Solutions for Industrial Computing Blog
The Solutions for Industrial Computing Blog is the place for conversation and discussion about industrial computers, systems and controllers; communications and connectivity; software and control; and power strategies. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: How Does Windows 7 Compare to Vista? (Part 1)   Next in Blog: Basic HTML: Images, Links, and Colors.
How Does Windows 7 Compare to Vista? (Part 2)
Posted September 03, 2009 1:00 AM by ETOB
To fairly compare the performance characteristics of Windows Vista and Windows 7, I installed both operating systems on my computer and ran some basic, everyday kinds of tests on them. To learn how I did this, click here. My computer is a Dell Inspiron E1505 with a 2 GHz Coretm 2 Duo processor with 2 GB RAM. It's not a very powerful computer, but this machine exceeds all of the minimum requirements for both systems.
I was not sure what the performance tests would show, but I figured that the results would be fairly close. Newer operating systems require higher performance hardware for the advanced features and graphics, so running two operating systems on the same computer should give something of a performance advantage to the older operating system. (Just imagine running Windows 95 on a modern computer.)
First Test
The first performance test compared the time it took the computer to start, go to standby, return from standby, and shut down. I did each of these actions 3 times and averaged them.
Result: Windows 7 performed 57% faster then Vista on this test.
Second Test
The second performance test was the time taken to install applications.
Result: Windows 7 was 36% faster installing these smaller applications.
I ran into a problem while installing Nero, a disc-burning application. First, I installed the software on Windows 7. It took 13 minutes. When I installed Nero on Vista, it took 19 minutes. I thought that this was too large of a difference, after all, both computers are using the same hardware. So I uninstalled Nero on Vista, and then reinstalled it. This time, the installation took 23 minutes. I was expecting it to be either the same as the first time, or closer to the time it took with Windows 7. I don't know why it took 4 minutes longer the second time, so I decided to uninstall Nero on Windows 7 and then reinstall it to see what would happen. The second install with Windows 7 took only about 30 seconds longer then the first. To me, this seems acceptable. Windows 7 performed this part of the test much faster then Vista.
Result: Windows 7 was 60% faster installing these larger applications.
Third Test
The third performance test was transferring and burning data files. I transferred 4 GB of music from an external hard drive, and then burned these files to a DVD.
Result: Windows 7 averaged 6.29% faster then Vista during this test.
This test was the closest between the two operating systems. This is probably due to the speed of USB 2.0 and the speed of the DVD burner. Both times, however, Windows 7 was slightly faster.
The total time for Vista to perform these tests was 45 minutes 9 seconds, while Windows 7 only needed 34 minutes 6 seconds (32.4% faster). Not only is this operating system higher performing then its predecessor, it is also loaded with new advanced features, features that are not seen in any other operating system, all of which I will explain next week in part 3 of this series.
Good Answers: 213
Re: How Does Windows 7 Compare to Vista? (Part 2)
09/05/2009 11:44 AM
So, back to basics. I am not at all concerned with how Windows 7 compares to Vista. The real question is, how does it compare to a GOOD operating system (i.e., Windows 98 SE, Ubuntu Linux, Unix, OS-X or whatever Apple is calling theirs now, even BSD)?
Location: Currently on break at home in Houston, Texas USA
09/08/2009 3:39 AM
Exactly, cwarner7_11! Windows 98 was still based on MS-DOS - 98 Shelled from DOS and worked rather well. Their problem arose when they completely eliminated MS-DOS from their operating system. It is as though their OS's after 98 seem to be still looking for MS-DOS and getting lost in the process. Everything beyond 98 seems to take on the feel of a stop-gap or temporary fix - not really addressing the core problems but just working around them. This may be philosophical but it is the best that I can conjure up to describe the feel of their current OS's.
09/08/2009 11:39 AM
That would be an interesting comparison. This blog was to show the differences between Vista and 7, I was not trying to say that these were the only options for operating systems. There are a lot of people who use Microsoft Windows, and that doesn't seem like its going to change anytime in the near future, so it is probable that you will have to use this sooner or later, either by your choice or your employer's.
Good Answers: 97
09/09/2009 2:22 AM
I guess the best scenario would be to compare the kernal
Hobbies - Fishing -
09/11/2009 10:27 AM
Although this video was marked way off-topic, it is very close to the bulk of the conversation in this thread and offers some levity. It is a MS/Matrix parody and very funny. Check it out for a good laugh.
Cheers.
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
Anonymous Hero (5); Anonymous Poster (41); bwire (31); cwarner7_11 (1); ETOB (3); GRAY HAIRED OLD GOAT (1); Hooker (6); Jaxy (8); lighthasmass (4); Ried (1); Tony Aston (1); tropicalspeed (3)
You might be interested in: Waveguide Pressure Windows, Windows, Infrared Windows
