Previous in Forum: Spin Core Pulse Blaster, changing frequency   Next in Forum: How Fast an Analog Coincidence Circuit Can Be Designed
Load Cell Model 1040
07/02/2007 9:25 AM
sir, please give me mountings load cell model 1040, or schematic diagrams load cell model 1040, because its for final taks, I hope your can help me,
Good Answers: 54
Re: Load Cell Model 1040
07/02/2007 11:59 PM
What brand are you using?
Fans of Old Computers - Vector 1 - New Member
07/03/2007 11:13 AM
Try this link
Precision Load Cells Tedea-Huntleigh Model 1140
July 3, 2007
Our Products
Instrumentation
Monitoring/Display
Signal Conditioning
Stress Analysis
Strain Gauges
Transducers
Load/Torque Cells
Displacement
Pressure
Data Acquisition
Vibration
Accelerometers
Analysis
Physical Testing
Material/Composite
Fatigue/Durability
Physical
Environmental Test
Chambers
Our Manufacturers Ashcroft
Astro-Med
Capacitec
Celesco
Cincinnati Sub_Zero
Data Physics
Data Track
Doric
Ectron
GP:50
Honeywell
Kaman
Kistler
Lebow Products
Michigan Scientific
Morehouse
MTS Systems
Non-Linear Devices
Revere Transducers
Sensortronics
SRI Pmd
Strainsert
Tedea-Huntleigh
Tovey
Trans-Tek
Unipulse
Vishay Measurements
Group
Precision Load Cells Tedea-Huntleigh Model 1140 Precision Load Cells Tedea-Huntleigh Model 1140 are a low profile single point load cell designed for direct mounting of low cost weighing platforms.
The small physical size, combined with high accuracy and low cost, makes this Precision Load Cells Tedea-Huntleigh Model 1140 ideally suited for retail, bench and counting scales.
Tedea-Huntleigh is the world's largest manufacturer of Precision Load Cells.
Precision Load Cells Features:
• Capacities: 15 - 150 Kg (33 - 330 lbs.)
• Stainless steel construction
• 6 wire (sense circuit)
• Single point 400mm x 400mm
• (15.75 inch x 15.75 inch) platform
• IP54 protection (IP67 optional)
July 3, 2007
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." Mark Twain
01/06/2017 1:32 AM
The small physical size, combined with high accuracy and low cost, makes this Precision Load Cells Tedea-Huntleigh Model 1140 ideally suited for retail, bench and counting scales. password manager
To be or not to be,this is a question
Register to Reply 3 comments
Alicee (1); BRANSON (1); Vulcan (1)
You might be interested in: Cell Processors, Battery and Fuel Cell Components
