Previous in Forum: EOT Cranes   Next in Forum: Carbon Brushes
23 comments
Motor Rotation for the Fresh Air Handling Unit
06/21/2014 4:01 PM
sir i have asking about the rotation of the motor of the FAHU,during monthly pm of the fahu back to start the motor and we check the rotation is clockwise move.my question is what is correct moving of the motor?CW?or CCW?
Re: motor rotation for the fresh air handling unit
06/21/2014 4:05 PM
The motor should always rotate whichever way that makes the air move in the desired direction.
It will very likely make the air move when rotating either direction, but it is always best to make the air behave as the operator wishes.
06/21/2014 4:15 PM
mam the position of the blower assembly is CCW ,the actual moving is CW,
Reply Off Topic (Score 3)
06/21/2014 4:27 PM
thank you lyn,
06/21/2014 4:27 PM
Which side are you standing on? CW and CCW have absolutely no meaning this far.
06/21/2014 4:39 PM
The outside.
Good Answers: 70
06/21/2014 4:54 PM
"during monthly pm ...." Is this a 3 phase motor? Did someone disconnect the motor leads without noting the phasing? Most air handlers I've dealt with usually has an arrow close to the drive pulley showing direction of rotation.
06/21/2014 5:08 PM
yes three phase motor,okey thank you. we will check the arrow
Reply Off Topic (Score 6)
06/21/2014 5:51 PM
It depends on the blower wheel....
06/21/2014 5:58 PM
yes thats why im telling,now our two units of FAHU same moving opposite derection.ty brod.now i want to suggest to my team leader its time correct the blower rotation.thank you guys.
06/21/2014 6:23 PM
This is true only of forward-curved centrifugal fans/blowers. Chances are it will fit the OP's situation, but we don't know for sure.
06/21/2014 6:35 PM
Reply Good Answer (Score 5)
06/21/2014 11:57 PM
Haven't you contradicted yourself? #8
06/22/2014 3:09 AM
No he did not contradict himself. He replied to Tornado's claim that he had restricted his answer to forward curved fans.
FC or BC, fan wheel rotates in direction of air flow.
06/22/2014 1:06 PM
much better i will take the actual video then i upload the video,we will see.thanks.
06/21/2014 6:24 PM
Whichever way it says in the equipment manual, Deidre.
Good moaning!
Good Answers: 70
06/21/2014 7:36 PM
Equipment manual? What equipment manual? What's an equipment manual? Damn it! Was that those papers that got sucked into the air handler and we had take the thing apart?
Reply Score 1 for Off Topic
06/22/2014 9:41 AM
...........or.........when all else fails read the instructions...........If the haven't got chewed up by the fan
06/22/2014 12:25 AM
All I've known is digital clocks. They rotate?
Re: Motor Rotation for the Fresh Air Handling Unit
06/23/2014 12:31 AM
There is nothing called correct rotation for such units. The one designed for providing correct results is the correct direction. If you go by books - internationally if the the shaft is rotating anticlockwise - seen from shaft ( load) end - is considered positive direction. But that is not mandatory or compulsory. You may look at the ceiling fan in room to identify it. So don't get drifted by Correct direction.
Let us discuss the practical issues not the classroom.
Good Answers: 70
06/23/2014 12:51 AM
if the the shaft is rotating anticlockwise - seen from shaft ( load) end - ........ Is that anything like anti- gravity?
06/23/2014 1:06 AM
couldn't get your comment .. can u elaborate ??/ anticlockwise and anti gravity - where do you draw parallels??/
Good Answers: 266
06/23/2014 12:53 PM
I have not seen to many air handlers that did not have some type of marking on it for rotation. So find it and follow it.
06/23/2014 5:23 PM
Yes.
I find that round and round works well on most fans. -- JHF
Reply to Forum Thread 23 comments
bongski (5); Circuit Breaker (1); Crabtree (1); dj95401 (3); KeepItSimpleStupid (1); lyn (3); M.R.Iyengar (2); MOBI (1); ozzb (1); SolarEagle (2); Tornado (2); Zvi (1)
