Previous in Blog: Sparking would be bad: Newsletter Challenge (01/02/08)   Next in Blog: Soda Pop: Newsletter Challenge (01/15/08)
Tuning Fork Disagreement: Newsletter Challenge (01/02/08)
Posted January 06, 2008 5:01 PM
The question as it appears in the 01/08 edition of Specs & Techs from GlobalSpec:
Giovanni was tuning his piano using a tuning fork when his friend Tommaso stopped by. Tommaso listened for five seconds and then confidently told Giovanni that the key was in tune. Giovanni disagreed. After about five more seconds, Tommaso was forced to agree that the key wasn't in tune afterall. What happened to change Tommaso's mind?
(Update: Jan 15, 8:44 AM EST) And the Answer is...
After 5 more seconds, there was a noticeable decline in the volume of the note. The closer two sounds are in frequency the lower the "beat frequency" produced by the interference of the two sound waves. It is actually impossible to precisely tune a musical instrument, given enough time there will always be a beat, however Giovanni is probably going a little overboard here.
http://members.aol.com/chang8828/tuning.htm
Re: Tuning Fork Disagreement: Newsletter Challenge (01/02/08)
01/06/2008 6:34 PM
Listener fatigue .
Good Answers: 88
01/08/2008 12:08 AM
Turns out Tomasso (who always had a bit of spring in his step) was moving so fast past Giovanni that he red-shifted G's A# to an F♮.
Good Answers: 22
01/06/2008 7:46 PM
Several possibilities come to my mind (not all are serious):
1. Tommaso realized he had tinnuitis (ringing in the ears), and this had fooled him.
2. Giovanni realized he was using the wrong tuning fork.
3. Tommaso plays a different instrument and doesn't know how to tune a piano. He thinks that because he is an expert at his own instrument, that makes him an expert on other instruments.
4. The pitch changed as Giovanni continued playing the key. The strings played by that key are worn out and need to be replaced.
5. Tommaso is on drugs. He come down off his high during the second five second listening period.
01/06/2008 11:13 PM
When Tommaso was passing by, Giovanni was checking the different keys on the piano board to see which key matched the tuning fork. What Tommaso heard was the key that did match the tuning fork, Giovanni then pointed out that the key he was playing was not the correct key, so when Giovanne played the correct key that should match the tuning fork he agreed they did not match.
Regards JD.
Good Answers: 88
01/07/2008 1:11 AM
As the piano string rings, the higher modes decay leaving only the fundamental. Because piano strings are under enormous tension (the total force on the metal frame of a Concert-D grand piano can exceed twenty tons), the strings produce overtones which are not exact harmonic multiples of the fundamental. The tuning fork may match in frequency the initial overtones, but appears to mismatch seconds later as the overtones decay, "exposing" the fundamental frequency, which will not match in pitch.
01/07/2008 2:16 PM
I think that you are right. At least as far as the challenge question goes.
Pianos contain multiple strings per key or note. When you tune the piano with double or triplet strings you do not tune all strings to the exact same note. Rather, you tune the center string slightly sharp from each of the others to provide a richer tone. If the blend of notes are not correct it will produce an undesired effect and you could get a note that sounds off-key.
Also, during the tuning process you need to mute the companion strings to that key or you get two notes. If one string has a longer and louder sustain it will override the other string as it decays. It can get pretty frustrating trying to tune multiple strings without damping the others.
Pros take years to lear the techniques by practicing and practicing.
01/08/2008 8:29 AM
In re to Europium's reply #4 and Anonymous's reply # 9, I am sold, guys. You know your stuff. Now, can we get back to talking about the harmonics of Black Hole's accretion discs, please?
Good Answers: 88
01/08/2008 8:35 AM
I get it. Your wife is forcing you to read this thread. Again. Maybe you could appease her by treating her to a nice meal at a five-star restaurant. That usually works!
01/08/2008 4:21 PM
Regarding tuning the centre string to a higher pitch than the outer ones - I could be wrong - but my understanding was as follows:
Because of coupling via the bridge, the restoring force on each string depends on the presence and relative location of adjacent strings. Because the strings move in synchrony, the restoring force on all three strings reduces when the strings are vibrate at the same time. This means that they will vibrate at a lower frequency when struck together than when struck separately. The centre string sees nearly twice the value of this effect as do the other two, so it needs to be tuned to a sharper pitch initially to compensate.
That would mean the objective of tuning the centre string sharp is to prevent beat-notes once they work together, rather than for any subjective effect such as "richness".
[For what it is worth, when dealing with the first note on each section of the piano, I've heard tuners to under-compensate the centre string initially, then counts the beats with all working together and increase the pitch of the centre string accordingly. I'm not certain what is the heuristic as they move away from the reference they've calibrated in this way, but they only seem to need to do this about once per octave.]
Reply Off Topic (Score 4)
#142
01/21/2008 6:45 AM
Unfortunately, the reason you give for the overtones being out of tune is the inverse of the truth. To the extent that the restoring force is due to the in the string tension, the overtones will be in exact multiples of the fundamental frequency. The cause for overtones on a piano being sharper than the fundamental is the contribution of restoring force due to the rigidity of the strings (the curvature for a given lateral displacement goes as the inverse square of the length, compared with the required inverse linear relationship)
01/07/2008 7:56 AM
A trick of sound called sympathic vibrations can allow the piano to set the tuning fork to vibrating if the frequencies match. In this example the key was not inducing the vibrations on the fork.
Also keep in mind that most of the keys on a piano use more than one string so if only one of the strings slips it will cause a distortion in the note. To tune the piano correctly one needs to silence all but one string on a key and start tuning each string individually. After the first string is tuned the other strings can be added in and tuned to match the first.
01/07/2008 9:26 AM
As usually, too many possible answers, too little information or limiting parameters.
01/07/2008 11:24 AM
When two frequencies 'interfere' with each other, they produce two new frequencies, one frequency being the sum of the two and the other being the difference between the two. It is the difference frequency that is the give-away. What Tommaso heard was a low-frequency 'throb' that was the difference between the tuning fork and the struck note in the five seconds while standing there, and concluded that as there was a difference between the note coming from the tuning fork and the other coming from the string and, therefore, that the piano was not precisely in tune.
As europium has correctly pointed out, the strains in a piano frame as it comes up to pitch from tensioning the strings are a significant fraction of the overall strength of the frame. So, changing the tension in one set of strings will adjust the shape of the frame slightly, and in so doing it will alter the pitch of the other strings, particularly near the centre of the frame where dimensional distortion will be the greatest. For this reason, a piano tuner will revisit the other strings periodically during the tuning process and give them a gentle 'tweak', as well as the one under primary consideration.
It takes a long time to tune a decent piano really well, and even then its pitch will change slightly as the ambient temperature changes; it changes the stresses in these components thereby altering the vibration frequency of the strings; the tuning.
Of course, Tommaso and Giovanni were both perfectionists and the propsect of buying an electronic keyboard instead was far beneath them....
01/07/2008 11:54 AM
All of this make me wonder.
The average person, say, with a family, does not get his piano tuned frequently. Usually only when it is moved or undergone some other major climatic (climactic? ) change, or if there is a VERY noticeable change in one or more notes/keys. Perhaps a professional musician would have his piano tuned more frequently, but I remember our Steinway "Verti-grand" being tuned only once every few years, and that was with 4 young-to-teen-age kids taking lessons, sometimes overlapping but usually sequentially, over many years, and a family friend who WAS a professional pianist (and later Professor of Music) who would recommend when the piano needed tuning.
My question is this, would a high quality electronic/electric piano sound just as good or better (being ALWAYS in tune, by definition I believe) than a medium quality home-type (vertical or spinet) that might de-tune somewhat naturally over time? I recently played one priced at about $3000 at a local store. Its quality (realism in action and tone) impressed me as being comparable to "real" pianos in the same price range or higher.
Or am I just ignorant about pianos? Maybe I should be asking this on a piano website, but I am hoping that engineers who are also musicians might be more objective than a typical classically-trained pianist who might shudder at the thought of one's primary piano being a non-acoustic "toy".
One of the greatest advantages I saw in this little baby (same number and size of keys as a "real" piano, but in a much smaller "table-top" package), besides its compactness, was the ability to switch from loudspeakers to headphones and thus practice quietly, without disturbing others. Also, direct recording to digital media is possible as well, and not to mention fun factors, as, like other less expensive keyboards, other musical instruments could be synthesized as well.
And, I believe, you would NEVER need the services of a piano tuner!
01/08/2008 8:12 AM
Actually a lot of electric pianos play one or more electronic recordings or a real piano based on the combination of keys being played. So in reality you are hearing the recordings of a real piano, not the compilation of electronicly generated frequencies as the old electronic pianos of the 60's and 70's.
This also goes back to the era of the moog. The fine electronic instruments of today, as fanastic as they are using recordings of actual instruments, can not replicate the unique qualities that the moog producted, as the moog allowed for a wide variety of analog adjustments to the tone qualities.
01/08/2008 10:04 AM
Thanks, Rick. But if they are simply electronic recordings, and not a true synthesized not, how do the simulate the sharp attack and decay variation and sustain effect (using the pedals)? Just like a real piano, the harder you strike the key, the louder and sharper the note is, and the longer you hold it the slower is the release.
These effects I would think would be harder to re-create with a digital recording than just manipulation the synthesized tones to begin with, but then I am no digital audio expert.
01/08/2008 3:02 PM
You might be surprised at the detail put into key-strike sensors in the latest generation digital pianos. They turn fine pressure differences into very precise wave form profiles for a more faithful response tone. Most of the high end digitals do have at least 3 pedals for attack and decay, some have even more.
The downside of moog synths was always that one hand played notes, the other hand made the wave forms of the notes - intuitively. That is why most of the looped tapes were polysymphonic - sounds piled on sounds with different qualities and octaves to give a fullness. The names of the "instruments" that were made by combinations of these loops was at most an approximation of what that sound. Throw in a Lowrey horn and pedal and you've got an amazing invention.
All this being said, anytime a song called for a piano in a recording studio, it would always be strings and hammers.
If you want the grand-daddy of all anolog systems, google TONTO-The original new timbral orchestra. This beast was a Moog Series III modular with Oberheim, EMS, Arp 2500/2600 modules plugged in here and there. I hate to date myself, but it appeared on a few of my Billy Preston Albums.
Mens Sana In Corpore Sano
01/09/2008 8:02 AM
Like Cuz' says these pianos, even ones ten years or older, are extremely complex instruments. It's just that with highly integrated circuitry, you can pack a ton of technology into a small cheap keyboard.
01/09/2008 9:14 AM
Well, the one I saw was not that small, and not that cheap. It may not have been as mechanically complex as a piano, but it was priced similarly to small pianos I have seen, like spinets and short uprights, even some baby grands. One of the things that made it different from the typical "electronic keyboards" made so famous by Casio, Yamaha, and others, was that, besides having the full complement of keys, the same as an acoustic piano (88 keys), the action felt mechanically realistic.
I found this paragraph in the Wikipedia article interesting. Perhaps the "digital sampling" mentioned in the article is the same as the "digital recording" referred to by RickLee above. However, the technology goes way beyond that as described below:
"Since the 1980s, digital pianos have been available, which use digital sampling technology to reproduce the sound of each piano note. The best digital pianos are sophisticated, with features including working pedals, weighted keys, multiple voices, and MIDI interfaces. However, with current technology, it remains difficult to duplicate a crucial aspect of acoustic pianos, namely that when the damper pedal (see below) is depressed, the strings not struck vibrate sympathetically when other strings are struck, as well as the unique instrument-specific mathematical non-linearity of partials on any given unison. Since this sympathetic vibration is considered central to piano tone, digital pianos do not sound the same as the best acoustic pianos. Progress is being made in this area by including physical models of sympathetic vibration in the synthesis software."
01/09/2008 1:11 PM
I've tried a Yamaha Disklavier, which is officially considered a Hybrid (splitting hairs or what). The key action feels authentic to what you would expect from a traditional piano, and it does have pedals including the Damper and Uno Cordo that do their job......BUT-The Rompler technology misses something in translation. The sound has no depth and texture. And considering the price-I'll stick to a second hand upright.
In reply to #67
01/10/2008 7:52 AM
I will agree, an acoustic piano is going to be extremely difficult to duplicate in electronics. Technology will close the gap but will not likely perfectly match the real thing. But for the novice just learning, a good electronic keyboard with velocity determination on the keys will give the learner the necessary experience to get the fingering developed and to strengthen the hand muscles. All this without the expense of constantly getting the piano tuned yearly.
In reply to #87
01/10/2008 9:16 AM
Thanks, Rick. That's kind of what I was thinking, too.
#94
In reply to #87
01/10/2008 10:20 AM
Even twice-yearly piano tuning is a small cost compared with decent piano lessons (and we don't want the little dears suffering RSI because of poor technique, now, do we?)
Good Answers: 247
#99
In reply to #87
01/10/2008 11:16 AM
True.
re velocity sensing:
In addition to velocity sensing, my ensoniq also had aftertouch (pressure) sensing, enabling expressiveness unavailable to a conventional instrument, nor to quite a few electronic gizmos. Aftertouch could be used to add a growl to a sax, vibrato to a trumpet, etc. (or changing any parameter in any way) by pressing harder or not so hard on the key after the initial key press. Remarkably natural feeling. (But, of course, was useless for realistic piano sounds.)
#101
In reply to #99
01/10/2008 11:23 AM
Try a clavichord - that ancient mechanical contraption even allows you to adjust the pitch after the note is sounded.
In reply to #101
01/11/2008 7:32 AM
As flexible as it is, you can not crescendo a piano!
#118
In reply to #115
01/11/2008 10:20 AM
Clearly you can't crescendo a single striking - but you can repeat strike (hard to avoid vulgarity here, perhaps?). More significant, the perception of a crescendo can readily be achieved by building the sound with successive notes (perhaps even the most creative of us work better when given some constraints to overcome).
Good Answers: 247
#122
In reply to #101
01/11/2008 11:36 AM
Funny you should mention it. For a long time, I wanted to build a clavichord, probably from a Zuckerman kit. Now, the instruments I already have spend a lot of time idle, and about the last thing I need is another building project. Also, the idea of having one doesn't resonate with me as it use to. I think they are pretty neat, but they no longer pull my heart strings.
01/08/2008 9:00 AM
Well, it depends. A perfect 5th, or 7 semitones, is 1.5 times the root frequency. 27/12 = 1.4983070768766814987992807320298, which isn't quite 1.5. So it depends upon whether the http://en.wikipedia.org/wiki/Equal_temperament tuning or the http://en.wikipedia.org/wiki/Meantone_temperament tuning method is being programmed.
For the piano in René's humble café, it probably doesn't matter, as everyone puts cheese in their ears while Edith sings. Plinky plinky plinky, plinky plinky plonk....
Good moaning!
01/09/2008 8:19 AM
How frequently you need to tune the piano will depend on the volume (all senses) of use - as well as how fussy you can afford to be. Opinions vary, but I believe that a concert-grade piano that is played for two-to-three hours each day needs tuning every two-to-three months; if you practice Rachmaninov at full volume it would even be more frequent. A well-built piano (your Steinway or equivalent) that is played gently for half-an-hour a day or less will usually show signs of needing tuning in about six months, but will probably take no harm if left for up to a couple of years - and many people are quite happy to put up with the imperfections.
01/09/2008 9:35 AM
Yes, typically a note/key would have to go dead or the strings start buzzing or some other noticeable defect before Mom called the piano tuner to fix it and then go ahead and tune the whole piano. We did get it tuned more frequently when my older brother took drum lessons from a well known retired and semi-legendary local Dixieland jazz musician who doubled as a piano tuner. We enjoyed having him over to the house where, after my brother's drum lessons, he regaled us with Dixieland tunes for an hour or so on the piano, commented on the pianos tuning, and as a result, Mom would schedule him back for a more frequent tuning, when he would entertain us more after he finished tuning it. I think he enjoyed the visits and the opportunity to perform again, even if for a small audience. On the rare occasion that he performed in public with one of the old Dixieland bands (usually the Singleton Palmer Band), we would sometimes be treated to free tickets as his personal guests. He was a great old guy!
In reply to #60
01/09/2008 10:25 AM
That was perhaps too long - by the time something dies or starts buzzing you might expect permanent degradation ("set" effects at the end of the string, for example).
Unfortunately (cost wise), none of my family or friends will put up with degradations that (to my ear) are less irritating than the basic issues that apply to all Steinways. (I.e. bottom octave sounding way out of tune when sounded alone, pitch of top end changing during the course of the note, etc - all due to the overtones being essentially non-harmonic. BTW, Fazioli has made a start in correcting the top end, but there's no-one local who's equipped to tune the sympathetic resonators he uses for the purpose)
Good Answers: 247
01/09/2008 3:33 PM
Good question.
I play an electronic keyboard, and use to pay a grand piano. There is really no comparison, but for me, being an uncouth uncultured nitwit, the electronic is just fine for the reasons you mention. The action is much lighter, so if I went back to a grand it would take awhile to adjust... but I play poorly enough that no one would notice: One sows ear is pretty much like another.
My second synthesizer was an ensoniq, (an interesting mix of sampled and pure synthesized sounds) and the sales brochure read exactly like an ad for a sophisticated multiprocessor computer -- which is what the thing was, but I'd have though they'd advertise it in musical terms.
I've now gone even further down scale to a small Yamaha -- and its fine! Fun for me, fun for the kids, etc. And, of course, it makes a million bizarre sounds that could never come out of a piano. It's not a "piano" but it is a great instrument in its own right. And dirt cheap besides.
In reply to #75
01/09/2008 4:42 PM
Well, pianos are on of the most ubiquitous instruments there are in whatever form or fashion, and I have always envied those who could either sight-read popular sheet music or play by ear and entertain friends, family, and the public at large with their skill and artistry. I own a few keyboard "toys" myself, and having had a few lessons as a child, consider myself more of a "duffer" when it comes to playing (around with) the piano. I can pick out a melody easy enough and add a couple of bass chords to accompany them, but that is about it.
I thought that if I had a real piano, or its electric equivalent, it might be something my kids would get into, and who knows, we might get a real musician in the family. Oops, I should add that my brother the Geologist is a fairly skilled musician, playing drums, piano, keyboard, guitar, and flute (and possibly others I don't know about) Currently, being into reggae music, he has developed a relationship with Bob Marley's band, The Wailers, whereby they often ask him to come up on stage and play his silver flute with the band for certain numbers they do when they tour in the US and he is able to get to the venue.
Anyone interested in Reggae music might enjoy his "Fluteman John" webpages:
http://home.earthlink.net/~flutemanjohn/
Yeah, that's him, the one whiteguy in the group photo!
Good Answers: 247
#81
In reply to #79
01/09/2008 9:09 PM
I'd definitely recommend getting either one... although the electronic ones are probably more likely to attract kids, and easier to fit into the house and move around I think. I found I wasn't using my ensoniq after we moved a few years ago (hadn't gotten around to unpacking it, finding a place near an amplifier and speakers, etc.), so I thought I might as well sell it to someone who would make better use of it, and get something inexpensive that the kids could play, and that had built-in speakers. Mine has a very good sample-based grand piano sound, does not have weighted keys, and for amusing myself, works great. The ensoniq went to a professional musician who was thrilled to get it, because is has some sounds which other pro keyboards can't duplicate. So everyone is happy.
Get one, have fun.
Good Answers: 88
01/08/2008 12:23 AM
Hello PWSlack,
Although there is a very slight change in net tension overall, it is rather the extreme tension of each string that causes the string to behave acoustically more like a metal bar than the idealized, infinitely-thin strings we find in physics textbooks. Where idealized strings produce perfect, integer-multiples (harmonics) of the fundamental, metal bars do not. In a piano string, even a slight departure from equilibrium stretches the string slightly. This effect, coupled with a real string's non-zero thickness, causes the overtones to depart from a purely harmonic relationship to the fundamental.
Cheers!
-e
#134
01/15/2008 4:45 AM
easie said:
Decadence
Jstacat
#138
01/16/2008 7:07 AM
What about Doppler?
01/07/2008 11:16 PM
Maybe it was in tune, but in the wrong octave?
01/07/2008 11:39 PM
To tune a note on a piano, the tuning fork and the note are sounded together, and if the note is in tune the combined sound is constant in volume over a long period. If the volume of the sound increases and then deceases (and so on), then the piano note is not the same frequency as the tuning fork, and the two sources of sound are said to produce "beats" The beat frequency is the difference in frequency between the 2 sound sources. The louder part of the combined sound occurs when the sound waves arrive at the ear in phase, the softer part of the combined sound occurs when the waves arrive at the ear out of phase by 180 degrees.
In the case in point, the piano not was out of tune by <0.1Hz, which produces beats at one beat per >10 seconds. When Tommaso heard the note and tuning fork it happened that the combined sounds were approximately in the same phase for 5 seconds, and hence were approximately constant in volume. Giovanni was listeneing for more than 5 seconds and knew that the notes were beating. In the following 5 seconds Tommaso heard the volume change as the note and tuning fork changed relative phase, and was therefore convinced that the note was not in tune.
Don't vote it only encourages them
Reply Good Answer (Score 9)
Good Answers: 88
01/07/2008 11:54 PM
Yes, but the combined sounds of the piano string and the tuning fork are not perceived as variations pitch, but as variations in loudness as the sound waves from each alternately reinforce and cancel.
01/08/2008 1:21 AM
I thought I clearly explained that the beats were a variation of loudness. Where did I even hint that the notes were perceived as variations in pitch
The beats occur with a frequency which is the difference of the 2 notes
Good Answers: 88
01/08/2008 8:28 AM
"I thought I clearly explained that the beats were a variation of loudness. Where did I even hint that the notes were perceived as variations in pitch."
Your hint is supplied by the fact of your response itself to the Newsletter Challenge, which asks why Tomasso perceives a change in pitch. But if your answer is not to the question posed by the Newsletter Challenge - and apparently it is not - then what question are you answering? The Challenge question does not ask why Tomasso perceives a change in volume, but why he perceives a change in pitch. If you are not even hinting, as you say, that the notes are perceived as variations in pitch, shall we then consider your answer off-topic?
01/08/2008 9:32 AM
"Your hint is supplied by the fact of your response itself to the Newsletter Challenge, which asks why Tomasso perceives a change in pitch."
C'mon "e"! Go back and re-read the original question! To0 lazy? OK, I will paste it here:
The question does NOT ask "why Tomasso perceives a change in pitch", but "what happened to change Tommaso's mind, and Lleros is clearly correct that with more time, Tommaso was able to hear the same thing that Giovanni had been hearing, i.e. amplitudinal beats with a long period caused by the extreme closeness of the two audio frequencies but not perfectly in tune (which would have an infinite period based on the calculation Lleros clearly stated.
You are usually better than that "e"!
Good Answers: 88
01/08/2008 2:56 PM
You're absolutely right. My bad. I should wait until after my morning coffee before making assumptions. Usually by then I'm too busy jumping to conclusions, but it keeps me in shape.
Good Answers: 247
01/09/2008 2:52 PM
I suspect that when he said "the louder part" and "the softer part" he was referring to loudness, not pitch.
OOPS -- caught this in the edit window. You've already been chastised for your woeful behaviour. No need for me to rub your face in a senior moment.
Ignore what I said above. But which?
01/08/2008 3:32 AM
I believe this is the correct answer!
cheers
RF_G
Regards, RF_guy
01/08/2008 4:32 AM
Wow. I think I'm going to remember this tid bit of info for a long while. Trying not to be sarcastic, but your changed part of my life. I'm sure that this can be used for other applications. Cheers. Nice Answer. Go Aussie
If you don't laugh, you cry.
#105
01/10/2008 2:38 PM
I think you are right !!! It couldn't be something as simple as listening more carefully or longer.
01/08/2008 12:27 AM
I think that when the fundamental note is struck and compared to the tuning fork, in the first 5 seconds the pitch may sound like a match.
As the fundamental note sympathetically excites the harmonic over and under tones and the strings at different octaves, the decay rate is shortened if the fundamental note is off by 1 Hz or even a fraction of a Hz. This rapid decay could be caused by phase cancellation or dissonant damping.
From this, if the instrument is not still resonating after 10 seconds the string or strings are not in tune.
Looking forward,
Tomqwest
01/08/2008 1:50 AM
One has to be careful in talking about the harmonics of a piano note. The string is considered to be a stiff vibrating component, and the "higher harmonics" are not true harmonics. This is what gives a piano its distictive sound.
Synthesising a piano using harmonically related electronic oscillators will not quite sound realistic unless the higher harmonics are adjusted.
I will stand by my explanation, that we are observing beats of the fundamental note of the piano and tuning fork, although in the tuning of a violin or a cello one listens for lack of beating between open strings which are a fifth apart. For example the 3rd harmnic of the open D string is matched to the 2nd harmonic of the open A string.
A certain amount of this technique is used by the piano tuner, but to a limited degree because not only do the notes on a piano contain non true harmonics, but the piano is tuned to a tempered scale whereby the fundamental frequency of notes are related to each other by the constant ratio between half notes of (13th root of 2):(1). This means that the 3nd harmonic of D is not the same frequency as the 2nd harmonic of A as it would be on a violin or cello.
A good solo violinist will play truly sweet notes according to the harmonics explained above, but will have to "pull" frequencies a little when playing to piano accompaniment.
Good Answers: 42
01/08/2008 2:31 AM
Having played piano, cello, clarinet, and spoons I have to agree with your beat answer. it was how we tuned our instruments. (But 1 beat every couple seconds was as good as my ear could discern!)
01/08/2008 5:39 AM
Hi GW.
I play the violin, and when the tuning fork is struck the string that is to be tuned will vibrate at the same frequence when it is in tune, it is called sympathetic vibration!
Spencer.
Good Answers: 42
01/08/2008 2:28 PM
I was always able to get the sympathetic vibration and still have a beat. It didn't seem to have a particularly high "Q" test.
I see the same thing in tuning variable speed drive systems, the forcing function does not have to be spot on the resonant frequency to excite the resonance.
Hobbies - Musician - Jimmy Page Wanna be (Who isn't?) Popular Science - Weaponology - Navy Fire Controlman and LCAC Craftmaster United States - Member - Member
01/08/2008 8:07 PM
I play guitar, but I don't ever tune it. Am I supposed to? I thought those knobs were for when the strings start buzzing on the frets, you crank a knob a few times 'till it stops buzzing. I wondered why my kids go outside when I reach for the axe!
Science does not know its debt to imagination. ~Ralph Waldo Emerson
01/11/2008 10:24 PM
Guitar players are never in tune... And we like it that way!!!
01/08/2008 8:03 AM
Actually the trick with the harmonics can be used to test the tune of a piano. For instance if you gently depress the "C" key on a piano such that the hammer does not strike the strings, and while holding it, sharply strike and quickly release the "C" key one octave lower, you will hear the note you are holding ringing. This is again an example of sympathic vibration. If the note is out of tune you will not hear the held note ringing.
01/08/2008 9:20 AM
Lleros MaHarg, I did not understand your calculations of the constant ratio between two successive half-tones (13th root of 2):(1) ????? In my humble opinion, it should be instead 12th root of 2 i.e, approximatively 1,059463... Perhaps the difference of tuning two contiguous half-steps using your formula would not be immediately perceptible, but considering a range of various octaves, I am not so sure...
01/08/2008 4:48 PM
Dear Slimac,
My apologies, you are correct, 13 notes to an octave counting the first note and the last one (an octave above). 12 half note eqally tempered intervals in between.
Ratio between half notes is (12th root of 2):(1) with ratio.
It certainly stirred a hornets nest, got the musicians out of the woodwork, excellent multi discipline discussion. Should be more challenge questions like this.
It's all freshman physics, with a small component from my cello playing days, plus a bit of logic
Lleros
Good Answers: 42
01/08/2008 5:28 PM
Most interesting is the applied science, obserations from practical application, and the theory from the musicians. ( Is this not true engineering, that is applied science?)
01/08/2008 10:47 AM
I am not disagreeing with your explanation and I will say that i am in agreement with the bulk of it.
However being a musician and having tuned several instruments and have had a piano tuned several times I believe what Giovanni was listening for are whats called Cross-tones. This is the effect that happens when to instruments are just barely out of tune. They are more of a pulsing that happens at a faster rate when the to instruments are at their farthest point of tuning and a much slower rate to the point where perfect tune in made and there is no more pulse.
For a close approximation of this phenomenon take 2 identical wine glasses and fill them half full with water. alternate ring them and keep the tone going as long as you can. if they are exactly the same fill and structure you will hear nothing in the background if they are slightly off you will hear the pulse of which i am speaking. gradually add or remove water from one glass and you will make the pulse faster or slower. Slower means closer to tune faster means farther from tune. Best to do this with your eyes closed and concentrate on the combination of sounds and the extra tone they make not the individual sounds.
I watched a blind man tune our piano when i was a child and I sat quietly for hours as he did so. (no easy feat mind you) He educated me as to what to listen for and demonstrated it many times during the tuning of our piano. At the 5-10 second mark if the long duration pulse is not heard then the string being tuned is now correct.
As stated by previous posters Tomasino... Tommas...tom...the other guy did not wait long enough to have been able to hear this pulse before making his decision as to the state of the tuning of this particular string.
Just a note: If you have a piano and want to have it tuned. If the tuner is not blind find another. Their perception of sound is much more acute than that of a person who can see. Plus its really cool to watch them do their thing without being able to see a thing.
01/08/2008 4:29 PM
As you appear to be a person who has done this in practice, I'd like to ask you a question: do you observe this length of cross-tone (or beat) when comparing a note on the piano to a note from the tuning fork? (I've no difficulty with the idea that you can hear this when comparing different strings that are below middle C, as the sound is relatively similar and decays at a similar rate, but I fear there could be problems when comparing with a tuning fork)
Thanks
Fyz
Good Answers: 247
#92
01/10/2008 9:25 AM
I can't help but notice that your post number is the second harmonic of Llero's. Spooky.
I think "beats", "beat," or "beat frequency" are the more common terms to indicate what you refer to as Cross-tones. Granted, I don't have any real data to support that, but in my experience, everyone tunes by listening for "beats", assuming lack of perfect pitch.
#95
In reply to #92
01/10/2008 10:36 AM
I suffer with what is known as "prefect pitch". It is a d....d nuisance when singing in ensemble (in fact I've had to learn to suppress it), and is of absolutely no help when tuning a piano. Perfect pitch would be better described as "absolute pitch" - the note's pitch is directly tied to its notation identifier within the ear-brain combination.
What it doesn't imply is greater frequency acuity. Even where some correlation exists, you would be looking at discriminating something in the region between a tenth and a twentieth of a tone, which is between 5Hz and 2Hz for the 440-Hz tuning fork - which is much less precise than is required to avoid interference effects degrading the piano's sound.
Good Answers: 247
#98
In reply to #95
01/10/2008 11:00 AM
"prefect pitch"
This would be the sort of pitch possessed by a chief of police, I assume. Therefore, I'm guessing it would be used in tarring and feathering criminals?
01/08/2008 1:05 PM
I agree much of what you say here. But, while many (most?) string players believe that they play to harmonics when a piano is not involved, this is not actually correct.
The most obvious demonstration of this would be the use of major and minor thirds. The "equivalent" harmonic relationships would be 1:25:1 (major third) and 1.2:1 (minor third). That is about 0.059 of an octave, or 0.7 of an average semitone. But I for one (when unaccompanied) play the difference between a major third and a minor third as a large semitone.
A secondary piece of evidence is the difficulty when instruments play one fifth apart. If the notes played separately sound "in tune", the sound when put together will often be terrible; I believe two factors are at play here - first, the 1.5:1 frequency relationship makes difference notes extremely audible, and second, the usual size at which we play a fifth is relatively close to the factor 1.5.
BTW, although I expect that your answer to the challenge will be the formal answer, I'm not certain that it is completely realistic. I'd appreciate your comment on the following:
Assuming the tuning fork and piano note to be somewhere between 440- and 512-Hz, they will both decay very significantly over a few seconds - possibly sufficiently that you it will be extremely difficult to detect a beat with a period of more than about three or four seconds. What could happen is that the levels are initially so disparate the general decay in amplitude hides the beating effect; then, as the note decays the levels become sufficiently similar that the beat is larger than the general decay.
This is of course purely theoretical - I would prefer to make a practical check, but my piano is due to be tuned in about four weeks, and its pitch is not close enough to my tuning fork to confirm whether I could detect a beat period of 5-seconds** or more in the presence of un-cancelled overtones and decaying levels.
The same does not of course apply to the difference in pitch between the multiple strings that make up the notes - they will have similar amplitudes and decay together, and the results will certainly be extremely audible
**N.B. that this represents a frequency difference of < 0.05%, or less than 1/24 of a tone
Regards
Fyz
01/09/2008 6:59 AM
"For example the 3rd harmonic of the open D string is matched to the 2nd harmonic of the open A string."
I believe this can lead to another snare if people tune using overtones without the fundamentals present. The natural frequencies of the overtones of the strings are not exact multiples of the fundamentals. The overtones only vibrate as exact multiples of the fundamentals when the action of the bow locks the overtone to the fundamental frequency.
When people tune using overtones alone this does not happen, and both overtones will be sharp; however, the overtone of the lower string will be sharper (relative to its fundamental frequency) for two reasons - it is a higher harmonic working on a shorter string, so any rigidity will have more effect, and the core of the string is usually thicker in the first instance. What happens with violin "e" strings is another matter again - the properties of a solid steel string are entirely different from the gut (or other soft-cored) lower strings. That is why I prefer to tune with both string fully vibrating simultaneously.
Now that's just an oversimplified theory - in practice when two strings played together they are coupled via the bridge and the bow, so they don't sound exactly the same pitch they would when played separately. Could this be the reason that other peoples' tuning sequence never sounds quite right?
Of course, it's not that critical in the end, as the pitch is continuously adjusted when playing - this is always needed to match our learned (cultural) expectations, and also to blend with other players when playing in groups.
Good Answers: 19
01/09/2008 8:23 AM
When tuning my guitar, the beating of the strings can also be seen as the amplitude of the vibration varies. When the two strings are closely matched, the amplitude varies only slightly and over a very long period. Being tone deaf, the visual aspect helps me alot.
Another amusing way of tuning the guitar is by puting a tiny piece of folded paper on the string and then tuning it with either another string or a tuning fork. The paper literally jumps off. Can be a pig to get it out of the guitar afterwards.
omw7
01/08/2008 8:07 AM
While I like the explanation that Lleros MaHarg gave us (and I will remember it for some applications), it is something that only somebody dealing with THIS situation would know (excuses, Lleros, if you just came to the answer by pure abstract thinking -I am only an engineer ).
I am still waiting for the explanation of the one who published the puzzle.
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
01/08/2008 9:59 AM
I have to disagree with you Indel. The explanation the Lleros gave regarding audio beats is basic physics, taught at the freshman or sophomore level in any Engineering school, in fact, even in High School Physics, and should be common knowledge for any engineer, not just "somebody dealing with THIS situation". I, and I am sure several others had reasoned this out as well, but Lleros beat us to the punch and posted first. Usually, I do not like to post the same answer as someone else who has nailed it, except to give credit by agreement and defend the answer if needed ("e", please note!)
Now, when it comes to his mathematical description of the frequency relationships of piano notes to the scale and to other instruments, well that is a cat of a different color. That would require some specialized knowledge of the physics of the piano, other instruments, and some music theory as well. But he only brought that up in relation to other posts, not to his original, and IMHO, correct answer. We could have just as easily been talking about a guitar string. In fact, I have used the zero beat method, as well as sympathetic vibration in tuning guitar strings from a tuning fork or from a piano.
Zero beating also has applications other than strictly musical or audio frequencies. Zero beating is a tried and true method of tuning a radio to match the frequency of another signal for optimum communication, often used by amateur radio operators (Hams) and others, especially back in the day before digital tuning when all you had was an analog dial and your trusty BFO (Beat Frequency Oscillator)
Bottom Line: You don't need "pure abstract thinking" (whatever that is!) to come up with or to understand his answer, even if you are "only an engineer"!
01/08/2008 10:41 AM
I agree with you in all you have said about audio beats. Actually, not only audio – Lissajou, eye pattern, you name it…
What I was saying was a bit self-criticism and a kind of (un)hidden envy for people who have time for "abstract thinking" i.e. things they are not involved with in their immediate professional life.
I know, this is how the great ideas have been "brewed", but I am just a humble worker who spends his spear time with stock market, tv action movies, some home improvement,
In one word (actually two - to avoid another correction) an ordinary engineer.
United States - Member - New Member Fans of Old Computers - Apple II - New Member Hobbies - Musician - New Member Engineering Fields - Systems Engineering - New Member Engineering Fields - Software Engineering - New Member
01/08/2008 3:08 PM
Further to the guitar example, a common method for tuning the instrument is to tune the "A" string, e.g. with the help of a fork and then play the A on the "E" string (5th fret). Both should have the same frequency, so you can tune the second string by eliminating the beat.
Of course You will repeat the same process with each newly tuned string and the one immediatley higher in pitch.
Beat is your friend, I believe it is indeed the right answer.
01/08/2008 10:52 AM
I think the frequency of the tuning fork and piano key were very close to sync and it took a few seconds for the low frequency difference beat to be heard by Tommaso.
01/08/2008 10:59 AM
Why post this? It just reiterates, with no explanation, what Lleros so eloquently illuminated in post #11.
Don't "guests" read before posting?
01/09/2008 8:17 AM
Because the fella wants to be heard in an international forum. Where else can you have a discussion with people on the other side of the globe?
01/09/2008 9:23 AM
Then why doesn't he register and sign in like the rest of us? And why doesn't he contribute more than just a lame and trifling rewording of answers that have already been posted with much more content to back them up? I am always disappointed when I get notified that someone has added a posting to a thread I have subscribed to and find only this kind of worthless wasted of electrons! And, you call that kind of short, anonymous, repetitious posting a discussion? Oh, please! If he just wants to chat with "people on the other side of the globe" he should go to Myspace or some other forum or chat room, but maybe they do not allow anonymous "guests" to post!
In reply to #59
01/09/2008 10:14 AM
I think that is unnecessarily unkind. It's a sensible and concise answer (although I'm doubtful whether it is correct for string vs tuning fork - I'll check next time the tuner comes). I think we should accept that guests are often trying the waters - and perhaps that those who are at least sensible should to be encouraged.
Good Answers: 247
01/09/2008 3:16 PM
And why post this? So we have 2 (now 3) rather than just one post that ads nothing new?
Don't members have better things to do than criticize guests? Perhaps the guest though his post was more succinct than Llero's excellent explanation.
In reply to #73
01/09/2008 4:22 PM
Touché, Ken. The count is now up to 6 gratuitous postings (counting yours of course!).
I will try to limit my future responses only to important, crucial, vital, essential, indispensable, necessary, needed, needful, or required postings!
In reply to #78
01/10/2008 8:08 AM
STL,
I like your postings, they give depth to the discussion, but consider the fact that we are more experienced at this. More than likely the newcomer is reading the question and just hits the very first reply button he sees, without reading any of the comments already posted. They may be preceiving the intent of the forum is to see how many different postings come up with the same thing. Preception is in the eye of the beholder.
Please keep posting your insightful experiences but please ease up on the new guys.
01/08/2008 3:08 PM
Perhaps Tommaso struck the octave keys and heard they were at the proper frequencies and compared them to the tuning fork frequency as well as that of the "tuned" key.
01/08/2008 3:33 PM
if the string being tuned is either new or very old, that is not having been tuned in a long time, when the string is stretched for tuning it will inevitably return to its original position this will cause a change in pitch. The string held the proper frequency for 5 seconds after an additional 5 seconds the string stretched changing the pitch. This is the result of being a new string or very old string. This happens frequently when tuning stringed instruments. A pitch can change over 10 seconds depending on the condition of the strings.
01/08/2008 7:13 PM
The mention of five seconds twice is the give away here. Beating. As the piano string and pitch fork vibrate at slightly different frequencies, the volume appears to change.
01/08/2008 9:02 PM
Most probably this is due to the Diopler Effect.
Since Giovanni was tuning the piano we can assume that he was stationary.
As Tommaso was passing passing by most probably he was walking towards Giovanni when he listened to the turning.
On the next five seconds most probably he was also stationary.
01/09/2008 6:37 AM
Perhaps Tommaso is completely tone-deaf and regards the question "is it in or out of tune" as a 50:50 gamble. Alongside with his acute amnesia he is unable to remember his previous choice, so when asked 5 seconds later it is another guess.
With the rules of probability and given the outcome at time t=0, with another non-weighted flip of the coin at time t=5seconds, his answer has changed.
01/09/2008 9:12 AM
There, you have it. A 440 Hz wave combined with a 440.1 Hz. I set a 90 degrees phase.
Lleros, I will vote for your answer as a good one.
01/09/2008 10:08 AM
Now add different decay rates that represent different decay rates for the tuning fork and for the piano string. Say set the decay to -6-dB at 2 seconds for the piano and at 1-second for the fork respectively. (I think that would be thetas of about 693m and 346m). You won't get a clear beat there
Now a second experiment: have the frequencies coincide exactly but in antiphase, start the piano 6-dB greater than an electronic reference, and set the decay of the piano to 6-dB at 7 seconds (theta ~ 100m) and the electronic reference at constant amplitude. Same frequency signals, but there is a clear minimum.
I believe this shows that the beat method is not suitable for observing frequency differences unless the amplitude decay times are sufficiently similar. This is clearly the case for comparing the sounds different strings of the same pitch, but more than five seconds per beat seems highly unlikely when comparing a piano note against a tuning fork as implied in the question (and inferred for the answers)
Good Answers: 247
01/09/2008 3:06 PM
I'm quickly swinging through here, (so forgive my possible too quick read of your response, but I've tuned pianos, and find LLeros explanation right on the money (at least in terms of it's being a good response to the question, which I assume is simply trying to get at the beat frequency concept.) I'd say that one beat every 4 seconds is about my limit for detection, but others could do better.
In reply to #71
01/09/2008 4:05 PM
Excellent, experience-based post. Kudos, Ken!
#84
In reply to #71
01/10/2008 4:39 AM
Actually, if you have access to a suitable instrument, you'll not find it hard to hear beats at even 30 seconds (on a single note from the piano), particularly in the lower-mid regions where the strings are in pairs and the destructive interference is pretty-much complete. But tuning to that accuracy is a different matter, and opportunities to hear such things in music are, to say the least, limited.
The situation when comparing a string with a tuning fork is completely different, however. So either it's a badly-posed question, or the beats are much faster but only become audible to Tomasso as the sound levels of the piano and the tuning-fork become similar - after about six seconds.
By the way, if I had my 'drathers, I'd have a tuning fork that was about 441-Hz, and tune to the known error - that way you know which direction to adjust.
Good Answers: 247
01/09/2008 3:20 PM
01/09/2008 9:53 AM
OK, since some of our guests are having some fun with this thread I'll have a go as well!
Giovanni was tuning his piano using a tuning fork when his friend Tommaso stopped by. Tommaso listened for five seconds and then confidently told Giovanni that the key was in tune. Giovanni disagreed. After about five more seconds, Tommaso was forced to agree that the key wasn't in tune after all. What happened to change Tommaso's mind?
It seems that Giovanni and Tommaso, besides being music lovers and excellent piano tuners, are also hit-men and members of the local Mafia. And as usual, when Mafiosi want to settle an argument, weapons are drawn. Well, it seems that Giovanni ("The Tuner") got the drop on his buddy Tommaso ("Tommy Two-tone"), and, staring down the gleaming barrel of a shiny chrome-plated Colt .45 ACP automatic, Tommy was "forced to agree" with his friend and change his mind. The five seconds were exactly how long it took Tommy to decide if it was worth finding out whether or not his Looney Tunes "buddy" would pull the trigger or not if he continued to disagree!
Engineering Fields - Electrical Engineering - Analog and Digital Circuit Design Engineering Fields - Electromechanical Engineering - Transformers, Motors & Drives, EM Launchers Engineering Fields - Engineering Physics - Applied Electrical, Optical, and Mechanical
Good Answers: 119
01/09/2008 10:17 AM
The "beat" frequency (f1-f2) was ~0.1 Hz. Tommaso needed to wait a full 10 seconds to hear it.
01/09/2008 12:35 PM
The first thing that struck me, was the Doplereffect. This question is for realistic, accurate ENGINEERS, not for shaky, sensual MUSICIANS.
So, after looking through al the dilldalling forerunners, I was glad as I came to the Guest with the diopler, - there is still hope for the engineers.
However, I dare not ask for his/her age.
In reply to #66
01/09/2008 1:23 PM
Maybe someone needs their dioplers changing? 4mph is not large enough to create a discernable change in pitch, and the sounds would be coming from much the same direction, so their relative pitches would be essentially unchanged. Obviously, Tomasso has to be relying on beat notes.
When moving, he'd hear level variations just from the reflections, so he's more likely to think the piano is out of tune when it was actually correct. Plus "stopped by" presumably means just that.
In reply to #68
01/09/2008 2:14 PM
Now THERE is a guest (#68, not #66) with something worthwhile to say, as opposed to #66 who seems to just grab onto anything that, sort of, sounds right to him, and he gets to make fun of "shaky, sensual MUSICIANS" and calling people with other answers "dilldalling forerunners" (I guess that includes you, too, Fyz! ).
Call it unkind (and I have been called worse ), but personally, I would like to see more from guests like #68 and less from those like #66. I hope #68 comes back and registers with his own screen name so we can become more acquainted and appreciate his contributions. Guests like #66 can just, well...GO AWAY!
By the way, #50 wrote "diopler", when I am sure he was referring to the "Doppler effect", and not "diopter", which is an optical measurement. I am hoping that #66 just repeated the mistake for comic effects (which I am pretty sure is what #68 did when he repeated it as well). At least that part of his post was amusing!
Normally, I try not to be nitpicking on speling misteaks <grin> but it might be a bit indicative here. Perhaps more posters should use the spell-check function. Both "Doppler" and "diopter" were offered by the spell-checker as alternatives to "diopler".
#83
In reply to #69
01/10/2008 4:26 AM
These so called insults passed right over my head. "Shaky, sensual musicians" sounded good to me, as I was always rather pleased with my vibrato. To my mind, Dilldahl should be a Scandinavian version of a classic Indian dish - perhaps on second thoughts I should take that one as an extreme affront.
In reply to #83
01/10/2008 9:10 AM
"These so called insults passed right over my head. "Shaky, sensual musicians" sounded good to me, as I was always rather pleased with my vibrato. To my mind, Dilldahl should be a Scandinavian version of a classic Indian dish - perhaps on second thoughts I should take that one as an extreme affront."
You should take it as an extreme affront, but not for the reasons you refer to. I don't know why "Shaky, sensual musicians" should sound good to a musician (OK, I get the sensual part, but not Shaky), since he is contrasting that description with "realistic, accurate ENGINEERS", implying thereby that shaky (flaky?) musicians cannot be realistic or accurate, like Engineers. Well, brother, I have known plenty of so-called "engineers" who were not realistic, nor accurate, and musicians who were steady as a rock and both realistic and accurate, so I don't think it is fair to stereotype any profession.
And to accuse all the posters of alternate solutions as "dilldalling", where I guess he means "dillly-dallying", well, I will just leave you to draw your own conclusion after reading the Merriam-Webster definition below:
dillydally
Main Entry: dil·ly·dal·ly
Pronunciation: \ˈdi-lē-ˌda-lē\
Function: intransitive verb
Etymology: reduplication of dally
Date: 1741
: to waste time by loitering or delaying : dawdle
#93
In reply to #90
01/10/2008 10:17 AM
There, there now (pats STL on head). Doubtless, it was intended as an affront, but failing my ability to apply suitable punishment (boiling oil being regarded as unacceptable these days) I prefer to reinterpret as if at least some part of the post had been sensible.
Now, Shakin Stevens isn't quite my thing, but the fact remains that music should be at least in part a sensual pleasure, and the right sort of shaking is fine (be it vibrato or maracas). I definitely go for rock-solid (in the sense of controlled rather than rigid) rhythm, dynamics and and intonation - and that's not a bad analogy for engineering design either.
Good Answers: 247
#97
In reply to #90
01/10/2008 10:55 AM
Unless there is someone here actively engaged in tuning a piano, and in vital and immediate need of theories thereof, then I think all of us would have to say we are dillydallying. (Of course, such a person would best carry around a spectrum analyzer to see if anything we've said bears any resemblance whatsoever to practice.)
3Doug (1); agua_doc (1); Anonymous Hero (1); Anonymous Poster (20); ArcticZone (1); Blink (21); bob c (1); Cardio07 (1); Crabtree (1); cuznmonkey (2); dmunk (2); geomech (1); GW (3); indel (5); jdretired (1); jfcayron (1); LCAC32 (1); leveles (1); Lleros MaHarg (3); Lleros Marharg (1); mjb1962853 (1); omw7 (1); Physicist? (26); PWSlack (1); RF_guy (1); RickLee (10); Scapolie (1); Slimac (1); Snaketails (1); Steve S. (4); STL Engineer (17); tomqwest (1); user-deleted-1105 (1); user-deleted-13 (7); Vasilios (1)
Previous in Blog: Sparking would be bad: Newsletter Challenge (01/02/08)   Next in Blog: Soda Pop: Newsletter Challenge (01/15/08)
