Previous in Blog: Here's What Space Debris Does to the Kevlar Shielding Protecting the International Space Station   Next in Blog: NASA's Flying Saucer Test
27 comments
This Machine Erases Entire Trees in Seconds
Posted June 29, 2014 3:06 PM
From Gizmodo:
Remember those giant shredders that can chomp on anything, from cars to fridges? This mechanical monster is basically a smaller version of those, attached to an excavator arm. It can disintegrate any tree in seconds. If there's ever a zombie apocalypse, I want to have one of these.
Re: This Machine Erases Entire Trees in Seconds
06/29/2014 3:15 PM
No Christmas this year I guess.....
06/30/2014 7:34 AM
STOP!..........
I said Clear the North forty, not the south forty/.
06/29/2014 10:33 PM
THAT "Cookie Monster" loves sawdust for breakfast, lunch, dinner...and...snacks!
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
06/29/2014 11:40 PM
That's hilarious...and the comments from the tree huggers are over the top!
This happens every couple seconds in every sawmill in Canada that produces over a couple hundred thousand board feet of lumber per day. It's called a "canter line". Logs go thru at about 1 log per second and come out the other end as a river of lumber. In the basement of the mill, a river of pulp chips comes down off the log where the round parts that don't make the square lumber are chipped off. It isn't uncommon to process 30,000 logs in a couple of 8 hour shifts.
Obviously, you need pretty sophisticated machinery in the bush to keep up with the hungry sawmills. Trees come down pretty fast.
The gizmo on the excavator is just a device to clear off areas that need to be denuded of plant growth, like a powerline or gas line right-of-way. Everything gets mowed down to the ground, whether its a bigger tree or willows. Usually the wood isn't large enough or the right species to make it worth harvesting the logs....for example, Poplar grows very fast but virtually no one uses it because it is structurally weak and can twist like a pretzel when it is dried.
But it's fun to set one of these loose and watch the tree huggers have major rectal hemorrhages!
Jon.
06/30/2014 12:21 AM
Wonder what they would say if they saw 10,000 acres clear cut?
06/30/2014 12:53 AM
There's a clearcut near Prince George that apparently can be seen from space. Memory is a little foggy, but it seems to me it was done because of either cleanup from a big fire or chasing bug killed wood. It likely is larger than 10K acres.
Most normal clearcuts are in the range of 5-40 acres.
Since Northern BC has seen an infestation of bugs, killing gazillions of acres of lodgepole pine, the clearcuts in these areas are pretty darn big...no use letting the wood rot.
Jon.
06/30/2014 1:04 AM
Years ago, Weyerhaeuser bought out a forest company (Dierks) in the south with holdings of 1.2 million acres.
Their property surrounds our family farm. Because of the mixed hardwood trees, they clearcut thousands of acres and planted Pine trees.
It looked like hell for years.
We still have Pine beetles in Arkansas.
06/30/2014 1:21 AM
Nobody said (some) forest companies were smart. They have been finding that mixed forests make it harder for pests to decimate. But that makes it harder to log.
Jon.
06/30/2014 7:38 AM
and what happens, they pick the species that returns the most and log that out, and sacrifice the rest.
06/30/2014 9:04 AM
Forest companies? Around here they do a selective cutting program, as designed for them by Penn State. They leave a few trees that they want to grow (read that as black cherry in NW Pa) remaining, but to deter deer from eating the new growth, they pile all the branches and tree tops in between the remaining select trees. The idea is to create an impassible area to stop deer from entering the cut area for 10 years or so. However it also stops humans from using that area for the same length of time. No hiking - no biking - no hunting - no ATV riding. The real kicker is when the few spindly trees they leave, that have grown up protected by others trees around them, are subjected to a good gusty thunder storm. Down half of them come.
And in ten years what are we seeing? A thicket of small saplings so thick you still can't walk through the area. I hear PSU is re-thinking this process - it may not have the effect they predicted it would.
06/30/2014 7:37 AM
one thing about replanting with softwood instead of hardwood, is that can invite paper mills to relocate there,
06/30/2014 9:42 AM
"for example, Poplar grows very fast but virtually no one uses it because it is structurally weak and can twist like a pretzel when it is dried."
Then why do I see Poplar boards in the local Menards? Pre-sanded four sides and ready for woodworking.
Structurally weak? That entertainment center I build out of Poplar is holding up quite nicely, doesn't seem like a weak wood for cabinetry projects.
Build a house out of it? I'm not a Structural Engineer or Architect, so I wouldn't try building a house on my own in the first place. It'd trust the contractor to select the right materials for the job.
06/30/2014 10:25 AM
There are multiple species of poplar.
Our south side of the barn was sided with poplar that was at least 80+ years old and with the exception of the weathering was very sound. We resided with hemlock and sold the weathered planks, ...... the other sides that didn't get the sun pine or hemlock was used.
My brother built his house using poplar as most of the framework 30+ years ago. All of which was logged and milled from our property.
But like I said before...... it may depend on the type of poplar.
06/30/2014 10:35 AM
First time this city boy learned that there was more than one type of Poplar.
I don't really study trees or lumber that much, so much of what I know is from the woodworking shows on PBS Saturday 'noonish block,' (11AM-2PM). I did learn why we have Hickory in the US when there is none in Europe, thanks to The Woodwright's Shop. Roy Underhill had this entertaining story about how we 'laid our mountains out the right way' for Hickory to survive the Ice Age. In North America the Hickory could freely 'run' south to avoid the glaciers, while in Europe, they got 'crushed' bwtween the glaciers to the north and the frost line of the mountains to the south, since in Europe the mountain ranges run east-west, while North American mountain ranges run north-south.
06/30/2014 10:55 AM
Roy Underwood, I loved that show..... probably because it was like it was live and they didn't edited anything out of the tape ...... and I like to share two things.
One time he'd cut himself and was bleeding pretty bad..... they had a commercial break, and when they returned, his hand was bleeding pretty bad and was all gauzed up, his hand it looked like a club...... and the blood was seeping through.
Another time he was showing the different type of wooded screws...... he had a very large one that was a large cider press. about 14-16" diameter by maybe 8 feet high.... he described it, and gave it a good slap and walked to the camera.... only thing was, that slap got the screw moving back and forth, I that it was going to fall down,.... but fortunately for him.... it stayed standing.
That interesting about the tidbit about hickey, thanks.
06/30/2014 11:19 AM
UnderWOOD, not Underhill, thanks for the correction.
He also ended the hickory episode with an anecdote about 'hickory water,' (the leavings after you boil hickory canes to make them flexible to bend into arcs for rakes and such) and how an old country doctor friend of his used it for a very refreshing cocktail, just to lead up to the closing pun of the ep, "Thanks for the Hickory Daiquiri, Doc."
06/30/2014 11:24 AM
Underwood, I didn't even noticed........
My brother made a horse drawn cutter (25+ years ago) using hickey for the rails......
We boiled them, formed them in a jig and then laminated them in jig.
Another thing about hickory, when we ran into a stand of hickey, what didn't make logs, we made into fire wood. We didn't use the wood splitter on this, because it was actually a lot faster and easier to split by hand with an axe.
06/30/2014 1:51 PM
I think Underwood even showed that in the hickory ep, as well as litterally driving a square peg (the rough-split hickory) through a round hole (the shaping die to make the 'teeth' of the rake. He had a joke or two about that as well. he really seemed to be enjoying himself in that ep, all those anectotes, all those jokes of varying quality (most so bad they could only be done on television, a live audience would have drowned him out with the groans), He was in rare form as a raceunteer- racooner- racketeer- That fancy word for 'storyteller,' the one that implies an ability to make even the most mundane tale seem wonderous and enchanting.
06/30/2014 1:54 PM
Just checked Wikipedia, and I was right the first time, it is Roy Underhill.
06/30/2014 2:17 PM
Roy Underhill is his name. (There is/was some confusion about his name.)
The Woodwright's Shop is his show.
06/30/2014 1:44 PM
Loved his show - and I remember him telling that story about hickory. You can still watch the Woodwright's Shop online via North Carolina PBS.
07/01/2014 3:27 PM
It's still on WYCC Ch20 in Chicago too.
And it looks like he's still producing new seasons. Roy is sure going strong like Old Hickory.
Good Answers: 32
07/01/2014 4:01 PM
Poplar is very popular with Pattern Makers for making bulky patterns with limited use for foundries. Price is main concern vs. using mahogany or other hard woods and ease of cutting, sanding and piecing together courses or layers of wood. When sectioned and glued in layers there isn't much warping. Also the patterns are lighter and easier for the molder to handle. Sometimes they'll use poplar to build up thick sections and layer mahogany up on the outside of the pattern.
Spinco
07/01/2014 6:31 PM
It's also pretty popular to use poplar for fish boxes.
06/30/2014 2:44 PM
As a hardwood, it's not as strong as say, oak, maple or hickory, but it is cheap.
Mr.Ron from South Ms.
06/30/2014 4:18 PM
I would compare poplar to a weed.... It grew very fast. When we made lumber out of it we would saw it green, because it did not keep well, and the would be so much water/sap in the wood, it would seem like it was raining when you sawed through it. But the logs were clean. We would get 20 feet easily on the log and 30" on the stump.... Anything larger, you'd have shake.
06/30/2014 2:35 PM
Red Green would have loved that.
70AARCuda (1); adreasler (6); lyn (3); phoenix911 (8); Phys (1); ronseto (1); sawmilleng (3); SolarEagle (1); Spinco (1); Usbport (2)
