Coatings & Surface Engineering Blog
The Coatings & Surface Engineering is the place for conversation and discussion about coatings; substrate modifications; cleaning and surface preparation; and friction, lubrication and wear. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Heads Up: Computer Display on Contact Lenses   Next in Blog: Bioactive Film Improves How Implants Bond with Bone
20 comments
What's Your Favorite Wood Finish?
Posted August 11, 2016 7:00 AM by cheme_wordsmithy
This question is for all you CR4ers who love working with wood. The universe of wood finishes is a big one. There are so many different kinds available depending on the protection you need and the look you want on your project. For the novice craftsman, the finishing step can be daunting, especially since it truly can make or break your project.
As I became more invested in woodworking, I began researching more about different finishes. I found it helpful to break down the myriad of coating products into different types, starting with the most basic categories: surface finishes and penetrating finishes. Penetrating finishes are those that absorb into the fiber of the wood, while surface finishes don't penetrate far and instead build up on the top of the wood's surface. Of the penetrating finishes, I found there were three common types used.
The first is linseed oil, which originates from flaxseed and is available in either "raw" or "boiled" forms. The boiled form is often preferred, as drying chemicals are added to accelerate the otherwise week-long curing time. In order to dry properly, the oil must penetrate the wood and any excess must be removed from the surface after application. Linseed oil will add a yellow hue to the wood which will darker over time, and it brings out the grain of the wood nicely with a soft gloss. It is often used as a medium with wood-coloring oils and stains. It is easy to apply, but on its own does not provide protection against water or UV rays. However it can be mixed with varnish to enhance these properties. Linseed oil also has a short shelf life, and shouldn't be used if it gets thick in the can.
Number two is tung oil, a deep penetrating oil that originates from the tung tree. It is the most protective natural oil finish available, providing some water and UV resistance for the wood. Tung oil is often sold in mixtures with varnish, but "100 percent pure" tung oil is a favorite for those seeking a natural finish which enhances the organic look of the wood. It is slightly less yellowing than linseed oil, doesn't darken over time, and dries to a matte (non-glossy) sheen. Being all-natural, pure tung oil is safe (FDA approved) for contact with food, making it a popular finish for wooden utensils. It also has a long shelf life: pure tung oil can last many years if properly stored. The downside to tung oil is its long drying time (at least 2 days) and curing time (at least 2 weeks), as well as the need for multiple coats (at least 3 or 4).
The last is Danish oil, a blend of varnish, curing oil (typically tung or linseed), and mineral spirits. Danish oil combines the qualities of penetrating oils with the protective properties of varnish to create a more durable finish than natural oils alone. Drying and curing times for Danish oil are slightly shorter than all-natural oils alone. However, Danish oil still requires multiple coats.
A safety note for those new to wood finishing: finishes like Danish oil and boiled linseed oil which contain drying chemicals are susceptible to spontaneous combustion if left in a pile or hot container. Please ensure to hang your rags or towels out individually when drying, or soak them in water to prevent any chance of starting a fire.
Of the penetrating oils I discussed, I will admit I've only personally used Danish oil, but I was happy with the results I got. Aside is a picture of a decorative wood spoon I finished with Danish oil, followed up with a coating of paste wax to add some shine. For all you fellow woodworkers who've used these types of oils, I encourage you to share your projects and let us know your favorites!
Re: What's Your Favorite Wood Finish?
08/11/2016 1:19 PM
My favorite finish is shellac, but it depends on a few factors, one being durability; another being beauty and another being ease of application and maintenance. It also depends on the wood and whether it will be exposed to the elements. Varnished mahogany looks beautiful on a vintage yacht, but application and maintenance is a big negative. A modern finish may be easier to maintain, but will lack the beauty of varnish.
Mr.Ron from South Ms.
08/11/2016 1:38 PM
Some years back I did a good bit of furniture refinishing, mostly stripping layers of paint off what people would call primitive antiques. Some pieces were intended to be painted -- they were made of mixed woods. For most of the others I used varnish or a varnish stain; often the wood wasn't nice enough to stand on its own with no added color. With any finish, the hardest part of the process, at least for me, was using a series of thin but even coats to finish the piece. Takes patience, and even hand, and the right brushes.
When we had our wood floor replaced a few years back, we used recycled wood -- spruce that had been reclaimed from a 100-year-old factory in Brooklyn. Our contractor used several coats of tung oil to finish it. This works well for a floor because it penetrates well. We can buff out scratches with fine steel wool, and if we need to refinish a buffed patch, you use some more tung oil. This picture is a good representation of the color (cabinets are cherry). The finish stands up well to us and dogs.
08/11/2016 2:55 PM
My finish of choice is spar urethane, it gives a golden honey hue to natural light woods and provides a waterproof finish that lasts indefinitely....available in gloss, semi-gloss, or satin finish....In some cases where certain effects are desired I use a variety of stains...I reserve the use of oils to dense oily woods like cocobolo and ebony and others...but it's hard to beat spar urethane gloss when it comes to bringing out the beauty of highly figured woods...
08/12/2016 10:13 AM
What kind of wood is that? Lovely grain pattern.
08/12/2016 12:51 PM
It's called curly Maple....aka fiddle back, tiger, ripple....and then you have quilted...
...and then you have burled...
These examples are unfinished raw wood....waiting for a project...even though they look bumpy, they are quite smooth...the final finish smoothes the appearance...This is the quilted..
08/12/2016 1:24 PM
Gorgeous guitar! Your handiwork?
08/12/2016 2:03 PM
I do have the plans and all to make these fender bodies, but when I was getting parts I found this body which was exactly what I was going to make, for a decent price($300), I couldn't justify the time, so I bought it....the assembly was challenging enough...I decided on a white pickguard in the end....
08/12/2016 7:06 PM
I did make this though...
08/15/2016 8:09 AM
WOW that looks laser-cut. Stunning! What's the wood and what finish?
08/15/2016 12:01 PM
That's pine with a spruce top...I designed and cut the pattern with a scroll saw, it has a similar, but different, pattern on the left side...the wood is about 3/4 inch thick and it's finished in spar urethane....The panel behind the scroll work is poplar and is stained dark walnut...The back is cut 45° and fits into a corner if needed....It's a TV stand...It's mounted on wheels and has a figured maple front piece at the base...The wood joining is done by various methods so that the entire assembly required no nails or screws, just hammer and glue....
08/15/2016 2:09 PM
Very good. To cut that with a scroll saw you must have the patience of Job.
08/15/2016 2:47 PM
If memory serves it took about 12 hrs each over 2 days, for each bird....that's just the scroll work....Prep work took a bit longer...
08/15/2016 4:12 PM
Truly stunning to be able to come up with a design that actually looks like a Great Blue Heron (I'm assuming a heron?) and then to execute the design in wood ... I'm in awe.
08/15/2016 5:00 PM
Yes a Heron and an Egret I believe, if memory serves...You know your birds...It's challenging to design scroll patterns, but it's fun to have a new design work....Hard woods are much more sturdy than soft woods like pine, that's why I went with a thicker wood for such a delicate pattern....Then I saturated the wood with a thinned out coat of spar urethane to harden the wood, before coating it with an unthinned coat or two....For the finish coat I usually use the spray can version for a smooth topcoat...
Good Answers: 54
08/16/2016 5:40 AM
Do you wet sand between coats?
08/16/2016 8:52 AM
You generally need to sand after every two coats...but I dry sand, usually with about a 220, lightly, with a wipe rag in one hand and smacking the paper on the piece to dislodge dust accumulation...and just use paper on finish coats....The only time I use water on wood is when removing oil and stain...I use a 50/50 mixture of water and ammonia spray on the wood and rinse with water...hardwoods only...softwoods I just sand it off...
Good Answers: 54
09/10/2016 3:30 AM
With 220, do you get sanding marks in the clear coat?
Water and ammonia will take stain off? What about old stain? I usually sand it off or I've also used steel wool too.
And any advice on cleaning up water stains on wood?
08/16/2016 10:35 AM
We live on a lake and have herons that wade in the shallows and hang out on various docks. The babies look like pterodactyls. No egrets though.
Good Answers: 54
08/12/2016 11:03 PM
It depends on the project. Here are some general answers:
1. For something that needs a lot of protections (sun, rough use, etc) but is indoors, I use a water based spar urethane. I know the pros like oil, but this is much easier to clean up.
2. For something that will be outdoors (rain, sun, heat, cold) I use oil based spar urethane. Even though it's a little messy to use, it lasts a lot longer.
3. For finer wood work, Tung oil. I've never use Danish oil and the only time I use linseed oil is when I'm glazing a window.
08/13/2016 12:40 PM
For small objects and snooker cues check out superglue and accelerator. Gives incredibly tough finish when polished up with fine wet and dry.
Peter Jensen
Autobroker (3); BestInShow (6); Brave Sir Robin (1); Pj3ns3n (1); ronseto (1); SolarEagle (8)
