Previous in Forum: Understanding Engineers   Next in Forum: Visual Effects from an Anti Gravity Device
How Does the Light Barrier Differ from the Doppler Effect?
06/08/2013 6:10 PM
I just have one question and if it can be answered, I'll understand relativity. How is the speed of light being the same regardless of the speed of the source or receiver, any different than the plain old Doppler effect for any type of wave. The sound barrier did not lead to the conclusion that time and space is warped when the speed of sound is not altered by the speed of the source or the receiver. I don't understand how the Michaelson Morley experiment led to the theory of relativity when it should have just led to the conclusion that light is the only wave that does not need a medium to propagate. I recently watched a TED talks YouTube video by Ramesh Raskar where he filmed a light pulse using ultra high speed camera technology. If he had filmed 2 pulses going in opposite directions, space and time would not have altered to prevent them from receding from each other at twice the speed of light. Einstein's thought experiment of catching up with a light beam and looking at it also seems to be false. He stated that the light beam would not look stationary but would still recede from him at the speed of light. Filming the light pulse shows this is not true.
What sparks the intelligent, inflames the ignorant.
Re: How does the light barrier differ from the doppler effect?
06/08/2013 6:18 PM
My limited understanding of redshift of light would not contradict the doppler effect in the frequency of sound.
redshift and the - Curious About Astronomy? Ask an ...
Re: How Does the Light Barrier Differ from the Doppler Effect?
06/08/2013 7:15 PM
With acoustic waves, if you are moving toward the source of a tone you would measure a faster speed for the sound wave and a higher pitch than someone who was stationary with respect to the source. Likewise someone moving away from the source of a tone would measure a slower speed of sound and a lower tone.
For light only the frequency (or wavelength) changes; the speed of light is always measured as the same value. (The caveat, of course, is the speed of light being measured is the speed in a vacuum.)
06/08/2013 7:38 PM
I took quantum mechanics back in the early 80's. I believe that the Michelson Morley experiment interpretation, was in error. If you read the history of how they thought the "either" worked (in 1888), any matter (like the earth) flowed through it, as they thought it like water, where it flowed around the solid object. Then in the same class they explained that Lorentz contraction results in the inability to measure the relative motion of light or matter through this either.
I think this introduced the biggest paradigm lock on figuring out a unified physics.
Or as Abe Lincoln said, I just removed all doubt.
06/08/2013 8:28 PM
What an interesting and oft asked question, let's dig down....oh, already we've hit bottom....It's rather simple, the stretching or contracting of the wave varies the wave length, and thus the perceived color....light is pure energy, sound is a reaction of mass disturbance...
"The speed of sound in an ideal gas is independent of frequency, but does vary slightly with frequency in a real gas. It is proportional to the square root of the absolute temperature, but is independent of pressure or density for a given ideal gas. Sound speed in air varies slightly with pressure only because air is not quite an ideal gas. In addition, for different gases, the speed of sound is inversely proportional to the mean molecular weight of the gas, and is affected to a lesser extent by the number of ways in which the molecules of the gas can store heat from compression, since sound in gases is a compression wave."
"The speed of sound is variable and depends on the properties of the substance through which the wave is travelling. In solids, the speed of transverse (or shear) waves depend on the shear deformation under shear stress (called the shear modulus), and the density of the medium. Longitudinal (or compression) waves in solids depend on the same two factors with the addition of a dependence on compressibility.
In fluids, only the medium's compressibility and density are the important factors, since fluids do not tolerate shear stresses. In heterogeneous fluids, such as a liquid filled with gas bubbles, the density of the liquid and the compressibility of the gas affect the speed of sound in an additive manner, as demonstrated in the hot chocolate effect."
"In the Earth's atmosphere, the chief factor affecting the speed of sound is the temperature. "
https://en.wikipedia.org/wiki/Redshift
https://en.wikipedia.org/wiki/Speed_of_sound
06/08/2013 9:03 PM
Guys I obviously came nowhere near to making my question clear. Let's forget about all the little details about the Doppler effect. They are not important to my question. Let's go back to fundamentals. Air is a medium for sound. Don't worry about the temperature or pressure, we'll just assume our sound wave is travelling through idealized air at a maximum speed of 750 mph. Now, if you're driving your car and blaring your horn at a pedestrian, the sound pitch goes higher as you approach him and lower as you pass and pull away from him. However, correct me if I'm wrong, the speed of sound is constant at 750mph no matter how fast you're moving or how fast the pedestrian is moving. However, if a wind is blowing, it will affect the speed of sound. I believe the Michaelson-Morley experiment was to try to find the medium for light which they called ether and whether there was an ether wind that they could measure affecting the speed of light. The earth's movement through the ether would have created an ether wind on the earth's face but the earth's movement would not have created a wind that would have affected the speed of light through space. So far I can't see the difference between how light behaves and how sound behaves except that light has no medium. And if there is no difference, how did Einstein make the jump that in order to maintain the constancy of the speed of light relative to all other motion, time and space would have to be warped.
06/08/2013 9:59 PM
Could you restate the question clearly?
First of all I think aether is an archaic term that has no relevance in modern science...
06/08/2013 11:09 PM
No, you're wrong.
You're stuck on the 'known' speed of sound in air at sea level (known to be about 770 mph) between an emitter and a detector that are static with respect to each other. But if an observer actually tries to measure the speed of sound, then the motion of the observer to or from the source will affect the speed the observer measures. As I said in my previous post, if there is a source emitting a tone and I am moving toward that tone the speed I measure will be faster than 770 mph. Likewise, if I am moving away from the source I'd measure a slower speed.
06/08/2013 11:17 PM
Go to this link http://hyperphysics.phy-astr.gsu.edu/hbase/sound/dopp.html It clearly states that the speed of sound is not affected by the speed of the source or receiver.
06/09/2013 11:49 AM
No response? Did you try googling speed of sound and doppler effect? Do you still think I'm wrong?
06/09/2013 12:20 PM
You keep missing the point. Yes, the speed on sound in air is the same regardless of the speed of the source or the observer.
BUT suppose you didn't already know the speed of sound or the pitch P of the sound being emitted. As you approach a source at velocity v you would measure the speed of sound as 770mph + v. And you'd record a pitch P' which is higher than the pitch P heard by someone stationary (at rest in the emitter's reference frame).
That doesn't happen for the speed of light. For the speed of light regardless of your speed v, you will always measure a speed of light c (the same for you or for a person in the emitter's reference frame). You will, however, measure a frequency f' which is higher than the frequency measured by someone stationary with the emitter (at rest in the emitter's reference frame).
06/09/2013 12:33 PM
06/09/2013 12:51 PM
I'm trying to understand your reply. Velocity is distance over time. So if you're 770 miles away, you'll hear the sound in 1 hour. But if you're moving towards the source at the speed of sound and you're 770 miles away when the sound begins, you'll hear the sound in half an hour at the halfway point. The sound has moved half the distance in half the time so it is still 770 mph, totally unchanged by your velocity towards the sound. So how are you measuring the speed of sound at 770+v mph? You're only measuring the frequency increase due to the doppler effect but the speed of sound is unchanged. The speed of light would give you the same result. Please watch the youtube video I mentioned.
06/09/2013 1:05 PM
Here's a diagram.
06/09/2013 1:14 PM
That's not a speed, it's a frequency the rocket plane is measuring.
06/09/2013 4:07 PM
Okay, you're hopeless. I'm done here.
Good Answers: 44
06/10/2013 12:24 PM
Not quite hopeless...
I don't think either one of you wants to agree, but maybe slightly less on your part.
He is referencing the actual "speed of sound"...not the perceived frequency of the sound received. Just as the perceived speed of light receding appears red...the light is not moving more slowly than the speed of light.
The color of the speed is perceived differently. If you moved towards the source of light at the speed of light it would appear at its true color, not shifted towards red.
06/10/2013 3:34 AM
It is rather rude to blare a horn at a pedestrian. Remember, pedestrians have right of way on a road system and motor vehicle users are only licensed. If this is inconceivable, knock one over and see how the police, the insurance company and the driver licensing authority repsond.
Good Answers: 114
06/08/2013 10:22 PM
The Michaelson-Morley experiment didn't lead to the theory of relativity, they looked for the preferred direction and were surprised to find there wasn't one. That led to the support of ditching the æther, and thus the support of relativity. It confirms that light has the same speed in all directions, no matter that you are traveling in just one. Einstein got there independently, he realized that the æther was not necessary and that there could no be a preferred direction because that would lead to a preferred place, a place at the center of the universe.
06/08/2013 11:05 PM
Whether the experiment directly influenced Einstein or not, it still supports the contention that the speed of light is independent of the speed of the source or the speed of the receiver. This would not have been true if the experiment had found an ether wind or preferred direction as you state. So this discounts the existence of ether. Not sure why because the ether could have been at zero velocity with no wind at all and we could have measured all velocities in relation to the speed of the ether which could have been zero. Instead we could measure all velocities in relation to the speed of light which is always the same regardless of relative velocities. But I digress, that was just an observation.
My question still is how does the behavior of light, having a constant speed that is always measured the same regardless of the speed of the source or observer, differ from the behavior of sound in still air which is also always measured the same regardless of the speed of the source or observer. If you can tell me the difference, then maybe I could understand how the results of the experiment support that some uniqueness in the behavior of light, different from the behavior of other waves, could lead one to understand that time and space must themselves bend to support the constancy of the speed of light.
Good Answers: 114
06/09/2013 8:17 AM
"So this discounts the existence of ether. Not sure why because the ether could have been at zero velocity with no wind at all and we could have measured all velocities in relation to the speed of the ether which could have been zero"
If the ether had been at zero velocity, in all directions, the point at which this measurement was taken would be the center of the universe. The Earth, the Solar System, the Milky Way and yes, the Universe would all be revolving about, or moving to or from, that place. That is more difficult than the universe of Aristotle and Ptolemy which was centered on Earth, not a point on its surface.
06/09/2013 9:00 AM
I don't really want to veer off on a debate that has nothing to do with my question. I don't care about the non-existent ether or it's nature. To me the ether would have been akin to a large lake on which the universe floated. You wouldn't have to know where the center of the lake was in order to measure relative velocity, you could measure your relative velocity to the water by sticking your speedometer directly under your boat. Anyway, I don't care about this or any other niggling details because they have no relevance to my question. Also the fact that sound can't be bent by gravity and those other details the other guy mentioned also have no relevance. If my question is not clear, which it doesn't seem to be, could someone rephrase it for me? I want to know if the specific nature of light, the one where light speed is not relative to source or receiver, is no different to the nature of the speed of sound in air, the one where sound speed is not relative to source or receiver as it is in the doppler effect, how did the Michaelson-Morley experiment show that the only way the particular nature of light speed, the one where light speed is not relative to source or receiver and is always constant, could be explained in that time and space must not be constant. If the experiment does not lead to that conclusion, how did Einstein manage to do it. Where's that guy Jorrie or Jordaan who wrote Relativity 4 Engineers, he would know the answer.
Good Answers: 114
06/09/2013 10:45 AM
The argument is that if no point in the universe is favored, if none is the center, then they are all equal and they all would have to measure the same speed for light if there is to be a system of physical laws.
06/09/2013 11:15 AM
I still don't get what that has to do with my question.
06/09/2013 1:04 PM
If the speed of light is constant in space, isn't that an absolute motion to which everything else is just relatively slower?
06/09/2013 2:03 PM
No, the speed of light is not a constant in space. It is constant relative to the person seeing it. That's why the theory is called relativity. Other things are also relative to the person viewing it. Time, distance, mass and simultaneity all differ depending on the reference frame of the observer.
canary
06/09/2013 2:20 PM
So you're saying the speed of light is not a constant but varies relative to each observer? Ok, I thought I was on a physics forum but evidently I'm mistaken. It's been years since I've been here but there used to be an entire section on relativity. Is that gone now?
06/09/2013 3:33 PM
This is an engineering forum. Before you try engaging with physicists, I suggest you start with the basics:
http://en.wikipedia.org/wiki/Theory_of_relativity
canary
06/09/2013 4:02 PM
My bad. I'll try to find a physics forum. Are there any engineers on this forum?
06/09/2013 8:24 PM
You show me an engineer that understands Relativity and I get a physicist to build my house!
06/10/2013 5:13 AM
The issue is that the speed of light is fixed in vacuum and it is the absolute maximum velocity possible for anything.
Einstein's theory leads to this equation for summing two collinear velocities:
http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/einvel2.html
bioramani
06/10/2013 3:26 PM
What are you trying to get out of it?
My head is circling after reading all the gentlemen talking about it but still can't get any thing worthwhile.
Regards;
Nadeem
Nadeem
06/09/2013 1:13 AM
Does the speeds of sound and light depend on gravity or electrical/magnetic/IR/UV fields?. Can light be bent by electric/magnetic fields?.
pnaban
06/09/2013 2:49 PM
Insignificant relevance to my question.
Good Answers: 69
#129
06/13/2013 1:25 PM
Well, maybe light can't be bent, but it can certainly be twisted under the influence of a magnetic field, this proves that they're related.
Yeah, I know, nothing to do with the subject, I just rememberd the Faraday effect.
Regards
06/09/2013 1:57 PM
The answer is that there is indeed a difference between the speed of light and the speed of sound. Sound has a more or less constant velocity relative to the air it passes through. If you move fast enough you can catch up with it and pass it. That's what happens when a supersonic plane passes the sound barrier. The speed of sound is not relative to the person hearing it, but completely independent of the person hearing it.
Light is exactly the opposite. Its speed is not relative to the medium it passes through, but relative to the person seeing it. If you see the light coming from a distant star, it approaches at the speed of light, c. If you travel toward the star at half the speed of light, you might expect to see the light approaching you at 1.5 times the speed of light. But instead the light still approaches you at the speed of light, c. However, the Doppler effect shortens the wavelength, so that it looks bluer than it did before.
That makes sense because your velocity toward the star should make the "collision" between your eyes and the light more energetic, and bluer light has higher energy than redder light. Yet the speed remains the same.
No matter how fast you travel, the light approaching you from the star has the same velocity, but varies in energy and wavelength. How is it possible to have the same velocity? After all, the light is traveling at the speed of light relative to the star, and also relative to you approaching the star. In ordinary Newtonian physics, that would be impossible. If you are traveling on a train track at 60 mph, and a train is traveling toward you at 60 mph, your velocity relative to the train is 120 mph, not 60 mph. But with relativity, if the train is light, then its velocity relative to you would be 60 mph, not 120. It simply does not add up linearly. It is ALWAYS 60 mph, no matter how fast you are going. And it is also 60 mph for the people sitting in the train station. How can that be true?
Like this. The people in the train station see your train and the oncoming train approaching each other at a combined velocity of 120 mph. You see it coming at 60, and the oncoming train sees it at 60. The trick is that if you are inside one of the train. The word relativity is derived from the fact that you see different things relative to your own point of view, and your own velocity.
So how can it happen this way? After all, velocity is a function of distance and time, and how can that be changed? The great genius of Einstein was that he realized that space and time are not constant. They both change as you change velocity. Time slows down ("time dilation"), space shrinks ("Space contraction), and mass increases, but you can't see that happening to yourself. You see that happening to everythign else, but not yourself.
Imagine you are about to leave a planet to go to a distant star. As you turn on your impulse engines (Not a warp drive. If you've got a warp drive, leave it off, and contact NASA right away. Warp drives avoid this problem in the interest of plot development.) and accelerate toward the distant star, the space between you and the distant star shortens relativistically. But you don't notice that because your space ship gets shorter too. If you try to measure the distance from on board your space ship, it looks the same because your space ship has shortened by the same proportion, so the RELATIVE distance from your space ship to the star looks exactly the same, relative to the size of your space ship. But if someone else on the planet measures your space ship, then as you accelerate your ship would look shorter and heavier, and your clocks would look slower.
From your position on the ship, the changes in space and time work together so that light coming toward you from the star has a shorter and more energetic wavelength (blue-shifted Doppler effect), and always has the exact same speed due to your own time dilation and space contraction. Maybe it would be more accurate to say you can't tell the difference in speed because of your own time dilation and space contraction.
Bottom line, sound and light both have Doppler effects, but they operate completely differently.
canary
06/09/2013 2:25 PM
Oh lord, someone out there who understands relativity please help me.
06/09/2013 8:28 PM
Common, you did ask and can't handle the answer?
06/09/2013 9:00 PM
That's an answer but do you think it's the right answer? I have a feeling you have no idea.
06/09/2013 10:19 PM
You lose me here. No I have no idea, but I am not the one that asked a question! I gave up trying to understand this long ago. The problem as you will find is in the receiving end. Its not the one that can not explain it, but it is the one that does not understand it. I have fun now with lesser problems than relativity, which is challanging enough for my small brain to work it out.
Do I think it is the right answer? Well its long enough to try to explain something from a person that seems to have the knowledge required to understand this with the will to help you. I took the liberty to mark it a GA so lets leave it there. Its a good answer.
06/09/2013 10:34 PM
May I frame this? It not only explains relativity perfectly to me but it explains every question I've ever had about every aspect of existence. Thank you. I've always measured answers by quality and I've had it all wrong. It's the quantity of answer that matters. It's been a slice, now I'm just going to back away, slowly.
06/09/2013 11:10 PM
Apparently, you will know the right answer when you see it.Therefor,you must already have the answer,so please enlighten everyone with the correct answer.Or are you seeking an answer that will support your pet theory, and if the answers do not agree,then you keep looking?
You will not find YOUR answer here,because the contributors to this forum have tried diligently to break it down into a relative Pablum consistency to make it easy for you to digest.
I think they have been very patient,and you have been very obstinate.
I will not even attempt to try to explain it any further.
Perhaps you should go back to Gerber #1(relatively speaking) and work your way up to solids.
It is good to challenge the status quo,but it pays to understand thoroughly what it is that you are opposing before you begin.
Come back when you understand general relativity,and special relativity,then present a challenge worthwhile of a thoughtful person.
I am looking forward to your presentation in the future.
06/09/2013 9:05 PM
06/09/2013 10:21 PM
Did you try to get away with your feelings, then it did not work!
Or was that the doppler effect?
06/10/2013 1:34 PM
There is a relativity section here, and it run by Jorrie. He has an E-book linked to his blog. You are capable of searching for it. Please note that he doesn't care for trolls, but try your luck anyway.
06/10/2013 1:39 PM
Really? You consider me a troll. You think it's a personal insult to someone when you disagree with them. Anyway Jorrie was the guy I was looking for. I didn't see that relativity section so I wrote him and bought his book (tough read so far). He said he's not active here anymore and he gave me another link and I will go there once I'm done here; if that's ok, or not, with you.
In reply to #64
06/10/2013 1:57 PM
You certainly are a troll when you have been given the correct answers and them mark everybody of topic that doesn't agree with you. Please go to that link now.
<unsubscribe>
In reply to #66
06/10/2013 2:09 PM
C'mon, you have no idea if they're the correct answers or not. I say they aren't. Attack my arguments, not me personally. That's what trolling is.
#104
In reply to #68
06/11/2013 9:16 AM
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
06/10/2013 2:12 PM
For a "high level" view understanding, I think you pretty much stated everything.
In reply to #69
06/10/2013 2:55 PM
Thanks. I appreciate that. Actually writing that answer helped me refine and simplify my own understanding of relativity a bit, even though I've been reading about it for some 40 years.
canary
Engineering Fields - Aerospace Engineering - Retired South Africa - Member - The Rainbow-nation Engineering Fields - Engineering Physics - Relativity & Cosmology Popular Science - Cosmology - The Big Picture!
Good Answers: 69
#101
06/11/2013 6:12 AM
Canary, your post is essentially correct, but there are a few things that are not strictly correct.
"Light is exactly the opposite [to sound]. Its speed is not relative to the medium it passes through, but relative to the person seeing it."
When light passes through a medium like glass or water (or 'compressed space', for that matter), its speed is still constant to an observer moving with the medium, but to outside observers light's speed is influenced by the relative movement of the medium (the Fresnel effect)[1].
"How is it possible to have the same velocity? After all, the light is traveling at the speed of light relative to the star, and also relative to you approaching the star. In ordinary Newtonian physics, that would be impossible."
The best way to understand this is by considering that you and the star each have your own definition of simultaneity, in other words the way you synchronize two clocks at some distance apart for the measurement of the speed of light)[2]. This takes care of all the 'spookiness' of time dilation and length contraction, which many people find not very palatable.
"The great genius of Einstein was that he realized that space and time are not constant. They both change as you change velocity. Time slows down ("time dilation"), space shrinks ("Space contraction), and mass increases, but you can't see that happening to yourself. You see that happening to everything else, but not yourself."
The modern view tries to steer clear from this description. In the special relativistic scenario of no gravity, 'spatial contraction' is just an observational effect, not something that 'really happens' to space. But it is still marginally acceptable to view it as you described...
"... and accelerate toward the distant star, the space between you and the distant star shortens relativistically. But you don't notice that because your space ship gets shorter too. If you try to measure the distance from on board your space ship, it looks the same because your space ship has shortened by the same proportion, so the RELATIVE distance from your space ship to the star looks exactly the same, relative to the size of your space ship. But if someone else on the planet measures your space ship, then as you accelerate your ship would look shorter and heavier, and your clocks would look slower."
Can you see the difficulties that this explanation suffers from? You can avoid it all by just considering the differences in clock synchronization between your ship and the observers on the planet. The (almost) meta-physical explanation is not necessary.
I hope it helps a little to make this thread more meaningful.
-J
[1] http://www.st-andrews.ac.uk/~ulf/media.html
[2] http://cr4.globalspec.com/blogentry/21742/One-way-Speed-of-Light
In reply to #101
06/11/2013 1:54 PM
"Canary, your post is essentially correct, but there are a few things that are not strictly correct."
Thanks for the corrections, Jorrie. Also, I think I focused on time dilation and space contraction because that was how I was first introduced to relativity, in the 70s, and only later learned about the effects on simultaneity as the answer to some apparent conflicts, so simulataneity seemed secondary to the basic concept. Interesting that it is now considered primary and the others are considered secondary. They got all the attention in the popular press.
I thought that introducing simultaneity into the discussion would only add to the confusion, but now I see that is a more elegant way of introducing the constancy of c than my explanation.
canary
Good Answers: 114
06/09/2013 3:13 PM
You come on here asking for demanding answers on your terms. When it is not served up in such a manner as to inch its way through your convoluted brain, you respond unpleasantly.
You are the supplicant here, we are not.
Signing off.
06/09/2013 3:55 PM
"My terms" are to get correct answers. Weird huh? Do you really think your answers are in any way correct? Please sign off, I was going to ask you to do so anyway, thanks.
06/09/2013 4:45 PM
You seem to be the only one here that doesn't understand either the question or the answer, why are you blaming others? Maybe the problem is you.....You're not only rude but dull witted as well....oh and don't bother with the impotent 'off topic' vote, I'll do it myself....
....click....
06/09/2013 6:14 PM
Sound is mechanical energy, it is transmitted molecule to molecule, no molecules=no sound.
Light, a form electromagnetic energy (e.e.) is different. While e.e. can travel through wire, waveguide and fiber optic cable, a medium does not seem to be required. As the e.e. increases in frequency different radiation properties emerge. At DC, only the magnetic portion is radiated, at the extreme high end, more particle properties are evident. As for the Doppler effect, someone else will have to answer if the frequency is shifted or is the "wave" compressed? The difference would be similar to FM modulation vs Phase Modulation. An FM radio will detect both, but they in fact are quite different.
06/09/2013 6:40 PM
I already stated in my 1st post that light does not need a medium whereas sound does. Does not answer my question.
06/09/2013 8:30 PM
Maybe it does and you can not see it!
Good Answers: 44
06/10/2013 12:45 PM
Yay! Thanks for that. I didn't think the physical/electromagnetic theory was going to ever be presented directly.
Of course, I came to the party late...
06/10/2013 3:12 AM
It appears that someone here just likes ARGUMENTS - not really looking for an answer....
THIS IS NOT THE PURPOSE OF THIS FORUM.....!
Good Answers: 22
06/10/2013 8:18 AM
"If he had filmed 2 pulses going in opposite directions, space and time would not have altered to prevent them from receding from each other at twice the speed of light."
You are right but the above has nothing to do with relativity because you are considering just how quickly are "moving" to each other two points in space (the fronts of the 2 pulses). I can give you another example: consider two strong lasers that are 1km from each other and are intersecting their beams on the same point on the Moon; suddenly (in a fraction of a second) their position is changed so that they almost point to each other (their intersecting point is now very close to the surface of the Earth at 0.5km from each other). So, if you consider the speed of the intersecting point (some 384000km in a fraction of a second) you can obtain "speeds" that can be even millions of times bigger that "c". But relativity applies only to speeds of "real objects" and they are limited to "c".
Regarding the understanding of relativity, it's not easy. If you consider for example understanding temperature you can say it's well understood - we know "how" and also "why". Understanding gravity is different - we know "how" but we don't know "why". But for relativity we know "how", we have no idea "why" and we also have the problem that "how" is contrary to our "common sense", so even "how" is not in fact fully understood and accepted by our mind. I have spent many hours to fully understand "how" and I have now my own "theory" that explains it very well, so that my "common sense" is fully satisfied. If you are interested in this I can try to share with you some concepts (although a full explanation would probably need a small book - which I have now only in my head).
06/10/2013 10:11 AM
Finally, a non-insane person on these forums. I was feeling like an evolutionist at a Tea Party rally for a while. People here seem to think that because I'm reading mountains of evidence on google contrary to what they're saying, that I'm being obstinate or argumentative. Everything I've read says you can't push any wave faster than it's maximum speed through a stationary medium (light differs in that it's max speed is unencumbered by a medium). If you try to do so, the extra energy you impart into the wave will manifest itself as increased amplitude or frequency but not a change in velocity. Yes a few have said this but they then start to contradict themselves or I'm unable to understand the subtleties of what they go on to say.
If you see the youtube video of Raskar, you'll see that I'm not talking about the movement of a laser pointer on the moon. It's as Riker said, a strobing effect to slow down the speed of light so we can see a pulse propagate. However, the strobe effect would apply equally to two pulses shot past each other so I don't see the relation of that to the moving laser pointer point you made.
What people also don't seem to understand here is that my "common sense" has to be satisfied. Science is not religion, I, as a "suplicant", do not have to blindly accept the explanations of the "high priests" on this forum if they are contrary to other facts I'm reading. When I try to show them these facts, they won't consider them and are accusing me of trying to understand the subject matter on my terms. The last guy, knowing little about about the subject matter, suggesting I should accept the explanations based on their volume giving them weight, was the last straw. The post he was referring to was largely factually correct, it's just that I disagreed with the conclusions he drew.
I'd love to hear your theories, Alex, but this question is still stuck on understanding the Doppler effect. If they are right, that the speed of a wave through a medium is not only affected by the speed of the medium but by the speed of the source or observer, then my question can go no further. If they are right that the speed of light differs for each observer and is not constant for all inertial frames, then I don't understand relativity at all. But, please, tell me your theories.
06/10/2013 12:16 PM
The universe has no obligation to satisfy your common sense. Relativity was opposed by other scientists because it did not satisfy their common sense, and yet now it is universally accepted by physicists as the way things work. Not because there is any high priest telling them so, but because the data proves it. I was not drawing any conclusions in my previous post. I was simply laying out what the facts are that physicists have accepted about how light works. It does not satisfy anybody's common sense. It is still the best description of how the universe works, even if nobody actually knows why it works that way.
You haven't cited these "mountains of evidence on google," and I sincerely doubt that you have found a single piece of evidence that contradicts what I said in my long post. The Raskar video does not prove anything about relativity. It simply shows what a single extremely short pulse of light would look like if you could actually watch it proceed, by taking many pictures of many pulses, each one slightly later than the previous one.
You admit that you don't understand relativity, but that you would understand it if only someone would answer your question about the Doppler effect. What you are actually saying is that you want someone on the engineering forum to please confirm that all the physicists for the past century were wrong about the speed of light, so that you don't have to tolerate the tremendous discomfort you feel at the idea that the universe does not conform to your common sense.
I have to say that if you are lucky, you will be disappointed. If you are not lucky, you will persist in believing that your common sense is better than Einstein's training and his lifetime of looking at actual data, and every physicist since him. Also if you are not lucky, you will continue to think will that people will want to discuss things with you even when you insult them rather than by present any actual evidence. It is a stretch for me to even write this post, after your reaction to my previous one.
And if you think relativity is difficult, wait till you get to quantum physics.
canary
06/10/2013 12:30 PM
Thanks for playing. I have no need to respond to your post. Could you please join your other 2 friends in the timeout box.
06/10/2013 3:39 PM
You may have your favorite answer in your head and that is the reason you are rejecting all the answers. Please enlighten us and tell us for our edification as to what the truth is?
Nadeem
Nadeem
In reply to #74
06/10/2013 4:05 PM
I did over and over again. I'm saying there is no difference in behavior between a sound wave and a light wave in a still medium (no medium for light). The observed velocity of the wave is independent of the motion of source or observer. Once we get that established, I want to understand why, if light behaves just like any wave (except for the medium part) how does its "strange" behavior lead to the theory of relativity.
Good Answers: 25
In reply to #76
06/10/2013 5:12 PM
Wrong,
If you are at the source of a sound wave and then accelerate in a straight line to 75% of the speed of sound, the sound wave will be travelling away from you at 25% the speed of sound in the direction you accelerated and 175% in the opposite direction.
If you are at light source and accelerate in a straight line to 75% the speed of light. The light will still be travelling away from you at the speed of light in all directions.
It is very difficult to "wrap ones head around" this concept but, that's what has been proven.
Troy
#81
In reply to #78
06/10/2013 6:01 PM
Hmmm you're making me think. So if I'm both the source and observer that's where the difference is between sound and light. So if you're in a jet plane at mach1, the speed of your sound relative to you is 0 in front of you and mach2 behind you. However for an observer in front of you, the source's speed does not change the speed of sound, only the pitch. Light does not work this way if the source and observer are the same person. Light speed is the same in all directions. Ok, that's the answer I wanted to hear under my terms. I just have to wrap my head around it now.
In reply to #81
06/10/2013 10:32 PM
I think its the other way around. You make Mach 2 and the sound you make is at Mach 1 which is Mach 1 behind. It still has a speed right!
Sound before you is I would say Mach -1 - pure arithmetic of course.
Good Answers: 125
#110
In reply to #81
06/11/2013 4:15 PM
It sounds like you understand sound.
Think about this regarding light:
You are in a glass train moving at 50% the speed of light. You have a flashlight, a mirror on the ceiling, and a light detector on the floor. You aim the flashlight at the mirror, turn it on, and the detector indicates light. You saw the light beam travel straight up then straight down hitting the detector.
I am standing on the ground watching you go by. When you flash the light, due to your velocity, I see a light beam travel at a forward angle up to the ceiling (it had to angle from my perspective due to the speed of the ceiling) and down at a forward angle to the detector.
You saw the light beam travel a distance x. I saw the beam travel a distance much more than x. We both saw the light hit the detector at the same time. Therefore the speed of light is the same for someone moving at 50% the speed of light as someone at rest.
Since I report a longer beam, and we both saw the detector struck at the same time, time was running slower for you than for me.
Good Answers: 69
#112
In reply to #110
06/12/2013 4:49 AM
"You saw the light beam travel a distance x. I saw the beam travel a distance much more than x. We both saw the light hit the detector at the same time. Therefore the speed of light is the same for someone moving at 50% the speed of light as someone at rest."
WJMFIRE, I know this is a (good?) common popular explanation for the constancy of the speed of light for all observers, but beware: it is full of holes. The problem is that you and the train traveler do not have the same definition of time, or rather of simultaneity. You do not know which clock is "slower" than which, because this effect is complementary - it depends on who is looking at what clock. Further, you need multiple observers with clocks synchronized per inertial frame in order to perform such an observation.
The modern version is that you cannot measure the one-way speed of light at all, simply because you have to use that one-way speed to synchronize the two clocks you need. The outcome is then a given. We measure the two-way speed with one clock and then just take it to have the same speed both ways. This warrants deeper discussion than what I have time for presently, but I will try to prepare a Blog post to address some of the latest insights.
-J
Good Answers: 125
#120
In reply to #112
06/12/2013 6:40 PM
Thanks for that Jorrie.
I am looking forward to your blog.
My knowledge is very rudimentary with regard to this stuff, but i love it.
Good Answers: 69
In reply to #76
06/10/2013 5:58 PM
Ralf, I try to stay out of these 'heated' debates, but I'll give you one hint. A statement like "The observed velocity of the wave [in a medium] is independent of the motion of source or observer" is ill defined. If you mean the velocity of the wave as measured by an observer moving relative to the medium, then it is not independent of the movement. On the other hand, if you meant as measured by another observer that is static relative to the medium, then it is independent of the motion of source or observer.
In the case of light (no medium), you can have no observer static relative to the medium and hence the wave velocity is the same relative to every inertial observer, irrespective of his movement. The tricky part is that many inertial observers, all moving at different speeds and measuring the speed of the same light wave relative to themselves, will obtain the same speed for the wave, i.e. c.
The secret lurks in the relativity of simultaneity; all these observers would have different notions of what simultaneous means, but relativity defines simultaneity precisely so that all observers measure the speed of light as c.
Hope this helps. I unfortunately do not have much time to clarify this further.
-J
#82
In reply to #80
06/10/2013 6:05 PM
Thank you Jorrie, I will think hard on this. This was the first couple of pages of your book and I was already having trouble. I guess this relates to Einstein's mirror. It's why he would still be able to see his reflection if he was in a car travelling at the speed of light.
#85
In reply to #82
06/10/2013 6:47 PM
I can see the answer's here but I'm like a python on a hippo; there's a good meal here if only I could get my head around it. I guess it's too much to ask why light behaves this way and then I have to understand the other pieces of the puzzle especially the relativity of simultaneity. This could take years.
In reply to #85
06/10/2013 7:24 PM
"This could take years".
Then that would rule out simultaneity.
In reply to #86
06/10/2013 10:35 PM
You still hanging in there? Had a nice chuckle about your comment! Thanks!
Good Answers: 69
#97
In reply to #82
06/10/2013 11:43 PM
"This was the first couple of pages of your book and I was already having trouble. "
Keep it up, because once you have absorbed chapter 2 of the little book, you will be able to work out all the answers that you asked for here.
In reply to #97
06/11/2013 12:52 AM
Thanks for posting your explanation. I would be very curious, if you have time, to hear what you think of answer #23, my first attempt to answer the question.
canary
06/11/2013 4:16 AM
Just on the side and entirly Off Topic.
Can you see yourself here somewhere?
#103
In reply to #100
06/11/2013 9:12 AM
06/10/2013 1:42 PM
I agree with you.He does not want the correct answer, he wants an answer that supports his misguided theory.When someone agrees with him, he will be satisfied and happy.He will be wrong, but happy.He will be blissfully ignorant of the facts, but that is not my problem.I refuse to waste any more time trying to spoon feed an infant that keeps turning his head away from the spoon, and spitting up whatever goes in his mouth, because it does not "taste" right to his "common" sense.He is obviously bored, and seeks to fill his empty life arguing with others because he can not make the mental leap necessary to understand the principles that Einstein has established.If he would expend as much energy really trying to understand relativity,instead of railing against it,he might make some progress.
Someday, when and IF he truly does understand it, he will look back at his infantile arguments on this forum. with embarrassment for being so ignorant.
If not, he will have learned nothing.
"Ignorance does not consist of what a man does not know.It consists of what he knows that just isn't so." Abe Lincoln
His remarks are destined for /dev/null.
06/10/2013 8:23 AM
The speed of sound is about 1000 ft/sec in air with respect to the air. If points A and B are 1000 ft apart, an explosion at point A would be heard by an observer at point B about 1 second later and vice versa. If the wind were blowing in the direction A to B, an observer at B would here the sound less than a second later and observer A would hear an explosion at B more than a second later. Measuring the difference in transit time in each direction would allow you to determine the velocity of the wind. A and B could be two airplanes flying at a constant separation and the same argument would hold. This is what the Michaelson-Morley experiment was designed to do with respect to the velocity of light, i.e. measure our speed with respect to the medium (the aether). The result, of course, was that the speed came out zero no matter in which direction it was measured.
If A and B are stationary with respect to each other, the speed of sound as calculated by the transit time is determined by the wind speed, but there is no Doppler shift. A sound wave emitted from A at 1000 hz would be received at B at 1000 hz. If B were approaching A, there would be fewer sound waves "stored" between A and B as time goes on. B would therefor receive sound waves at greater than 1000 per second and the sound would be Doppler shifted upward. So Doppler is only observed when there is relative motion between A and B.
In regards to the light experiment, I think you were referring to this.
http://web.media.mit.edu/~raskar/trillionfps
It's a bit of a trick. You are not seeing a single light pulse, but a series of extremely short exposure pictures of a series of repeating light pulses taken slightly later each time to give the illusion of motion. It is the familiar strobe effect that makes wagon wheels in old western movies appear to turn slowly. I do not think you can infer from watching this movie the speed of the light pulses with respect to each other.
06/10/2013 10:33 AM
If it's true what you say, then the Raskar video would not be celebrated at all. He wouldn't need all those expensive cameras. He could just film a bunch of time delayed pulses with a normal camera and superimpose them all to give an illusion of pulse propagation. Yes, he is filming multiple pulses so they can register on the camera but the whole purpose of this experiment is to film light speed as it really happens.
06/10/2013 11:27 AM
On the contrary, I think it's extremely impressive. The engineering challenge of capturing images with trillionth second exposure with precision timing is no mean feat. My "bit of a trick" expression was not meant to indicate otherwise, but to describe how it is done, i.e., with repeated laser pulses, capturing each slightly later.
06/10/2013 12:07 PM
I don't understand this statement then, "I do not think you can infer from watching this movie the speed of the light pulses with respect to each other."
If he's not doctoring the speed of light, if it's actually being represented truthfully in slow motion as 1 femtosecond = 1 sec on film (or something like that), and if relativity is correct that no observer can see real information go faster than the speed of light, then two pulses fired simultaneously past each other (if only he had done that), then, I think, we would have not been able to see the two slow motion pulses separate from each other at twice the speed of light. This is because lightspeed is constant for all inertial frames of reference whether I'm observing from the outside or whether I'm hitching a ride on the tail end of one of those pulses. Yes, I agree that if I was on the tail end of one of those pulses, I'd see the other tail end recede from me at lightspeed and not twice the speed of light. I'd see that because the doppler effect would maintain the constant velocity of the pulse but it would highly red shift it. This just leads back again to my original question. How did the Michaelson Morley experiment show anything other than light behaving as any other wave except that it didn't require a medium.
Good Answers: 44
06/10/2013 1:00 PM
You are not seeing the speed of light pulses with respect to each other
You are perceiving the light pulses with respect to the camera lens, the internal workings of the camera, your eye, etc.
You cannot be there with the light pulses...at the speed of light...to see how they perceive "each other" with respect to "each other"
In reply to #59
06/10/2013 1:17 PM
So if I'm taking a video of 2 sports cars passing each other, there is no way I can infer how fast, from the video, they're separating from each other? And if one of those cars had a horn and I was on the back of the other car, I wouldn't hear a lower pitch from the horn and the speed of the sound would be altered by the car's relative velocities? I disagree once again.
06/10/2013 8:17 PM
Are you saying the Doppler shift is the result of altering the speed of sound, and not the compression/then expansion of the wave front?
#88
In reply to #87
06/10/2013 8:21 PM
Nope I'm saying I disagree that the velocities of the cars alter the speed of sound. Anyhoo I got the answer I wanted from Troy36 and Jorrie. The rest on here weren't even close.
06/10/2013 9:00 PM
A closer analogy would be the wagon wheels on an old western movie. Can you tell how fast the wheel is turning as it appears to move forward and backward due to the stroboscopic effect of the movie projector?
Good Answers: 44
06/10/2013 1:14 PM
You are watching the speed of light pulses with respect to the camera lens, its internal workings and your eye, etc.,
...not with respect between themselves...
You have to be there...at the speed of light...which you cannot be...
In reply to #60
06/10/2013 1:34 PM
You don't have to be there at the speed of light anymore than I have to be there, at the nanoscale, to design a microchip. We have all sorts of measurement tools to allow us to be anywhere we want. When we are moving away from a star, we can measure its speed of light and see that our velocity or its velocity does not alter the speed of light. Minus the details you're concentrating on, that's exactly like me hitching a ride on the back of a light pulse. Yup, believe it.
Good Answers: 44
#136
In reply to #63
06/14/2013 6:21 PM
From the earth's perspective, certain stars appear to red-shift.
From the perspective of an object with identical motion characteristics to the earth in the same line with that object and referencing that object there would appear to be a blue-shift.
The speed of light between all objects is same.
The perception of the compressed or rarified light waves is different.
Good Answers: 114
#137
In reply to #136
06/14/2013 10:12 PM
Would you like to have another go at this, please:
"From the perspective of an object with identical motion characteristics to the earth in the same line with that object and referencing that object there would appear to be a blue-shift."
Good Answers: 44
#164
In reply to #137
06/17/2013 3:19 PM
Umm...no?
Good Answers: 44
#165
In reply to #164
06/17/2013 3:34 PM
But...how about a picture:
Good Answers: 114
06/10/2013 10:10 AM
I just dropped in to see if anyone had succeeded. Apparently, no one has.
Justice Potter Stewart said, of pornography, he couldn't define it, but he recognized it when he saw it. For you to reject all of the answers, and all of the responders who offered those answers, implies that you will recognize it when you see it. I think not, you have been offered several approaches but seem to fail to do any work yourself to see if they work. It's like asking the chef to chew and to pre-digest your meal for you.
06/10/2013 2:01 PM
Let me try another tack with you guys. Say you have a baseball pitcher on the back of a flatbed truck listening to the "sweet" sounds of country music. You are on the road facing him with a radar gun as he lets fly a fastball. The pitcher can only pitch 100 mph fastballs. (Don't get caught up in the details.) Your radar gun always measures the speed of the ball at 100 mph plus the speed of the flatbed truck. Now the pitcher picks up an air horn and your gun is set to detect the sound so you can move out of the way in time. If the truck is moving at 770mph, you'll hear the horn just as the truck hits you. It's because the speed of the truck can't push the soundwave any faster than 770 mph. If your radar gun could measure the speed of sound, it would always be 770mph regardless of the speed of the truck. If the pitcher could pitch sound waves, they would go at 770mph regardless of how fast or slow he pitched them. This is the difference between solid objects and energy waves. I contend that sound speed is also constant in any inertial frame of reference so how did that fact not lead to the theory of relativity but the identical behavior in light did.
In reply to #67
06/10/2013 2:55 PM
Oops I forgot one thing. Let's put a flashlight in the pitcher's hand. You will see the same behavior for light as you did for sound. The speed of light through air is not affected by the speed of the truck. This behavior of light spawned the theory of relativity but the identical behavior of sound didn't. Why? I'm not trying to overturn relativity, I'm just trying to understand this one tiny part of it that doesn't make sense to me. In other words trolling.
Alex. Roman (2); Anonymous Poster (3); bioramani (1); Canary (13); cuba_pete (8); Drew K (6); HiTekRedNek (4); IdeaSmith (12); javiertrejo (7); JCase (1); Jorrie (20); JWthetech (2); Kim2012 (1); lyn (3); Nbutt (2); passingtongreen (8); pnaban (1); PWSlack (1); ralfcis (68); Rixter (3); SolarEagle (3); StandardsGuy (2); Troy36 (1); Usbport (5); WJMFIRE (2); Yahlasit (2)
