Previous in Blog: Calculating Machine: Newsletter Challenge (01/04/11)   Next in Blog: Too Close for Comfort: Newsletter Challenge (03/01/11)
Satellite Mass: Newsletter Challenge (02/01/11)
Posted January 30, 2011 5:01 PM
A satellite is geocentrically orbiting 2,000 km above the surface of the Earth with an orbital speed of 6.5 km/s. What is the satellite's mass?
And the Answer is...
The speed of an object orbiting a planet (Earth in this case) at a radius r, is independent of its mass. We can prove this statement by applying Newton's Second Law . Let m be the mass of the satellite and M the mass of the earth. The we can write
ΣF=ma=(mv^2)/r^2
Since gravity is the only force acting on the satellite, the total gravitational force is
ΣF=GmM/r^2
When equating these equations, we see that the satellite mass is canceled out because it appears in both sides of the equation. Solving for the satellite speed, we get
v=√GM/r
This is independent from the mass. Therefore by knowing the speed and the orbit of a satellite, we can't determine its mass.
#108
In reply to #88
Find in discussion
Re: Satellite Mass: Newsletter Challenge (02/01/11)
02/23/2011 2:14 PM
Sorry - English is not my language. Maybe I don't understand the question. I am confused: What about the small screw (1 gram or so) the satellite just has lost? Does it accelerate or slow down? Does it change the orbit?
#109
In reply to #108
02/23/2011 9:26 PM
Compared to what?
If you are comparing it to the mass of the hypothetical satellite orbiting earth in the challenge question (that mass would be about 12% of the Earth's) then it is likely to fall back onto the satellite.
If a screw got loose from the INternational Space Station it would not appreciably change speed (beyond what velocity it might have when it left the Space Station).
I would not worry about your English. It is probably much better than my ability to speak and write your language. ;-)
02/15/2011 5:41 AM
Dear members, with assumtions we have ....
For a small satelite to stay in orbit at 2000 km it has to move at 4427 m/s. However it moves at 6500 km/s. Therefore 2073 km faster than it should. So it moves faster because it is heavy and the attraction force between two objects come into play. The resultant angular velocity * mass of the satelite must therefore = F = mass satelite * mass earth * G / (r*r) Solving for r we get 13533.34 km This r is between the centers of the 2 objects. Taking into account the earths radius of 6371 km and assuming the 2000 km distance between their surfaces then the radius of the satelite must be 5162 km .Assuming it is made up of roughly the same stuff as earth and knowing that the mass is directly proportional to the cube of the radius and having earths mass as 6x10^24 kg we have the mass of our satelite = 0.53*mass earth = 3.1382x10^24kg
#100
02/15/2011 8:34 PM
Mass is irrelevant.
A.W.
In reply to #100
02/16/2011 12:10 PM
Mass is relevant for barycentric orbit.
Mass is relevantly insignificant for geocentric orbit
D.G.
#102
02/22/2011 3:56 PM
The orbit is fixed by the speed and the level about the surface of Earth, ie depends not on the mass.
edouard_robinet@web.de
#105
02/22/2011 8:40 PM
It seems the mass is irrelevant as long as the pull of Earth's gravity at 2000 km altitude equals the centrifugal force e.g. g (@ 2000 km) equals v**2/r
Myth: Safety rules and equipment is expensive and incnvenient.
Good Answers: 69
#106
In reply to #105
02/22/2011 11:05 PM
Hi Billy,
It is relevant, as the "pull of Earth's gravity at 2000 km altitude" depends on both masses and distances from the barycenter (Gmems/(re+rs)2), while the satellite's centrifugal force around the barycenter depends only its own mass and distance (msvs2/rs).
The values given in the question do not correlate with a negligible satellite mass, but with some 7.52*1023 kg, or 12.5% of Earth's mass.
-J
#116
In reply to #106
03/04/2011 10:30 PM
Thanks for the equation and the lesson. I posted without doing the detailed math first and oversimplified the problem (8366/6366 = roughly 3/4, 3/42 is a little more than 1/2, and (6500 m/s)2/8366000 m is a little more than 1/2 of 9/8 m/s2. Later after looking at the velocity again I realized that 6.5 km/s looked a little slow for orbital velocity at that altitude. I also originally assumed that the satellite was man-made and its mass was insignificant compared to the earth. (A faulty assumption).
This reminds me of what one of my professors told me about 30 years ago: When we ASSUME we make an ..... ;)
#107
02/23/2011 3:37 AM
Satellite mass is 0 kg
#110
02/24/2011 12:57 AM
what with a virtuell coordinate system with the zero-points in the center of the satellit rotating around the center of the earth/the barycenter of the earth-satellite system?
Good Answers: 69
#111
03/02/2011 10:07 PM
The 'official' answer is as bad as the second equation given.
It should be ΣF=ma=(mv^2)/r, otherwise r also cancels out.
It is pretty clear that this question's originator did not do any sums, otherwise he/she would have noticed that no satellite can geocentrically orbit at 2000 km above Earth at 6.5 km/s orbital speed. This requires a mix of coordinates systems plus a fairly heavy satellite. See #89 above.
-J
Good Answers: 137
#112
In reply to #111
03/03/2011 5:27 AM
Agreed Jorrie
The ma=(mv^2)/r^2 is probably just a typo, but you'd think a Challenge setter would be little more careful!
As you say, the 'official' answer is poor. If "you can't determine the mass as it cancels" is all that is expected, there's no need to specify both the height and the speed. Just need to say the satellite mass is << Earth mass, and either height = 2000km or speed = 6.5km/s. Giving both figures, which don't agree for a low mass satellite, has given rise to the discussion.
Also the answer appears to be just as written when the Challenge was set, with no comments on the points raised in the thread.
Cheers.......Codey
Good Answers: 130
#113
In reply to #112
03/03/2011 6:11 AM
That's the way it works Codie.
You lodge the question AND your answer - then the Q is posted, then your answer - on the appointed date.
One obviously has to be a good question composer - and have the right answer.
Neither I would class as "easy"
Or 'try not to be too cruel' on those who give it a go, if you ain't done it.
Good Answers: 137
#114
In reply to #113
03/03/2011 7:19 AM
OK, I didn't think I was being cruel exactly, but fair point, I might take you up on that sometime.
But presumably there's no reason the setter can't follow the thread and perhaps add a few comments to the answer, if necessary.
Codey
Good Answers: 130
#115
In reply to #114
03/03/2011 7:42 AM
They sometimes do and I'm sure 'Anonymous Poster' will be a great boon.
But clearly the setter here/there was "throwing a rat into a pit of hungry pythons to see which would 'win'"
It's 'entertainment' and it's not bad at that.
I enjoyed it and I learned a great deal about who knows what.
In reply to #111
03/10/2011 8:54 AM
Agreed. It was a poor question and answer. As you and others have pointed out, the mass would have to be huge. I bet the tidal forces from it would be pretty destructive here on earth.
34point5 (8); Accountable (11); Anonymous Hero (11); Anonymous Poster (8); Billyj03 (2); carel (1); Codemaster (9); dyfedg (1); ebolton (1); JohnDG (9); johnfotl (1); Jorrie (20); PWSlack (1); Randall (3); rastas (1); rethinker (1); Snel (4); Usbport (6); Waldo120 (3); WAWAUS (2); WilhelmHKoen (14)
