Previous in Blog: Measuring Solar Power: Newsletter Challenge (08/14/07)   Next in Blog: Electric Field: Newsletter Challenge (08/28/07)
Page 3 of 4: « First < Prev 1 2 3 4 Next > Last »
Pyramids: Newsletter Challenge (08/21/07)
Posted August 19, 2007 5:01 PM
User-tagged by 1 user
The question as it appears in the 08/21 edition of Specs & Techs from GlobalSpec:
We have records that the volume of a pyramid was known by about 1800 BC. Wikipedia speculates that some form of early calculus-type of system was used. But the volume of a rectangular-based pyramid can readily be calculated without calculus. How?
(Update: August 28, 8:30 AM) And the Answer is...
Take two pyramids, one with base 'w' x 'd' and height 'h', the other with all dimensions doubled. The double-size pyramid consists of one of the original pyramids, plus a rectangular block w x d x h, plus four prisms whose joint volume is the same as the volume of the rectangular block, plus four corner pieces that add up to one single-height pyramid. So we can write:
8.Volume = Volume + block + prisms + (bits-of-pyramid) = 2.Volume + 2.w.d.h
Solving this gives: Volume = w.d.h/3.
Note 1: that the top does not actually have to be perpendicularly above a point on the base, because the missing bits can be handled in the same way; and
Note 2: that people of that time could have extended the concept to non-rectangular bases, as they already understood the concept of average areas.
#157
In reply to #155
Find in discussion
Re: Pyramids: Newsletter Challenge (08/21/07)
08/24/2007 5:03 AM
Hi Randall
That is unusual for you in that I couldn't follow it. The following is my misunderstanding of what you wrote:
I assume that when you write "equilateral top triangles" you mean "congruent....". But the only way I can see to create two tetrahedra from a square-ended pyramid is if we cut the pyramid along a diagonal of the rectangular face - and the two halves only have equal volumes if the apex is perpendicularly disposed to the centre of the rectangular face; as I understand you have already defined the apex to be perpendicularly disposed to one corner of the rectangular face, that is not possible.
An additional difficulty will be proving that each of these halves has the same volume as the cheese-pared tetrahedron that never formed a part of the pyramid.
Fyz
In reply to #157
08/24/2007 6:34 AM
You're right I meant congruent not equilateral.
Have you realised that I'm only dealing with a quarter of the design: the same arguments need to be applied to all four corners. If the apex had been above the centre of the base then the four corners would have been identical: just thought I'd try to kill two birds with one stone.
The apex is vertically above the "inner" corner of the cuboid I have chosen, so the slicing of the two parts of the pyramid is along the diagonal from this inner corner to the near right corner of the pyramid, and, of course the sloping edge/"corner" of the pyramid runs within this slicing plane.
#160
In reply to #159
08/24/2007 6:50 AM
Yes, I realise it's one section (only a quarter if the pyramid is symmetrical) - hence the apex being vertically above one of the corners. You can cut the pyramid using either diagonal of the corner. I've assumed the cut goes through the orthogonal edge. Only the triangles in the base and on the shared cut are necessarily congruent - the other sloping sides are not. So these are not identical tetrahedra - they only have identical bases and heights. To know the volumes are equal you either have to assume that sliding the top around at the same height leaves the volume unchanged (this relies on a concept of adding zero-thickness slices - primitive intuitive calculus), or to rely on Euclid's calculus-based proof.
Have I missed something here?
Fyz
In reply to #160
08/24/2007 10:16 AM
The whole point is that although the two tetrahedrons are very different shapes, any horizontal slice through them both reveals two congruent triangles: A & B. This is a projection from above.
Add all the congruent triangles up and the two solids must be the same volume. I know this is an infinite sum (calculus like), but, I think it would make sense to: say a pyramid designer.
#169
In reply to #166
08/24/2007 11:53 AM
I think you are right the pyramid designer would understand it instantly - like many great ideas, the infinitesimal basics for calculus are obvious - but only in retrospect. However, it possibly wasn't known, which is why the problem was couched as "without calculus (with related methods like this being implied)"
Fyz
#171
08/24/2007 12:14 PM
I was thinking that all my drawing and disecting of pyramids might be wrong way to go about this.
Firstly I thought make a pyramid ( scale model ofcourse ) drop it in to a full container of liquid what spills out is the volume of the pyramid ( you could make several to check accuracy )
Then I was thinking why not just take a block of dimensions Length x Bridth x Height pick a spot on top for an apex and cut away the four slopes.
Weigh the block before and after cutting ( again several may be done to check accuracy )
Then use the proportion to calculate the full scale pyramid.
#173
In reply to #171
08/24/2007 12:21 PM
See # 172. Once you've accepted the scaling assumption, dissection and simple calculations are all you need to develop the general case.
Fyz
#172
Pyramids: a clue (or perhaps my particular cheat?)
08/24/2007 12:17 PM
The technique I used relies on scaling: i.e. the relationship between the volumes of similar* shapes. I'm pretty sure it would have been unproved at the time, except for specific shapes such as parallelepipeds and prisms. But the question said "calculate", and I believe the idea would have been available for that purpose.
Fyz
*= shapes between which all equivalent linear dimensions are scaled by the same multiple, and all equivalent angles are the same
N.B. that my objection to the methods that used a scaled model and measured the liquid displacement was a combination of it being primarily measurement, of applying only to the specific shape of pyramid for which the model was made. (I wasn't too happy that the reference period was about 1500 years before Archimedes either). Had I been worried about the scaling I would have mentioned that too.
#230
In reply to #172
Pyramids: a very strong clue
08/26/2007 9:36 AM
I already suggested we use scaling of "similar" figures, where all corresponding angles between the similar figures are equal and all corresponding lengths are in a fixed proportion. Also that you only need this to work with a factor of two (or any single fixed non-unity factor, for that matter).
Now, about that frustum?
08/24/2007 1:26 PM
Can I just point out the irony of nobody using the somewhat hackneyed phrase " out of the box thinking" yet.
Oops. Just did.
Good Answers: 247
#188
08/24/2007 3:14 PM
How about proof by analogy?
We know rcapper's solution is correct for rectangular pyramids, in which the apex is above the center.
So, we take a vertical plane, and use it to cut through one sloping wall of the pyramid, so that the edge of the cut is a trapezoid. Now we skew the pyramid to the right and note that the trapezoid has skewed, but not changed in area: it still has the same a major and minor sides and same height. (We also know that the volume of the skewed box that would contain this pyramid remains the same after skewing.)
So, just as we know it is sufficient to describe the infinite points along a line with just the end points, we also know that an infinite number of such sections could be cut into the prism. We know that, at each one, the same effect will be observed, namely that skewing these trapezoids does not change their area. Therefore, just as the same formula applies to a cube or a rhomboid, the same formula applies to a pyramid or a skewed pyramid.
I think it is reasonable to assume that the Egyptians knew there were an infinite number of points along a line, and similarly an infinite number of planes across a solid.
#190
In reply to #188
08/24/2007 3:29 PM
I think the intended solution is simpler. See post #172 for a starting point?
Fyz (and you have to catch me before you can burn me)
08/24/2007 5:21 PM
By George, I think I've got it. No fooling!
The solution requires taking ANY rectangular based pyramid with base of L and W and height of H, put it in a box of L, W, and H, then construct a mirror image box and pyramid on top, apex to apex. Now you can take the ends of the new double box rectangular prism and write a general formula for pyramids, Vp= n x L x W x H, where n is the unknown factor (we all know it is 1/3 of course). Now if you add the 6 volumes they must add up to the double box, Vb = 2 x L x W x H.
I did this and solving for n gave me 1/3.
I will have to send the rest of the proof later because I have to get home!
#194
In reply to #192
08/24/2007 5:35 PM
Hey STL,
I think you have it, but don't you have to use complementary pyramids? I like the wirror plane part. Clever
Tom
Good Answers: 22
#195
08/24/2007 6:12 PM
Here's my high-tech attempt to replicate a low-tech method for finding the volume of a pyramid.
Let's say the Egyptians wanted to know the volume of a pyramid before they built one to full scale and they decided to create a formula using a cubical block and experimenting. Now let's take a cubic block that is 10 units x 10 units x 10 units. The block will look like this:
We know the cube has a volume of 1000 cubic units.
Now draw a line across the top surface from the midpoint of the front surface to the midpoint of the back surface. Draw lines from this bisector line to the bottom corners of the front and back surfaces where thy meet the right profile surface. Remove material from the block in the area outlined by these lines. The block now looks like this:
Now, what is the volume of the block?
Note that the top surface has lost half of its area, but the bottom retains its full area. So the lost volume must be somewhere less than half than original.
Also note that the front and back surfaces lost area. The edges of the slanted surface are diagonals that bisect rectangles formed by the front and back surfaces and the bisector line on the top. Because a diagonal divides a rectangle into halves, we see that the front and back surfaces lost one fourth of their areas. If a rectangular block is split along a diagonal, it loses half of its volume. We can think of a cube as two rectangular blocks joined at their largest faces. So, this block now represents one and a half rectangular blocks, or three fourths the volume of a cube. We tell our trusty Egyptian scribe to record the formula in the current form as V = LWH – LWH/4.
Now we draw diagonal lines from the first bisector to the bottom corners of the front and back surfaces at the left profile, and again remove the material within the outline. The result is a prism:
Because we have removed the same amount of material as we did in the first step, we tell the scribe to adjust the formula thusly: V = LWH – LWH/4 – LWH/4 = LWH – LWH/2 = LWH/2.
Now we draw diagonal lines from the midpoint of the top edge to the bottom corners of the back surface, and again remove material within the outline to this shape:
We have a similar situation to the first time we removed material. We have removed part of one half of the prism, but it is not one half of that one half. What is the relationship we need to find the volume of this item?
What I believe is that volume is directly proportional to surface area. I have not confirmed this yet, as I need to run some numbers. I will post my findings later.
And yes, I did finish my pyramid. I just haven't finished my math yet.
#196
In reply to #195
08/24/2007 8:16 PM
Using the hint, it looks easy if we can make the leap that V=λabh where λ is some constant number. This is what makes STL's solution (and others, of course, earlier on) so attractive in that it uses boxes whose volume are known to be of the form abh. Is there another way around this? I know we can can take corners of a cube and show the abh/3 form there, but how do I say it applies to all pyramids?
In reply to #196
08/24/2007 11:24 PM
I will show you how my method will apply to ANY rectangular based pyramid, because I will do it without using a cube! I will use a rectangular prism, so the solution is more general.
However, I think I will start with a clean sheet! Look for my next post with the proof.
In reply to #199
08/25/2007 12:29 AM
I think we should all be posting mention of our proofs in a margin.
Good Answers: 247
#210
In reply to #199
08/25/2007 4:13 PM
But only somewhat more general. Fyz's proof will also pertain to pyramids in which the apex is not over the center of the base.
Also, not to oversell Fyz's proof in any way... but it is said that his proof will turn atheists into believers and believers into atheists.
In reply to #210
08/26/2007 2:23 AM
Uhhh.....Ken? Have you looked at my solution in post #205? After all, your quote above is from your post #210. My solution IS totally general. It does cover the general case where the apex may be anywhere over the center of the base.
Geez, I thought I had done it and found a solution that followed all the rules, but I am being ignored, or worse, trivialized! And people are still submitting "solutions" based on the use of a cube instead of a general rectangular prism or worse, fluid or semi-fluid, or even weight analysis. How can fluid or weight measurements be considered a "calculation" solution? Even if calculations are used subsequently to "scale up", it is still based on a measurement other than the Length, Width, and Height of the pyramid!
How about it Fyz? Do you see anything wrong with my solution? It is totally calculation oriented and uses no calculus, only basic algebra and geometry. Heck, I did not even have to use trig! And has anyone presented this complete solution with proof before me? If so, I will be the first to congratulate them, but I have not seen it.
Surely my solution and proof is not hard to follow (unlike some others I have seen), since it uses only basic algebra!
Do I REALLY need to draw you guys a picture?
Good Answers: 247
#236
In reply to #214
08/26/2007 2:26 PM
STL, you wretched moronic nitwit!! I'm kidding, of course, and understand that when you wrote this it was late at night. I think you did not absorb what I wrote, namely: But only somewhat more general. Fyz's proof will also pertain to pyramids in which the apex is not not not not over the center of the base. I hope that you can see that your response to that, namely "My solution IS totally general. It does cover the general case where the apex may be anywhere >>> over the center <<< of the base," strikes me as nonsensical . The more general case is where the apex is, to repeat, NOT over the center of the base.
For example:
As I hope you can see, a rectangular prism which has the same base as the pyramid does not fully contain such a pyramid. So your proof fails from nearly the first statement. I don't think anyone has trivialized your "proof" ... perhaps they are politely ignoring it (letting you feel smug in your knowledge that you have proven something) given that long ago Fyz stated that his proof would cover both right pyramids and oblique pyramids, as well as pyramids with non-regular bases.
Rcapper's proof pertaining to pyramids which fit into a cube clearly, simply, and elegantly proves the formula for the special case of pyramids that fit into a cube in the stated way. Your proof adds little to that: your are still dealing only with right pyramids, but your proof takes up far more space.
As far as others posting possible proofs that rely on measurements, etc... Isn't it unreasonable to expect people to thoroughly read all 200 plus posts here? It is also reasonable to assume that in 1800 BC proof methods might be quite different than they are now. It is very likely that Egyptians simply arrived at the formula empirically (a view which some historians hold) and that formal proofs were of no use to them. They would no more "prove" (in the Euclidean sense) that their formula is correct than we would "prove" (in the Euclidean sense) that F=MA. So any post that proposes a method the Egyptians might have used seems like a valid contribution. We can only gain from such posts -- one can certainly choose to ignore them, but there may be some interesting insight in them. I especially liked the post from the writer of the upcoming book: It can make one wonder about the difference between weighing in the conventional sense and the balancing of equal weights. The latter intuitively proves scalability, but the former does not.
In reply to #236
08/27/2007 12:50 PM
First of all, let's not change the rules in the middle of the game. Fyz stated that it must include the case where the apex does not lie directly over the center of the base. Fine. My solution does that. Now you want to ADD that it must include cases where the apex does not lie over the base AT ALL! Now who is doing things the Egyptians would never have considered? ("Hey Pharaoh, that new pyramid is looking a bit lopsided, don't you think? Aren't you afraid it might fall over?")
Also, as pointed out, using the cube to find the answer requires you to ASSUME that the factor is universal and extends beyond the simple cube example, whereas my solution does not use the cube, but actually includes positioning the apex ANYWHERE over the base. And it PROVES that the solution is universal, not ASSUMES it. If you want to use the term "oblique pyramid", fine. I believe you will find the definition does NOT put the apex outside of the base, just that it cannot be over the CENTER of the base, which is exactly how Fyz stated it in #22, so why are you pushing this "outside the base requirement"?
Finally, when I read the challenge, the question of Egyptians was to state that calculus was not needed, as the Egyptians did not have calculus and the question was simply stated as:
So once again, I ask, how does my solution NOT meet the challenge as stated in the original question, even including Fyz additional requirement, or clarification, in #22? It may not be what Fyz has in mind, but it certainly solves the challenge.
Good Answers: 22
#266
In reply to #195
08/27/2007 6:37 PM
Well, I finished my math, and did not find any direct porportionality between area and volume, at least to say that if a solid loses a given amount of surface area it will lose the same porportion of volume. That relationship may be true when the loss does not create a surface with a different angle than before. I still have more ruminating to do on this.
#270
In reply to #266
08/28/2007 4:05 AM
IF you mean what I think you mean, you won't find one. For example: if you remove material from all surfaces in a way that allows the solid to remain the same shape, the relationship is V = k.A1.5
(Where k is a proportionality constant that depends on the specific shape.)
Fyz
08/25/2007 1:10 AM
Ok, Tom (Guest #194). I don't know if this includes the "complementary pyramids" you mentioned, but, as I promised in #192 earlier here goes:
First construct a rectangular pyramid with a base of length L and width W and a height of H. Then construct a box (rectangular prism) which encloses the pyramid, with the same dimensions, L, H, and W.
Next construct a mirror image box and pyramid above and touching (at the mirror plane) the first two, corners to corners (of the boxes) and apex to apex (of the pyramids). Now you have a new, double box of dimensions L, W, and 2H containing both pyramids. You will notice that the faces of the new double box are now each a base for new rectangular pyramids, all of which meet at the same apex on the mirror plane. We will describe the volume of each pyramid by a general formula, VP = n H L W, leaving out the multiplication signs for brevity. The universal constant, n, is to be found.
If the apex is located at any point on the mirror plane such that it divides the length, L, and width, W, into two shorter lines, L1, L2 and W1, W2, such that L= L1 + L2 and W = W1 + W2, these shorter lines will be the heights of the other four pyramids.
Now we can easily see that the volume of the double box, VB = 2H W L, as each single box has a volume of V = H W L. The double box exactly contains all six pyramids, so that:
VB = V1 + V2 + V3 + V4 + V5 + V6 and the pyramids' volumes are:
V1 = V2 = n H W L
V3 = n 2H W L1
V4 = n 2H W L2
V5 = n 2H L W1
V6 = n 2H L W2
Substituting these volume formulas in the summation equation above we get:
2H W L = (n H W L + n H W L) + n 2H W L1 + n 2H W L2 + n 2H L W1 + n 2H L W2
Simplifying:
2H W L = 2Hn (WL + WL1 + WL2 + LW1 + LW2)
Then, WL = n (WL + WL1 + WL2 + LW1 + LW2) and
1/n = WL/WL + (WL1 + WL2)/WL + (LW1 + LW2)/WL and
1/n = 1 + (L1 + L2)/L + (W1 + W2)/W = 1 + L/L + W/W = 1+ 1 + 1 = 3
So, if 1/n = 3 then n = 1/3 and the universal formula is VP = 1/3 H L W.
Q.E.D. !!!!!
Is this what you had in mind, Fyz?
In reply to #205
08/25/2007 1:38 AM
I had to read that a couple of times, but it looks good. Is the assumption of a 'universal constant' valid though ? I think it probably is, but I have a nagging feeling that Fyz has sometjing very elegant lined up, that can probably be expressed in just a few lines. I can visualize what you mean in my head, but it would be nice (if you have time) to see one of your cool drawings just to re-inforce the description. In essence, I think the idea was mentioned before though I'd have to trawl through this thread to find where.
In reply to #206
08/26/2007 3:50 AM
"I can visualize what you mean in my head, but it would be nice (if you have time) to see one of your cool drawings just to re-inforce the description."
Well, I don't have any CAD at home, so here's the best I could do with MS Paint.
Numbers 1 through 6 show the enclosed pyramids and Box 1 and Box 2 are the stacked rectangular prisms that enclose them. L, W, and H are Length, Width, and Height.
Oh, although some of the pyramids may look like square based pyramids, as H+H looks very close to W, it isn't necessarily so. Imagine H as very large or very small and it makes no difference.
In reply to #218
08/26/2007 5:07 AM
Nice drawing STL. I really must stop being so lazy, and investigate drawing stuff properly. The pictures fit what I imagined from your description earlier.
In reply to #205
08/26/2007 5:02 AM
Back here, I was implying the same thing. I didn't bother with drawings or numbers because visualizing a box sliced through edge-to-edge is not rocket science. You get 3 pairs of pyramids.
a.b.c.1/2.f .2 + b.c.a.1/2.f.2 + c.a.b.1/2.f.2 = Vbox = a.b.c
3.a.b.c.f = a.b.c
f = 1/3
If the apex of a pyramid is not over the base, then you can cover the case by considering that each of it's quarters forms 1/4 of a rectangular based pyramid*. The leap-of-faith is that pyramid volume is a constant fraction of base area x height.
Being able to construct a square pyramid from 8 smaller square-based ones would be nice, but I got stuck with that bit. Now, by the beauty of KAD™ ;
The above horror is a square based pyramid that has been sliced in 2. The objective is to see what will fill the gap between the adjacent half pyramid sides. If your sides have not yet spilt, consider this. You move upwards from the point where the two pieces touch. The average area to traverse/fill the gap can be used, since one dimension increases in direct proportion to the other decreasing. The missing volume is thus half of one of those half pyramids.
If you buy this, them let me proceed. Position 4 square based pyramids adjacent to each other. Fill the voids between adjacent pyramids using 8 of those 1/4 pyramids. We've now used 6 pyramids. Drop 1 more inverted pyramid into the gap in the centre, and cap it all with 1 more. We now have a new pyramid, twice the height of whatever square based pyramid we started with.
* eccentric pyramids, in which the apex lies outside the base, excepted.
Shameless as I am, I shall hide this post and run. Beware, I use Etch-a-Sketch as well.
#238
In reply to #219
08/26/2007 3:07 PM
If I understood how to "Fill the voids between adjacent pyramids using 8 of those 1/4 pyramids", I'd be right with you. I really can't see how they fit. That doesn't necessarily mean it can't be done - just that I can't see it.
Fyz
#222
In reply to #205
08/26/2007 5:31 AM
Not what I had in mind. Once you assume a universal constant, you only require a single case. So you only need the six pyramids in the perfect cube that was proved very early on. If you think about it, the universal constant assumption already implies both morphing and linear effects of linear stretching....
The proposed method only requires scaling of identical shapes (an admittedly unjustified assumption, but it's a calculation, not a proof, and this is the smallest I know to make), plus cutting-and-reassembly, knowing the volumes of prisms (itself easily proved by cutting-and-eassembly), and arithmetic.
In reply to #222
08/26/2007 6:47 AM
If one started with a cube formed from 6 identically shape pyramids, it could be compressed across 2 of it's major axis. If the initially parts are differently coloured and plastic, the whole thing would end up resembling a box as illustrated by STL. This is just a thought-thing, since frictional platen effect would mess the experiment up. The question in my mind is would Egyptians playing in the mud have tested a numerical hypothesis, or sliced shapes to reach their conclusions.
In reply to #222
08/26/2007 8:52 PM
"Not what I had in mind. Once you assume a universal constant, you only require a single case."
Granted, it may not be what you had in mind, but doesn't it correctly address all the particulars in your challenge? And, I did not ASSUME a universal constant, I proposed it, then proved it by creating formulae that covered the general case for a rectangular pyramid, and solved for the constant. How does that NOT solve the challenge?
If you assume a universal constant, you have proved nothing. Solving for a specific case using the cube only proves that it works for that example, not for all. I don't see how solving for algebraic equations that are the parameters of the general case can be considered "morphing" or "linear stretching". Maybe I just don't understand how you are using those terms.
Good Answers: 247
#248
In reply to #245
08/26/2007 11:32 PM
I don't see how solving for algebraic equations that are the parameters of the general case ...
... if only it were the general case. The general case is an oblique pyramid. Your "coffee creamer" is a tetrahedron, which is also an example of an oblique triangular pyramid.
Back in post 22, Fyz wrote:
The challenge is to find a way that works for any rectangular-based pyramid, regardless of relative height or whether the apex is over the centre of the base.
In reply to #248
08/27/2007 12:25 PM
Whoa, there! You are confusing my earlier attempt with my final solution, which has nothing to do with "creamers" and everything to do with the apex being anywhere, not just over the center of the rectangle. Don't you see that? My solution does meet the requirements he posted in #22.
Good Answers: 143
#254
In reply to #252
08/27/2007 12:29 PM
And this is a good place to point out that I am the numbskull who screws up terminology. Now that I understand what an oblique pyramid is, what do you call one where the apex is not above the base at all? That's the one I was busy worrying about.
Tom
In reply to #254
08/27/2007 1:05 PM
Tom,
As Blink correctly pointed out, that case where the apex is not above the base at all is also an oblique pyramid, but it is usually not considered. Such a structure would be cantilevered and not necessarily self-supporting if it were constructed with uncemented blocks. At some point, and I am sure it depends on many factors, including block size, weight, perhaps even friction (as the blocks may have to slip somewhat before falling off) if the apex were far enough outside of the base the upper portion of the pyramid would topple over.
I remain unconvinced that the challenge, as stated by Fyz, must include such hyper-oblique pyramids.
Good Answers: 247
#257
In reply to #252
08/27/2007 2:27 PM
Actually I wasn't jumping back to your earlier attempt to suggest that your current attempt relied on coffee creamers. I was just using your catchy terminology to elucidate what I meant by an "oblique pyramid".
Your current attempt (post 205) seems problematic in the following ways:
It starts by saying to construct a rectangular pyramid. So far so good. Here's my pyramid:
Next, you say: "Then construct a box (rectangular prism) which encloses the pyramid, with the same dimensions, L, H, and W." At this point I'm stuck, because I can find no rectangular prism that both encloses my pyramid, and has the same dimensions, L, H, and W. Can you?
If I could get past that, then I could move on to where you claim there is a universal constant that pertains to all the pyramids in your construction (and presumably to all pyramids in the real world). You appear to be starting out with that which is to be proved: namely that there is a universal constant. The math would work out the same, if there were actually six different constants, n,o,p,q,r, and s with their average being 1/3. How do you counter the argument of someone who says "A highly oblique pyramid looks very skinny; therefore it must have a different constant, maybe .25. In your construction, the fatter looking pyramids have a larger constant... maybe .4. Cones, being round, must therefore have another constant." I can't see that the math proves that n (and only n) applies to each of your 6 pyramids -- you seem to be assuming that.
I'm probably being obtuse.
In reply to #257
08/27/2007 4:28 PM
Look, we could argue all day about whether or not your extremely oblique (apex not over base at all) pyramid should be included in the challenge. I will admit that it would not work for those. My point is that this does solve the challenge for all ordinary rectangular pyramids that might normally be constructed. In all the examples which I have researched on web that attempt to teach the mathematics and geometry of pyramids, you almost NEVER see your example given.
But to say that my methodology is wrong because I am starting out with that which is to be proved, then finding the proof by solving for a single number mathematically is incorrect,...well I just don't understand your thinking. When I went to school we were taught not just, "here is the theorem, learn it and use it", but also, "here is the proof of that theorem". So I approached the problem in that way.
The hypothesis is that there could be a single universal constant that fits all cases of the normal (non-extreme) rectangular pyramid. Formulas were developed for the general case where six pyramids just fit inside a box, using the same three variables. This allows us to also add the formula for the sum of those values and set it equal to the volume of the box. If these equations are solvable for the constant, then any other pyramid that uses those same variables can be solved by the same equation, because none of them are a distinct and limited case, like the regular pyramid would be. These equations in fact conform to the parameters where the apex may lie anywhere over the base.
I then proceeded to mathematically prove that my constant, n, was equal to a single real rational number. Where did I throw out any possibilities that n could be any other number? I did not assume that. It worked out by itself. If there were any other numbers possible, then the answer would have been some polynomial or other formula and not a single constant.
I am still waiting for Fyz to comment on the viability of my solution. It may not be the same as his, after all, there can be many ways to skin a cat (ooh, sorry, Del! ), but that does not mean it is wrong.
I am still looking forward to see what Fyz had in mind tomorrow!
#262
In reply to #261
08/27/2007 4:39 PM
Hi STL - all that is irrelevant. An overhanging pyramid can be created by subtraction of suitably formed pyramids with a vertical right corner if need be.
The real problem is that, so far as I can tell, your "proof" would only work for the original square-base half-height pyramid (six per cube). The reason is that otherwise you have (at best) three different pyramids duplicated in reflected pairs, and the only way to equate their volumes is to assume that it doesn't matter which dimensions make the base and which is the height - which is effectively assuming the universal formula. And, if the original pyramid does not have its apex above the centre of the rectangle, the volumes of at least one of the opposing pairs will in general* be different - see my post #260.
If I've misunderstood what you have done, please provide more explanation.
Fyz
*There are some special cases where they are the same, but they are not particularly interesting for this purpose.
In reply to #262
08/27/2007 5:07 PM
"The reason is that otherwise you have (at best) three different pyramids duplicated in reflected pairs"
NO,NO,NO. If in my diagram the apex were very near the left side, for example, or even on the edge, the opposing pyramids would not be reflected pairs. They would hardly be equal in size, one could even be zero in volume! Only the top and bottom would be equal in size. The other four pyramids do NOT have to be half-height for this to work. The mirror box was constructed simply to make the identification of the other general pyramids simple, and to simplify the math needed to solve for n. Since I can find the same n for non-half-height pyramids as well as for half-height pyramids, it must be a general case. The cube solution does not do that.
Maybe you are confused because I used L1 or L2 and W1 and W2 for the height of those other four pyramids, but I could just have easily used other variables, z, y, x, w, v, u, t, s, or r! (since a through q are normally used for constants). I thought it would simplify the thought processes needed to visualize the geometry, but maybe I was wrong.
#260
In reply to #245
08/27/2007 4:19 PM
Hi STL
I must be misunderstanding what you have done.
What I see is a pyramid whose apex is off-centre reflected about a plane through the apex that is parallel with the base. This creates a second pyramid and a frame for a rectangular parallelepiped. Within that frame you have six pyramids. But the volumes of these pyramids aren't equal; for example the apex could be directly above one of the edges, in which case (at least) one of the pyramids has zero volume.
Please clarify.
Fyz
In reply to #260
08/27/2007 4:53 PM
Yes, Fyz, exactly right. That pyramid would have zero volume, since its height (above its base) would be zero, but the other five pyramids would still add up to the volume of the "double box" which exactly contains them. Put the apex at a corner of the base rectangle, with two pyramids of zero volume. It still works. That is the beauty of solving this problem algebraically using variables, all cases are covered by the general formulas. That is why I split the Length, L, into L1 and L2, and the width, W, into W1 and W2, which would represent the choice of any point over the base of the first pyramid. The formulas (formulae?) for all the pyramids were then put in terms of these variables.
Now, do you see any error in my logic or algebra?
#265
In reply to #263
08/27/2007 5:41 PM
I had assumed I had communicated what I take to be the fallacy, which was why I was assuming the drawing was being misinterpreted. Either I hadn't communicated the fallacy, or you disagree, or I'm still missing something.
What I am saying is that you are assuming that a single formula exists that connects the base area and the heights of the pyramids in your drawing. In fact, you are assuming more than that, - you are assuming it uses the product of the base area and the height to the apex in a direction orthogonal* to the base and a fixed constant will give the correct volume. Without assuming such a formula, I don't see how you are calculating the relationships between the volumes that make up the rectangular parallelepiped.
If you do assume such a formula, I can't see why you can't simply apply it to any pyramid to find the constant. In which case so you could base it on the pyramid-in-a-cube (sounds like a formulaic restaurant chain) without going to the trouble of making this construction.
What am I missing?
Fyz
*To put a rather ridiculous counter-example, how do we know in advance, for example, that the formula should use the base area times the orthogonal height, rather than the average area of two opposing faces multiplied by their internal orthogonal separation nearest the base? Or that the constant is not a shape-dependent variable, or...
In reply to #265
08/28/2007 12:39 AM
"To put a rather ridiculous counter-example, how do we know in advance, for example, that the formula should use the base area times the orthogonal height, rather than the average area of two opposing faces multiplied by their internal orthogonal separation nearest the base? Or that the constant is not a shape-dependent variable, or..."
Because this is a theorem, a proposition. A theorem, like a theory, does not need to be known for certainty in advance. It can be educated guesswork. But then you must prove the theory or theorem, by using either formulas which represent a general case, or by a multitude of examples such that the preponderance of evidence leads to the conclusion that there is a high degree of probability that the theory is correct, or a combination of these. I believe that I showed mathematically by giving a general case as well as specific cases as formulas which allowed me to solve for the constant, finding not a polynomial or multiple solutions, but a single, rational number, 1/3.
Any more than that I cannot say without a risk of repeating myself, over and over again for the umpteenth time, just as you are, so one of us, or both is missing something! IF I saw how I made a mistake, I would admit it, but I just don't see it!
#272
In reply to #269
08/28/2007 4:26 AM
Perhaps I was being a bit hard. As I understand it, what you have done is to show that the proposition does not lead to inconsistencies for this type of assemblage*. So it lends support to the proposed solution. Coupled with measurements on volumes of various pyramids, this would indeed be enough to support the use of this formula as a physical model - just as we used "Newton's laws of motion" in their original form until problems were observed at very high velocities. But that is not the same as proof. (Nor, to be fair, is mine - unless you accept the additional assumption I stated. But the assumption is much less stringent than requiring that a formula exists for the generalised shape)
Hopefully, we can agree on that?
Fyz
*I'm not certain that the Egyptians would have had the algebraic tools to do what you've done - but that's fair enough, as it was not an explicit requirement of the question.
#207
08/25/2007 11:45 AM
Here is a simple tabletop demonstration to "prove" that the volume of a pyramid is 1/3 time the base times the height.
Equipment and materials:
two 5lb blocks of cheese (usually square and long like bar stock)
a long knife
and a beam balance scale.
Nice flat table top
Proceedure:
Lay a block of cheese down on the table with the square end facing you and the long side running away.
Make one cut perpendicular to the table, corner to corner the long way of the cheese. Now turn each piece a quarter of a turn to the left or right. This should lay each half "on its back". Now make another perpendicular cut on each half.
This leaves you with two pieces that are quarters of the pyramid and two pieces of "waste". If you do the same to the other block of cheese you will have four quarters that make a full pyramid and four pieces of "waste".
Now for the magic: Two pieces of waste weigh the same as one quarter of the pyramid. You can check this with your balance. Thus 10 pounds of cheese produced the equivalant of 6 equal parts (or each 5 lb block produced 3 equal parts.)
Thus the pyramid itself weighs four sixths (two thirds) of 10 pounds or 6.6666 lbs. And the volume equal to the base times the height would weight 20 pounds. Thus the volume of the pyramid is one third the base times the height. QED
It is likely that brick mud was the first material used for this sort of demonstration. Bricks were the primary building material of Mesopotamia prior to Egypts use of limestone. It is likely that the origin of this "formula" as implied in a problem in the Rhind Papyrus (see Gillings) circa 1800BC was Mesopotamia. There are artifacts that consist of turned alibaster vases found in the palace at Ebla that date to the early dynastic period of Egypt. This is evidence of trade and contact in the 3000BC to 2500 BC time frame, before the pyramid builders began on the Giza Plateau.
Contrary to popular belief, the Egyptians were very exacting mathematicians. The so called "Recto Table" of the Rhind Papyrus is exact when breaking fraction of numerator two into the sum of unit fractions (numerator one).
Look for my forthcoming book for other facinating stories / discoveries in "Mathematics Before the Greeks"
In reply to #207
08/25/2007 2:20 PM
Is the book a re-print ?
#209
In reply to #208
08/25/2007 4:00 PM
No. A manuscript that I've been working on a long time.
In reply to #209
08/26/2007 3:20 AM
When it all get's finalized, you could give it a plug in the 'Biography' section of your profile. Books that cover the origin of maths, and put it in a more tangible context, are always interesting to read.
Good Answers: 247
#211
In reply to #207
08/25/2007 4:51 PM
It would be interesting to first cut off the ends of the two pieces of cheese obliquely to form two parallelepipeds, and start the demonstration from there. Would the pyramid quarters formed then actually fit together? Would it be possible to generalize the demo from right pyramid to oblique pyramid?
When you publish, do let us know -- I'm sure you'll find some readers here.
Good Answers: 143
#212
In reply to #211
08/25/2007 6:44 PM
Ken,
If you can show the right pyramids to be OK (and that clearly depends on that universal constant), then i think it is easy to generalize to obliques.
In the Rhind papyrus, they use subtraction, so that is understood at least in part. They have no zero, so this may be a little shaky.
In the Moscow papyrus, they clearly add volumes.
So, with a small/tiny/miniscule leap of faith, we might assert that they knew you could subtract volumes. And, to some extent, problem 14 in the Moscow papyrus does lend itself to a subtraction of volumes.
If you know you can subtract volumes, then any right pyramid can be turned into an oblique pyramid by subtracting another, smaller, right pyramid, or even two if you want to make it doubly oblique (BTW, Egyptians had no need of oblique pyramids since stone work does not lend itself well to such structures). If the universal constant is OK, both right pyramids can be well described in terms of one of the aforementioned boxes, either of which has a well-defined volume.
As always, the applicability of 1/3 to ALL pyramids is the possible weak point and I suspect Fyz has an answer based on proportions. The figure in problem 14 suggests an awareness of proportion and I think they were aware of Pytagorean techniques.
We'll see. Hopefully, I didn't get the papyri mixed up.
Tom
#213
In reply to #212
08/25/2007 7:47 PM
Going back to the square base pyramid with central apex being half the height above the base as the sides are long.
Knowing that six of these fit into a cube the base being each surface. Which proves by simply observation the formula for this pyramid as being L x B x 2H / 6 or
L x B x H / 3.
Take two of these pyramids.
Divide one by 4 through the apex horizontally & vertically you are left with 4 pieces a quarter of the base size and volume. (4 sided base)
Take the second pyramid and divide this one diagonally through the apex leaving 4 pieces a quarter of the base size and volume. (3 sided base)
All eight of these pieces are still covered by the above equation but now two things have happened.
Firstly the apex is no longer centred and secondly the shape of the base does not matter.
This could be further explain by a front or/and elevation of the pyramid when positioning the of apex along a line parallel to the base the area seen does not change on the front, end or plan views & if the areas haven't change surely the volume remains the same?
In reply to #213
08/26/2007 2:33 AM
"Going back to the square base pyramid with central apex being half the height above the base as the sides are long.
Knowing that six of these fit into a cube the base being each surface.."
Enough with the cubes and square based prisms, already! Please take a look at my solution and proof in post #205 and tell me if that doesn't meet the challenge to find a solution by calculation for any rectangular based pyramid! I think it does!
#217
In reply to #215
08/26/2007 3:31 AM
Yes STL you are right your formula does work well done.
I was just pointing out that it is possible to reason that the formula work for all 'right' pyramids e.g. by halfing asquare one you will be left with rectangular.
#225
In reply to #212
08/26/2007 5:50 AM
Not variable proportions - just linear scaling* ("similar" figures in the strongest sense), volumes of right prisms (that already needed transfer, which I see as subtraction and re-addition??), cuts and re-assembly, addition, and integer subtraction (not via zero, however).
*An extra clue? Only a factor two scaling is needed
Good Answers: 247
#237
In reply to #212
08/26/2007 2:53 PM
I hadn't read translations of the papyri, until just now. Great stuff! I particulary like the fractional doubles. They seem so strange, from our perspective. It would be great to be able to go back in time, to actually live with this system for a while.
#223
In reply to #207
08/26/2007 5:42 AM
This gives an approximate result for the shape you have chosen. You can make a number of measurements on a number of different shapes and draw the conclusion that is is likely that the 1/3*base-area*height applies to all rectangular pyramids.
But you can do that without resorting to (essentially imprecise) weighings, and using only the much less tight assumption that the multiplication constant is the same under linear scaling (which also means that you don't need to know which dimensions to multiply before you start). That is the intended challenge, and the basic knowledge was certainly available to the ancient Egyptians.
#241
In reply to #207
08/26/2007 5:04 PM
Hi Danmoody
It's an elegant approximate demonstration for any particular case. But applying it to a large pyramid means assuming that scaling actually works between the convenient mud prototype and the large pyramid. It is possible to produce a demonstration that requires only that linear scaling by a factor gives volume scaling by a factor of eight. All the other techniques and background information were known - i.e. cutting, reassembly, addition, volume of a prism. You'll see that my solution is expressed using subtraction, which fits better with current notation - but that is not really needed.
The technique works for tetrahedra as well. The reason that I chose rectangular based pyramids is partly that these were of interest to the Egyptians, and partly because it allows the simplest method of cutting. However, the application to tetrahedra is actually quite straightforward, and it is easy to develop the volumes for overhanging tetrahedra from tetrahedra with a right-angled corner - though this does require basic subtraction.
A question on the use of unity numerators: - I can imagine that the notation for fractions could have advantages in avoiding ambiguities if the standard communication medium was in some sense linear. However, in that case it seems a bit perverse not to use 1/2+1/6 for 2/3. To my mind, that makes this looks more like communications jargon to keep a mathematical elite secure than an intrinsic belief that this is a good way to express fractions. Do you have a view on that?
08/26/2007 5:25 AM
This is a solution I've only checked for when the top of the pyramid is in the center and the sides L and W not necessary the same, rectangular.
If the distance from any side to the centre is the base of a triangle and the height is the other side and the pyramid surface is the hypotenuse, then if you think of how to add up numbers 1 to 9 = 9+1 and 2+8 and 7+3 etc and apply this to the triangles working to the corner, then:
half the length of the pyramid side * half the distance to the centre * the height.
do this for each side and add them up, this then equals the volume?
Don't understand some of the others post, so hope this is not a repeat?
regards JD.
#224
In reply to #221
08/26/2007 5:44 AM
Sorry, but I, in turn, don't understand what you are doing.
Fyz
In reply to #224
08/26/2007 12:16 PM
Yes done it on the run, I dont know what I'm doing either.Adding areas not units so it does not work.
Sorry Fyz and everybody. Regards JD
08/26/2007 9:12 AM
I read as many of the previous replies as my early morning eyes would allow, but if someone already stated this I did not catch it.
The pyramids are a series of rectangles stacked atop one another. calculate the volume of each rectangular section from bottom to top and add results.
or..
calculate the volume of each rectangular section from top to bottom and add results.
do I win? ooh, I hope I did. what's the prize? is it coffee? I really would like some coffee!
cr3
I never apologize. I'm sorry that's just the way I am.
#228
In reply to #227
08/26/2007 9:26 AM
Too late - loads of pyramids built from rectangles already. Anyway, this requires one of the following:
that you already know the volume of a frustum (a rectangular plate with sloping sides);
that you look for improving approximations as you increase the number of layers towards infinity (= calculus); or
that you are explicit about how you calculate the volume of the frustum relative to the volume of the pyramid.
In reply to #228
08/26/2007 9:31 AM
Frustum?
I thought the blocks for construction were rectangular? Simply rectangular.
Now where is my coffee?!
#231
In reply to #229
08/26/2007 9:45 AM
You'll have to get your own coffee The question was about pyramids, not about stepped structures roughly in the shape of pyramids, and the "avoiding calculus" reference was to proposals that the ancient Egyptians "must have had" calculus, because apparently they left a record that included an exact factor of 1/3. The figure of 1/3 is not accurate for a structure built entirely from rectangular blocks - which obviously isn't a true pyramid anyway.
In reply to #231
08/26/2007 9:55 AM
stupid pyramids. $5 USD coffee at starbucks Physicist....get your own coffee.. blah blah... I'm going back to bed.
In reply to #228
08/26/2007 12:23 PM
that you already know the volume of a frustum...
OK , so my construction arrives at a frustrum that is 7/8 of a full pyramid (truncated at half full height). That's got to be worth at least a biscuit, even if the art-work was slightly lacking.
Good Answers: 143
#235
In reply to #234
08/26/2007 1:18 PM
Ha! The evil deed is done. Decomposition of a rectangular parallelpiped was truly a wild duck (oops, I mean goose) chase. Can someone please tell me how to insert drawings (sketches) into a message.
Tom
In reply to #235
08/26/2007 4:04 PM
In the editor screen, there's a green icon like a camera. Click it, and it contains a browse feature to locate an image on your computer. etc etc.
ps, did you like my rather slopey way of illustrating the 22 = 8 !
Good Answers: 143
#242
In reply to #240
08/26/2007 7:34 PM
BTW, I love the little pyramids in #219(?). I'm pretty sure that works if you can extrapolate to rectangles.
If not, it makes a good bed for an Egyptian mystic to lie on.
Thanks for pointing out the doggoned little camera.
The letters are hard to read so the ones on top are K, P, O
The ones on the bottom are L, M, N
This looks suspiciously like what one of the early posts had, so I may be duplicating that. If so, my apologies.
The triangular bases KPO and LMN are identical and parallel and vertically aligned. The other three faces are thus rectangles. Construct the diagonals KN, KM, OM. There will be three identical triangular pyramids KLMN = KOMN = KPMO which make up the whole of the original pyramid, thus making each 1/3 the volume. Any non-oblique polygonal prism (including a right rectangular one where we know volume = abh) can be deconstructed into two or more triangular prisms which we can solve in general form.
Further any non-oblique pyramid can be deconstructed into an oblique pyramid and a non-oblique one, allowing application of this solution to the oblique case (there's probably an easier way to do this, but ...).
Intermediate details have been left to the reader (Hey, that worked for Felix Bloch, why not for me).
I wish I could have thought this up myself. I did not; I'm only a good thief. But, I'm holding on to the source until I see if there are any other good problems in there. For those who enjoy a challenge, this proof may be found at the intersection of 5 and 42. Further, it is most likely that this proof would have been known to Thomas J. Jackson, Professor of mathematics and artillery at Virginia Military Institute in the years prior to the American War Between the States. Or, you could Google it.
Absolutely great puzzler, Fyz. By the way, there's a guy at Exeter who did much the same thing for dodecahedrons. How close is that to you?
Tom
In reply to #242
08/26/2007 9:21 PM
Hi Tom,
Glad you made it with the posting pictures thing - took me a while 'till somebody told me. All I have to do now is spend a bit of time using CAD/Paint-type programs, then I can end the suffering of all those who endure my doodled scans. Nah, they can wait. LOL. The prism trisection has been done on this thread a fair few times before. What surprises me is the lack of attempt to employ Ptolemy/Heron, if nothing else, just to spread the knowledge a bit - that's half the fun of good challenge questions.
I'm still befuddled at a way of equating STL's 'creamer' type shape to pyramids. I thought I had it, then lost it. You can work backwards and imply that 6 similar pyramids deducted from a larger shape equate the volumes, but I thought I had a way of doing it the other way round. Confusing, but I know what I meant.
To make it even more annoying, there is a theorem that relate 3 intersecting spheres, that possibly might be deployed to say something meaningful in relation to this particular Challenge Question. I have no idea what. Not this one, but something to do with siting spheres on the sides of a tetrahedron - they will share a common intersection. I forget the precise name of the theorem I refer to, but it does show the diabolical levels to which 3D geometry can go.
The numbers on your picture showed up fine , as you will now see yourself. I might take issue with you about American Civil War era intervention here, but not too strongly , given the delights of such things as Langley's advantageous angle etc (it's in there somewhere, if not , the music is fun).
Fyz's seemingly 'innocent' question has given rise to a whole bunch of excuse to discuss esoteric geometry. Whatever the delivered 'answer' may be, I'd say that makes it a good question.
Just as a slight p.s, I do believe that there is an Exeter contingent very close by. They don't all partake of the Challenge Questions, but are seldom far away. If the Royal military Canal had been constructed some 10 mile North, I could sleep with both eyes shut at night.
I will, of course, still sulk for not having being awarded a biscuit by Fyz.
Am away for a while, so I'll have to catch up with the fun here later.
K
Good Answers: 247
#247
In reply to #246
08/26/2007 11:14 PM
Did you know that "coffee creamer" is just another name for "tetrahedron", which is just another name for a triangular pyramid? If you go back to your post 63, you have two congruent* triangular pyramids (each having, as an obvious base, the base shape of the original prism). Then you have a tetrahedron that looks like a coffee creamer... but it is also a pyramid, and you could use any of the four triangles as a base, and it would look about the same each time. The "height" would then be somewhat more than half the height of the other two pyramids.
In your post 63, you say that the three pieces are equal in volume. Knowing that 2 of the pyramids are congruent, and knowing the 1/3 constant we are searching for, we know that the third piece, (which looks less pyramidy because of it's perspective --or ours) must be 1/3 of the total. But, if we don't already know the 1/3 constant, then we can't be sure that the 2 obvious pyramids are not each (let's say) .3 of the total, and the creamer .4 of the total. At least I can't see how you could say all three are the same volume, without first using the constant we are trying to "find".
But, if when you said they were the same volume, you had a different reason to say that, then you've hit the jackpot... at least far enough for a donut and a cup of lukewarm coffee. However, you'd then need to skew the starting prism, to make sure it all still works.
Please memorize this list of shapes. I note that we've only dealt with one or two shapes from the list, and many of the links from this list describe numerous varieties.
BTW, I think some evil doers have been using the term "right pyramid" incorrectly. In a right pyramid, the apex is over the center of the base. Otherwise, the pyramid is oblique, as is the case with the coffee creamer shape. Also the four smaller (quarter) pyramids you can combine to form a right pyramid have right triangles on several faces, but are also oblique pyramids.
* Strictly speaking, they may not be congruent. If the legs of what looks like a right triangle that forms the prism base are not equal, then the two pyramids that result from cutting would not occupy the same space, but would be mirror images. They would clearly have the same volume, but they would have a "handedness" that a fully congruent pair would not have, I suppose. I don't know what term distinguishes one variety of similarity from the other. Symmetrically congruent?
In reply to #247
08/27/2007 4:28 AM
Ahh, Ken. ' That'd be right' as they say down under. I know you'll never believe it, but I did have a way of resolving STLs creamer dilemma in my mind. Just couldn't get it onto 'paper' good enough. If you can just get back to yanking his chain, I'll return soon enough with better proof. If I can't, I'll see if I can drench you with good math-reference sites. You do realise <grinning sarcasm> that St Louis has one of the coolest architectural structures on the planet < diversionary tactic>. You two can fight it out - I'll await fyz's 'solution' and see which muppet is mad enough to disagree.
PS - You may wish to update your computer software.Well, I did say I'd advance mine to match.
Good Answers: 247
#250
In reply to #249
08/27/2007 9:36 AM
The software is posolutely, absotively, bloomin great! Even the help works! I'll have to spend more time poking around it when I have a minute. It captures so many of the Windows foibles so well, I rolled on the floor, and nearly passed out from laughing so hard.
What a treat to start off the week. Thanks!
In reply to #250
08/27/2007 10:47 AM
...It took me ages to stop laughing when I first saw it. Think of the potential for leaving it on someones computer in the office ! Watching it myself was nearly the end of me - seeing somebody else's perplexed reaction to their new software update ? There's not enough gaffer tape in the world to contain my probable reaction.
Good Answers: 247
#253
In reply to #251
08/27/2007 12:28 PM
In those companies where the IT department does the updates remotely, there are always two polar opposites: the IT guy who instinctively blames the user, and the user who instinctively blames the IT department. You can construct the script for a short play just thinking about the possibilities, as the two get together to do some finger pointing and screaming.
#258
In reply to #242
Re: Pyramids: Newsletter Challenge (08/21/07)
08/27/2007 3:59 PM
"There will be three identical triangular pyramids KLMN = KOMN = KPMO" That seems (to me) to be wishful thinking. KPMO=KLMN iff triangles KOP and LMN are equilateral.
Then, I don't believe that KLMN can ever be congruent to either of the other two tetrahedra, because KPMO and KLMN always have two right angles at one corner, whereas KLMN has two right angles at opposite ends of NO.
Sorry to be a damp rag
Fyz
Exteter - I'm not familiar* with that work, do you have a reference?
*It would be surprising if I was really, because the only reason I came up with this was to satisfy myself that the claim that "the ancient Egyptians must have had a primitive form of calculus to come up with the formula" could be countered without suggesting they resorted to guesswork based on limited measurements (i.e. didn't adhere to their own standards).
#267
In reply to #258
08/27/2007 7:32 PM
It all depends upon their definition of volume. It is obvious, but not so easy to prove, that as all cross-sections meeting any plane parallel to their base of two tetrahedra with congruent bases and the same height are a pair of congruent triangles, the two tetrahedra have equal volume.
Euclid, on the other hand, insists on only using congruent triangles or solids and when they are not available uses reductio ad absurdum to prove his point. If the Egyptians had a more practical and less rigorous definition my "proof" would be adequate (the revised version might be valid even by Euclid's standards but as I cannot draw and cannot even cut triangles of cheese to fit together - I did try - it's difficult to show that the two left-over tetrahedra are congruent and not just equal)
In reply to #267
08/27/2007 11:16 PM
sometimes I don't feel very smart.
#271
In reply to #267
08/28/2007 4:12 AM
That still does not help with KLMN, which does not usually have a face that is congruent to a face of either of the others. If I'm wrong about this, please show me.
Fyz
#275
In reply to #271
08/28/2007 7:50 AM
No, it does not deal with KLMN (I don't see how that can be congruent to the other two in normal circumstances, having tried several times)
I was just replying to your comment about whether the Egyptians adhered to their own standards.
#239
08/26/2007 3:47 PM
Just fill a bucket with liquid, then dunk any irregularly shaped object in it and measure the volume of liquid that spills over the side. That's how to calculate the volume with out calculus or any math.
#244
08/26/2007 8:34 PM
that simple
(height)*(area of the base)/3
#259
In reply to #244
08/27/2007 4:03 PM
How the ***** did you find that out without someone having resorted to calculus?
#276
08/28/2007 8:40 AM
It is simple.
Consider a cuboid with rectangular base A x B and height 2H. Volume of such cuboid is Vc = A x B x 2H, what was, I hope, obvious fot the ancient people.
Now take the central point inside the cuboid, H away both from the bottom and top of the cuboid and imagine the pyramides which are made by the cuboid's walls and the central point. There are six (smooth side) pyramides:
two pyramids A x B base and H height (top and bottom pyramide),
two pyramids A x 2H base and 1/2 B height,
two pyramids B x 2H base and 1/2 A height.
This pyramids fully fill the cuboid's volume.
Of course the volume of a pyramide Vp, eg. A x B base and H height, is not simply Vp = A x B x H but is smaller and is:
Vp = epsilon x A x B x H , where epsilon is a constant factor for pyramid.
Now you can write:
Vc = A x B x 2H = sum of the volume Vp of the six pyramids =
= epsilon x (6 x A x B x H)
From this you can easily see that : epsilon = 1/3 ,
so the volume of pyramid A x B base and H height is 1/3 x A x B x H.
Ready!
Now, Ramzes, 12 amphors filled with wine please!
Piotr Grabowski
In reply to #276
08/28/2007 9:29 AM
Piotr,
You have solved for only one case, where the apex of your 6 pyramids lies directly over the center of their bases. These are known as right pyramids. This is far from the generalized case which I presented in #205, and illustrated in #218, but you got the idea. At least you did not limit yourself to a square-based cube. Your "cuboid" would be more correctly called a rectangular prism, which is the common box shape. It is also known as a right (or 90°) parallelepiped, a six-sided polyhedron where all of the faces are parallelograms AND all angles are right angles, or in other words, all the faces are rectangles.
Unfortunately, there are some who say even my general solution does not solve the challenge, but I guess we agree to disagree. My solution includes oblique (non-centered apexes) pyramids, but only if the apex is over the base. Extremely oblique pyramids, where the apex lies outside (not directly over) the base are not proven by this solution. However, in light of the reference to the Egyptians and pyramid building (did they ever even build non-square pyramids?), it is hardly fair to include these extreme cases.
I hope you will check my solution and see how it is more general then what you have proposed.
#279
In reply to #276
08/28/2007 9:34 AM
Request denied.
Even if this works, it only solves the problem for right pyramids (with the vertex above the centre of the base). If you can justify your statement that "you can write Vp = epsilon x A x B x H, where epsilon is a constant factor ..." you can regard the job as done for these pyramids. Although that is unnecessarily restricted it would be good enough for practical purposes, as that is the only kind of pyramid we intend to build. Therefore, if you can do that without making use of the "official" solution, 3 amphora filled with wine will await you by the foot of the pyramid currently under construction (at 1800 BC). Otherwise, in view both of your having repeated suggestions made by others and rejected for precisely the above reason, and of your temerity in proposing your own reward, you will head the list of slaves to be tortured to death and subsequently interred immediately prior to the next sealing.
Ramesses
In reply to #279
08/28/2007 9:51 AM
Yikes! If that's how Fyzaoh "Ramesses" treats his servants, me and the other Israelites are outta here! Red Sea, shmed sea. We'll cross that river when we come to it. 40 years wandering in the wilderness? Heck, after this gig we can do that standing on our heads! Who needs Pyramids anyway, I got some plans for this really nice Temple...
- Mosses
#285
In reply to #282
08/28/2007 10:05 AM
We are a civilised society - we don't torture faithful and obedient slaves here.
But did you hear about this years harvest? Not too much straw. After those comments, guess which slaves are not going to have first access for brickmaking (favourite adopted son or not).
Did I hear "time and a half for overtime"? Sounds about right - off you go to the slammer.
(I reckon you always were a basket-case)
Fair O
In reply to #285
08/28/2007 11:01 AM
Unfair O,
Well, that's the last straw! (he, he)
Sounds like a bunch of Bull-rushes to me!
Hey, do you like frogs? Bloody rivers? Locusts? Dead babies? I hopes so, cause "It's go time!"
Go find yourself some Nubian scabs, cause the UPW (United Pyramid Workers) is shutting you down, O Mighty One! Oh, and good luck getting your wimpy son Mernephtah to ramrod those scab workers and finish your great projects. He couldn't cut his way out of a papyrus bag! His idea of a scarab amulet is a real dung beetle on a string, including the dung. I'm telling you, that boy's steps don't go to the top of his Pyramid! He's got the hieroglyphics of an "L" on his forehead. He is NOT the sharpest spear in your armory, to say the least. When his Greek tutor asked him to define "Geometry", he said, "Well, I got a trunk, some branches, twigs, and a lot of leaves. Gee, Ah'm a tree!"
<chanting>Let my people, GO! Let my people GO! Let my people, GO! Let my people GO!
#287
In reply to #286
08/28/2007 11:35 AM
You don't really believe that "found in a basket ***t? (perhaps even Pharoahs can't admit to producing progeny with Israelite slaves...)
Frogs and locusts are both good battered and served with French toast. I'm not too keen to try human flesh (KJ and all that), but red rivers are not that unusual, and they are safe enough if you boil the water first.
Do you think you should write a musical on this basis? Dr. A. L. Webber did quite well out of Joseph, and he espoused much the same personalised historic approach you are promulgating.
In reply to #287
08/28/2007 11:58 AM
Already been done as an animated film, "Prince of Egypt" (1998), with music by Stephen Schwartz (the "Godspell" guy). Nominated for and won many awards including Oscar:
Academy Awards, USA YearResultAwardCategory/Recipient(s) 1999
Won Oscar Best Music, Original Song
Stephen Schwartz
For the song "When You Believe".
Nominated Oscar Best Music, Original Musical or Comedy Score
Stephen Schwartz (music/lyrics)
Hans Zimmer (orchestral score
And look at that cast:
Val Kilmer ... Moses/God (voice)
Ralph Fiennes ... Rameses (voice)
Michelle Pfeiffer ... Tzipporah (voice)
Sandra Bullock ... Miriam (voice)
Jeff Goldblum ... Aaron (voice)
Danny Glover ... Jethro (voice)
Patrick Stewart ... Pharaoh Seti I (voice)
Helen Mirren ... The Queen (voice)
Steve Martin ... Hotep (voice)
Martin Short ... Huy (voice)
It's a wonder Disney hasn't brought it to the Broadway and London stage! But, then, Dreamworks isn't owned by Disney, is it. It's owned by Paramount!
Here is the Wikipedia article if you are interested:
http://en.wikipedia.org/wiki/The_Prince_of_Egypt
In reply to #288
08/28/2007 12:13 PM
By the way, when Steve Martin and Martin Mull used to perform together, they would bill themselves as Steve Martin Mull. I wonder if SM and MS do the same thing, as in this film, when they find themselves together....Steve Martin Short? They could even do a sequel to the "Three Amigos", but without Chevy Chase: "The Two Amigos"
That could open up all kinds of possiblities for Steve Martin (although some may be dead):
Steve Martin Landau (in a very funny version of "Space: 1999" or "Mission: Improbable")
Steve Martin Milner (new partners in "Adam-12-1/2" or "Route 666")
Steve Martin Scorsese (directing hysterically funny mobster movies)
A very funny aerospace company could be Steve Martin-Marietta?
How about Steve Martin Luther King, Jr.? (gives a whole new meaning to his line in "The Jerk": "I was born a poor black child in Alabama...."
#280
Pyramids: Completing the solution
08/28/2007 9:49 AM
To complete the picture as regards direct solution for pyramids with the apex overhanging, plus tetrahedra and polygon-based pyramids.:
Take a reference pyramid, and extend its sloping edges a factor two to make a double-height pyramid of eight times the volume. Cut the reference pyramid away from the top of the the extended pyramid, to leave a frustum. Now make two full-size cuts through the frustum so that they separate a pyramid that is identical to the reference pyramid from one of the corners (N.B. that, for an overhanging apex, there may only be one corner where this is possible). This will simultaneously separate three prisms - one with a rectangular base, and two with triangular bases. The total volume of these three prisms is 2.w.l.h (you can cut and reassemble each of the three prisms to make "right prisms" to confirm this if you think it is necessary). This (2.w.l.h) is equal to the total volume of the double height pyramid (= 8 reference pyramids) minus the volume of the two reference pyramids we have removed; that is 6 reference pyramid volumes. So a single reference pyramid has volume 2.w.l.h/6 = w.l.h/3.
This method will work for any pyramid whose base is a parallelogram, but not with arbitrary shapes such as tetrahedra.
The basic method (using vertical cuts to create right prisms) works with non-overhanging tetrahedra, where we need up to 10 cuts:
. The first cut horizontal to separate the original tetrahedron
. Three further vertical cuts from the top edges of the frustum, just sufficiently long to separate a vertical right triangular prism
. Two outward-going vertical cuts orthogonal to each of the three immediately previous cuts (six in all). These will define three right prisms resting their sides, and three quadrilateral pyramids.
.The three quadrilateral pyramids can be assembled to make one reference tetrahedron.
. By apportioning the area of the base triangle (4 x the area of the base of the reference prism), we can see that the sum of the prisms is 2 x base-area x height (the dimensions again being those of the reference prism), and the sums continue as for the rectangular pyramid above.
We can then extend the situation to any overhanging tetrahedron by filling empty space to create a non-overhanging tetrahedron, and then removing at most two other non-overhanging tetrahedra to leave the original tetrahedron whose volume was to be calculated. We can then return to Euclid's methods to extend the tetrahedral result to cover any polygonal based prism.
Good Answers: 143
#289
In reply to #280
Re: Pyramids: Completing the solution
08/28/2007 12:06 PM
So I have this mental picture of Edward G. Robinson staring down at you in a mud pit, saying "So, Moses. How do you like your proof now?"
Tom
#291
In reply to #289
08/28/2007 12:20 PM
I believe Mr. Robinson to be history, since Moses cast his staff on the ground at his feet, and it bit him. Then Moses climbed out (and by all accounts, lived to 120).
Regarding my 'proof', if you accept the assumptions it seems fine to me. I.e. unless you know different, I think it "does what is says on the tin.". If you have reservations, spit 'em out. Otherwise, it would be good if someone who is handy with a drawing package would illustrate the processes (it's always hard to follow a verbal description of a 3-dimensional process).
Fyz
In reply to #291
08/28/2007 12:26 PM
And you thought you had trouble following MY solution! My graphics are a piece of cake compared to what it would take to illustrate what you just described!
ROFLMAO at Fyz's "simple solution".
Good Answers: 247
#293
08/28/2007 1:15 PM
Re the official solution:
What an elegant, simple solution, clearly and concisely explained. Wow.
Even without drawing it, it's easy to visualize. STL has pretty good drawing skills, and I bet he'll volunteer to draw it for those who need help with the visualisation.
For cheese lovers, it would be a simple matter of starting with a largish pyramid, cutting off the top half ("half" as measured by height) and setting that aside to serve as a reference for the original single-sized pyramid (of volume = "Volume"). Then slice off the 4 pieces that, once removed, reveal the rectangular prism over which the smaller prism was perched (before the knife came out). Then, just cut off the four corner pieces, which clearly can be assembled into a perfect replica of the single sized pyramid.
How cool.
With your description and STL's drawing (the one I think he'll volunteer to do), all nicely colored to show how the four triangular prisms equal the rectangular prism, etc., this really should be published on one of the math sites so students everywhere have access to it.
Well done proof, and a great stimulating challenge question.
In reply to #293
08/28/2007 1:38 PM
"What an elegant, simple solution, clearly and concisely explained. Wow.
...this really should be published on one of the math sites so students everywhere have access to it.
Well done proof, and a great stimulating challenge question."
Fyz! Don't sit down too quickly. You just might just squash his head and kill poor Ken!
Sorry, can't oblige on the drawing, even if a dumb idiot like me could understand this "elegant, simple solution", I am just too busy eating my sour grapes, sulking in my corner, and doing my Rodney Dangerfield impression.
I don't get the "formulas" that Fyz used. Maybe if he used proper notation it would all become much more clear. Surprisingly inerudite for a Physicist. "bits-of-pyramid", indeed! And he had to use 8 pyramids while I only used 6. I would say my proof was much more efficient! <grin>
Reply to Blog Entry Page 3 of 4: « First < Prev 1 2 3 4 Next > Last »
3Doug (7); Anonymous Poster (30); Blink (28); coconutpete (1); danmoody (2); design-engineer (1); Dino007 (2); English Rose (10); Goober (2); Hendrik (1); jdretired (5); John77 (10); kbarr (1); Kris (28); lambros san (5); mfiedler56 (2); MusicAl (2); PatyO (1); Physicist? (84); Randall (4); rbixby (2); rcapper (1); RickLee (2); satyoda (1); SJAMacMillan (6); STL Engineer (59); TexasCharley (4); TVP45 (18); user-deleted-1105 (1); wangito (1)
Previous in Blog: Measuring Solar Power: Newsletter Challenge (08/14/07)   Next in Blog: Electric Field: Newsletter Challenge (08/28/07)
