Previous in Forum: Google Challenge Update   Next in Forum: Why do we still not know what this is?
What Is It?
11/01/2014 8:22 PM
The gear is 1 inch in diameter and the whole thing is just over 1/2 inch high.
Re: What Is It?
11/01/2014 8:33 PM
It looks like some sort of impeller out of a small pump....
Good Answers: 26
#81
Re: What Is It?
11/03/2014 8:52 AM
I agree.
Re: What Is It?
11/01/2014 8:37 PM
An impeller for ... something ...
Is it related to the weapon, or is that a red herring?
Re: What Is It?
11/02/2014 1:12 AM
Weapon?
Re: What Is It?
11/02/2014 9:34 AM
- on the screen of my mobile 'phone, the nail clippers looked rather like some kind of miniature antique pistol.
Re: What Is It?
11/01/2014 8:58 PM
It's the water circulation pump for your hydroponic herb garden....?
Re: What Is It?
11/01/2014 9:09 PM
Pnaban is looking for one of these mini-turbines to install in a rain downspout.
Re: What Is It?
11/01/2014 9:44 PM
Just Guessing, maybe an impeller from a fish tank pump?
Regards JD.
Re: What Is It?
11/01/2014 9:48 PM
It's your first 3D printer piece resting on an Intel based laptop with a fingernail trimmer. This 3D piece will be used as the powder measure in your new .22 long cartridge reloader.
Re: What Is It?
11/01/2014 9:54 PM
Sorry. You can't reload rimfire cartridges.
Re: What Is It?
11/01/2014 10:32 PM
Oh, so now you tell me you want the primer to work too.
My you're getting fussy.
I guess you just never tried.
Re: What Is It?
11/01/2014 11:02 PM
Nope, never had reason to look for reloading equipment for rimfire brass. So, I'm wrong about not being able to reload it.
I can't imagine being that desperate.
I wonder what happens if you hit the same firing pin dimple a second time?
I don't see any way to pound that back out.
But, you're still wrong about the function of the object. It has nothing to do with ammo reloading.
Re: What Is It?
11/02/2014 7:05 AM
I did not think for a minute that you were actually reloading. I was being silly.
I am a little disappointed that it is not a part from your 3D printer.
Re: What Is It?
11/02/2014 10:17 AM
Hey, at least I accurately identified two of the three objects in the pictures.
Re: What Is It?
11/02/2014 10:34 AM
Ah but you can reload .22's though is not economical http://m.youtube.com/watch?v=LW0QSX4NcU0
Good Answers: 16
Re: What Is It?
11/02/2014 11:40 PM
Not exactly true. You can reload rimfire cartridges by ironing out the firing pin indentation and then pouring in a liquid primer formulation and rotating the case till the primer dries out. Really tricky, risky, and not worth the trouble but it can be done.
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
Re: What Is It?
11/03/2014 8:42 AM
It can be done, I've done it with mixed success.
Nothing is fool-proof to a talented fool
Good Answers: 97
Re: What Is It?
11/01/2014 11:47 PM
Its the reason copy/printer/fax machines have a low MTBF?
CRTL-Z
Re: What Is It?
11/01/2014 11:51 PM
Nope, never known one of these to fail in service.
Good Answers: 97
Re: What Is It?
11/02/2014 12:11 AM
From an ice maker?
CRTL-Z
Re: What Is It?
11/02/2014 12:39 AM
Nope. Normally used at, or near, room temperature.
Good Answers: 140
Re: What Is It?
11/02/2014 1:58 AM
From a water meter...
Re: What Is It?
11/02/2014 2:41 AM
You're all wet.
Good Answers: 97
Re: What Is It?
11/02/2014 2:42 AM
A heat sink for a small bearing.
Re: What Is It?
11/02/2014 10:30 AM
No.
Good Answers: 11
Re: What Is It?
11/02/2014 5:17 AM
a nail cutter holder.
Re: What Is It?
11/02/2014 6:47 AM
It's a rotational distributor for a yard sprinkler.....or possibly a small fountain in your hamster cage....
Re: What Is It?
11/02/2014 10:29 AM
Nope.
Good Answers: 97
Re: What Is It?
11/02/2014 6:55 AM
Coolant pump in a graphics card.
Good Answers: 183
Re: What Is It?
11/02/2014 7:23 AM
Dispenser ?
Re: What Is It?
11/02/2014 10:33 AM
It does not dispense.
Good Answers: 183
#139
Re: What Is It?
11/04/2014 8:47 AM
Yes, it is the cover lay take-up mechanism of an inhalation medication dispenser that packages the powder in small pockets in a continuous reel.
I am deeply surprised since you wrote that it does not dispense.
And now you say it is part of a dispenser.
In reply to #139
Re: What Is It?
11/04/2014 9:10 AM
As I said to Beenaround: the object of the entire discussion was the device pictured below.
"What is it".
It should have been obvious to all that it was a part of a larger, more complex device. The purpose of the larger device was NEVER a part of the discussion.
It does not dispense anything.
In reply to #142
Re: What Is It?
11/04/2014 9:57 AM
A valid argument if you had indicated that #70, #86, #91, #91, #100, #101 (in a humorous way), #105, #110, #111, and #113 all identified devices with parts within them that performs the same function as this part. Insisting that this part of the dispenser does not do the dispensing or measuring is disingenuous at best and an outright lie at worst.
Still this has been an amusing exercise. I thank you. This was far better than reloading a .22 cartridge.
Re: What Is It?
11/02/2014 7:30 AM
Its the Tick-Tock "click" gear in a clock run by a synchronous motor.
Re: What Is It?
11/02/2014 10:34 AM
No ticks here.
Good Answers: 114
Re: What Is It?
11/02/2014 2:42 PM
Sorry, I missed this and posted a similar answer.
Good Answers: 114
Re: What Is It?
11/02/2014 9:14 AM
Does the gear drive the impeller? or does the turbine drive the gear? It does have the look of a waterwheel.
Perhaps something from a flow meter, but that is as far as I get.
Re: What Is It?
11/02/2014 10:36 AM
The gear drives it.
Good Answers: 97
Re: What Is It?
11/02/2014 10:26 AM
It is a dispenser for measured volumes , like shooters (at room temperature)
Re: What Is It?
11/02/2014 10:37 AM
See #30.
Re: What Is It?
11/02/2014 10:36 AM
Used to maintain alignment and prevent damage during transport; a plug.
Re: What Is It?
11/02/2014 10:38 AM
Not for either.
Re: What Is It?
11/02/2014 10:40 AM
It is white. It looks to be made of plastic but it might be a white ceramic coating on some precision metal casting.
Re: What Is It?
11/02/2014 10:48 AM
It is injection molded plastic. My guess is that it is un-pigmented Acetal copolymer.
Celanese trade name Celcon®. Just my guess.
Re: What Is It?
11/02/2014 10:42 AM
Pushs air in your cordless keyboard blaster
Re: What Is It?
11/02/2014 10:50 AM
It does not push anything.
Quite the opposite.
Re: What Is It?
11/02/2014 11:05 AM
Is it the $127.98 replacement impeller for a Dyson hand held vacuum?
I thought you said they were overpriced pieces of....
Re: What Is It?
11/02/2014 11:13 AM
It is not part of a vacuum cleaner.
It doesn't suck, or blow.
Re: What Is It?
11/02/2014 11:31 AM
Did you take that from a forty year old rocket engine?
Re: What Is It?
11/02/2014 11:42 AM
Nope. There was nothing left of the 40 yo rocket engine.
Re: What Is It?
11/02/2014 11:44 AM
The gear drives the impeller, but it doesn't suck or blow. Liquid, then. A pump of some sort. Fuel pump?
Re: What Is It?
11/02/2014 12:05 PM
The gear drives the impeller. The gear drives it.
but it doesn't suck or blow. Correct.
Liquid, then. Incorrect.
A pump of some sort. Incorrect.
Fuel pump? Incorrect.
Good Answers: 114
Re: What Is It?
11/02/2014 1:15 PM
It is part of the escapement for a clock.
Re: What Is It?
11/02/2014 1:28 PM
No. It is used once a day, but not to tell time.
Good Answers: 97
Re: What Is It?
11/02/2014 1:40 PM
Part of a siren for an alarm system.
Re: What Is It?
11/02/2014 1:44 PM
Nothing alarming here.
Re: What Is It?
11/02/2014 3:55 PM
Another look at the two main parts of this assembly.
Re: What Is It?
11/02/2014 8:02 PM
Its part of a bicycle bell. The rotor hits a hammer that hits the bell and its driven by a rubber wheel being pushed onto the wheel side.
Alternatively it runs against a small plate and makes a crackling sound.
Re: What Is It?
11/02/2014 11:03 PM
Is there not more to it than that? OP pics show a linear bit & something else in the centre of the gear -
Floss or die!
Re: What Is It?
11/03/2014 9:24 AM
Looks like a governor for some spring-loaded device..
It's not Rocket Science
Re: What Is It?
11/03/2014 4:16 PM
Wild guess here, but it might be one of the drive gears and fan from a hair dryer? Used once per day (perhaps), but then one would have to have hair. If not, then it's ona dees, or ona does.
Good Answers: 125
Re: What Is It?
11/02/2014 6:34 PM
Deer feeder dispensing gear.
Good Answers: 225
Re: What Is It?
11/02/2014 10:39 PM
Perhaps a rotational speed control air damper for a photo copier/printer/clock, or maybe in conjunction with a bit of formed duct it is a small cooling fan for some apparatus?
Good Answers: 15
Re: What Is It?
11/02/2014 11:08 PM
Part of a stacker, counter for some document, checks, cards, or machine handled small packaging?
For every action, there is an equal and opposite criticism.
Location: kibbutz nir-david, a beautiful rural village in Israel
Re: What Is It?
11/02/2014 11:18 PM
it is the "turbine" for a water flow meter.
I was working in the gardens of our kibutz, and this devices were repaired in the nir by Kibutz Heftzi- ba.
Re: What Is It?
11/02/2014 11:22 PM
Sounds correct, but Lyn said gear drives it -
Floss or die!
Good Answers: 225
Re: What Is It?
11/02/2014 11:40 PM
It would appear that there is a detent on an inner gear that is possibly keyed to the impeller, and which locks with the outer gear to positively drive the impeller in a clockwise direction, but allows slippage in an anti clockwise direction.
Re: What Is It?
11/02/2014 11:42 PM
paddle that changes the date tag over in a clock
Re: What Is It?
11/03/2014 12:13 AM
A heat sink
Good Answers: 123
Re: What Is It?
11/03/2014 12:27 AM
Working end of a hemorrhoid massager?
Bob
Re: What Is It?
11/03/2014 12:38 AM
it is the test print of Lyn,s 3d printer.
love4everyone
Re: What Is It?
11/03/2014 2:20 AM
Push and turn bottle top for sealing in dry goods that have to breathe
Torque is not cheap
Re: What Is It?
11/03/2014 3:25 AM
Its a wheel of some sort the blades act as suspension. micro bug?
Re: What Is It?
11/03/2014 4:26 AM
A rotary valve or dispenser?
Regards JD.
In reply to #68
Re: What Is It?
11/03/2014 4:52 AM
Pinch of salt, one revolution of lime juice, two revolutions of tequila. Blather, rinse, repeat about 10x.
Re: What Is It?
11/03/2014 5:11 AM
Looks like it might be part of a uni-directional clutch.
Good Answers: 15
Re: What Is It?
11/03/2014 5:48 AM
Bathroom scale regulator
Good Answers: 114
Re: What Is It?
11/03/2014 6:34 AM
It is a one-off, purpose built, device.
That purpose is to befuddle the scientists and engineers who frequent this place.
Re: What Is It?
11/03/2014 7:09 AM
It's a device for gradually moving the labels around on a laptop.
Re: What Is It?
11/03/2014 7:18 AM
I have gears like this in my laser printer cartridges.
In reply to #74
Re: What Is It?
11/03/2014 7:25 AM
But he says it's used once a day.
Re: What Is It?
11/03/2014 8:05 AM
Back in the old days I would guess a part of a damper from a turntable tone arm cue mechanism. The impeller rotates in silicone damping fluid to slow the arms descent...
Good Answers: 11
Re: What Is It?
11/03/2014 8:14 AM
Internals for a massaging shower head??
People Living in Competition, All I want is to have my peace of mind - Boston
In reply to #77
Re: What Is It?
11/03/2014 8:26 AM
Really? You shower every day?
Re: What Is It?
11/03/2014 8:25 AM
I have no idea, but your labels are migrating.
Re: What Is It?
11/03/2014 9:02 AM
Guts off'n a teasmade, auto coffee machine or bread machine.
Floss or die!
Good Answers: 18
#83
Re: What Is It?
11/03/2014 9:04 AM
Its the new Ford 6.0 Diesel turbo impeller replacement,
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
Good Answers: 27
#84
Re: What Is It?
11/03/2014 9:08 AM
It seems like it is an idler or speed governor that induces some rotational air resistance of some sort... similar to a very old turntable mechanism?
vsar
In reply to #84
Re: What Is It?
11/03/2014 9:13 AM
Could be, but would be surprised at it having such a relatively large gear.
Good Answers: 97
#90
In reply to #87
Re: What Is It?
11/03/2014 9:36 AM
I agree. The gear tooth size indicates a sizeable amount of torque requiered to be transferred one way or another. Can the answer be purchased for a small fee?
CRTL-Z
Good Answers: 225
#115
In reply to #90
Re: What Is It?
11/03/2014 5:46 PM
I wonder if the tooth size has more to do with the 3:1 ratio of teeth to vanes, and whether that has anything to do with a particular rotational alignment requirement of the part.
An Xray examination of the first set of pics seems to indicate a second detent arrangement opposite the more clearly visible one in the pic.
Re: What Is It?
11/03/2014 9:11 AM
WJMFIRE, Typically not used outdoors, nor to feed anything.
IdeaSmith Not a noise maker. You'd never hear itduring normal use.
spades. No speed control.
Stuart21 There's much more to it, as you will see.
Beenaround None of the above.
az native Again, no.
spades I gave you a GA for that part of your explanation which is correct. Very preceptive of you.
Grochy It doesn't care what the date is.
jdsighter It's plastic.
bob c
sohail0110 It's injection molded, not printed.
merc600sec no joy.
oak51 Although it isn't, it acts more like an impeller than a wheel.
Tornado Nope, it's never wet.
Brian Falconer It only moves in one direction, but is not a clutch.
Beenaround Nope.
passingtongreen Millions exist. It does seem to be a mystery.
Randall No, that's witchcraft.
roy hammy Not these.
TommyTech What's a turntable tone arm?
AverageJoe Always dry.
Stuart21 It's guts alright, just not from those.
I'm enjoying myself, hope you all are too.
In reply to #85
Re: What Is It?
11/03/2014 10:05 AM
Powdered or granulated something dispenser
Floss or die!
In reply to #85
Re: What Is It?
11/03/2014 10:39 AM
I'm still thinking it's a damper for a device that opens at one speed and closes at another.....
In reply to #85
Re: What Is It?
11/03/2014 11:12 AM
spades I gave you a GA for that part of your explanation which is correct. Very perceptive of you.
No you didn't: I gave him the GA..... Only saying so that you can go back and bump him up to 2.
I assume you're talking about the "one way" or "smooth ratchet" part of the design.
In reply to #96
Re: What Is It?
11/03/2014 3:17 PM
My mistake.
I'll vote it GA now, even though it's really not a complete, nor correct answer, it still shows great perception.
I'll publish the answer, along with a couple pictures tomorrow, if I'm of a mood to.
Good Answers: 27
#86
Re: What Is It?
11/03/2014 9:12 AM
It appears to be some sort of indexing mechanism less the arm/lever.....
Good Answers: 27
#88
Re: What Is It?
11/03/2014 9:19 AM
A thumb wheel and metered dispenser
Re: What Is It?
11/03/2014 10:01 AM
This looks like a spindle mechanism for the take-up reel on a cash register or printing calculator. The pawl-and-ratchet drive the "impeller" clockwise and the "vanes" allow the tape reel to slip backward. These are relatively light-duty parts.
"When in doubt - check it out!"
Anonymous Poster (1); AverageJoe (1); az native (1); Beenaround (4); bob c (2); Brian Falconer (4); Doorman (2); English Rose (1); europium mkII (4); Graycav (1); Grochy (1); Hendrik (4); HiTekRedNek (1); IdeaSmith (3); James Stewart (2); jdretired (2); jdsighter (6); Jerrell Conway (1); JohnDG (13); LakeGrl (1); lonster (7); lyn (38); merc600sec (1); nick name (2); North of 60 (1); NotUrOrdinaryJoe (1); Noudge79 (1); oak51 (1); passingtongreen (6); PWSlack (1); r&ddoc (1); Randall (3); redfred (10); Rockyscience (1); roy hammy (2); SimpleMind (1); sohail0110 (1); SolarEagle (3); Some guy (1); spades (6); Steve of the North (1); Stuart21 (5); texasron (1); TLC Designer (2); TommyTech (2); Tornado (2); Unredundant (3); vsar (2); WJMFIRE (2); yesyen (1)
