Previous in Forum: How to Remove PTFE Coating from Inside the Pipe?   Next in Forum: Looking for Tacky/Sticky Reusable Adhesive
65 comments
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Troubleshooting a Steel Rolling Mill
08/06/2013 7:26 AM
Hi Guys, Gals and Gurus,
I'm after some help - and freely admit this is kinda "homework" - in that I need to write a presentation for a job interview.
If the rolling mill, with its usual settings, is now producing material that has the poor surface finish and fails on material properties. Fifteen of this week's coils are not fit for sale. And...guess what...it's for a new customer!
I have to:
  • describe how to find root causes
  • describe typical causes & how to deal with them
  • describe effects on the company
My initial thoughts are:
  • check that the settings are correct - haven't been knocked/nudged or "improved" without consultation
  • that despite the settings being correct, for some reason the temperature is dropping below the recrystallization temperature - hence the material properties issue
  • temp survey needed
  • control system issue perhaps?
  • Would the low temp issue affect surface finish?
  • that something has damaged the surface of the rollers/become embedded, hence surface finish issues
  • Would the loading mechanism for the rollers have these sorts of effects? My initial thought would be that this would only affect the thickness...
  • I want to know total week's production rate - are 15 coils 50% or 0.5% of production
Other questions that occur to me:
Can rollers be resurfaced in situ?
  • How long would this take? Obviously zero production during this time (plus cool down/reheat time) on this line.
  • Can the new customer work be moved to another line? Or deliveries rescheduled? Stock used?
  • If an electrical fault, can the work be done without powering down the heating system...or at least without waiting for plant to cool completely?
  • Is rolling mill shut down going to impact upstream continuous casting line?
I have been doing research online, but thought I'd top this up with some expert advice
Can anyone help? Thanks! :o)
Chaos always wins because it's better organised.
Re: Troubleshooting a Steel Rolling Mill
08/06/2013 7:56 AM
Ask where the quality assurance document/standard manufacturing practice document is for the process, and start there.
If the facility doesn't know how to make the stuff correctly, then how is an interviewee supposed to know?
Good Answers: 75
08/06/2013 10:11 AM
Good Answers: 75
08/06/2013 12:50 PM
Oooh! Just thought: use the PFMEA and Control Plan!
I've spent enough time writing these darn' things over the years...let's put 'em to good use I love Quality Systems....
<waves a feather on a string and opens a tin of tuna to distract Del...>
08/06/2013 7:59 AM
Why wasn't it flagged up when the first coil with poor finish came off the line? Inspection proceedures/issues?
Is there sufficient length on the factory floor for an archery range (neglecting any safety issues?)
08/06/2013 8:18 AM
Yep. Why have fifteen duds been made instead of just one?
Are all fifteen duds the same?
08/06/2013 9:43 AM
Solve the issue on the one, and the other fourteen will go away as well.
08/06/2013 9:55 AM
There is no 'away'
Mind, if you leave 'em outside the factory gates, they'll be gone in the morning.... I blame Kris
08/06/2013 10:13 AM
Rumour has it they are needed to make a new bathtub.
Good Answers: 75
08/06/2013 10:14 AM
PMSL! Round here, you don't even need to leave it outside the gates...and it disappears in daylight.
Pesky squibs
08/07/2013 9:13 AM
Agreed. Also, the distribution of failed coils with time.
Good Answers: 75
08/07/2013 11:41 AM
Got it! Thanks
Good Answers: 75
08/06/2013 10:13 AM
Good point! (and GA)
I'll ask about the Archery. It's about time we had a shoot-off
08/06/2013 9:31 AM
What about a metallurgy sample on the material before it enters the rolling mill, to make sure it meets spec?
Also, it wouldn't hurt to re-check the analysis to make sure the finished goods are out of spec. There's always the chance of an error by the technician doing the analysis or that the tools he/she uses are out of calibration.
Good Answers: 75
08/06/2013 10:16 AM
GA. There's another slide - I reckon 10 should get me through the 15 mins.
I've been told to allow 1.5 hours for total interview "experience"!
08/06/2013 9:35 AM
I'd leave this statement, "Oftentimes a root cause will have a root cause" out of anything you present to the interviewer.
Good Answers: 59
08/06/2013 10:00 AM
I didn't say that's how she should present it, just something to think about.
08/06/2013 10:18 AM
Well, I'd call it stating the obvious.
Now, here's a root cause map that looks sufficiently complex to impress even the toughest interviewer: Root Cause Analysis For Beginners - Service Link
Page 50.
Hey, where'd that other post go??????
At least you didn't post anonymously!!!
Good Answers: 75
08/06/2013 10:27 AM
Thanks lyn...checking it out now
Good Answers: 59
08/06/2013 9:50 AM
I'm not sure how detailed your presentation needs to be. For the first part, describing how to find root causes, you might want to consider explaining your strategy. How did you come up with that list of potential root causes? For example, are you using lean manufacturing techniques to be sure nothing is overlooked? Oftentimes what at first glance seems to be a root cause will have a root cause, so a technique like the 5 whys analysis will help you find the true root.
For this type of interview your process can be just as or more important than your final answer. They can train you on the job but not how to use your brain!
(Sorry, I replied earlier under the wrong user name!)
08/06/2013 10:14 AM
Two usernames? Perish the thought!
Good Answers: 75
08/06/2013 10:21 AM
I thought that was banned under the CR4 Rules....
08/06/2013 10:24 AM
A wise, now belated, university lecturer in the past: "Rules are for the obedience of fools and the guidance of the wise".
Anyway. So is "homework". It's a pleasure doing such a trifle for a username that is so greatly respected.
Good Answers: 75
08/06/2013 10:42 AM
Aw shucks <scuffs sneaker toe in the dirt>
Everyone's help is greatly appreciated...and I hope I obeyed all the "posting a question" rules
Now trying to get the cat to keep his paw out of the printer....
08/06/2013 10:29 AM
Do as I say, not as I do...
08/06/2013 10:44 AM
Good Answers: 75
08/06/2013 10:20 AM
I wondered how lyn replied in #5 to post #7....
Good point on the 5 whys - I use the technique but it's "so obvious" I don't need to explain it...LOL
Hmmm....slide on 5 whys & 5C fault analysis....slide on possible causes....slide on WHO to ask for more details.....slide on tests to be carried out.....slide or two on effects on company (demonstrate commercial awareness)...Feeling better about this...
08/06/2013 1:49 PM
(Sniff...) I smell conspiracy!
08/06/2013 10:12 AM
Is there a pattern to the fifteen; were they all evening shift, for example?
Good Answers: 75
08/06/2013 10:24 AM
<slaps forehead> Oh yes!
Funny, at the last place, that was the first (or maybe second) question I asked...didn't occur to me in this pretend scenario!
08/06/2013 10:47 AM
Sometimes intelligent people overlook the bleedin' obvious. Don't be frightened to ask the question. The only stupid question is the one that is never asked.
08/06/2013 10:50 AM
Were these LynDoor™ coils? Nuff said...
08/06/2013 11:04 AM
Could be.
We use the Microsoft manufacturing philosophy. Get it close enough to ship and let the end user sort it out.
Here at LynDoor™ we subscribe the the 5 W's quality plan.
1. Why does it need to be that good?
2. What difference does it make?
3. When did that requirement get added?
4. Where did that spec go?
5. Who cares?
Good Answers: 75
08/06/2013 11:11 AM
5Ws and and H...
How do they get away with it??
08/06/2013 11:24 AM
Careful, there. KrisDel™ might action for plagiarism.
08/06/2013 1:52 PM
Yeah, very careful - I think Hillary Clinton has that copyrighted.
Good Answers: 75
08/06/2013 11:02 AM
Just thought of another: Check maintenance records. And training records, possibly.
08/06/2013 12:06 PM
"Check maintenance records." If there are any.
One day it was working correctly, now it isn't. What changed? Were the roughing or finishing rolls changed? Pickling solution?
As far as the surface finish, having a series of diameter changes with the wrong gap or speed settings can cause defects as well. Including micro-cracks toward the interior.
"control system issue perhaps? " ARRGH! Sorry, you just hit a sore point. If you mean the instrumentation, or I/O then OK. Most people (read OPS) mean program when they say control system. A DCS/PLC very very rarely goes "sort of bad". If it could add 2+2 and get 4 yesterday, it can do so today, or it is an obvious molten heap sobbing in the corner. If someone has changed the program (again what human changed what), or mis-tuned a PID loop, that is a different story.
2 cents
Good Answers: 75
08/06/2013 12:28 PM
Thanks for the nudge - I did indeed mean instrumentation, I/O or damage to the PLC.
I'm a mechie, so the boxes "do magic" and are always right (from their input to their output). Honest
Good Answers: 75
08/06/2013 1:31 PM
Duh! 8D Analysis (for some reason, the last company at which I worked called it 5D - I know they left out D8; I'm trying to work out which other three* they omitted...)
*There are actually nine stages in the 8D process - D0 to D8....
08/06/2013 1:57 PM
I have a suggestion for D9. Teach your team to count. Or, is that D10?
Good Answers: 75
08/06/2013 3:26 PM
Perhaps it was designed by a computer scientist...
Hang on, no. Then it would be to 0101D Process....or the 09 0D Process
I'm confused as to how/why you Plan (D0) before putting together your Team (D1)
08/06/2013 3:49 PM
More likely an MBA. Those who can, do. Those who can't, become business majors.
08/07/2013 10:54 AM
No, this is D10.
Good Answers: 75
08/07/2013 11:35 AM
LOL!
08/07/2013 2:44 AM
I think it's a good working title for the next KrisDel blockbuster....
08/07/2013 3:07 AM
Along the John Harvey-Jones model? Good thought.
08/07/2013 5:51 AM
A single point to start and concentrate on: What component or equipment is responsible for the "surface finish"? Approach faulting in discrete steps.
Good Answers: 75
08/07/2013 11:40 AM
One of the questions I have!
It seems logical that the surface finish of the rollers will have an effect, as will the pressure load and the thickness reduction. Anyone know more?
08/07/2013 9:18 AM
Sorry if I missed it, but are we talking of Hot Rolling of steel or Cold Rolling ? It definitely makes a difference.
Good Answers: 75
08/07/2013 11:44 AM
It's not specified in the interview question...so I "decided" it's hot rolling so I'll mention temperature control and keeping it above the recrystallisation temperature.
08/07/2013 11:38 AM
Mr Wentworth just told me to come in here and say that there was trouble at the mill, that's all - . . . .
(Sorry, I just couldn't resist )
Good luck with the interview. At least they weren't asking for a simple block of flats. Doh ! There I go again. Rotating knives and all.
Good Answers: 75
08/07/2013 11:43 AM
What do you mean...trouble at t'mill?
(Noooo....don't get me started!!!!)
Thanks - it's tomorrow, so I'll report back...
08/07/2013 12:02 PM
All the best.
08/07/2013 12:40 PM
Me too. Good luck!
Good Answers: 75
08/07/2013 4:43 PM
Search for intelligent life here, at 21:30 (note: will not be available after Mon 12 Aug 2013)
ENJOY!!!!
I know.
- I know you know...
08/07/2013 4:53 PM
I'm listening as I type.
Thanks,
Cheers.
Good Answers: 75
08/07/2013 7:55 PM
There will be another one along next week
Once they get to the end of series 4 (the last one as KH died, on stage, during the off-season), they'll start back with Beyond Our Ken.... If you haven't heard them, Much Binding in the Marsh is worth a listen. I think there are only about 6 episodes left in existence.
If you spot "Life with Lyons" in the schedule - you might enjoy the everyday story of an American family in the UK in the 1950s....
In reply to #59
08/07/2013 9:48 PM
That would be very interesting since I am from Arkansas, and grew up on a farm by the creek in the 1950's/1960's. Before TV, believe it or not. No cares, but no money.
My sister, brother and I still own the property. (My avatar is a small lake there)
Some of it was homesteaded by my great (or great great) grand parents and I found a land grant deed to some of this property that had U. S. Grant's signature. He was president at the time.
Good Answers: 75
In reply to #60
08/08/2013 2:20 AM
How fantastic! Real history (Mind you, in certain parts of Cornwall you'd still be regarded as an incomer...)
Here's the episode list - if I spot they're being rebroadcast, I'll PM you. Each episode is available for 7 days from broadcast. I heard one as part of the Saturday morning Comedy Greats programme a few weeks back. More info - it got to TV too!
<ER wanders off humming...Where the Arkansas River/Leaves Oklahoma/It runs free and rambles/Muddy and wild...>
Good Answers: 114
08/08/2013 8:05 PM
"Go on Jules, show 'im your 'arris"
For the uninitiated, that is a double layer of cockney rhyming slang.
08/07/2013 5:18 PM
One last thought: You mentioned "temp survey needed". Along those same lines (whether this is hot or cold rolled), what type of historical data gathering do they have for doing analysis on the process. If they have a SCADA system, they will most likely have some sort of historical logging package (PI, INSQL...).
Process knowledge, raw data, and intelligence make a might powerful troubleshooting combination.
Good Answers: 75
08/07/2013 7:51 PM
Great minds!Slide 7: Temperature survey (i.e. what are we getting) and review of logged data (when did it (if it did) change)
I like to think I have the intelligence (or can tap into others'!! Slide 3: Assemble Team), I think I've covered the raw data....wish I had more process knowledge! I'm working on the principle Savvy mentioned - they are more interested in how I think that what I know. Of course Slide 3 is also about using more knowledge than I have.
Thanks for taking the time to suggest. I hope maybe the thread will help others preparing a similar presentation.
Good Answers: 75
08/08/2013 5:10 PM
A huge thank you to everyone who commented here. The interview went pretty well today (0900-1030). Turns out I'd met the interviewer when he was a baby engineer...and I didn't remember, although he did! Generously, he only told me that on the way back to reception
About three weeks until I hear back (I'm the first they're interviewing), so fingers crossed.
08/09/2013 11:05 AM
Suggestion: follow-up letter/e-mail/whatever, thanking them for the interview opportunity and selling something else: "I don't remember mentioning that I......[insert something to savour].". Something along those lines.
Good Answers: 75
In reply to #64
08/11/2013 4:29 PM
Bugger - I thought of something on my way home....can't remember what it was now....will sleep on it...
Thanks
Register to Reply 65 comments
Anonymous Poster (1); Brave Sir Robin (1); Doorman (1); Dr. Harry (1); English Rose (26); GameJudge (1); Kilowatt0 (2); lyn (8); passingtongreen (1); PWSlack (14); SavvyExacta (2); triniboy (1); Usbport (3); user-deleted-1105 (3)
