Coatings & Surface Engineering Blog
The Coatings & Surface Engineering is the place for conversation and discussion about coatings; substrate modifications; cleaning and surface preparation; and friction, lubrication and wear. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: What's Your Favorite Wood Finish?   Next in Blog: Defects Actually Strengthen Roman-era Concrete
Bioactive Film Improves How Implants Bond with Bone
Posted August 25, 2016 12:00 AM by Engineering360 eNewsletter
Researchers from several universities have developed a technique for coating polymer implants with a bioactive film that significantly increases bonding between the implant and surrounding bone. The polymer, polyether ether ketone, also known as PEEK, has properties that make it appealing for use in implants, but it doesn't bond well with bone. The research team tested several methods to coat the polymer, including using a thin film of yttria-stabilized zirconia followed by a coating of hydroxyapatite. The team then heated the coating with microwaves, which makes the crystalline hydroxyapatite structure more stable in the body and more capable of bonding with bone.
Editor's Note: This news brief was brought to you by the Coating & Surface Engineering eNewsletter. Subscribe today to have content like this delivered to your inbox
Good Answers: 27
Re: Bioactive Film Improves How Implants Bond with Bone
08/29/2016 9:21 AM
"The team then heated the coating with microwaves, which makes the crystalline hydroxyapatite structure more stable in the body and more capable of bonding with bone."
Does the above means they have to "nuke" the patient too, to enable the supposed implant to stick /stay in place? Another patient safety issue!
vsar
