Previous in Forum: Is Water The Key To Shutting Down South Dakota's Boom?   Next in Forum: Is Spray Foam Insulation as Safe as Advertised?
17 comments
Soldering
09/12/2014 3:08 AM
hello everybody
can i know what i do title about "soldering" for i do my final year project (FYP).
thanks you.
Re: SOLDERING
09/12/2014 3:18 AM
Title: "Difference of Soldering and TIG welding equipment under consideration of the newest technology available."
Re: SOLDERING
09/12/2014 3:25 AM
"The environmental and health consequences of the recent reduction of the use of lead in commercial solders."
Good Answers: 104
Re: SOLDERING
09/12/2014 5:10 PM
"The reliability consequences of the recent reduction of the use of lead in commercial solders."
Re: SOLDERING
09/12/2014 3:28 AM
"Commercial solderng process for surface mount devices"
"Was the change to lead free solder justified"
"Re working surface mount devices"
"Common soldering faults"
"Health issues with hand soldering"
"Mechanical strength of soldered joints on SM and through hole components"
Etc
Re: SOLDERING
09/12/2014 3:37 AM
what is the meaning "SM" at last title.?
thanks a lot...
Re: SOLDERING
09/12/2014 8:13 AM
"Sub-miniature".
Del is on the way to the Naughty Step for using an undefined abbreviation. ;-)
Re: SOLDERING
09/12/2014 8:25 AM
<cough> Surface mount
I think if you read through my post you will see the words surface mount earlier on... ok I don't define the abreviation, but it hardly requires the deductive powers of Sherlock Holmes to correlate the two. But Ok I'll have a wee sit on't naughty step, I need a rest.
Re: SOLDERING
09/12/2014 8:32 AM
Well, it could be either or both. Come back, Del. All is forgiven.
:-x
Re: SOLDERING
09/12/2014 1:19 PM
thanks a lot
Re: SOLDERING
09/13/2014 3:35 PM
I think he proposed to compare surface mounted component soldering integrity versus though-hole integrity. Factors like failure rate in production processes, physical and electrical reliability, and electrical interactions.
Re: SOLDERING
09/12/2014 3:33 AM
hope similar with my courses WELDING...
Re: SOLDERING
09/12/2014 3:40 AM
"To braze or not to braze? That is the question."
"Thermite hammers ultrasonic solvent arc explosion!"
Re: SOLDERING
01/03/2023 8:44 AM
Shock, horror, probe.
Re: SOLDERING
09/12/2014 7:40 AM
"Too Hot to Solder"
"Soldering Made Sexy"
Re: Soldering
09/14/2014 7:47 PM
First, learn how.
Re: Soldering
09/14/2014 8:19 PM
I suspect you were an undergrad once, a VERY long time ago...
Where did you learn to solder?
I suppose you actually did learn it on your grandfathers knee. I know I had to learn it a alone in a cold basement. I certainly couldn't have written a scholarly dissertation on it.
Why the un-helpful remark? I know you are a GURU and all; but, the wise crack does not, I think, improve anyone's opinion of the poster.
Thanks,
Pete
Re: Soldering
09/14/2014 8:41 PM
Pete,
I suspect that you copied all your "scholarly dissertations" from a homework cheat site.
You seem to be, unfortunately, of the opinion that you can write a paper on something about which you are ignorant.
"can i know what i do title about "soldering"
I think "learn how to solder" was a more productive response than your BS remark to me!
Register to Reply 17 comments
bigg (1); IdeaSmith (1); lyn (2); nik khairul amilin (3); PWSlack (5); Tom_Consulting (1); user-deleted-1105 (2); xray45347 (2)
