Defense & Security Technology Blog
The Defense & Security Technology Blog is the place for conversation and discussion about materials; communications & surveillance; electrical/electronic components; and design & assembly. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Flamethrowers Find Industrial Uses   Next in Blog: Drones Could Blacken Battlefield Skies
9 comments
Fighter Jets Get Laser Weapons (in 2023)
Posted May 11, 2016 9:38 AM by HUSH
Pathfinder Tags: aerospace air force Laser weapon
The first laser ray gun was fictionalized in the 1898 novel War of the Worlds and as a result, energy weapons have been staples of science fiction armories ever since. There are endless permutations of sci-fi energy weapons, be it a phaser, ray gun, light saber, plasma gun, pulse rifle, or even sharks with frikkin' laser beams attached to their heads, but the concept is generally the same--weapons that discharge high energy projectiles or beams instead of bullets, and generally make a pew, zap, or similar onomatopoeic sound.
There have been no less than a dozen attempts at creating and implementing a laser weapon for use against enemies on the battlefield, but outside of one rigged up on a Navy ship, lasers are mostly used to disorient enemies and designate airstrike targets. Even though we've heard promises of laser weapons before, the U.S. military recently announced plans to have fully functional, lethal laser weapons systems mounted on aircraft by 2023.
The benefits of laser technology over conventional weapons systems are clear. There is no physical ammunition to reload, which is easier and more cost effective. Lasers travel much faster than bullets or missiles and can be precision aimed. Energy weapons can also be powered up or down to vary the lethality of shots, and targets can be neutralized without creating an explosion.
In recent years, the U.S. Army and Air Force have been studying the technology of Boeing's High Energy Laser Mobile Demonstrator (HEL MD). The HEL MD is a 10 kW solid state laser mounted on an Oshkosh that produces a beam about the width of a dime and can hit targets from miles away. In tests last year, the HEL MD proved capable of eliminating 150 mortar rounds and UAVs in foggy and rainy weather. The U.S. Army believes it can use this system as part of an active defense against incoming aerial threats, while the Air Force intends to mount the HEL MD on a fighter to provide anti-missile defense. Lasers are sometimes used to confuse the navigation of anti-aircraft laser-guided missiles, but the HEL MD would actually destroy the missile before it got too close.
The first in-air tests are expected to start in 2021, and will most likely be outfitted on an adaptable fighter such as the F-15. Implementing the HEL MD on the F-22 Raptor or F-35 Lighting II, America's next generation fighters, isn't possible because it would sacrifice some of their respective stealth capabilities.
Eventually the Air Force wants to install a more powerful HEL MD system on an AC-130 gunship plane for offensive missions. The final goal is to have a scaled 300 kW system for engaging offensive targets from very long distances from a fighter platform, and then eventually on a drone platform.
Of course, the single biggest challenge for the growing role of the HEL MD is the power generation, especially if the system is going to be used on combat aircraft, where every component must meet aerospace standards and be essential. Air Force Chief Scientist Greg Zacharias said that much of the development work on the HEL MD over the next few years would be reducing the complexity of the system to make it airworthy, which ultimately means compromises between the size, weight and power of the weapon system.
Unfortunately, this does not make bombs or missiles obsolete, at least any time soon. Lasers still require line-of-sight aiming, something a guided missile does not. The power required to destroy a tank with a laser is sublime--it's just not possible now or soon.
This makes lasers another tool in the military tool chest, and less the coming of age of directed energy weapons. Still, we get ever closer to the light sabers, phasers, and sharks with lasers.
Re: Fighter Jets Get Laser Weapons (in 2023)
05/11/2016 1:52 PM
'...mortar rounds...', unless you mean something like pistons.
05/11/2016 7:47 PM
The title says Fighter Jets Get Laser Weapons but this picture doesn't look much like a jet.
05/12/2016 7:14 AM
Your Right. Looks to me like a C-130 cargo plane. No wonder we are having problems beating the enemy. We are probably sending Cessna's in to drop troops.
Good Answers: 11
05/12/2016 11:32 AM
Could be that the beam is not coming FROM this plane, but that it is being fired AT this plane. The fighter firing the beam is out of the picture! Makes sense if they want a large slow-moving target.
People Living in Competition, All I want is to have my peace of mind - Boston
05/12/2016 4:05 PM
Yeah, that makes more sense. Thanks!
05/12/2016 5:10 PM
It is a C-130, and they're showing it because it had a laser mounted in it (already). In this test, the laser was a 100 kilowatt-class chemical oxygen iodine laser (COIL).
I think the idea is to shrink the technology so that it can be installed into a fighter jet. I'd be concerned that adding a laser means losing rockets or guns, but that's up to the smart guys at NAWCWD to figure out which is the best use on the aircraft for its mission.
05/12/2016 7:21 PM
It's good to see the Airborne Laser (ABL) concept is not completely dead! http://foxtrotalpha.jalopnik.com/the-airborne-laser-may-rise-again-but-it-will-look-very-1724892313
05/12/2016 7:32 PM
This is definitely a great idea. You would think that after starwars movies came out that they could have developed it before now. Technology wise we have had this technology for quite some time. I hope that we are the only ones that have it and don't share it with so many countries before we per fect it better. So many times we share the technology before we do OR our military secrets get hacked and lose the leading edge.
I spent 8 yrs in the navy and worked in intelligence and could not believe how lackidazical our classified material was shared AND compromised.
05/15/2016 3:10 PM
Just like command and conquer games
formerly Legolaz
AverageJoe (1); Peterpipper (1); Rixter (3); Sailor Rick (2); truth is not a compromise (1); Usbport (1)
