Previous in Forum: Grouting Cement   Next in Forum: Milling Lumber--Green or Dry?
Grouting Cement
12/12/2013 6:42 AM
Dear All
The total volume of work = 2.3 cu M, the quantity of cement in cum = 2.3
as we know cement is available in market in 25 kg bags what is the volume of 25kg cement is = ??.00 cum)
Regards
Re: Grouting Cement
12/12/2013 9:59 AM
It probably says on the bag and is a range depending on how wet you mix it.
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
Good Answers: 1693
Re: Grouting Cement
12/12/2013 5:58 PM
32 bags.
No, wait. 24.
13.
5
Is it premixed and frozen?
Re: Grouting Cement
12/12/2013 6:50 PM
Simulate a cement bag as a (Piet Hein) superellipsoid of volume V = abc/2; divide the result into 2.3 m3.
Good Answers: 203
Re: Grouting Cement
12/13/2013 5:42 PM
AP-
In the USA a standard bag of cement is 1 ft3 and weighs 92 lbs., and 1m3 = 35.31 ft3. Also 2.2 lbs = 1 kg
(92 lbs/ft3) * 35.31 ft3/m3 * 1 kg/2.2 lbs= 1476.6 kg/m3
(25 kg)*(m3/ 1,476.6 kg) = 0.017 m3 per 25 kg bag
THAT'S A LOT OF CEMENT!. I hope you are getting a truck or ready mix and not mixing it yourself!
I did the above with a slide rule and verified it with my phone. I'm old enough to know how to use it and boy did I enjoy it! Try one of those nostalgic moments sometime!
Good Luck, Old Salt
Re: Grouting Cement
12/13/2013 8:24 PM
Dear All
I've calculate the volume of grouting cement per footing column I am getting 0.014m3 and we do the actual pouring of ground cement, one footing consume 1 1/2 bag of grouting cement. therefore 2.3 cu M of volume required 70 bag.
Regards
Newbie
Good Answers: 295
Re: Grouting Cement
12/31/2013 11:38 AM
Wait... What?
70 bags total ÷ 1.5 bags/column ≈ 46 columns.
2.3M3/46 columns ≠ .014M3 /column... Not even almost
Anonymous Poster (1); Doorman (1); lyn (1); Mike W (1); old salt (1); Tornado (1)
