I am trying to understand how hydrostatic systems work but I can't understand this I copied it from the book I am reading :
(If the hydraulic cylinder (also under pressure) is at rest,
e.g. in clamping hydraulics the forces are in equilibrium.
This effect may be described as hydro-static. However, if
the piston in the cylinder is moved by a supply of flow
under pressure, then not only is the pressure produced
from potential energy effective, but a boost pressure is
also effective which is created by the kinetic energy. This
pressure must be and is taken into account in fluid power
systems. The relationships in this process or system may
not really be described wholly as hydro-static, but the
hydro-static relationships predominate.)
can any 1 explain it for me please :)?
