Previous in Forum: Discolered Breaker Terminals   Next in Forum: Liquid Resistant Starter for 4.8 mW Slip Ring Motor
Data Center VTs Failure
12/07/2013 12:10 AM
Our data center has a VT failure (phase A only) every two months or so in a different location. Each set of VTs connected Yg-Yg 34kV/380V. I have noticed floating ground in some locations. What can be the cause?
Good Answers: 181
Re: Data Center VTs Failure
12/07/2013 6:04 AM
What is the VT used for?
Yg Yg to me seems strange Y Y with one leg earthed (grounded) on the secondary is the norm in the UK.
Can you give more information?
12/08/2013 2:16 PM
More information is required, such as what side of the transformer they are connected to, if you are overloading the output of Phase A VT, etc.
If I had to guess I would say they are failing due to voltage spikes or over voltage (eg- power quality issues).
Have you considered connecting up a voltage data logger?
12/09/2013 4:03 AM
Does the "floating ground" mentioned mean that the system has a distorted neutral, how was this detected?
"Snap shot" checks of the 6 secondary voltage measurements-3 line to line & 3 line to earth at different VT locations might yield some important indications of what your problem is.
Recommend you peruse my thread on Tarrif metering with earthed VTs.
Your VTs may require inversion damping.
Register to Reply 3 comments
Instruform (1); jack of all trades (1); TonyS (1)
