance should be 300mm.
Good Answers: 42
05/14/2013 3:05 AM
I did not find in IS 1255/83 ch.6.3.3 " Clearances" a reference to the minimum desired clearance between power and instrument cable (laid in ground).Control cable is not an instrument cable and-with some exception-control cable in Switchyard-is not shielded or armored.
Julius
7anoter4 (2); electricalexpert65 (1); JRaef (1); lyn (1); TonyS (1)
