Previous in Blog: The Widgetator: Newsletter Challenge (08/07/07)   Next in Blog: Pyramids: Newsletter Challenge (08/21/07)
Measuring Solar Power: Newsletter Challenge (08/14/07)
Posted August 12, 2007 5:01 PM
The question as it appears in the 08/14 edition of Specs & Techs from GlobalSpec:
A satellite designed to measure solar power is in an equatorial geostationary orbit. Every year on June 20th the satellite measures the incident solar power for an entire day. The satellite remains in orbit for 10,000 years and its orbit remains intact. During the 10,000 years the amount of solar power measured by the satellite on June 20th steadily increases. Over these 10,000 years, the Sun's output has not varied. What's causing the increase?
(Update: August 20, 11:38 AM) And the Answer is...
There are two contributors to the increase in measured solar power. The first Perihelion Precession. The Earth will be much closer to the Sun on June 20th 10,000 years from now than it is now. The second effect is the slowing of the Earths rotation. The Earth's rotation slows about .005 seconds per year, so in 10,000 years an Earth day will be about 50 seconds longer meaning 50 more seconds of solar power collected on June 20th.
Re: Measuring Solar Power: Newsletter Challenge (08/14/07)
08/15/2007 7:45 PM
is it possible for a satellite to remain in a perfect geostationary orbit for 10,000 years or could drag slow it down ?
#90
It's so simple - Global Warming, you fools
08/17/2007 1:38 AM
#91
In reply to #90
Re: It's so simple - Global Warming, you fools
08/17/2007 4:31 AM
irritating attempt at humour?
#94
08/17/2007 2:26 PM
Would the earth axis change due to annual magnetic field variation?
Good Answers: 22
#97
In reply to #94
08/17/2007 3:11 PM
More likely the other way around. Remember that a magnetic field results from a flow of electrons. If the Earth did not spin, and have a molten iron core, it would not have a sustained magnetic field. The Wikipedia entry on the Earth's magnetic field explains this relationship:
"The field is similar to that of a bar magnet, but this similarity is superficial. The magnetic field of a bar magnet, or any other type of permanent magnet, is created by the coordinated spins of electrons and nuclei within iron atoms. The Earth's core, however, is hotter than 1043 K, the Curie point temperature at which the orientations of spins within iron become randomized. Such randomization causes the substance to lose its magnetic field. Therefore the Earth's magnetic field is caused not by magnetized iron deposits, but mostly by electric currents in the liquid outer core.
"Convection of molten iron, within the outer liquid core, along with a Coriolis effect caused by the overall planetary rotation that tends to organize these "electric currents" in rolls aligned along the north-south polar axis. When conducting fluid flows across an existing magnetic field, electric currents are induced, which in turn creates another magnetic field. When this magnetic field reinforces the original magnetic field, a dynamo is created which sustains itself. This is called the "Dynamo Theory" and it explains how the earth's magnetic field is sustained."
The full article is here.
#102
In reply to #97
08/20/2007 7:47 AM
This sounds like a good basis for a Perpetual Motion thread...where're PlbMk, PWSlack and Masu....
#114
In reply to #94
08/22/2007 10:34 AM
The poles are predicted to reverse themselves ...
#115
In reply to #114
08/22/2007 11:30 AM
How is it relevant that the Poles wish to return home? (seeing that they have no more to do with the challenge than the magnetic poles)
#95
08/17/2007 2:30 PM
Global warming only works below the ozone barrier doesn't it?
So a satellite in orbit wouldnt be effected.
#98
In reply to #95
08/17/2007 3:30 PM
That is true of most greenhouse effects and the warming due to man's activities. Over geological timescales there are cycles of heating and cooling that are commonly referred to as global warming and cooling*. Some of these are due to orbital variations and others to changes in solar emissions - but the second has specifically been excluded from this challenge.
*In reality, it's all heat coming in and being re-radiated at different rates, so it's always a combination of both...
Fyz
#100
08/19/2007 6:35 PM
From the CRC Handbook of Chemistry and Physics (1982), the ratio of the aphelion to the perihelion of the Earth's orbit is approx. 1.034. If we square this number to obtain relative radiational flux density we get 1.069. The Handbook also gives the relative observed secular braking of Earth's rotation as -2.8 X E-8 per century or a day with a factor of 1.0000028 longer after the 10,000 years. Clearly the rotation of apehelion effect is overwhelmingly dominant.
Always keep that book handy.
#101
In reply to #100
08/20/2007 6:38 AM
No, the rotation of the aphelion is only a small part of the shift (~17%); and because 20 June is currently so near the aphelion, this this would only provide about 7% of the change on its own. It's the time-movement of June 20th (relative to the "fixed stars") that does the main work. (This is due to its correlation with the precession of the Earth's North-South axis)
#104
08/20/2007 9:25 AM
The earth's rotational speed steadily slows and a day is slightly longer.
Ken Haselby
#106
In reply to #104
08/20/2007 9:50 AM
From post #100: "a factor of 1.0000028 longer after the 10,000 years". And the question says 'power' not 'daily energy'.
Sad, isn't it.
Good Answers: 143
#107
08/20/2007 12:58 PM
Nah. Fyz nailed this one.
#108
In reply to #107
08/20/2007 3:33 PM
Hi TPV
Much as I'd love to take the credit, Codemaster was the first to say it had to be distance from the sun (post #2), Guest identified the largest contributor to the change in distance (post #46), and GWJ provided the confirmatory detail (post #54)
Fyz
Good Answers: 137
#109
In reply to #108
08/21/2007 4:06 AM
Thanks Fyz, I must admit that after my post #2 the discussion got so complicated, aphelions, perihelions and so on, I wasn't sure whether it was confirming my suggestion or not!
Codey
#117
In reply to #109
08/22/2007 3:33 PM
I always think it's a mistake to assume that long words mean complicated concepts. However, this is one of those times when I think that maybe it was worth having been forced to study the classical languages at school; then again, how much fun could I have had during that time... (I wouldn't of course, because the law says you must spend a certain number of hours in school - but maybe I'd have learned some physics or Spanish and Russian instead)
#112
08/22/2007 8:06 AM
The earth's orbit is self correcting. We just don't know how that works yet.
#113
In reply to #112
08/22/2007 8:47 AM
"Self-correcting" to what? I hope you know what you mean, because I certainly don't.
#116
08/22/2007 12:48 PM
......how could the answer not be Global Warming? Are you sure?
United States - Member - New Member Engineering Fields - Optical Engineering - New Member Popular Science - Cosmology - Astrometrist Engineering Fields - Engineering Physics - New Member
In reply to #116
08/23/2007 12:49 PM
Global warming affects the temperature at the earth's surface.
The challenge was for a satellite above the earth's atmosphere. This is affected by the solar radiation and how close the earth is to the sun.
Global warming is affected by the above. PLUS the earth's atmosphere insolation. If the earth radiates heat, then it is cool. If greenhouse gasses hold the heat within the earth's atmosphere and near the ground, then the earth is warm.
#120
08/23/2007 9:08 AM
I am afraid I am in TOTAL disagreement with your answers.
1) First of all the perihelion precession, although it is a well known effect WILL NOT change the perihelion distance and therefore the radiated power to an object tracking the earth, as is the case with a geostationary satellite. All that the perihelion precession will do, is to change the azimuthal position of the of the long axis (apsis) of the earth's orbit in space; the shortest distance from the sun (perihelion) and the longest (aphelion) however will remain unaffected.
There is a different phenomenon viz. orbit circularisation and decay, that occur with VERY LONG time constants (millions of years) due to energy losses e.g. impact with dust and meteoroids. These will eventaully cause the earth to come closer to the sun and therefore increase the "solar constant" and hence the solar power density as perceived by the satellite but these are completely different to the quoted event !
2) The second effect quoted is also not going to make any differenc to the solar POWER received at the surface of the satellite. Although the length of the "day" will increase as described and therefore the "Energy per day" will also increase, the question is talking about POWER not ENERGY.
POWER is the ENERGY PER UNIT TIME and will remain constant, as far as this phenomenon (reduction of the anular rotation velocity of the earth) is concerned.
There is one other phenomenon that WILL increase the solar power VERY slowly with time (again counted in millions of years). This is our Sun undergoing the last cycle of its thermonuclear evolution and becoming a "red giant", eventually engulfing the earth and destroying all forms of life (at least as we know it) by "frazzling" it !
I have an an unfair advantage on most of your participants and by the looks of it on your aditor / contributor, since I happen to be a Space Scientist ( a rear breed indeed)
Better lack next time !
In reply to #120
08/23/2007 1:31 PM
1) Your first point is partially correct. However, all of the orbital elements of the earth's orbit are changing. While I was studying for my degree in astrometry, I used the American Ephemeris and Nautical Almanac frequently. It came out every year with the position of the sun, planets, moon, etc. And it had a series expansion for the sidereal orbital elements of the earth (or position of the sun). In my post #57, I refer to a US Naval web site which refers to some of these cycles. They are caused, primarily, by the interaction of the gravity of the sun on the rotating earth and on the earth / moon system.
The key here is the date of June 20 in summer. That is the only day on which the solar power is measured. Today, that date occurs near aphelion. During the 10,000 years, the earth's north pole will precess until summer in the northern hemisphere occurs near the time when the earth is closest to the sun (perihelion).
The advance of perihelion with respect to the fixed stars contributes a smaller part, but also contributes to the earth being closer to the sun on June 20.
2) I agree with your second comment.
#126
In reply to #124
08/23/2007 1:40 PM
How can (should) we co-ordinate our timing?
Fyz
In reply to #126
08/23/2007 1:43 PM
Fyz
Normally I work during the day (Eastern standard time). Today I took off. Most of my comments will be before 8:30 am or after 7:00 pm.
George
#129
In reply to #128
08/23/2007 3:19 PM
I guess it's back to independence and replication, then.
Fyz
In reply to #124
08/23/2007 1:40 PM
When I say I agree with the second part, I mean that power is energy per time. The length of the day should not affect the power.
#125
In reply to #120
08/23/2007 1:37 PM
The first part of the 'official' answer is partially correct - 20th of June is now near Aphelion. Because of the way the long-term calendar is set up, 20 June will approximately track the precession of the orientation of the Earth's axis. That, combined with the (less significant*) precession of the perihelion itself mean that midsummer (and so June 20th) will be near Perihelion in 10,000 years time (I think it will be at perihelion in about 12,000 years). The principle thus becomes equivalent to the difference in solar power incident on the satellite (this year) at 20th June or at 20th December.
* I think the ratio is about 5:1)
The other part of the official answer is of course junk - both in terms of the principle (as you say, day length wouldn't affect power anyway), but also in respect of the number given - it's closer to 0.17 seconds, so even the resultant change in energy/day would be insignificant compared to random variations.
As a space scientist, you doubtless knew all this - in which case I would suggest that your mode of expression is unhelpful to those less fortunate in their background than yourself.
Fyz
#130
08/24/2007 6:50 PM
the orbital precession is a valid reason for added heat gain and the I will concede that 50 seconds longer days will also contribute. 50 seconds a day equates to almost 6 hours in a year. Therefore a year is very nearly 365 days not the current 365 + 6 hours which gives us leap year once every 4 years.
This factor must also be accounted for and may make this brainteaser more difficult, in 10,000 years and lengthening days without changing "Leap Year" from every 4 to 5 and then 6 etc. year increments, the calender dates will precess forward in the yearly seasons. In 5,000 years the leap year should occur at 12 year increments, without this change included over the 10,000 years Jun 20th will have become mid fall to winter, spring and back to summer a number of times.
#131
In reply to #130
08/26/2007 5:52 AM
Where on earth do you get 50 seconds from? The expected value is about 0.17. Averaging over a year seems strange - precession will not affect that average.
3Doug (3); Achurchill3 (2); agua_doc (1); andrew pate (1); Anonymous Poster (37); Codemaster (4); cuznmonkey (4); English Rose (3); Gil Fernandez (1); GWarburton (1); GWJ (9); jimbu (1); jimpithecus (1); Jorrie (1); Odessey2001 (5); Physicist (5); Physicist? (31); PWSlack (5); resubmit1 (2); RickLee (3); Ron H (1); silvCrow (1); TVP45 (2); Uncle Red (1); user-deleted-1105 (3); Vasilios (1); yellowcat (1)
