Previous in Forum: Sensor For Zinc Plating Fumes   Next in Forum: 0-25mA & 0-100mV Simulator Diagram 24VDC Supply
4-20mA Simulator Using 10k Pot & 24VDC(750ma Rated) Supply
09/10/2014 7:31 AM
Urgent, please help me do a circuit diagram having 4-20mA output taking in mind the 24V source and 10k potentiometer. Thank you.
Good Answers: 985
Re: 4-20mA simulator using 10k pot & 24VDC(750ma rated) supply
09/10/2014 7:55 AM
You will need many more parts to finish this task; wire, connector, terminal junctions or solder, shrink tubing, other electronic parts.
Getting a potentiometer to vary current between 4 and 20 mA is such a basic question that you have to have either a mental block (I've been there) or an unstated problem (calibration, resolution, noise, explosive atmosphere, etc.) holding you back.
Please fill in your missing uncertainty.
09/10/2014 8:41 AM
Thank you for replying. Sorry sir, I'm a newbie here. This project is for a device that will be used in sourcing for calibration. I'm asking for a circuit having in mind the 10k potentiometer and 24V but not only those electronic parts.
Sir, sorry but I will make a new discussion, I have put the wrong details. Thanks!
Re: 4-20mA Simulator Using 10k Pot & 24VDC(750ma Rated) Supply
09/10/2014 8:56 AM
Sorry, the details of this post is misleading so I made a new discussion here http://cr4.globalspec.com/thread/97515/0-25mA-0-100mV-simulator-diagram-24VDC-supply
thank you!
Register to Reply 3 comments
