Workbench Creations Blog
Workbench Creations
Previous in Blog: Fixing a Capacitively-started Motor   Next in Blog: Building a Yew Warbow
5 comments
Building a Lighted Ball
Posted December 31, 2015 7:00 AM by frankd20
You may recall that last year I set up lots of lights on my house synchronized to music. I did the same this year and even expanded the lights quite a bit. One of the new lighting features I added was a ball of my own design. I didn't make a ball thinking about the New Year's Eve one in Times Square, it was more that I wanted something that was different than what others do. The dimensions of the ball are based on the length of the strings of lights I used to make them fit correctly. It turns out that my ball is roughly 6 feet in diameter, a coincidence as that is the same size as the Times Square ball was until 2009, when it doubled in size to a diameter of 12 feet.
My ball is made of 24 PVC pipes (sorry, no Waterford crystals) and a metal frame. The PVC pipes are secured at both ends and bent around to form the arc of the ball, although it isn't perfect. The hubs at the top and bottom of the ball were the hardest part of the build. To make them I used the round part from old brake drums. I welded on steel spokes and a rim to form 24 pockets that notched PVC pipe would slot into. In the center of the hubs I welded metal pipe that would slide over the central metal mast and allow for adjustment.
Once assembled, I painted all the PVC pipes black and fitted them with strings of RGB LED bulbs, which totaled 1,800 bulbs. Each of the 12 strings has 150 bulbs and is double backed at the top so each string forms two columns of the ball.
The bulbs themselves are of the WS2812B variety and use a single SanDevices E6804 to control them. I used two old computer power supplies to provide the 5V necessary to run the lights. Each bulb can be addressed individually and are coordinated to create patterns, have text pictures, or even video displayed on the ball. A Raspberry Pi connects to the SanDevice via Ethernet and runs the ball as well as the other roughly 6,000 bulbs on my house this year.
Here are some videos of my lights this year; the ball can be seen on the right side although it looks very small from the camera view.
Ball Close Up
All I Want for Xmas
Dominick the Donkey
Festivus Song
You're a Mean One Mr. Grinch
Wizards in Winter
Re: Building a Lighted Ball
12/31/2015 10:51 AM
How's your wifi working?
Good Answers: 52
12/31/2015 11:40 AM
My wifi works just fine?
These lights don't cause much in the way of interference since they are powered by decent DC supplies.
If you mean that because the lights communicate by Ethernet, I created a separate network for the lights with its own router/switch. The raspberry pi that controls everything is linked to both networks but only sends the lighting control data over one.
12/31/2015 2:40 PM
No, there was a thread recently claiming that Christmas lights were interfering with WiFi. I was a bit skeptical.
http://cr4.globalspec.com/blogentry/26799/Holiday-Lights-are-an-Unlikely-Source-of-Wi-Fi-Interference
Good Answers: 52
12/31/2015 3:25 PM
That explains the question, I had not seen that blog. Being into ham radio I can tell you that xmas lights do add a lot of rf interference. In my experience the noise used to be from incandescent lights with a bimetallic blinker and today comes from cheap power supplies used in some higher function led lights. All of my lights are connected to higher quality power supplies and are less prone to those issues.
01/01/2016 5:58 AM
Well done, really good effects and I have never seen anything like it!!
A "one off".
Happy New Year.
Andy Germany (1); frankd20 (2); Rixter (2)
