Previous in Blog: Lost Binoculars: Newsletter Challenge (01/29/08)   Next in Blog: Dumbbells: Newsletter Challenge (02/12/08)
Cleaning The Pool: Newsletter Challenge (02/05/08)
Posted February 03, 2008 5:01 PM
The question as it appears in the 02/05 edition of Specs & Techs from GlobalSpec:
Tomas purchased a new swimming pool for his family. Unfortunately, after their first dip in the pool, they discovered their daughter, Juanita, was allergic to chlorine additions. Tomas tried using bromine and several other chemicals, but little Juanita also developed a rash from exposure to these harsh chemicals. She was unaffected by very low levels of the chemicals, but these would only clarify and adjust pH while leaving the algae and parasites alive. How can Tomas kill the algae and parasites and keep the pool clean without giving Juanita a rash?
(Update: Feb 12, 8:54 AM EST) And the Answer is...
Tomas should purchase a chemical free UV sterilization system for the pool. The UV water sterilization system should allow them to kill the algae and parasites and keep their pool clean with only residual levels of chlorination and pH control chemicals. Tomas will not get a rash because high levels of harsh chemicals are not required. Another benefit is Tomas will never have to add chemicals to the pool again.
Industrially, UV Light Systems are useful for sterilization, curing, analysis, identification and sunlight simulation. One manufacturer even provides a consumer product for pools, the Sentry Aqua Guard Pool System.
#86
Re: Cleaning The Pool: Newsletter Challenge (02/05/08)
02/06/2008 8:18 AM
Ozone! My hot tub uses it,
02/06/2008 8:18 AM
Tomas and his family, while enjoying their chlorine free pool, happen to notice an odd looking couple in the distance using a map fashioned into a crude telescope watching them swim. It is very advisable not to skinny dip around here.
#88
02/06/2008 9:15 AM
Tomas can utilize ultraviolet technology to kill bacteria while keeping his daughter rash free.
#89
02/06/2008 9:28 AM
Look to municipal wastewater treatment systems, they have all been changing over to ozone often combined with UV. For the pool system and without the need of 99.999% purity as wasterwater treatment, a UV system would work. The water passes into the UV chamber where one or several UV bulbs irradiate the water. The UV has a peak at 254 nm, which happens to correspond well with the absorption of DNA. This results in the DNA being split and killing simple organisms such as bacteria and algae and even small parasites.
Tell Tomas to shop here: http://shop.solardirect.com/product_info.php?products_id=332
Now little Juanita can swim without those pesky chemicals.
#90
02/06/2008 10:58 AM
Two choices: An ozone generator, or a high intensity UV source
#91
Cheap and reliable sensor for chlorine levels?
02/06/2008 11:03 AM
I am thinking that a possible better solution is to regulate the chlorine with a simple feeder running off the filter pump and set the chlorine level at the same value that you get from a salt system.
The more I read about some of the alternates, chlorine doesn't seem too bad; if you control the concentration.
Some of the issues that I didn't consider is what is the environmental impact if you have to dump 20,000 gallons of pool water to repair the pool? That happened to the previous owner after a hurricane damaged the pool.
All of the alternate systems still require weekly shock treatments of chlorine (as recommended by the manufacture) anyway. Then there are long term maintenance costs. UV bulbs degenerate in intensity, other chemicals can stain or degenerate objects in the pool, blah, blah.
Does anyone know of a cheap and reliable electronic sensor for chlorine levels?
It would seem that if you could monitor the chlorine levels you could dynamically adjust the infusion of chlorine to keep the level consistent with the demand. A simple software program can easily manage that with a cheap PIC microcontroller.
Any ideas?
Location: Somewhere in the hills of Pennsylvania, I think.
In reply to #91
Re: Cheap and reliable sensor for chlorine levels?
02/06/2008 11:43 AM
"Does anyone know of a cheap and reliable electronic sensor for chlorine levels?"
I don't think that one exists. For if one did, it would be fairly simple to design an inexpensive chlorine/bromine dosing system that would probably become the de-facto standard for pool water care. It could measure and adjust the chlorine/bromine concentration on a regular basis and shock the water once a week. And, I'm thinking that you could also regulate PH and total alkalinity as well. Hmmm..., off to the drawing board I go.......
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
Reply Off Topic (Score 6)
02/06/2008 11:20 AM
Could an Overhead tank and sprinkler sytem help.. Running/moving water when combined with adequate exposure to sunlight and air would prevent algae formation and also kill the parasites. Filters could clean the water when its moved from the swimming pool to the tank. A sensor could automate the pump function.. Evening it would move out the water from the pool.. Sunrise could activate the waters downward journery.. The tank could be fitted with solar panels to make the pump work..
Good Answers: 22
#94
02/06/2008 2:15 PM
STL hinted at using electricity. Tomas could build 2 large Tesla coils, one on either side of the pool. Then fire up the coils and let them run for a few minutes, and shut them down before anyone goes for a dip.
The coils could also be incoporated into a security system that will keep an interloper from taking an illicit midnight swim.
In reply to #94
02/06/2008 3:02 PM
something like one of those backyard bug "zappers"?
Who said engineering couldn't be fun.
Mens Sana In Corpore Sano
#97
In reply to #94
02/06/2008 3:11 PM
I assume that you are trying to create electrical discharges? That may do something in the air, but what effect do you expect in the water? Post #69 describes one view of what electrical storms can do to pool water (though it could be that the cause is not the electricity itself).
Frank N Stine
In reply to #94
02/06/2008 4:01 PM
IMLUVINIT!
02/06/2008 3:09 PM
One other method is using biquanides-the same sanitizing agent used on contact lenses. The pool would have to be shocked (using bromamines-they break down fast in UV light) once every couple of weeks, and pH monitored. Because the biquanides dont break down microorganisms, the filters would have to be changed more often, and the scum line cleaned regularly, but precious little Juanita would get to swim safely without worrying about getting a tumor from 3D's tesla coil.
#100
In reply to #96
02/06/2008 3:27 PM
Chemical the pool like usual. Put the kid in a scuba diving Dry-suit. no skin/water contact, and acts as a flotation device to boot.
#98
02/06/2008 3:17 PM
Based on the consensus here, the economic way would to use chlorine in large quantities and keep Juan (or should that be Alicia) away from the pool until the levels decay to suit her (which could be speeded up using a cascade or fountain).
#102
02/06/2008 8:23 PM
In some areas of Europe, colloidal silver is used for disinfection of swimming pool water. Colloidal silver has been used as a disinfectant for > one century; however, the EPA has started action against its widespread use because it is too effective and a number of industries are using it without adequate controls.
#103
02/07/2008 7:51 AM
Would ultraviolet light work
My question is where did the third character "John" appear from in the previous challenge question
Quote " Tom realizes that he could build a Galilean Telescope from the lens in the magnifying glass and a lens from Johns glasses (John is nearsighted). They could then use this telescope to do their research."
In reply to #103
02/07/2008 11:01 AM
They don't tell us everything! They won't answer questions either. Then we all go nuts trying to figure these things out.
On a serious note, I think Alice had a sex change in the interim.
02/07/2008 11:38 AM
Empty the pool completely and tell the kids it is filled with new exotic 'Water Lite' .. maybe they won't realise (but don't let 'em dive)
In reply to #114
02/07/2008 12:00 PM
They could freeze the pond and take up curling, or maybe just dump loads of cornflour in it and see who can walk furthest. If it's the right shape, they could just drain it and get skateboards. Another possibility is a big krill-feeding whale, though salps may be more manageable.
#119
02/12/2008 10:56 AM
I can see where the UV system will not give a rash to Tomas, but does it solve Juanita's problem?
#120
02/12/2008 12:07 PM
Tomas should consider an electronic water conditioner from Oxion Water Technologies (www.Oxionwater.com). It is very effective and affordable.
#123
02/12/2008 2:10 PM
Swim in a European pool and you will notice there is no chlorine odor. Europeans have virtually standardized on ozone as a disinfectant, while Americans swim in a soup with more than 3 ppm chlorine. Ozone (O3) kills both algae and parasites, and any residual rapidly decomposes to harmless O2. Some low level of chlorine (about 0.5 ppm) is still recommended to ensure disinfection, however.
Good Answers: 70
#124
02/12/2008 3:33 PM
There is a line of pool chemicals marketed as 'SoftSwim', that I have used for ten years in my pool with excellent results. This system is peroxide based, but doesn't bleach hair or irritate skin (except in the concentrated form which is pretty nasty). In addition it doesn't require the constant monitoring with the ph test kit, and is therefore much less of a maintenance issue.
#125
02/13/2008 3:49 AM
Caribbean Clear has worked well in my swimming pool for the past 20 years.
http://www.caribbeanclear.com/
3Doug (1); ad4yt (1); agricola (1); agua_doc (1); alzie (1); Anonymous Hero (20); Anonymous Poster (44); askjoet (1); Cardio07 (1); cuznmonkey (2); FKIA (5); funtlrn (1); Goanna (1); Hendrik (3); InventiveFarmer (1); johnfotl (1); Just an Engineer (1); Keith E Bowers (3); Kris (2); leveles (1); Nigh (2); ozzb (1); RickLee (8); Sleepy (1); STL Engineer (4); Student (1); Stueywright (1); taejonkwando (4); The Prof (1); tick-tock (1); tomfranpat (1); tradestar (1); U V (1); user-deleted-1105 (6)
