Engineering Management Blog
The Engineering Management Blog is the place for conversation and discussion about engineering and project management, technology forecasting and planning, productivity tools, and safety and security. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Top 10 Time Killers   Next in Blog: Hiring Practices Narrow Employment Choices
9 comments
The Advantages And Disadvantages Of Open Plan Offices
Posted September 14, 2013 12:00 AM by CR4 Guest Author
Why Open Plan Offices?
In the 1950s in Germany the Quickborner team of management consultants developed the radical office layout idea of Bürolandschaft or 'office-landscape'. This consisted of free and open plans of furniture scattered in large, structurally undivided spaces with mechanically controlled environments. Unlike the American open plan, strategic use of partitions and large plants created some degree of differentiation and privacy. The use of carpets and ceiling absorbing panels tempered the noise of a large office to some degree. Whereas in the secretarial pool chatter was frowned upon, the new type of open-plan office encouraged disclosure, discussion and debate.
Demographic Differences
Research carried out by the International Workplace Studies Program at Cornell University found that people over the age of 30 prefer working in a closed space environment, Younger workers, in particular, reported a stronger preference for team-oriented offices because they provide greater access to colleagues from whom they felt they could learn. Older respondents, however, found it more difficult to concentrate in open offices, possibly because over a number of years they had become more comfortable with traditional offices, Becker says.
In my personal experience of working in the same office for the last 10 years I realise that there are many pros and cons to working in an open plan office.
Communication
PRO: Open plan offices help communication. Proximity to our colleagues makes it easier to have spontaneous micro-meetings.
CON: Millions of people who work in open-plan offices today know that there is such a thing as too much communication. This could be sitting through a colleague's deconstruction of last night's Corrie or the loud and smug colleague give her blow by blow account of her romantic weekend in Rome with her perfect boyfriend.
Increase In Focus
PRO: Working in an open plan office can help you focus on the job in hand.
CON: Working in an open plan office can drive you to despair; it's so noisy that you can't concentrate on that presentation that has to be finished in half an hour! The only way to drown out the noise is to wear earphones, which isn't allowed will be brought up in your next appraisal.
Teamwork
PRO: Increased teamwork. It is easier to work together as one team when communication and ideas are flowing.
CON: There is no privacy apart from the multiple toilets breaks you take just to have a break from your colleagues.
Learning
PRO: Being in such close proximity helps build an atmosphere where people learn from each other on an almost unconscious level.
CON: You find yourself saying words in your day to day conversations that you realise other people in the office say, and wonder when you lost your identity and your soul.
Help
PRO: If you need help you can ask.
CON: You can ask but it happens too much you might get a reputation of not being up to par in your job. Best to google the answer and learn it yourself so it is not used against you at a later date.
Air-Con
PRO: Offices are regulated by a constant temperature in open plan offices.
CONS: The office gets divided into Girls vs boys. The boys are always hot and the girls are always freezing. This creates daily arguments, bad feeling and plots to breaks the air con with a hammer.
So what is the answer? The perfect solution would be glass partitioning between the desks. That closed off space between you and your colleagues would give you privacy, focus, protection from the air con and a general result of more productive workflow. You will still be within the team, and working more efficiently.
Do you work in an open plan office? What do you feel about this sort of working environment? Please leave your comments below!
Editor's Note: Katy Lever is an aspiring writer from Manchester. She works in an open plan office and often muses the pros and cons of it. She recommends Applied Workplace.
Image by Wikimedia Commons
Good Answers: 61
Re: The Advantages And Disadvantages Of Open Plan Offices
09/14/2013 6:00 PM
When a company I worked for went "open plan" I left ASAP. Absolutely nothing to recommend it.
Good Answers: 25
09/15/2013 7:12 AM
I worked for 30 years in open office in India. These offices were common here. There are Pros & Cons as stated above. Open offices are open for loud talks for group of people, also disturbance to thinking people doing some creative jobs. Unionised staff prefer open offices so they share thoughts with others about just whining. Now days most of offices have small cubicles which saves space and other costs.
09/15/2013 8:51 AM
The last department I worked for moved our "space" to one with lower partitions...about 4ft high vs the previous 6ft high...the difference was almost an open space in terms of view when standing, and in sound...we all complained so much that the company bought us all $300 noise cancelling headphones! I still have mine and use them in my retirement! The fact that most of my group traveled extensively had a lot to do with our being able to stand the new environment for the periods we were actually in the office...otherwise we all would have left...the company solved the problem by eliminating my entire department, and eventually sending everyone home to work! In jobs where secure client information in conversations is necessary, this never works.
09/15/2013 4:51 PM
It depends on the type of work being conducted. For example, a drafting room works fine in an open plan. An open plan may not work where desks are manned by people who are on the phone constantly. Work space also depends on how much space is available and how far apart work stations are. From the start, computer stations have been partitioned off, either by management or by the workers themselves. I have worked in both environments and prefer the partitioned space.
Mr.Ron from South Ms.
09/16/2013 6:09 AM
The open plan could be more energy efficient if the thermostat was set a bit higher to suit the females, but control the humidity - lower than typical.
That way the hot blooded males could use a floor or desk fan to provide them with a nice working environment.
Floss or die!
09/16/2013 7:11 AM
Mind you, this problem is not unique to open plan -
Floss or die!
Good Answers: 7
09/16/2013 7:45 AM
Ambient noise used to be more of a nuisance before email. But telephones are still intensively used in some cultures.
09/17/2013 9:09 AM
I like the idea of "progressive" offices myself
The first law of thermodynamics is you do NOT talk about thermodynamics.
09/17/2013 10:56 AM
I need silence. I *love* having my own office space.
AstroNut (1); energyconversion (1); Mizuti (1); ronseto (1); Snel (1); Stuart21 (2); suresh sharma (1); Tom_Consulting (1)
