Good afternoon. I would like to share an issue for input/discussion.
The issue is motor/vfd failure. The application is a crane/hoisting hot metals. Two 270kw 3phase 480v, 890 rpm slip ring type motors used which can run either together or individualy through gearbox(s). Over the last 6 mos, 3 motors, and one drive have failed. (each motor is run by its own vfd). Damage was to the stator, and rotor windings on one (the latest, burned/arcing) and stator only on the other two (very low resistance to motor frame from each winding) The vfd damage, i believe but am not certain, was to its internal power supply. Prior to the above incidents, the motors ran (well) for about 3 years. They were originally set up with thyristor-drives. The drives were replaced with vfd type units. The rotors are shorted at the resistor connection via a contactor. (they can be run in a different mode, without the vfds, via resistor banks and contactors, for emergencies) Before I jump into whats been checked, tested, Im inviting comments from others whom may be familiar on the topic. Thanks.
