Coatings & Surface Engineering Blog
The Coatings & Surface Engineering is the place for conversation and discussion about coatings; substrate modifications; cleaning and surface preparation; and friction, lubrication and wear. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Bioengineers Streamline Process for Making Medical App Sensors   Next in Blog: Heads Up: Computer Display on Contact Lenses
9 comments
A Sharp Solution to Water Treatment
Posted February 18, 2016 12:00 AM by Engineering360 eNewsletter
In many parts of the world, clean water is luxury. An Engineers Without Borders chapter at Utah State University teamed up with a rural town in Mexico to solve a water purification problem in an innovative and sustainable way. Using concrete, washed sand, and PVC pipes, they created a filtration system with one rather surprising component - rusty nails. The town's water was contaminated with arsenic, but the nails removed the toxin by forming a precipitate in which the arsenic sits on the surface of the iron. Water passes over the nails, through a diffuser plate, and then through a sand and gravel filter, removing both arsenic and bacterial pathogens.
Editor's Note: This news brief was brought to you by the Coating & Surface Engineering eNewsletter. Subscribe today to have content like this delivered to your inbox
Re: A Sharp Solution to Water Treatment
02/18/2016 8:44 AM
I would say clean water is a luxury in all parts of the world. It's just that many of us have taken it for granted.
02/19/2016 6:28 AM
Start with Bear Gryll's rule of 3's: You can live 3 minutes without air, 3 days without water and 3 weeks without food. Obviously none of these are "luxeries". All are absolutely essential for human survival. The only entities that have taken it for granted is big industry and greedy politicians who allow big industry to abuse these precious commodities. When the US gets big money out of our political system - then the world's (not just the US') problems can finally be solved.
02/19/2016 9:01 AM
Your whole world view is this: pure horse hockey and applesauce! You can't even spell luxury, much less describe it. You are wasting our precious air, do us all a favor and get a new brain.
Actually, without big industry, and good government policies (and officials) in place, there would be no public water supply, much less a food supply. Without big industry, there would be no controls for air pollution from you pot-headed troglodytes running around grunting at your camp fires, and poking each other in the eyes with sharp sticks.
Grow up, stop whining, get a job! The 3 major problems in the world right now: (1)left wing socialists, (2)even further left wing socialists, and (3) you guessed it, outer space left wing Kool-Aid drinking communists.
Good Answers: 64
02/19/2016 9:55 AM
James Stewart, I would agree with the worldview points and the value of industry, large and small, and the value of government, if there are operating on good principles. Innovation and experimentation often come out of the R and D of companies, sometimes funded by governments.
As far as how you communicated that, I'm not so sure about that. Maybe read "How to Win Friends and Influence People" by Dale Carnegie. As I tell my son, "you may have a great idea but if you don't commuicate it well, or alienate people, you won't get to see your great idea implemented.
One of the greatest discoveries a man makes, one of his great surprises, is to find he can do what he was afraid he couldn't do. Ford, Henry
Canada - Member - Specialized in power electronics
Good Answers: 80
02/19/2016 5:56 AM
This is similar to the filters that the Rotary Club is distributing for free to various remote communities except they use an all concrete design produced locally and don't use of the rusty nails.
My question to the Chemists is:
Would the nails (or other locally available metal) be useful in removing other contaminants such as mercury or lead?
Figuring out a few simple "addition" to the basic biological sand filter would help a lot of people affected by polluted water sources.
Experienced is earned, common sense is taught, both are rare essentials of life.
02/19/2016 9:15 AM
maybe on lead removal, somewhat doubtful, but it depends on alkalinity being in the water, and probably on the small availability of some sulfate being present in the water.
Lead sulfate is highly insoluble, and that is what usually stops people from poisoning themselves with lead when they combine any "potable" water supply with lead pipes.
The Romans (in Rome) learned this lesson the hard way, since their water source was in fact actually highly pure (channeled by Aqueduct from the Alps), but then they used lead pipes. Some say this may have led at least partially to the down fall of Rome.
Mercury does not behave the same way as arsenic or lead, with one exception: when any heavy metal is present at trace (but perhaps still chronically toxic) concentration, one of the best ways to reduce the concentration to tolerable levels (survivable, not chronic effects) is to use charcoal filtration. Activated charcoal usually contains alkaline earth metal ions (Calcium and/or Magnesium) that can exchange with the "heavies" in a very spontaneous manner (good binding of the heavy ions), and can tie up Arsenic depending on the type of arsenic present.
If heavy metals are a serious threat due to downstream piping (as in Flint, Michigan), the solution really should be to increase the hardness and alkalinity of the water (by treatment additions), so as to stabilize any lead pipes, or pipes with metal containing arsenic (such as low grade copper).
If a locality has a water source that is laden with mercury, it might be possible to use something like sulfide to precipitate the mercury (along with some other heavy metals if present), also to improve the efficacy of such treatment by the addition of ions (such as copper (II) ion) that are also insoluble with sulfide. This should enhance co-precipitation of the mercury to lower residuals than simple treatment. It can also be used effectively to remove excess sulfide (which is toxic in its own right). The final water still needs to be free of sulfide and copper, as well as the targeted ions.
Good Answers: 153
02/19/2016 6:11 AM
Iron in the form of ferric chloride or ferric sulphide has been used to remove arsenic from ground water for many years. The process usually involves coagulation that can be separated from the water easily by filtration. But the use of iron requires that the arsenic be in an oxidized form (arsonate rather than arsonite) and complete oxidization using just air would require the water to stand in a shallow open lake for weeks or months. The arsenic bearing water is therefore usually pre treated with manganese oxide, chlorine, permanganate or other oxidants to speed to oxidization process The pre treatment also has the advantage of killing bacteria.(Ozone works better for both oxidization and bacteria treatment and has a lower contact time but is regarded (wrongly) as a sophisticated technique.)
While this initiative is cheap and better than no treatment at all it suffers from the following problems. It makes no attempt to remove the unoxidized arsenic. The process will become increasingly inefficient as the nails leach out the arsenic, so the nails will have to be changed periodically. The change frequency is a function of arsenic concentration, degree of rustiness of the nails and flow rate, none of which are measured. It only works with ferric oxide not ferrous oxide so the type of rust on the nails is important. With the optimum ratio of 20:1 iron to arsenic removal is only 80% efficient (this solution does not even attempt to create optimum conditions so removal could be as low as 30%). The World Health Organization guidelines call for a maximum arsenic concentration of 10µg/L of drinking water. The villagers of Mexico deserve more from us than a cheap botched up solution.
Good Answers: 80
02/19/2016 6:26 AM
Thank you for this instructive contribution.
I will have to figure out how to add a "simple" ozone generator to the filter the Rotarian use. Need something that can be made and maintained locally and from "surplus" electricity from a solar panel used for many applications.
02/19/2016 11:05 AM
Why not just make a large Van de Graaf generator that is powered by a windmill, and make sparky corona discharge over some hack saw blades above the water? If the wind isn't blowing you could surely find a couple of Mexicans around with nothing to do to peddle the wheel.
Brave Sir Robin (1); facilitiesmgr (1); James Stewart (3); jhhassociates (1); marcot (2); tburgak (1)
