Defense & Security Technology Blog
The Defense & Security Technology Blog is the place for conversation and discussion about materials; communications & surveillance; electrical/electronic components; and design & assembly. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Will the U.S. Navy Build the World's Only Supercavitating Ship?   Next in Blog: F-35 Goes "Top Gun"
11 comments
Velocitas Eradico (I, Who Am Speed, Eradicate)
Posted February 11, 2015 10:08 AM by HUSH
Pathfinder Tags: defense navy railgun weapon
Guns are so early 20th century. Depending on country and culture, they may even be so 19th century. Yes, they remain the primary means of personal self-defense for both military and civilian purposes. But for military needs, the large calibers mounted on wagons, trucks, trains and ships for about 100 years have been replaced by advanced weapons that can strike with pinpoint accuracy from remote distances.
Guided missiles and precision bombing ultimately eliminated battleships from the Naval Vessel Register. Even the world's largest gun ever built, the Schwerer Gustav (80 cm caliber; pictured left), was obsolete by the time it reached the battlefield, and is more of a footnote than anything else. In fact large caliber artillery experienced a relatively short duration of supremacy on the battlefield, from--at most-- the beginning of industrialization until the Atomic Age.
But new developments in a technology that's been touted for 20 years may put guns back on the front lines. There have been numerous media stories in recent years about the potential for railguns, and most concluded with a variation of "this technology needs further development before battlefield realization." They've done a good job capturing imagination due to the extreme destruction capable from one shot, which obliterates targets with nary an explosive.
Now the U.S. Navy is experimentally mounting a railgun onto a catamaran, known as a joint high-speed vessel (JHSV), to ascertain seaworthiness in hopes of integrating the weapon into a next-generation destroyer in 2018.
Despite only recently entering mainstream awareness the earliest incarnation of a railgun dates to a 1922 U.S. patent filed by Frenchman Louis Octave Fauchon-Villeplee, who created a gun that fired bullets with stabilizing fins. The concept of the railgun is the same today as it was then. Two long, parallel rails connected to a power supply, each representing an opposite pole. When a conductive projectile is placed between the rails the circuit is completed. Also created is a magnetic field that is directed at right angles away from the rails and armature, which ultimately is what provides kinetic force to the projectile. Higher energy along the rails creates an equivalent increase in projectile speed, and experimental projectile speeds of 20 km per second have been achieved.
However, materials science has lagged behind, as creating rails that resist the excessive thermal loads has proved troublesome. Current rates of fire are limited to about 2 or 3 per minute because of this challenge, even on the type the Navy plans to implement. Railguns also require immense electrical energy, in this instance 34 megajoules. Next-gen warships are the only platforms able to supply this type of power. However, such warships will also require a railgun that can communicate with planned weapons systems, as well as one that can be scaled to fit in available deck space. These are the obstacles that will hopefully be solved with the at-sea tests on the JHSV.
Why invest in such a troublesome technology? Sustainability and safety. One shot from a railgun will cost significantly less than a missile. It's also exponentially more powerful, in some cases obliterating armored vehicles before continuing to travel for miles. Since the projectiles aren't explosive themselves, they also don't present a risk to personnel or the ship.
Of course there are other applications for railguns, such as designs to launch space craft via a railgun system. Humans cannot survive the inertia that would be applied to a spacecraft projectile, but cargo could be supplied to space stations at a much lower cost. There is also the potential for using railguns to initiate inertial confinement nuclear fusion, where the guns will replace lasers to fire energetic plasma at a fuel. Such guns will need to be scaled down to a great degree.
While the Navy needs a new weapon, the world may gain new accessibility to space and maybe even a groundbreaking power source. For now, railguns should still be filed under "needs development."
Re: Velocitas Eradico (I, Who Am Speed, Eradicate)
02/11/2015 10:57 AM
"Humans cannot survive the inertia that would be applied to a spacecraft "
Errr, note to self... don't risk procrastinating.. it may be fatal.
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Hobbies - Target Shooting - New Member Safety - ESD - New Member Technical Fields - Education - New Member
02/12/2015 8:27 AM
Railguns built into minshafts dug into the tops or sides of mountains near the equator.
What is 2 km/s of delta V at 1.5 km above sea level worth?
-A-
question everything
02/12/2015 10:36 AM
What I'm suggesting is launching payload to a rendezvous orbit.
Get something into a high enough ballistic path and then use mono propellant to establish a highly elliptical orbit.
This way there is no need to try for escape velocities from inside the atmosphere.
Let's get crazy sci-fi here and suggest burning a laser hole in the atmosphere just prior to launch (milliseconds) so as to further reduce in-atmospheric drag.
I suggest the first vehicle carry a few tons of pellets for a 3D printer. That way, a more traditional rocket (carrying only fuel) could catch up and circularize its orbit or use the oberth effect to go trans-planetary.
Afterword, our next space station could be assembled on the way to wherever we want it to go.
-A-
question everything
02/12/2015 9:35 AM
"One shot from a railgun will cost significantly less than a missile. It's also exponentially more powerful, in some cases obliterating armored vehicles before continuing to travel for miles. Since the projectiles aren't explosive themselves, they also don't present a risk to personnel or the ship."
No one should ever fire anything if they know their projectile will travel 'miles' beyond their intended target. And then the article says that because they are not explosive they do not present a danger to personnel or the ship. What a bunch of BS, what personnel or what ship?
I think this is a coward's weapon that should be abandoned.
02/12/2015 11:37 AM
"I think this is a coward's weapon that should be abandoned."
Every weapon is a coward's weapon, intended to give an advantage. It all started with a club in the hand of Neanderthal.
This discussion point could go sideways in a hurry.
02/12/2015 12:20 PM
Good Point Doorman: but the first club may have been a weapon to make up for a disadvantage. Like Mrs. Neanderthal beating on Mr. Neanderthal while he sleeps.
I say this is a cowards weapon because the shooter has no idea what he is going to hit after he hits the target and apparently if he uses the weapon he does not care. I don't know what else to call a person like that.
02/12/2015 1:03 PM
"...because the shooter has no idea what he is going to hit after he hits the target and apparently if he uses the weapon he does not care."
Full metal jacket bullet
1,900 pound general purpose bomb
Sarin gas device, left on a subway car, detonated by timer
There are different degrees of coward in this respect.
02/12/2015 1:24 PM
Agreed.
02/16/2015 2:17 AM
There is a lot of incorrect terminology in this "article"; typical right-column fluff.
02/16/2015 11:56 AM
Presumably the inertia made you late getting here... or maybe the dog ate your homework
United States - Member - U.S.A. Hobbies - Fishing - New Member
04/16/2015 11:47 AM
Can I get one to put in my sidecar?
There are always others less fortunate than you, be happy, to them you are Mr. Jones.
-A- (2); Doorman (2); Massey (3); possum (1); Tornado (1); user-deleted-1105 (2)
