Previous in Forum: VR3 Regulator Problem   Next in Forum: Electrical TNS Earthing System
25 comments
Control Magnetron Power Using a Variac and 2 MOTs
06/13/2014 2:10 PM
Hello,
I'm planning to build a microwave power generator with an adjustable power output. The easiest solution would be to take the magnetron and the associated power supply from a microwave oven and power it up through a variac. The variac will provide adjustable voltage to the microwave oven transformer (MOT). But doing this way, not only the HV to the magnetron will alter, but also the heating current to the cathode inside. I think that a better way to control the power is to provide a constant cathode heating current and only adjust the HV to the magnetron. So I need advice on this, please.
Say, if i take 2 MOTs from the same brand and model of microwave ovens and connect one MOT to the line voltage directly, the large wire on the secondary can be connected to the cathode to provide a constant heating current. For the second MOT, the thin wire on the secondary that hooks up to a capacitor can be connected to the magnetron. And the primary on this MOT can be connected to a variac to provide adjustable voltage. This way, the HV to the magnetron can be adjusted (on the 2nd MOT) while the heating current will be constant (on the 1st MOT).
My question is: for the HV wire on the secondary of the 1st MOT that is not connected to anything, should I connect it to something or ground it? I have read somewhere that if a secondary is left open, an arbitrarily high voltage can develop, and this would present a safety hazard. Also, for the high current, low voltage wire on the secondary of the 2nd MOT, should I leave it open or connect it to a resistive load or anything else?
Thank you very much if you could help me or give me some direction on this.
Sincerely yours
Re: Control magnetron power using a variac and 2 MOTs
06/13/2014 2:40 PM
If you are connecting the secondary to the cathode, what is your reference? your question will answer itself.
Schematics, please.
common knowledge...less common than common sense
06/13/2014 5:04 PM
You do not control power output with Mag voltage. Mag voltage is required to generate the radiation.
You control the output power by varying the Current thru the Mag.
You have a bit of study to do.
Find out why Microwave ovens control power by duty cycle rather than mA control.
Good Answers: 1142
Re: Control Magnetron Power Using a Variac and 2 MOTs
06/13/2014 7:44 PM
The magnetron is probably designed for the optimum output. If you want to vary the output level, you might consider controlling it by introducing an absorber.
Good Answers: 444
06/13/2014 8:09 PM
This is another Darwin Award winner in the making, and anyone who assists in this folly is entitled to Runner-Up status...post-humuously.
06/13/2014 8:17 PM
..." a magnetron designed for an output power of 200 kw peak will operate quite well
at 100 kw peak output by simply reducing the modulator drive level."
http://www.cpii.com/docs/related/2/Mag%20tech%20art.pdf
http://www.microwavejournal.com/articles/2090-a-solid-state-power-supply-modulator-system
06/13/2014 8:52 PM
06/13/2014 10:26 PM
06/13/2014 11:28 PM
06/17/2014 9:33 AM
As I posted #2, the info you have shown indicates a full voltage drive and PWM to control net current through the device.
Same as PWM for slot cars and model trains, among other applications.
06/13/2014 8:26 PM
I service kitchen equipment and the only thing I care to know about microwaves is that...if you don't know what you are doing 100%... they WILL kill you....sooner or later.......probably sooner..... I am curious as to why you want to do this..Application ??
Good Answers: 444
06/13/2014 9:58 PM
Thank you for sharing your expert knowledge, Dammit!!! This idiot doesn't realize that there's around 5kV lurking in that circuitry, energized or not, that the magnetron output may not be continuously variable from 0-100% because the magnetron does not "fire" below a certain plate voltage, that the positive side of the high voltage supply is connected to chassis ground not the other way around, that microwaves leak out any time the unit is operated without all the covers and screws in place, etc., etc.
Good Answers: 44
06/14/2014 2:32 AM
I gotta ask...how many people have you seen killed by microwaves...in your line of work??? I could see if you got your head in there, but getting the door closed would probably break your neck anyway.
06/14/2014 5:38 AM
Any object dropped from a height can be lethal, Bwana.
Good moaning!
Anonymous Poster #3
06/14/2014 9:11 PM
Why do you usually end with a derogatory pseudoname? I find it quite offensive!
06/14/2014 10:46 PM
Are you a member of the EOGOP?
06/15/2014 11:48 AM
Door closed...... Cute....... YOU need to open the back end and play around... I don't know anyone that was killed...only a friend of a friend...... it was a bench test and it killed him...I don't service them because I am not qualified...... you are qualified so you can put your fingers in there and poke around... Original poster is very qualified considering his/her posts.... How about you.........
06/17/2014 9:40 AM
When I wporked in the ship yard on the great lakes, there was a technician that worked on the ships radar unit in one of the yards on the east coast......... never locked it out.... then they ran tests on the radar unit.......... I'm not going to go on about the condition of the corpse.
Anonymous Poster #2
06/13/2014 10:31 PM
Can you tell us what color the wires are?
That will help in our analysis to determine which spell we use.
ffrohit3
Voodoo Power spells.
06/13/2014 11:13 PM
Be aware that one of the secondary wires is connected directly to the Iron corner of the coil. .
and these truthes shall be held self evident that all men are created equall
06/14/2014 12:02 AM
Thanks everyone for all the very helpful comments. Yes, I know that there's a 4-5 kV flowing around the circuit and about the Hartee voltage. Thank you for your concern about safety! I actually want to use this for a short project on moisture measurement of some very large pieces of materials. A microwave brick oscillator (generating some few hundred mW's) can't generate enough power go through the material, so a much higher MW power is needed. I have successfully connected a magnetron to a pyramidal horn antenna and measured the emitted power collected on another horn antenna about 0.8 meter away (with me and the measuring equipment hiding behind a metallic screen at a distance from the horn antenna with a MW oven leakage detector in my hand that is on all the time). The only problem is that the emitted power is so high that it is well over the range of my power detector, even with the attenuator in place. So I am looking for a way to significantly reduce the emitted power. If the direct variac-to-MOT method won't work (magnetron starts to fire at a too high power already), I think I'll go for the duty cycle method instead, together with the variac setting to get the magnetron to fire at the lowest possible power. Thanks everyone again for all the very helpful comments and for all the concerns for safety! :)
Good Answers: 444
06/14/2014 1:20 AM
Why didn't you state your goal in your original post and save us a lot of guesswork. You would have found out that there are already products out there that do what you want without reinventing the wheel.
I guess that you're doing this on the cheap, but you're facing a multitude of problems that have already been solved; the main ones being calibration, accuracy, repeatability, and precision. Just because you know how much energy gets absorbed by your moisture laden material tells you nothing about how much was reflected off it, how much was absorbed by the material, moisture, and ambient.
See if you can buy one of these on the used instrument market:
http://www.hydronix.com/
http://www.grecon.com/en/moisture-analysers-mm-6000
http://www.rgi-ms.com/html/moisture_principles.html
https://www.berthold.com/en/pc/moisture-microwave-technology
06/14/2014 2:33 AM
Why microwave?
What material and what moisture content are you measuring?
It would be much cheaper and simpler to use Infrared and Near infrared to detect moisture content.
You could also differentate between the measured object and steam in between the object and the measuring device this way.
And the souce could be a simple incandescent bulb driven at a lower-than spec voltage.
I saw one working on this principle about 30 years ago.It was very accurate and reliable.
The IR was used for actual moisture,and the NIR was used for vapor detection.
Good Answers: 117
06/14/2014 7:49 AM
Damn...I just gave an A. P. a good answer. I am slipping. Would somebody please (besides me) invite this guy to the forum....I am impressed enough to do so.
06/14/2014 9:22 AM
In addition to the infrared types I mentioned,there are conductivity types for use in certain applications, such as web (paper,textiles,etc.) and batch applications(Grain silos,etc.).
This technology has proven accurate and relaible for over 50 years,and is still used widely.
One such company is Strandberg Engineering (with which I have no affiliation or interest) but I have worked with their products.
They even make a hand held unit for spot checking material while in process and in motion.
Don't limit yourself to one technology.
06/16/2014 10:08 AM
Now if we can just Modify this to Burn out Po-Po's Radar guns, I'd be happy!
Reply to Forum Thread 25 comments
Anonymous Poster (3); corbinstein (1); Crabtree (1); cuba_pete (1); Dammit (2); HiTekRedNek (3); LongintheTooth (2); phoenix911 (1); RAMConsult (3); Rixter (1); SolarEagle (4); The.Tinkerer (1); UsernameJUDGE (1); Yusef1 (1)
