Previous in Blog: The Time Now is 2:10 p.m. (August 2024 Challenge Question)   Next in Blog: Imbibition Equations (October 2024 Challenge Question)
26 comments
Envelopes of Money (Sept. 2024 challenge question)
Posted August 31, 2024 12:00 AM
You are on a game show and the host of this game show displays three sealed envelopes.
  • One envelope contains $1,000
  • One envelope contains $500
  • One envelope contains $100
The host does not know which envelope is which.
You pick one envelope. Its contents are not shown to you.
The host instead opens one of the other envelopes. It contains $500. Remaining are the $100 and $1,000 envelopes.
You are given a choice - do you stay with your original envelope choice or do you pick the other envelope? Why?
Answer, 9.23.24
This is a twist on the classic Monty Hall problem. A similar concept, but where the host does indeed know the contents of each envelope (or door). After the contestant's choice, the host reveals a lower value prize and the contestant is tempted to switch doors. Paradoxically, the contestant should always choose to stay with their first choice. The Wiki article on this has multiple logical explanations.
In the scenario above, the host does not know which envelope contains what. This is a conditional probability scenario - your chances at $1,000 are 50/50 and you might as well flip a coin to pick.
5
Re: Envelopes of Money (Sept. 2024 challenge question)
08/31/2024 7:04 AM
It does not make any difference: all of the probabilities apply in exactly the same way to the $100 & $1000 envelopes.
Things only get interesting if the host does know which envelope contains what.
Reply Good Answer (Score 5)
09/02/2024 1:35 PM
Yeah, it makes no difference to you what's in the envelope the host takes, or even if he opens it. Your expectation is half the sum of the other two envelopes whether you swap or not.
09/23/2024 9:37 AM
Admin here...
This answer is correct. Thanks @Randall!
08/31/2024 7:18 PM
I would select the other envelope.The odds of getting the right one are 1 in 3 to start with.Now after one has been eliminated,the odds are 2 in 3 of getting it right, if you change doors.
08/31/2024 11:15 PM
NO! After one envelope has been eliminated, the odds are 1 in 2, otherwise known as 50/50.
09/16/2024 12:34 PM
It's similar to the game show on which door you chose #1, #2 and #3.
The odds still changes, whether the host knows or does not know what's in the envelope.
09/01/2024 4:32 AM
That only works if the host knows what the envelopes contain.
09/01/2024 5:00 AM
And of course, you have to assume that the host has an agenda.
09/01/2024 5:12 AM
The first one you picked had a 1 in 3 chance or being right.It still has a 1 in 3 chance of being right.
Now there are only 2 left,and your chances are 66% of getting it right if you change .
I admit,it is counterintuitive,but statistically that is how it works.
09/01/2024 2:17 PM
Since the host has no knowledge of which envelope is which, it is only by chance that he/she selected the one with $500. You now know that one of the remaining sealed envelopes has $100 and the other has $1000. You must choose 1 of 2, giving you a 50/50 chance.
Switch or not makes no difference! Randall's post #1 was correct.
09/06/2024 4:08 AM
"The first one you picked had a 1 in 3 chance of being right."
"Probability" has no concept of right: the envelopes might as well contain red, green and blue tokens; after you and the host choose envelopes, the probability of any token being in any envelope is the same for all three colours; when the host reveals what's in his envelope, the chances of one of the other colours being in any particular envelope is 50%.
The result can only change is an agency with a concept of value; knowledge of the positions, and, ability to change the result can have an effect.
09/01/2024 7:03 AM
When you selected your envelope, it was worth 1600/3 or $533.33. After you know that one of the other envelopes had $500, your expected return is $550.00. I would switch. Your odds will be the same or better. Whether the host knows which is which, he has still increased the odds with his selection.
09/01/2024 10:38 AM
Correction:
No, since the host draws the $500 envelope, your envelope contained either $100 or $1000, 50-50 chance, worth on average $550. Same with the other envelope.
The fact that the host drew his envelope after you is irrelevant. (Backward causality??)
Randall is correct...
Good Answers: 137
09/01/2024 10:40 AM
If this isn't the Monty Hall problem, it's a close relative
Monty Hall Problem:
09/01/2024 11:35 AM
It's definitely NOT the Monty Hall problem linked in your post, because in this problem the host is not permitted to know the contents of the envelopes. This means the host cannot influence the outcome.
AND, in the Monty Hall problem linked in your post, switching doors is ONLY preferable IFF the host wants the contestant to win. If the host has been instructed to attempt to save the sponsor's money, then the contestant is better off NOT changing.
Good Answers: 137
09/01/2024 12:49 PM
OK
09/06/2024 4:16 AM
"If the host has been instructed to attempt to save the sponsor's money, then the contestant is better off NOT changing."
It doesn't matter what the host wants, I assume he has to follow the rules set down by the shows producers. I don't think it has ever aired on this side of the pond, but, I assume that Monty never revealed a car after the contestant picked their first door. It would kind of spoil the shows ending if the contestant was offered the chance to choose the other closed door because he might get a better looking goat.
09/01/2024 4:41 PM
You switch envelopes. Marylin Savant answered this question several years ago and was railed on by many mathematicians. She subsequently proved them wrong and they, humbly, responded back that she was right and they were wrong. The answer of 2 chances to be wrong on the first pick and 50/50 on the second made switching the better decision. She also made a table of switching and not switching and switching was the best bet. Her IQ puts mine to shame so I'm going with the lady...
09/01/2024 4:48 PM
A link to her answer, please.
09/01/2024 4:55 PM
Your wish is my command :) Monty Hall problem - Wikipedia
09/01/2024 7:57 PM
Go back and read my post #10!
09/01/2024 9:13 PM
I'm sure it's me but I don't see the difference. He displays the contents of one of the unchosen envelopes. So, he may not have known the contents of any of the envelopes but he still revealed the contents of one of the unchosen envelopes. It might as well have been two envelopes with $500 and one with a $1,000. He has 1 chance in 3 of the $1,000 on the first go around and now has 1 in 2. The odds of not getting $1,000 the first time 2 out of 3. So it seems switching his first choice is the best bet. To me the difference in the two scenarios is superficial.
Good Answers: 137
09/06/2024 11:21 AM
If I'm not mistaken that was for the Monty Hall problem. Apparently this is different, I haven't tried to think it through in detail.
09/03/2024 5:53 AM
With the exchange rate on the $ these days it matters little.
09/03/2024 7:00 PM
I think it is better not to switch. If you think about it from a Stress Perspective.
You are better to make a decision and then decide to be happy with that decision and don't think about it again. The more you think about it the more worry and the more stress and time wasted.
Once you have calculated that you only have a 50/50 chance, the odds are the same if you think about it for a long period or a short period. If you think about it for a short period you can apply your mind to something else, and maybe solve another issue which you can then benefit from. So you are better to go with your first pick and move on
Aesop's fable of the fox and the sour grapes has a similar concept
09/06/2024 4:20 AM
The easy way to understand the Monty Hall problem, is to imagine that instead of 3 doors there are 100: when the contestant chooses a door he effectively splits them into two groops: one of one door with 1 chance in 100 of hiding the car, and, one of 99 with 99 chances in 100 of hiding the car. Monty simply eliminates 98 goats from the second group. The wise choice then is to switch to the other group.
Anonymous Poster (1); Codemaster (3); dkwarner (5); HiTekRedNek (2); phoenix911 (1); PWSlack (1); R_i_c_h (3); Randall (6); Rixter (3); VSted (1)
