Previous in Blog: Water Weight: Newsletter Challenge (November 2012)   Next in Blog: Roll of the Dice: Newsletter Challenge (January 2013)
Float Your Boat: Newsletter Challenge (December 2012)
Posted December 01, 2012 12:00 AM
Make a model boat of aluminum foil, and float it in a half-full bathtub. If you sink the boat (topple it), it will end up at the bottom of the bathtub. Will the pressure at the bottom of the bathtub decrease, increase, or remain the same?
And the answer is:
When the boat is floating it displaces a weight of water equal to its weight - this is the Archimedes' law. When the boat is at the bottom of the bathtub it displaces a volume of water equal to its own volume. The density of the metal foil (the material the boat is made of) is larger than the density of water (1.0), otherwise it would not sink.
The relationship between the weight (W) of water displaced when the boat is floating and the volume of water displaced (V) when the boat is at the bottom of the bathtub is precisely the density of the boat, or in equation form:
or
Re: Float Your Boat: Newsletter Challenge (December 2012)
12/19/2012 12:37 PM
Where are all the pessimists out there? The bathtub is not half-full, it's half empty!
In reply to #99
12/19/2012 12:52 PM
That's not pessimism. A half empty bathtub is a draining bathtub.
12/19/2012 2:40 PM
And so how many were going to St. Ives?
12/19/2012 4:24 PM
The "official" answer doesn't answer the question very well.
In reply to #103
12/19/2012 4:52 PM
That's being rather generous.
In reply to #103
12/19/2012 5:36 PM
I'm hoping that a software glitch truncated the posting. I do not see an answer at all in the posting. When I see a multiple choice question asked (increase, decrease or remain the same) I expect the answer to contain at least one of the multiple choice words.
In reply to #106
12/22/2012 9:14 AM
W>V means that more fluid is displaced for the floating boat. This raises the level of the water in the tub over the sunk case so it's pressure is greater. It is a nice compact way to do the problem.
stp
04/12/2017 1:58 AM
sewage treatment plant is a type of water treatment plant that enableswaste water to reuse by removing contamination from water. for details visit http://cleanwatersolutions.in/sewage-treatment-plant-stp/
Reply Off Topic (Score 6)
In reply to #108
Re: stp
04/14/2017 4:02 AM
I'll make a note to spam you when I have time.
a-non-a-moose (1); Anonymous Hero (5); Anonymous Poster (18); cchaf (15); cvogel (1); DocMartin (1); drbracerrick98 (1); Epke (1); Gadepalli Subrahmanyam (1); Gerry D (2); James Michael Ryan (2); kirchwey (1); kramarat (2); Kris (13); legray (5); moan8452 (1); MUKULMAHANT (1); owen (1); phph001 (1); Physicist? (7); rashavarek (3); redfred (5); robertM (1); sabriahmad (1); sean wiles (1); SimpleMind (1); snapo (1); SolarEagle (1); Sterling Marshall (1); stp12 (1); SubFrog (2); Tornado (4); Usbport (2); user-deleted-1105 (2); walt (1); WilhelmHKoen (2)
