Previous in Blog: Permanent Magnet: Newsletter Challenge (May 2016)   Next in Blog: Rope Race: Newsletter Challenge (July 2016)
Invisible Neutrino: Newsletter Challenge (June 2016)
Posted June 01, 2016 12:00 AM
A neutrino with an energy of 14 MeV is released from a fusion reaction in the core of the sun and travels on a path directly through Earth. An ideal neutrino detector capable of detecting every neutrino of that energy passing through Earth fails to detect it. Why?
And the answer is:
The neutrino has changed to a different flavor invisible to that detector. The neutrinos released in fusion reactions in the solar core must travel through the extremely dense material of the sun before exiting its atmosphere and travelling across the vacuum of space to Earth. On their journey from the center of the sun to space, neutrinos undergo oscillations and some change from their original electron flavors to muon and tau flavors.
This oscillation effect is the cause of the apparent discrepancy between the amount of neutrinos expected to be emitted from the sun according to the standard solar model and the number of neutrinos actually detected. Early detectors were only picking up between one third and one half of the expected number of neutrinos because they were looking only for electron neutrinos, and couldn’t detect the muon and tau flavors. The Sudbury Neutrino Observatory provided definitive evidence that neutrinos undergo oscillation to different flavors as they travel through the sun.
Find in discussion
Re: Invisible Neutrino: Newsletter Challenge (June 2016)
06/08/2016 1:17 PM
Good point. Publish or perish, as they say.
On the other hand, the dynamics of a star going nova may not generate the neutrinos at the same time as the shock wave. Does anyone know the timing of the shock wave vs. when the neutrinos are generated? When does the shock wave actually hit the core of the sun and when does Earth actually get destroyed?
canary
United States - US - Statue of Liberty - Who is John Galt?
06/08/2016 2:21 PM
The accepted theory is that the flood-flux of Neutrinos is the agent that rips the star apart. That implies that as the current of Neutrinos is streaming through the shell of the star, the *tiny* rate of collisions between the neutrinos and the normal matter tends to sweep the mass out and away, like a garden hose rinsing hard clay off the sidewalk. It takes a lot of flow to make the dirt move a little at a time. But with the core implosion releasing energy on the order of 10^51 ergs, even if only one in a billion-billion Neutrinos strikes a nucleon, there is power to spare!
I'd've written a shorter post, but I didn't have the time.
In reply to #64
06/08/2016 6:27 PM
Does the flood of neutrinos also affect the earth?
canary
In reply to #66
06/08/2016 6:43 PM
I believe that astronomers hope to be able to use timed detection of neutrinos at multiple sites to in order to direct telescopes in the correct direction to see the optical display from its beginning. They would hope to detect maybe three or four neutrinos at ecah site (on average). Does that reassure?
On the other hand, under the near-vanishing probability that our nearest star were to become a supernova, the unimaginable number of neutrinos would be enough to blow us to bits even before the optical radiation had the opportunity to fry us.
In reply to #67
06/08/2016 8:13 PM
For the "nearest star," are you talking about Alpha Centuri or Sol? I wasn't worried, but reassurance is not the right word. Detecting it so we can see the nova happening would be pretty cool, but if it is nearby there is no way to block it. We could all go a mile underground, or even to the Earth's core, and the neutrinos will still make us explode, right? That will be the hot flash to end all hot flashes (literally).
canary
In reply to #69
06/08/2016 9:37 PM
Oops, I edited out part that relates to the hot flashes. It seems like we can't see the neutrinos, so we would all just start getting hot for no apparent reason, until we and everything around us just exploded. A hot flash to end all hot flashes. Literally.
canary
In reply to #70
06/09/2016 8:56 AM
I meant Sol. And I doubt think you would have long to notice the hot flush.
In reply to #72
06/09/2016 2:35 PM
Thanks. What would happen if it was Alpha Centauri? Would we feel the bern?
In the movie 2012, one of the movie's premises is that suddenly the sun started producing a lot of neutrinos, heating up the interior of the Earth and making it expand, so that cracks appeared all over the world. Can you speculate about how close a nova would have to be to cause significant heating of the interior of the Earth?
canary
In reply to #81
06/09/2016 3:53 PM
IMHO and AFAIK. to cause significant heating by interaction with neutrinos, the nova would have to be in Texas.
In reply to #82
06/09/2016 4:59 PM
I used to have a Nova, and Chevrolet named it aptly. No va - means no go in Spanish.
#87
In reply to #83
06/09/2016 5:37 PM
Or New in Latin. Maybe it did go before it left the showroom
In reply to #87
06/10/2016 1:13 PM
True. It was only when it got old and worn out, that it would die upon making a sharp right turn into a lane of traffic at an intersection. I could always get it started and moving immediately, but this always made my wife at the time go into panic mode.
#86
In reply to #82
06/09/2016 5:32 PM
Assuming that you mean supernova, the nonlinear region has to be at least the size of the pre-explosion core, so that doesn't quite work. Just before collapse, the core of a supernova is about the size of the earth, and it's supposedly the neutrinos emitted from the centre of the collapsing core that heat up the mass well clear of the core. I'm not sufficiently expert to give dimensions, but even without the non-linear effect the neutrino frying range of a modest supernova would have to be larger than the radius of the earth.
In reply to #67
06/09/2016 1:17 PM
"...astronomers hope to be able to use timed detection of neutrinos .. in order to direct telescopes in the correct direction..." - Wouldn't that be a bit too late (unless nertrinos are in fact tachyons)?
#84
In reply to #79
06/09/2016 5:06 PM
The photons cannot escape the core of the supernova until the star has been blown apart by the neutrinos. About 1% of the neutrino energy is delivered to the stellar material*, mostly near the core of the star (possibly due to two-neutrino interactions as well as the higher material concentration). This is sufficient to accelerate some of the material to about 1/10th of the speed of light. Additional light will only be released when the consequent shock wave reaches the photosphere; the lower velocity of the shock wave provides the delay between neutrino observation and ight observation.
*This is a significantly higher proportion than would be released from individual neutrinos with energies of up to 30MeV. There are various hypotheses, but the mechanism is not understood.
In reply to #66
06/09/2016 11:16 AM
Only if the dam is out, and it is high tide in neutrino world. In bizarre old world, not so much.
This neutrino cascade is probably the result of stellar fusion using up all the hydrogen it can get, then trying to heat up more and switch over to other fuels, then the pressure inside the star goes postal.
There is a 99.99% chance our sun will not kill planet Earth that way, but some other star could. Our sun will burn out of hydrogen before all the alternate reaction pathways kick in that make too much of the heavies. At some point the ablation of outer gases overcomes the gravitational bottle, and Sol will expand as a red giant.
In reply to #74
06/09/2016 11:51 AM
When our star expands to a red giant, the orbit of the Earth will be inside this red giant. Sol will be a lot cooler than it is now but the Earth will not be very habitable at all inside this red star.
In reply to #77
06/09/2016 12:04 PM
Not habitable? Not exist, more likely.
As Sol expands the Earth will interact with Sol's atmosphere; so it will slow down and then fall into the much hotter interior, liquify and then evaporate...
In reply to #78
06/09/2016 1:46 PM
Before that, the moon will orbit further and further out due to tidal lock lead, then the solar wind continues to increase, and the resulting drag on the moon will decrease the orbit once again, right up to the point of collision with Gaia (Earth), and then we will no longer exist (or will be somewhere else).
#85
In reply to #80
06/09/2016 5:20 PM
Agreed. And I believe that the earth will be uninhabitably hot even before that happens.
However, even without such catatrophe, it would seem that the probability of the species homo ignorans being around for another five billion years is vanishingy small.
#89
In reply to #77
06/11/2016 11:25 AM
diameter of earth-orbit to the sun is more than 100 times the diameter of the sun, the volume of the red giant is more than a million time the volume of the sun and the density of the red giant is a millionst of the dense of the sun.
is this denser than earths atmosphere?
In reply to #89
06/11/2016 1:04 PM
I'm not sure if Sol's density, when it envelops the Earth, will be denser than today's atmosphere. However since the surface temperature of a red giant is typically 5000 K I'm sure it will be denser than the Earth's atmosphere at the time it envelops the Earth.
#136
In reply to #90
06/18/2016 10:00 PM
this is the mean-value, density in the center should be much greater than in peripheral.
#91
In reply to #89
06/11/2016 3:05 PM
That depends on when you mean; the Earth's atmosphere will get much denser and then deplete to a situation similar (but more extreme than) that of Mercury today.
Boring detail:
The mean s.g. of the sun is currently about 1.4. The density of the Earth's atmosphere at stp is about 0.0012. The density of the outer edge of the sun will be much lower than the average, so by the time it is expanding towards the Earth it will be several thousand times less dense than the Earth's atmosphere is at the present time. However, the expanding sun will have a surface temperature of about 4000K, and being very large will give an temperature for the earth that would be over 3300K even without any greenhouse effect. Not only will the oceans evaporate, but the water will dissociate and the thermal velocity of the resulting hydrogen will exceed the Earth's escape velocity, so the hydrogen will deplete quite rapidly (any molecular hydrogen already does because of the solar wind). This will be somewhere during the time that the rocks dissociate, releasing sulphur and carbon, to create an atmosphere of similar compostion to that of Venus but probably very much deeper. This will have a dramatic greenhouse effect at these high temperatures. After this, it seems likely that the solar expansion will be slow enough for various events (solar flares, solar winds, etc) to deplete the Earth's atmosphere, probably to below the density of the outer atmosphere of the sun. Finally the density of the surface gases will cause the Earth to slow down and fall in towards the sun, where increasing temperatures will finally consume it.
That's always assuming that something else doesn't happen first, of course (careful, those shades would be useless).
In reply to #91
06/13/2016 10:59 AM
Sounds like fun.
Did you ever think of taking up motivational speaking?
#110
In reply to #92
06/16/2016 5:27 PM
Are you suggesting I'm speaking through my anal orifice?
(fair comment - it's all just best guesses)
In reply to #110
06/16/2016 6:02 PM
No, it just reminded me of a soliloquy on Corner Gas.
Oscar Leroy is talking to the deputy sheriff Quenton that he feels old. He goes on to say that every day he wakes up feeling older and another breath closer to the jaws of death, but then one day you don't feel that way because you died. Quenton asks Leroy if he ever thought about taking up motivational speaking.
It's a fun series. I recommend it.
In reply to #110
06/17/2016 11:14 AM
If you are doing that, you need to document it with a research paper on rectal eloquence. I can see the headlines now.
#122
In reply to #119
06/17/2016 1:51 PM
I also play the trombone. 'nuff said
06/05/2016 8:00 AM
The obvious answer would be that the neutrino either loses a lot of energy on its way throught the sun - or indeed that it is absorbed in transit
(and I'd really like to see the physics of this hypothetical detector)
BTW, if this were instead the kinetic energy of a neutron (rest mass about 1GeV), the neutron would have had about 98% probability of decaying during the hour it took to reach the earth.
06/05/2016 1:11 PM
Notes:
. The oscillation hypothesis would be valid if the question limited the detector to electron neutrinos, but the question is specific "all neutrinos of that energy"
. Water baths are used to detect neutrinos via the interaction with the nuclei. Assuming that the dominant interaction is with oxygen and for simplicity that the trajectory sees only the average density of the sun, we find that the neutrino leaving the centre of the sun sees the equivalent of
. sun-density/oxygen-mass-proportion-in-water*mass-concentration-in-sun*path-length, or
. 0.25*1/8*0.001(?)*700,000 = 20km water-equivalent.
That's 500x the absorption length of a large subterranean neutron detector, and there's plenty of other stuff that can interact with neutrinos (I've failed to find cross-section numbers to allow estimation of the proportion of neutrons that interact).
. The energy required to release a charged lepton dependson the interaction, and similarly I've failed to find numbers. But the question was specific, so even a signle low-end 0.1-MeV interaction could take the neutrino outside the 100% range.
There is no doubt therefore that this could explain the failure to detect the single neutrino described in the question. But we would need much better information than I've been able to access to determine what proportion of neutrinos would escape detection. The success of much smaller water-bath detectors and the large path length suggests it might be the majority. (Maybe even the asking of the question in this form would support such a guess)
BTW, I rated Canary's answer as good. This is my attempt at explanation based on the alternative interpretation that "path" implies the neutron actually goes through the earth.
06/05/2016 8:13 PM
Sorry to keep answering myself, but I found "accepted" numbers for oxygen concentration in the sun as being between 0.75% and 1% by mass, except for the core (unstated). As oxygen constututes about 8/9 of the mass of water, the interaction with oxygen is equivalent to 9/8*0.0075*average-s.g.-through-path*path-length. The non-uniform density means the 0.25 average sg is a gross underestimate, so we can use 1500-km of water as a lower bound for the effective interaction length. That certainly increases the probability of interactions with oxygen (i.e. that involve significant energy loss). BTW, the threshold for interaction with water is about 5MeV,so the neutrinos that are detected by water are the (0.1%) 8B neutrinos with energy up to about 15-MeV and the very rare (0.01%) hep neutrinos. Unfortunately I have still not managed to find information that is suitable to estimate the interaction probability in the 40m deep Super-Kamiode water-based detector; however, the mere fact that energy loss is not mentioned in any of the general-interest journals suggests that the proportionate effect is small; however, the challenge wording refers to a single event, so there is no need for it to be a frequent occurrence.
(I'm assumming that the challenger is not imagining a super-narrowband 14MeV sensor that would be disabled by the energy loss due to the sun's gravity)
06/17/2016 4:38 PM
14 MeV neutron corresponds to what temperature if that is the K.E. only? Would that be considered a "cold" neutron?
In reply to #127
06/17/2016 4:52 PM
No, definitely not cold! https://en.wikipedia.org/wiki/Neutron_temperature
As you will see, the numbers needed for the expression of particle energies as temperature are often quite absurd.
06/06/2016 1:12 AM
the neutrino didn't pass the detector
06/06/2016 10:36 AM
Anti-social neutrino? I mean, what is the neutrino's motivation?
06/07/2016 10:22 AM
Capable of Detecting != Certainty of Detecting.
In order to detect the Neutrino, it *MUST* interact (collide) with another particle. Neutrinos are very good at avoiding any interaction with anything made of normal matter placed in their path.
So the short answer is is simply missed every single particle in its path and passed through the Earth completely undetected.
Longer answer: The cross section of Neutrinos is vanishingly small, the mass of particles along the path of the Neutrino present a cross section to the Neutrino that can be envisioned as a a gossamer web. The probability of a collision is proportional to the product of those areas, the product is woefully insufficient to expect the likelihood a collision.
That's not to say the detector didn't intercept another Neutrino that was travelling parallel to the first, but unless there were a billion or more Neutrinos in the bunch, chances are that all missed the screen. It's a little like using a steel rebar cage to keep gnats out of the house.
06/07/2016 11:32 AM
Have I (or the sun, for that matter) ever been dense?
Even the slightest interaction with matter would be sufficient to change the path of the neutrino, and all that is needed is 90-micro-radians. The ~1-Mm oscillation length of a neutrino is significantly reduced in the solar environment, meaning that the majority of neutrinos would show significant interaction with the solar environment.
Thus, although the neutrino was originally headed to pass through the Earth, it will most likely have been diverted by the time it reaches the chromosphere.
06/07/2016 12:07 PM
We are good at overanalyzing things.
The problem states that a 14MeV neutrino is emitted from a fusion reaction in the core of the sun and travels on a path through earth.
The question also says that the detector is perfect for detecting neutrinos at that energy. If that means specifically 14 MeV, then the simplest answer is that the neutrino wasn't still at 14MeV when it passed through the earth.
06/07/2016 8:10 PM
You say over-analysing. But IMO CR4 should not normally be the place for purely semantic challenges (or certainly not for me). If it's to be any use in keeping this geriatric mind active it has to go far deeper than that. An analogy: if it was a bullet trajectory CR4 would be more numeric and expect you to calculate gravitational acceleration. Going this far outside the normal range of normal CR4 (including my) experience I would still expect to identify the most likely reason for non-detection and also the associated mechanism.
It would be hard to make a detector to detect 14-MeV and not (say) 13.9-MeV, but an energy change exceeding this would be substantially less likely than a 0.04-radian deflection. Deflections exceeding 90-micro-radians would be orders of magnitude more likely, so this becomes a far more probable explanation.
On the semantic front, I agree that you can read the wording to imply that the neutrino remains on that path through the earth. If this implication is intended as a definitive instruction it excludes the most likely effect, which would be a shame (and as I wrote above, it seems to me that the only reason for bothering with such challenges would be to stretch the mind outside the normal range)
06/07/2016 10:30 PM
"An ideal neutrino detector capable of detecting every neutrino of that energy passing through Earth fails to detect it."
It says the detector is capable of detecting every neutrino of that energy, not that it absolutely does....so the neutrino passed though undetected....
06/08/2016 9:53 AM
Good point.
IDNHAC on anything further to add.
06/08/2016 11:18 AM
Unworthy of you, I think. IMO that sort of semantic approach is obvious, trivial, and unininteresting. (Interesting answers generally address what the question should have meant...)
06/08/2016 12:24 PM
Don't know why that one appeared as anon!
Fyz
06/08/2016 12:28 PM
There is a show on History channel where knifemakers are given a set of initial specifications for the knife they are to make.
It's amazing how often they produce a knife that doesn't meet the spec.
The statement of the question rules out generation of the neutron, direction and detection method at a specific energy as causes of the failure. The only thing it doesn't rule out is that something happened to change the energy level to something outside of the ideal range of the detector.
If this problem is supposed to be of the ,"do you see two faces or a Grecian urn" sort of exercise, then there is no point in overlooking the elegant, simple answers.
Remember, sometimes the best answer is the simplest and the most elegant solution. However, it is also usually wrong.
06/08/2016 1:05 PM
"Capable of detecting every neutrino of that energy" must mean that it does "detect every such neutrino" when it is fully active. According to this line of reasoning the "simplest and most elegant" answer is that the detector happened to be switched off at the time this particular neutrino passed through the Earth. Obvious, and to my mind so facile as to be normally not worth mentioning (though given the other answers in the thread I'm surprised I didn't spot it already). (BTW, the CR4 moderators can't be perfect, but they don't often let such things pass for "Challenges", though you wouldn't believe it reading the threads.) In any case, even if the detector is switched off 99% of the time, more particles will miss the Earth than would pass through the detector when it is switched off, so (as you wrote) the "simplest and most elegant answer" would in isolation only account for a small proportion fo the cases.
On the subject of the "only allowable answer relating to the energy", I think the wording is capable of a different interpretation. It only says "travels on a path directly through Earth". The A1 in England is a road that runs from London to Edinburgh. If I travel on the A1 it does not mean I follow it as far as Edinburgh. Similarly, the neutrino travelling allong a path that goes through the Earth does not mean it stays on that path. So (avoiding facile answers) we do have the choice: does the neutrino miss the Earth or does the energy reduce sufficiently as to be undetected. The vast majority of particles whose energy is reduced at all will miss the Earth, so I take this to be the best answer (though it took me a stupidly long time to realise).
On the other hand, having some experience of CR4 challenges and having become rather cynical, "The Answer" I am expecting is that the neutrino will have oscillated to a different flavour, which changes its energy; this answer would actually be incorrect, because the things that change during vacuum oscillations are the velocity and the rest mass, but not the total energy.
In reply to #60
06/08/2016 1:53 PM
Does a leaf fall in the woods if there is no observer present?
In reply to #63
06/08/2016 5:33 PM
Archaeology, the legal system and probably most things in our lives rely on the answer being "yes"
In reply to #63
06/08/2016 8:12 PM
I don't mind the legal system or several other systems being anthropocentric. However "the woods" almost by definition do not care (and often prefer) if human beings are around to watch the woods in action.
You are not as important as you think.
In reply to #68
06/09/2016 11:12 AM
The woods do not care if a leaf gets transferred into "the getaway car", the legal system does care a great deal about such things, especially if the tree is not native to the area in logical question, to the point that finding the tree = finding the murder scene, etc.
I am not important at all, except to God, me, my dog, my employer, and my wife, mostly in that order on any given day. I know I am important to God (and so are you the same amount), since He took up a cross while being beaten, and carried it up a hill, and let Roman soldiers nail him to it, just for me (and you). He also came back alive after three days with power.
Don't give up on me (or you) doing something great today, it can happen.
In reply to #73
06/09/2016 11:41 AM
On which topics: God would be omnipresent, so your "Does a leaf fall in the woods if there is no observer present?" question becomes void.
I have a problem with your order of importance. We are all of equal importance in God's eyes, so that places you level with the rest of us. God probably also has some priority for itself, even if continued existence is a given. Then there is the heavenly host... Scaling importance versus God's capability of assigning importance is far too deep for me.
Then, unless divorce is imminent, I think you will find the mutual importance of your relationship with your wife is greater than with any individual employer (however valued an employee you might be).
The woods might not care about one leaf, but they are the nutrients for the next generation, so don't take too many.
In reply to #63
06/09/2016 4:55 AM
And, if a man speaks in the woods where no woman can hear him: is he still wrong?
In reply to #71
06/09/2016 11:26 AM
Only he can miss being heard is if he does not cuss. Wife will always hear.
06/08/2016 12:54 PM
This is, of course, why I saved it until after all the speculation had run its course, or perhaps nearly so...These questions are specific, with little information provided...therefore they are subject to closer scrutiny than the usual casual statement or query...as such, any vagary is usually by design....sometimes it's just meant to lend uncertainty and foster a confusing atmosphere to add to the difficulty of reasoning out a definitive answer...but sometimes it's just a lame trick question designed to humiliate nerdy types...haha
06/21/2016 10:13 AM
The answer to that question is so simple,I will let my chauffeur answer it.
06/21/2016 11:11 AM
The flavor of a neutrino does not effect the neutrino's energy or mass.
Please be consistent with the given conditions.
In reply to #147
06/21/2016 11:25 AM
It's probably because this ideal detector requires a special AAA battery, and it ran down to below the threshold volts, waiting for the errant neutrino to arrive. The detector is still functional, but the battery let them down.
#151
In reply to #147
06/21/2016 2:07 PM
Each neutrino flavor has a different mass. As the flavor of a neutrino changes, the neutrino's mass changes.
See this article for more on neutrino flavors and masses: http://www.scientificamerican.com/article/nova-experiment-neutrino-mass-mystery/
#153
In reply to #151
06/21/2016 8:51 PM
The total energy is the sum of the rest mass and the kinetic energy. Total energy is independent of the flavour of the neutrino. This certainly invalidates neutrino flavour as an answer to the challenge; I also believe that this is what redfred's comment meant, although I can understand that the comment coud be subject to misinterpretation.
06/21/2016 3:18 PM
Ok,here's my chauffeur's take on the question,as worded.
Since the neutrino passes "directly through the Earth",it was not detected.
In order for it to be detected,it had to collide with the sensor (H20,etc.) of the detector and would not complete the journey through the Earth.
#154
In reply to #152
06/21/2016 9:41 PM
Your chauffeur should read the semi-technical* descriptions of neutrino detectors more carefully, as he would find that neutrino sensors only extract a proportion of the neutrino's energy. (Insofar as a neutrino has identity it would indeed continue its passage through the Earth.)
*Or, if he is a graduate in nuclear physics doing chauffeuring while wating for postdoctoral funding, he should make a critical reading of the subject as a whole during his "sitting around" time. In that case CR4 denizens would definitely be interested to see his full sumary for the layman.
P.S. I asked my chauffeur, and he said I should buy organic chicken breasts, hammer them flat with a rolling pin so they did not present too deep a target for solar neutrinos, season and and fry in olive oil for 2-1/2 minutes on each side (or until the inside was no longer pink).
In reply to #154
06/22/2016 12:45 AM
My chauffeur,hereafter referred to as "Justin"",replies that the keyword is "directly",meaning without deflection or interruption.A sensor would deflect or interrupt the path of the neutrino,albeit in a small manner.
#159
In reply to #157
06/22/2016 5:40 AM
Semantics, the bane of CR4!
But if you are going to 'do' semantics:
a) Your chauffeur's interpretation would make the challenge question self-contradictory, as it also states that ALL suitable particles are detected.
b) Paths do not necessarily have zero dimensions; as a rambler, I can perfectly well pass other people or stop for a chat and then continue on my way without deviating from the path.
Changing topic slightly:
Since about the middle of c18, individual chauffeurs (and chaffeuses) have generally been referrenced as "James", no matter how they are addressed in person. The name by which they are directly addressed is accepted only when the use of "James" would result in unacceptable ambiguity.
James was concerned that the wrong neutrino flavour would spoil the chicken.
The confidentiality agreement that all our staff sign means that James would never appear publicly in his professional capacity.
It would appear that Mr. Thyme has also realised that his appearance was "out of order", because when I tried to follow your U-tube link I got an apology that the video was not available.
In reply to #159
06/22/2016 7:49 AM
Justin is a very formal gentleman and insists on NOT being called "James" because it puts him in a generic class of ordinary chauffeurs.
He made several appearances on the tv series"The Beverly Hillbillies" in 1964,and is reliving the past,I suppose.
He is getting quite old now,and can't do as much as he once could,so I bought a log splitter to give his back some relief,arthritis and all, you know.
He was offended at first,but finally settled into using it.
However he still insists on felling the trees himself with a double bit axe,just to "keep in shape" as he says.
He carries a set of scissors in his pocket to catch any errant twigs on the topiaries of the estate.
"A stitch in time." and all that.
He only does 50 laps a day in the pool now in the afternoon,so he can be refreshed in time to prepare the dining room for dinner.
It won't be long till he will have to retire,and he will be hard to replace.
I am giving him the Benz when he leaves,since he has driven and cared for it from his first day on the job.
Good help really is hard to find nowadays.
PS:Try the link again,it works fine from my site,and I have to use a sat link to connect.
#161
In reply to #160
06/22/2016 8:18 AM
The link:
Maybe you have to be registered?
But at least you've explained what a Croatian chauffeur does. Just try to get James to go outside his narrow role (driving, collecting and being a fountain of information - some of it useful). That would be way below his dignity.
"Good help really is hard to find nowadays."
It always was - it's just we need it more as we get older...
P.S. good help for them as helps themselves?
In reply to #154
06/22/2016 12:54 AM
Allow me to introduce my chauffeur:
https://www.youtube.com/watch?v=bK9VoToteGU
06/21/2016 10:42 PM
This means Baskin Robbins may have flavors we are not aware of!
06/29/2016 5:48 AM
Incomplete information again. The original description was of an instrument "capable of detecting every neutrino of that energy". "Flavor" was not mentioned, and (AFAIK) there is no change in energy associated with the changes of flavour.
06/29/2016 11:39 AM
A Customer complains that a TV I sold him is not working,even though it is capable of over 100 channels.
A visit to the residence reveals it is not turned on.
Such may be the case with the neutrino detector.
Is it turned on,plugged in, etc?
Rather ambiguous question as worded.
07/01/2016 10:12 AM
Is it OK for me to say that he 'official' answer is a pretty poor one?
#171
In reply to #170
07/01/2016 10:40 AM
IMO: as an answer to the specific challenge question, it's about as good an answer as "because that day was cloudless"
#172
In reply to #170
07/02/2016 11:22 PM
in case of panic - keep quiet
07/03/2016 6:29 AM
This blog is getting too serious.
A more important question has been bothering scientists all over the world for years:
https://www.youtube.com/watch?v=vXp0i7Y1eVo
#174
In reply to #173
07/03/2016 6:46 AM
Not serious enough: the antique stone pavings of London are giving way to replacement by concrete slabs under a hail of chewing gum. Then we suffer from gum stuck under and around seats every time there is an event in a school hall. I advocate a tax regime that would make the price of gum cover the damage; this would doubtless be regarded as punitive, with populist politicians blaiming EC regulations and promising repeal when the UK leaves the EU. Perhaps compulsory loading of chewing gum with concentrated wormwood flavouring would be a safer alternative.
(Whoops, too late, we already voted).
In reply to #174
07/03/2016 7:06 AM
Perhaps old gum is not as useless as presumed.
Old gum from 40+ years ago could be useful in DNA research,especially when taken from school desks,to
plot immune systems changes over the years.
Hmm! I smell a research grant somewhere nearby.
#176
In reply to #175
07/03/2016 7:15 AM
Try abstaining for a while - restore the sense of smell to distinguish the aromas of bs vs. research grants? (If I got this wrong, the gum tax can fund the grant)
In reply to #176
07/04/2016 12:50 AM
I think everyone who chews gum should be required to throw it out the window on roads and highways when they are finished with it. It will coat the roads and make them resistant to all kinds of road damage, saving billions of dollars per year in maintenance.
canary
#178
In reply to #177
07/04/2016 9:45 AM
Roads are mainly damaged by the freezing of trapped water and by very large heavy vehicles. Not sure that gum will help with either of those. It would also reduce surface friction and already blocks drains. Not to mention its effect on high quality (sidewalk) paving (see post #174)
In reply to #176
07/04/2016 11:14 AM
Old bubble gum is like Amber...a perfectly dry,anaerobic environment for DNA, that if left undisturbed,will last for millennia.
DNA has been recovered from T Rex bones,where nothing was suppposed to be viable after 60+ million years.
Thousands of old school desks,sitting around in abandoned school house,just waiting to be analyzed.
(Not to mention bedposts)
Still smells like a basis for a grant to me.(And I haven't been near the cow pasture in weeks,or DC for that matter.)
If I were doing research in DNA,I would utilize this resource.
#180
In reply to #179
07/04/2016 5:02 PM
DC? - didn't you say Smiljan
In reply to #180
07/04/2016 8:30 PM
When the wind is right,you can smell the B.S. all the way to Croatia.
Reply Off Topic (Score 4)
#182
07/09/2016 12:57 PM
... every neutrino of that energy ...
In reply to #182
07/09/2016 1:57 PM
Already been pointed out (and ignored).
Anonymous Poster (2); Canary (12); HiTekRedNek (11); IdeaSmith (1); James Stewart (29); JIMRAT (3); JohnDG (8); Jpfalt (10); Mikerho (1); nvirciglio (1); Physicist? (49); Quasar (5); Randall (2); redfred (12); Rixter (3); SolarEagle (12); tick-tock (12); Usbport (4); wayneelowe (1); WilhelmHKoen (5)
