Workbench Creations Blog
Workbench Creations
Previous in Blog: Repaired Garage Foundation   Next in Blog: How to Motorize a Projector Screen
14 comments
DIY Maple Syrup Making
Posted March 22, 2015 12:00 AM by joeymac
Pathfinder Tags: maple syrup
If you love maple syrup and have certain types of maple trees on your property, you can collect sap and make your own!
It's that time of year when winter is fading and the maple sap is flowing. Now is the time to tap your trees. You need the temperatures to be above freezing during the day and have it freezing during the nights. I've found temperatures in the upper 30's and low 40's during the day and 20's at night work best for the sap to flow. Before you even start anything you must have your supplies ordered first. You don't need much, just a food grade bucket, tubing, a tap, and a drill. I use five gallon buckets with holes drilled into the lids for the tubing and to keep bugs, debris, and water out. First find some maple trees, preferably sugar maples. The minimum diameter of a tree to use is 12 inches for one tap and you can add two taps to a tree that is 21 inches in diameter or larger. I don't recommend putting any more than two taps in a tree.
When you've found your tree use a drill with a 5/16 bit and drill into the tree about two inches deep at an upward angle so the sap flows downward from the hole. I tape a piece of tape at the two inch mark on my drill bit to make sure I didn't go too far into the tree. Next you insert your tap or spile (I used a tap) and gently tap the tap into the tree with a hammer. I then attached the tubing to the tap and put the other end of the tubing into the holes of the lid that I pre-drilled with the bucket firmly attached. Now it's just about waiting for the sap to come out and fill up the bucket.
You should collect your sap every day from your bucket. I put the sap in one-gallon water jugs that I had lying around the house. The sap needs to be out of sunlight and kept cool or it will spoil. If you don't boil the sap after a week it'll spoil and go bad. It takes forty gallons of sap to make one gallon of syrup so I'd recommend tapping more than just one tree.
When boiling the sap, it's best to do it outside since a lot of steam will be generated boiling all that water off, unless of course you want to remove the wallpaper in your house. When boiling the sap use a large pot. When the sap is boiling, foam will develop on the top, so just skim it off and discard. When the sap starts taking on a golden color, it's time to transfer to a smaller pot. Once transferred to a smaller pot, the final boiling can be finished indoors on your stove. Keep boiling the sap until it takes on the consistency of syrup. Use a thermometer to check the sap, when the sap temperature is 7 degrees F above the boiling point of water then you've finished and now have maple syrup.
You're almost done, but there is probably a small amount of sediment in your syrup. I filtered it out by using cheese cloth. Pour the syrup in a sterilized bottle and cap and refrigerate. Depending on how sterilized everything was, your syrup should last for months.
Good Answers: 19
Re: DIY Maple Syrup Making
03/22/2015 10:44 PM
I have a single maple in a suburban environment. Last year I got a bag collector from a local forest park district and tried it for my entertainment. I got about 2.5 gallons of sap that I boiled down to about 1 cup of syrup. Tasted great!
This year due to such a rapid spring warm up, I was less successful. We did not have the normal freeze thaw sycles and only got 2 tablespoons of sap!
Maybe next year!
Good Answers: 102
03/23/2015 2:00 AM
We do rubber trees here and the "tap" scars over and needs to be reopened.....maybe your maple tree tap needs snaking out or relocating.
Don't drink rubber tree sap. Not good.
The folk that live up in the bush here have some other trees that they collect saps and resins from....having a big brawl with the rubber tree mob at the moment.
I love maple syrup. Only available in bottles here imported from Canada.....costs more than booze.
Just remembered one common tree here that yields a real tasty sap and its called a Palm Fruit tree, the juice is called palm juice and is tapped and collected in large quantities daily. Drink it straight, as fermented wine or put through a still as vodka. The fruit is excellent too.
Can you make a good libation with maple sap/syrup?
03/23/2015 1:25 PM
I believe you would get a rum but it would be sacrilegious subject a 'real' syrup to that kind of treatment when a good rum is so easily purchased.
Good Answers: 19
03/23/2015 10:23 PM
Maple sap is basically diluted sugar water, and does not normally clog the holes drilled in the tree.
03/23/2015 4:47 AM
Tapping sap is on my to do list
Good Answers: 19
03/23/2015 10:31 PM
I bought the small kit on a whim at a local museum store for around $10 US. A 5/16" tap, galvanized frame to hold a blue plastic collection bag, and about a 1 gallon bag. Last year got about 2.5 gallons of sap that boiled down to a cup and a half of syrup. Used a frying pan on the kitchen stove to boil it down, since I figured the frying pan had a large surface area to allow maximum evaporation.
Maybe some would say the syrup is a bit pricy, but it sure tasted good and it kept me and the kids mildly entertained. Go for it, Del!
Good Answers: 15
03/23/2015 5:42 AM
Have any of you ever heard of tapping Walnut trees for their sap to make syrup.
A friend of mine who is an organic farmer told me about it. Hes the first person I've ever heard of doing this.
scotchdrnkr
03/23/2015 6:00 PM
The Scarecrow Country Inn, Cookeville, TN, when they were still open, used to make a syrup from the boiled inner bark of black walnut trees. Sorry that's all I remember about the process.
03/23/2015 6:07 AM
We used to tap about 50 trees every spring. It is not so much fun for a kid when you do on a large scale like that.
We didn't do it for the fun of it, we did it so we did not have to spend money on store bought syrup.
Good Answers: 19
03/23/2015 10:24 PM
But you had a much superior product than the "store-bought" colored corn syrup!
Good Answers: 102
03/24/2015 12:04 AM
Tap or go without sport.
Your wise father was teaching you that work precedes reward.
03/24/2015 5:29 AM
Yeah, but I don't even like pancakes or syrup and it was fun the first year or so, then it just became a lot of work. I see some current systems up here where the sap is gathered by tubes hooked up directly from the tap to a central large collection vat. That seems much more practical then individual gallon milk jugs that had to be retrieved and emptied every single day without fail.
Good Answers: 102
03/24/2015 6:54 AM
Sounds like you grew up on a rubber plantation.
No automation at all, although plastic collection cups are now replacing the half coconuts they normally use.
04/14/2023 4:13 PM
My brother-in-law’s family make maple syrup. It’s quite an operation they have. They just won a award, I understand it’s pretty prestigious for maple syrup producers…
they just finished up about 2 weeks ago.
the sap shed smells wonderful, and maple syrup is great for a topping on ice cream.
Brave Sir Robin (1); davlamb (1); Massey (2); phoenix911 (1); Ried (4); scotchdrnkr (1); user-deleted-1105 (1); Wal (3)
