Previous in Blog: Sledding: Newsletter Challenge (02/26/08)   Next in Blog: Green Flash: CR4 Challenge (03/11/08)
Falling Ladders: Newsletter Challenge (03/04/08)
Posted March 02, 2008 5:01 PM
User-tagged by 1 user
Welcome to March edition of Monthly Challenge Question from Specs & Techs by GlobalSpec:
Three identical ladders standing squarely on a plane are simultaneously released, starting thirty degrees to vertical. One falls in an open frictionless area. The second falls, without friction, away from a wall that the base contacts initially. The third falls without slipping. In what order do they hit the ground?
Thanks to Physicist? for submitting this question!
(Update: March 18, 8:52 AM EST) And the Answer is...
The first is the earliest to hit the ground. The second takes the longest to fall.
For simplicity, consider the situation in the absence of air damping. As all situations are then lossless (at least until the ladders hit the ground), the total Kinetic Energy depends only on the height of the Centre of Gravity. The KE is the sum of three components: vertical, lateral, and inertial. Because the relation between the height of the CofG and the angle of the ladders is the same for all three ladders, they all display the same relation between vertical and inertial KEs, so the only effective difference is the amount of KE that is required for lateral movement. The CofG of the first ladder falls vertically, so all the available energy is available for falling-and-rotation. The second and third arrangements are identical while the CofG is accelerating horizontally away from the base of the ladder. However, once the angle becomes flat enough, the horizontal component of the CofG's velocity will need to reduce if the base is to remain stationary; for the non-slipping ladder, that is indeed what happens, but there is nothing to restrain movement of the second ladder away from the wall, so it departs with the CofG maintaining constant lateral velocity. Thus, once the lateral velocity of the second and third ladders reaches their peaks, the vertical KE of the non-slipping ladder can outstrip that of the second ladder, so the third ladder goes ahead of the second. Neither viscous damping nor turbulence would change this order.
Can't wait til the end of the month for a new Challenge Question? Check out these weekly challenges from CR4:
On A Forgotten Island: CR4 Challenge (03/18/08)
Reverse Engineering Dinner: CR4 Challenge (03/25/08)
Re: Falling Ladders: Newsletter Challenge (03/04/08)
03/02/2008 7:09 PM
Is the plane in level flight?
03/03/2008 8:06 AM
Apostrophe?
03/03/2008 8:09 AM
No thanks I've just eaten....
03/03/2008 4:50 AM
all 3 will hit the ground at the same time.
regards,
lashsd@yahoo.com
03/03/2008 6:47 AM
The real question here is: if three ladders fall on a plane and there is no one there to hear them fall, will they make any sound?
03/04/2008 5:42 AM
Sound is sound only when it is heard, not otherwise. -S. Saran
03/04/2008 5:55 AM
Maybe the black box flight recorder
03/03/2008 8:05 AM
P.S. The reason for starting at a thirty-degree angle is an attempt to make the shape of the foot of the ladder irrelevant to the problem. Other than that, the angle is arbitrary.
#116
03/11/2008 10:42 AM
I'm new to this forum and have not read of the comments yet, my feeling is that the ladder that is on a frictionless plane without any walls or other influence would hit the surface of the plane slightly ahead of the other two ladders, which would both hit the surface at the same time. This is because the frictionless surface would only impose resistance to vertical forces, such as at the feet of the ladder. The ladders will fall in a path via gravity based on their respective centers of gravity. The difference is that the ladders that have a wall or non-slip contact with the surface is that the COG must follow an arc to hit the surface. The other ladder will have the feet slide as the COG follows the most direct path to the surface of the plane; a vertically perpendicular drop to the surface.
Popular Science - Cosmology - New Member United States - Member - New Member
03/03/2008 8:11 AM
None of the three hit the ground. They each hit the surface of the plane at the same time.
-John
All worthwhile programmers know that constants always vary.
03/03/2008 8:35 AM
Yes, but after they strike the plane they hit the plain, but it depends on what the plane's AGL is above the plain.
Okay, I'm stalling, but if the plane stalls after getting struck by a ladder, then the plane may hit the plain before the ladders.
03/03/2008 8:14 AM
I would say the one with full slip would hit first. As the other two have a horizontal force applied to them at the base, there is a centrifical force involved. As the ladders rotate through an arc, they will experience an impedment due to the force on the base. Any force acting on a system will affect the acceleration due to gravity (ie the objects are not in free fall).
03/03/2008 9:21 AM
... As the other two have a horizontal force applied to them at the base, there is a centrifical force involved. ...
We may rephrase it like this: The ladders that experience an horizontal force (reaction from a wall or friction), also experience a smaller torque, as compared to the slipping ladder. Therefore, the 30 degrees rotation needed to turn the ladders horizontal will be slower for the ladders with the impediment at their bases. I need to check the reaction forces from the ground to nail this better...
If this logic is correct, then the ladder that will arrive second, will be the one with the contact against the wall, as it will leave it at a certain point (reminds of the dumbbell challenge) after which it will move under the same conditions as the first ladder.
Another way to see this, maybe better than the above one, is considering that the impeded ladders CGs are forced to move on a circle (at least for part of their "journey"). This means that we will always have a horizontal component in the CG velocity: this in turn "draws" some kinetic energy from the vertical component, consequently causing the CG to reach the ground later.
tkot
03/03/2008 9:27 AM
Good to see a couple of starters on the reply.
N.B. it doesn't make any difference to the answer, but the ladders are at 30-degrees to the vertical.
03/03/2008 4:52 PM
You seem to be on the right track here Tkot, just one small point:-
The ladders are 30 degrees to the vertical which means they must rotate through 60 degrees to land flatly on the plane.
And yes, this does look like a triple scenario of the barbell challenge which I missed out on.
03/04/2008 7:53 AM
Well maybe we just did not want to have you feel left out there Maniac.
03/03/2008 9:25 AM
OK, folks, it's a plain as well, but it needs to be perfectly flat (a plane) - that's probably why the CR4 team left my mistype unchequed. (If you want it to be a flying object, you'd all better follow guessed's advise and add an apostrophe).
03/03/2008 8:45 PM
A geometric plane, a (aircraft) plane and a carpenter's plane are spelled the same, but since we didn't know the answer to the puzzle the plain truth is we just had to be silly.
03/04/2008 9:44 AM
But wouldn't the grass growing on the plain offer any resistance?
Good Answers: 22
03/03/2008 3:47 PM
I'm beginning to wonder if anyone on CR4 is capable of giving a plain answer. Or is that a plane answer?
03/03/2008 6:27 PM
By Jove, I think Del was on to something! The problem did not specify that the plane was level, i.e., perpendicular with regard to gravitational force (in level flight as Del asked).
Hint: suppose the plane resides at 60º to gravitational force. Now, the ladders begin at 30º to the plane.
I have now concluded that the ladders will simply remain where they started from.
But! The original problem states that the three ladders are released and Fall so I guess it's back to the drawing (CAD) board.
Good Answers: 37
03/04/2008 1:28 PM
Must you plein about it?
03/04/2008 3:44 PM
Perhaps the plain is in plein air... But what does the word plein mean in your context?
Good Answers: 37
03/04/2008 3:50 PM
When used as a verb, it means "to complain". See http://www.onelook.com/?w=plein&ls=a, for example, which defines it as "(v. i. & t.) To complain. See Plain."
03/04/2008 4:16 PM
That is what I guessed (as plaintive is still in general use) but my usual dictionaries didn't give that spelling for your meaning. [Not too surprising? as even Webster says it was obsolete from 1913]
Good Answers: 37
03/04/2008 5:59 PM
I've got the One Look Dictionary on my favorites list for quick reference. I get so frustrated with msWord flagging about every tenth word because its built-in dictionary is limited to what I'm guessing is perhaps a fourth-grade vocabulary. I don't mind TOO much when technical terms are underlined by wavy red [except for the fact that so many common computer, word-processing, and Internet terms are not listed in a spell-checker embedded in a word processing program!], but there are so many others absent! Oh: and no, I didn't really expect "plein" to be in Microsoft Word's list.
I do add regularly to my personal dictionary, but I believe that there should be an optional enhanced vocabulary available for Word. Or do we need a corollary to Wirth's Law ["Software gets slower faster than hardware gets faster"] with the premise that "The dumbing-down rate will soon obsolete fourth-grade vocabularies."?
03/05/2008 8:40 AM
Your premise may well be correct - at which point the economy grinds to a standstill, people starve and either corrective actions kick in or some other society takes over the lead (ready to start the same cycle of barabarism, civilisation, degeneracy - always assuming that your particular society didn't bypass the "civilisation" stage.
On the other hand, I would consider a dictionary that includes words that have been considered obsolete for over a century to be too large - provided that words that are still reasonably current can fulfil the same function (in this case "plain").
P.S. I doubt you would be too impressed were someone to reply in middle English or Babylonian.
Good Answers: 22
03/04/2008 4:32 PM
Who says I was complaining?
I have things to complain about that are far more important than what goes on here at CR4..
03/03/2008 8:00 PM
I'm going to petition the Challenge editors for a question in metallurgy or process engineering. All these physics questions are giving me a headache. My instinctive and probably incorrect response is that all 3 ladders hit the plain, plane, or ground at the exact same time. I see it similar to if you were to drop a bullet from a height of 1 metre, or fire it dead horizontal from a height of 1 metre both bullets would hit the ground at the same time. OK engineers-how wrong am I?
Mens Sana In Corpore Sano
03/03/2008 8:16 PM
Depends on the aerodynamics of each bullet, and of course the curvature of the earth, etc.....
03/03/2008 9:45 PM
as long as we're giving fyz editorial license to have frictionless planes trains and automobiles, my bullets are aerodynamically perfect and the earth is flat
03/03/2008 11:22 PM
cusnmonkey,
As any good long range shooter knows it doesn't actually matter if the earth is flat or not and the BC of the bullet has no bearing on length of time to drop to earth. The only determining factor is the bullets being released at the same time from captivity, ie. from the end of the barrel and the other device at exactly the same time and under identical conditions, same air density, wind speed, etc... They both strike the earth at the same time. Just one is going a lot faster.
Chris
03/04/2008 6:18 AM
We are talking about different things. The bullets paradigm implies free fall, i.e. in the vertical axis it is only the weight that governs either bullet's motion. On the other hand, in the case of the ladders, the motion is not a free fall.
Imagine two bodies, one free falling and another sliding down a slope. They will both cover equal altitudes eventually reaching equal velocities (if there is no friction) but the trip time will be higher for the sliding body, due to lower acceleration.
tkot
03/03/2008 10:18 PM
As the base of the ladders has been eliminated, I will take a ques and say they fall in the reverse as stated. The one that does not slip being first, as the base will not leave to ground, second the ladder with its base against the wall, as momentum imparted to the centre of gravity will slightly lift the base off the ground, thirdly the the frictionless plain as the ladder will rotate about its centre of gravity lifting the base of the ladder further off the ground delaying contact with the floor.
Its all quite plane?
Regards JD.
03/03/2008 11:35 PM
As they are in true frictionless environment they may just float off into space because I am unaware of any frictionless environments on earth except supercooled environments in a vacuum and then the questions becomes which ladder breaks first as it hits the plane?
My vote is frictionless one lands first, base contact one second and of course the non-slipping one last as it has the most friction. The more friction the more drag and drag is just another way of saying slower.
Chris
Engineering Fields - Piping Design Engineering - New Member Egypt - Member - Member since 02/18/2007
03/04/2008 12:58 AM
I will thank the God for me not being there while falling.
It is better to be defeated on principles, than to win on lies!
Engineering Fields - Mechanical Engineering - I am here to help!!
03/04/2008 1:09 AM
When the ladder falls through air, it experiences friction in air. As the second ladder falls without friction (no air resistance, as I understand it), it will fall at faster rate.
First ladder will follow the second ladder as it falls on a frictionless area. As it slips fast the moment increases rapidly.
And, of course the third ladder will bthe last to touch the ground.e
03/04/2008 1:15 AM
The one that falls in an open frictionless area hits first, followed by the one that falls without slipping followed by the one that falls without friction away from the wall it is initially contacting.
While this really needs some maths to be backed up I can't be bothered (and don't think I have the skills to do a proper mathematical analysis) so here is my 'intuitive' reasoning. The one on the frictionless area experiences a rotation around its centre while falling while the other two are experiencing rotation around their ends which is slower. The motion of the one with a fixed end and the one on frictionless floor against a wall are identical up to the point where the one on the frictionless floor leaves the wall at which point its rotation is slower that the one whose end is fixed to the wall. This can also be seen if you trace the path that the end of the ladder takes in all 3 cases with the shortest path being the one on open frictionless area and longest being one initially against wall on frictionless surface.
03/04/2008 4:08 PM
Bob,
You have a very compelling argument:
For a theoretical infinitely thin line (so all points on the line are equidistant from the center of rotation) rotational inertia is the sum over R, of RδRδM - where R is the distance from the center of rotation, and δR and δM are a 'short increment of radius' and its equivalent mass, as δR tends to zero.
This becomes an integral of RdR, which yields the rotational inertia = (MR2)/2.
The ladder in the open frictionless space, as you say, has its center of rotation at its midpoint: so R = L/2. But it also has two 'arms' rotating about that center. Its total rotational inertia is therefore: 2 * (M(L/2) 2)/ 2 = (ML2)/4.
The other two ladders, having their feet constrained, have their center of rotation at the foot, and so R = L; and they only have one 'arm' rotating about that center. Their total rotational inertia is therefore: (ML2)/2.
The rotational inertia of the first ladder, therefore, is ½ that of the other two – so its rotation will accelerate faster.
Since for all ladders the center has the same distance to fall the time it takes the ladder to rotate from 30° off the vertical to 90° off the vertical is entirely governed by how quickly the ladders' rotational rate can accelerate (because all have their foot level with the plane, and we are assuming that the plane is solid and the foot cannot penetrate). Since the first ladder can rotate faster, sooner, it is the one that will fall to the plane soonest.
03/04/2008 2:14 AM
1,3,2.
Good Answers: 94
03/04/2008 5:06 AM
All 3 ladders will hit the ground moments before the compensation lawyer turns up.
03/04/2008 6:35 AM
"In what order do they hit the ground?"
Just being a bit pedantic about the phrase "hit the ground". does this mean if the bottom of the ladder does not leave the ground, then a hit is when the centre of gravity strikes the ground, or if the bottom of the ladder does momentary leave the ground is it a strike when it again touches the ground? As you can see if we are referring to the centre of gravity striking the ground, then time will elapse if any end of the ladder strikes first, this will cause the ladder to oscillate from end to end before the centre of gravity rest on the ground.
Regards JD.
03/04/2008 9:13 AM
As the bottom end doesn't lift, the problem should not arise.
03/04/2008 7:13 PM
Yes I must agree with guest, a simple experiment with a 12" rule, suggest that the bottom does not lift as it rotate about its centre of gravity?
Regards JD.
03/04/2008 7:20 AM
It seems to me that if they are standing on the plane to begin with that they are allready touching the plane before they fall.
03/04/2008 10:12 AM
A simple way to consider this is to use Einstein's Principle of Equivalence. Imagine conducting this test in an elevator moving upwards through infinite space far away from any large celestial bodies. The upward acceleration of the elevator is 9.8 meters per second per second, essentially the same as 'g' on Earth at sea level.
All three ladders will experience the same 'fall' towards the bottom of the elevator, and all three ladders will experience the same amount of rotation as they fall. In all cases the rotation is imparted by the floor to the ladder.
So all three ladders would hit the floor at the same time -- unfortunately the elevator compartment you chose to use was too small and all three ladders hit the far wall before they could reach the floor. So the test was inconclusive.
03/04/2008 10:20 AM
Seeing as how the question is looseley worded, one can assume anything, or nothing.
For instance, how far apart are the ladders?
How precise does the measurement have to be?
How far away is the measuring instrument (the observer?) that determines when they hit?
What is the angle to the observer relative to the the ladders? Are the ladders arranged in a radius equidistant from the observer, or are they in a straight line?
If the observer is not equidistant from all ladders, there will be a difference in measurement due to this factor alone.
Are the ladders falling toward or away from the observer, or at an angle?
Are alll ladders made from the same material? (there is a documented case of some materials not following the accelleration rules in free fall)
Do the second and third ladders fall in an open space?This is not specified, so it cannot be assumed.
Please restate the question more precisely, or be willing to accept variations in your answer(s)
03/04/2008 10:27 AM
A previous guest wrote:
"Are all ladders made from the same material? (there is a documented case of some materials not following the accelleration rules in free fall)."
My reply: You actually have documented evidence of materials that violate the principle of equivalence? That's literally incredible.
--Guest #36
03/04/2008 11:15 AM
"My reply: You actually have documented evidence of materials that violate the principle of equivalence? That's literally incredible."
Perhaps one, or more, of the ladders are made of feathers. But then, OSHA would go into convulsions, and the said feather ladders would be disallowed from the theoretical challenge problem...
03/04/2008 11:27 AM
This type of question is to be answered according to the usual "common sense" rule - i.e.:
If there is an interpretation that allows a reasonable answer without additional information, that is the correct one.
Thus, the ladders can be assumed to see identical conditions except for the differences as described, and the ladders do not interfere with each other.
The measurements do not need to be all that precise - for practical ladders you could easily hear the order of the impacts.
The position of the observer should be irrelevant, as the common-sense assumption is that simultaneous release refers to the same time-frame as the measurement of order of impact. Similarly, the observer would not be moving with respect to the plain.
Used colloquially as here, 'identical' would imply the material and dimensions are so similar as not to affect the outcome.
Other than the stated constraints, the space should be assumed to be open (a plane as well as a plane).
You should also assume that the ladders all see the same gravity, and that the gravitational field is perpendicular to the (ideal) plain.
I imagine that you already knew all this, but wanted to post before thinking too deeply about the problem.
Any more questions?
03/04/2008 10:54 AM
Are you quite sure that 'Elf & Safety won't blow a fuse at the use of ladders without suitable anchors?
Fans of Old Computers - Commodore 64 - New Member United States - US - Statue of Liberty - New Member Engineering Fields - Control Engineering - Process Control Engineer
03/04/2008 12:26 PM
Ladder #1 hits first, the only thing slowing it down from free fall is the horizontal movement acrossed the frictionless plane. This movement will be less than the other 2 ladders. Ladder #2 and #3 seem to almost be the same thing, however, the key is "without slipping". The 2nd ladder's angular velocity will cause the top of the ladder to hit the ground before the rest of the ladder. #3 will hit all at once so #2 will beat #3 "by a nose".
It is impossible to defeat a fool in an argument, he wil bring you down to his level and beat you with experience.
Good Answers: 143
03/04/2008 1:03 PM
3,2,1
But the important thing is that all three ladders, since they have been allowed to fall, must now be destroyed by the safety committee.
03/04/2008 1:19 PM
I am not really sure how the second case is different from the first case, but gravity is constant. They all fall exactly the same distance and have the exact same shape so the air resistance is the same, assuming sliding doesn't present a different amount of surface area cutting thru the air. They arrive at the same time I think is the answere he wants.
#103
03/08/2008 11:21 PM
The difference between the three cases is how many degrees of freedom exist. The first case has 3, the horizontal and vertical locations of the base of the ladder and the angle between the ladder and horizontal. Case 2 has 2: the vertical location of the base and the angle. Case 3 has 1 degree of freedom: angle. (That's my take on the problem.)
Being that the potential energy has to be split up into three distinct modes in case 1, there should be less energy in it's downward velocity causing more time to elapse before contact with the ground. Case 2 (against the wall) should have the middle time, and case 3 (fixed base) should put all its potential energy into rotation causing it to contact the ground first. Now this does ignore that fact that the top of ladder 1 might hit the ground first since the vertical translation along with the rotation cause the top to approach the ground, but I'm too lazy to break out Lagrange multiplies tonight.
-Sully
Good Answers: 22
03/04/2008 1:24 PM
Accudave hit on the same line of thinking as I composed my answer in Notepad. Here's what I concluded:
"Three identical ladders standing squarely on a plane are simultaneously released, starting thirty degrees to vertical."
I take this to mean that the ladders are being held up by hand, then tilted 30 degrees from vertical, and released by their holders at the same moment.
"One falls in an open frictionless area."
I take this to mean that the ladder falls in an area free of walls or any objects that it contact before it hits the ground. The lower end will slide as the upper end falls, and the ground presents no friction (maybe the ground has been slicked by an oil spill. The holder must have stood to one side of the ladder.
"The second falls, without friction, away from a wall that the base contacts initially."
I take this to mean the handler held the ladder against the wall before tilting and releasing it. The base of the ladder stays in contact with the ladder and air drag is ignored, minimal, or non-existant
"The third falls without slipping."
The only thing I can see from this is that the ladder encounters some form of friction and/or air drag.
1 - 2 - 3
The first ladder encounters no resistance. The second remains in contact with the wall at it s lower end until the top contacts the ground, then it slides away from the wall. The third encounters resistance of an unspecified type, but it is enough to prevent slipping.
I will have to give Accudave a vote for a Good Answer.
03/04/2008 1:42 PM
Gravity is the only force applied. Therefore, all of the ladders should hit at the same time.
03/04/2008 3:39 PM
The smooth ground and the wall exert forces perpendicular to and away from their surfaces. The ladder that falls without slipping will also experience friction.
03/04/2008 5:38 PM
In the first case, without friction or obstruction, the only thing keeping the ladder's center of gravity from free falling is the rotational inertia of the ladder. So, this one will hit first.
In the second and third cases the base is restricted from slipping horizontally, so the ladders cannot rotate about their CG. In addition to the resistance of rotational inertia, a decreasing portion of the ladder's weight is pressed sideways against the wall or whatever is restricting the base in the third case. So, less force is available to act against the rotational inertia. Furthermore, instead of falling straight down, the CG of the second and third case ladders must trace an arc.
I do not see how the second and third cases are different, until after the ladder hits the ground.
03/04/2008 5:40 PM
See the dumbbell challenge (two weeks back)
03/04/2008 7:51 PM
the ladder without friction will hit first.
the slipping ladder will hit nsecond
03/04/2008 8:08 PM
I submit that ladder #1 hits the ground first. Next, ladders 2 and 3 hit the ground simultaneously.
-John
03/04/2008 8:41 PM
Yes I agree that number one ladder will hit the ground first, because its centre of gravity will fall in a straight vertical line, but the centre of gravity of ladders two, and three, travels in the same arc, therefore 1 first, 2 & 3 together?
Regards JD.
In reply to #60
03/04/2008 8:52 PM
Hi jdretired,
"therefore 1 first, 2 & 3 together?"
I'm not sure what you meant by posing that as a question. I said that falling order in post # 60. I believe we agree on it. How bout it Physicist?
03/04/2008 9:17 PM
Hi JD and JohnJohn,
Don't know if Fyz will reply to you without giving too much of the answer away as he set the question, so let me try:-
There is a difference between the path taken by the COG of ladders 2 and 3 and hence probably a difference in timings.
Ladder 3 does not slide at all so it can be considered to be hinged at the base and therefore it's COG traces an arc equal to 1/2 the ladder length.
Ladder 2 however, I believe, will behave like the dumbell and at some point between 30 and 90 degrees it will part company with the wall and slide horizontally across the frictionless floor until it hits the ground.
In reply to #63
03/04/2008 9:40 PM
You said "[ladder 2] will part company with the wall and slide horizontally across the frictionless floor until it hits the ground."
According to the original problem: "The second falls, without friction, away from a wall that the base contacts initially. The third falls without slipping."
You could be right, but I'm with jdretired on this one. Intuitively I think we're got it pinned down (that's what engineers do don't they?).
-John
In reply to #65
03/04/2008 11:30 PM
Exactly. To paraphrase what I believe is meant( my interpretation words are in BOLD:-
The second falls (without friction between the ladder's base and the floor/wall) away from a wall that the base of the ladder contacts initially. The third falls without slipping at it's base ."
See diagram in my Post #70.
In reply to #63
03/04/2008 9:42 PM
Hi MPM
So when ladder two falls it generates some centrifugal force, and that has to be provided by g, so the path taken is a resultant? So number three should hit the ground just before 2. interesting.
Regards JD.
03/04/2008 9:25 PM
Hi john
Yes I agree with your answer, and was meant to give a reason why.
bad habits?
Regards JD.
03/05/2008 8:53 AM
If you consider the non-slipping ladder, you will see that initially its CofG accelerates away from the base; however, when it hits the ground the horizontal components of velocity are zero. That implies that it will have decelerated again, which would require a horizontal force towards the base; this is not available for case 2 (frictionless and restrained on one side by a wall). So the case2 ladder (like the dumbbells) must at some point part company with the wall. Therefore cases 2 and 3 do not follow the same paths.
BTW, this line of reasoning applies regardless of starting angle and air resistance...
Over to you...
Good Answers: 37
In reply to #60
03/04/2008 9:10 PM
without being able to prove it, my thesis is that each additional degree of constraint [just like degrees of freedom, but turned inside-out!] "retards" the fall by forcing the center of mass to comply with its dictates. This would say that the order is 1, 2, 3 (frictionless, wall-one-side, and no-slip).
A similar thought-experiment might be dropping three balls. The first drops along a tilted frictionless wall. The second drops along a wall with the same slope and very low friction coefficient against the ball, and the third along a similar wall with a high friction (say, 1.0 C-sub-f). The walls are tilted identically, in the same gravitational field, same height where the balls start, etc., etc.
I believe that the order would be 1, 2, 3. The first ball experiences only "diluted gravity" and accelerates at a rate depending only upon the tilt angle and "g". The second starts out rotating as well as falling, and so loses some potential energy to that mode, slowing the fall rate, until at some point the relative speeds switch us to sliding friction when it takes too much force to spin the ball faster. The ball will continue to spin but at less than the surface velocity rate, likely losing some spin to friction but gaining in downward velocity. The third one builds more rotational inertia throughout its travel, deducting still more from the initial Potential Energy value, and strikes last.
Good Answers: 22
03/04/2008 10:10 PM
As a follow up to an earlier post, I decided to add some illustrations. To paraphrase an old saying, 1 visual image = 1K chunks of verbiage.
Ladder #1:
Ladder #2:
Ladder #3:
I am sure the first two properly illustrate what the question states. The third one shows a possiblity; the wall may or may not be there at all, or positioned where I have placed it.
In reply to #67
03/04/2008 10:39 PM
Somehow I don't think FYZ had your #3 ladder in mind(?). See post #41. Although he didn't specify your ladder #3 situation specifically (I don't think). I'm not sure what your drawing shows is in the spirit of the problem. Maybe I'm wrong. Actually, I was wrong once before, maybe with the first wife, hmmmmmm
In reply to #67
03/04/2008 11:11 PM
Hi 3Doug,
I agree with your ladder 1 and 2 but not with your ladder 3.
Above is my interpretation of the way the ladders fall (OK, left or right doesn't matter).
As I said previously, ladder 3 does not slip therfore, we can consider it as if it were hinged to the floor at the bottom.
BTW, my drawing for ladder 2 is slightly inaccurate (Limitations of powerpoint to draw curves!). Once the COG leaves the circular arc it will not trace a straight line to the ground but a "curved downwards" path bacause the vertical velocity will be increasing all the way to the ground while the horizontal velocity that the ladder attains when it's base parts company with the wall will remain constant ( Just like the barbell Challenge!!! )
United States - Member - New Member Fans of Old Computers - Apple II - New Member Hobbies - Musician - New Member Engineering Fields - Systems Engineering - New Member Engineering Fields - Software Engineering - New Member
#83
In reply to #69
03/05/2008 7:18 PM
I agree with your analysis, except in the case of ladder 2 I understand that the base is moving AWAY from the wall, or it would be identical to ladder 3.
Regardless in cases 2 and 3 the COG's acceleration has some horizontal component that I believe to be the same in both cases.
In case 1 though, the COG will drop straight down vertically.
Intuitively in case 1 the forces acting against the fall are lower.
I say 1 hits first, then 2&3 together.
#84
In reply to #83
03/05/2008 9:11 PM
Hi jfcayron,
A teacher of mine once said the first 3 things you should do in any exam are:-
1. Read the question
2. Read the question
3. Read the question
Now, having read the question again, how can you possibly interpret that ladder 2 has it's base moving away from the wall?
Remember the ladders are at 30 degrees to the vertical when released, therfore whether you interpret "base" to be base of ladder or wall, it both amounts to the fact that ladder 2 falls so that it's top is moving away from the wall.
And no, it does not mean that it is the same as ladder number 3. Look carefully at my diagram again in post #70
#85
In reply to #84
03/06/2008 12:29 AM
You are right, I misread the question.
It does not change the predicted outcome: 1 then 2&3 together.
In reply to #67
03/05/2008 8:59 AM
Ladder 3 would behave the same as ladder 2 - but it is not falling without slipping. The only way that can happen is as MPM illustrates in #70.
Good Answers: 22
#86
In reply to #79
03/06/2008 12:59 AM
To explain my thinking about ladder 3: I thought "falling without slipping" meant that the bottom could move if forced to by the downward motion of the top of the ladder. I equated slipping with the absence of friction. Maybe I was having a reaction to something.
#87
In reply to #86
03/06/2008 5:07 AM
Perhaps I'm misunderstanding you. But: If slipping meant movement along a surface without friction, it would be meaningless in the day-to-day world.
Webster-Merriam on line gives the day-to-day meaning as:
to Slip: to move with a smooth sliding motion
On that basis, "without slipping" should mean that at no point does it move smoothly. Not ideal, but once an object starts to move under friction on a plane (uniform surface) it will move smoothly (in the day-to-day sense). 'This therefore implies that the base does not move along the surface - though it could move laterally if it leaves the surface vertically. We know from the dumbbell argument that the second ladder will slide along the surface at some point, which means that ladders 2 and 3 are at least different.
More directly, the usual technical meaning given by Webster Merriam on-line [as part of 4a)] is:
to Slip: to slide out of place or away from a support
Or by Oxford online [as 3] is:
slp: fail to grip or make proper contact with a surface
03/05/2008 2:31 AM
I don't think the bottom of the ladders in cases 1 and 2 stay in contact with the plane. In fact the top of the ladder may overtake the bottom and contact the plane while the bottom is in the air.
In reply to #71
03/05/2008 3:38 AM
Good question, but does it matter which part of the ladder strikes the ground first, I have sympathy for what you are proposing, but I believe that any part of the ladder striking the ground is classed as a hit. I strongly suspect that the base of ladder 2 leaves the ground, but does it land flat allowing ladder three to hit first, or does the top of the ladder 2 accelerate about its COG so the top of ladder 2, and the flat of ladder 3, hit at the same time?
Regards JD.
In reply to #72
03/05/2008 5:25 AM
For ladder 2's base to leave the ground, it would gave to describe an arc through the wall.
In reply to #74
03/05/2008 5:52 AM
Hi Kris
Get a 12" rule, place your finger at the bottom and let it fall. as it reaches the desk it will spring forward, most of it after the rule lands, in my mind the centripetal and centrifugal forces come into balance at approx 22½° before hitting the ground, it is then a matter of the whether the base slides or lifts, does the centrifugal force being generated by g acting in line with the ladder give an accelerated resultant, like when a ladder is falling down against the wall the bottom accelerates away from the wall faster than the top falls, so is this a case in reverse? I don't know, but put it up as a possibility? If it slides ladder 3 hits first, else how knows.
Regards JD
In reply to #75
03/05/2008 7:24 AM
Hi JD,
I just tried a ruler (against a 'wall') on my desk, and was pretty sure the thing only moved it's bottom end after hitting horizontal, but I'm not 100% sure of what I could see. It's like a variation of the dumbbell question. The ruler experiment definitely ends with it moving (in the direction of lean), but some brave soul will have to do the math to convince me of what's going on. An unconstrained ruler slides back against the angle of lean. My only conclusion so far is that it's worth playing with a ruler to see how it behaves.
Cheers, Kris
In reply to #76
03/05/2008 9:08 AM
You are right that the bottom of the ladder does not leave the ground until the ladder bounces - and even then only if either the ladder or the ground is rough (so that a point between the base and the CofG is the first to hit the ground).
I'll leave typing the sums for another day, though.
Good Answers: 37
#88
In reply to #76
03/06/2008 7:17 AM
I think I have the answer regarding experiments: yesterday's CR4 output included a link to "Phun: a 2D physics sandbox". I cannot see why the experiment can't be run in a virtual world where we can set degrees of freedom / constraint to our liking, set coefficients of friction to 0 (zero) or 1.00 or anywhere between, etc. Nor can I see where a 2D world differs from looking at the ladder precisely edge-on, a projection plane view. So: anybody downloaded it yet? Learned how to use it? Have time to use it?
Good Answers: 94
#89
In reply to #88
03/06/2008 8:41 AM
"So: anybody downloaded it yet? Learned how to use it? Have time to use it?"
Done the 1st, items 2 & 3 will have to fit in when I can manage it, looks like fun though.
In reply to #89
03/06/2008 10:36 AM
Brilliant took about 1 minute to create this solo ping pong game:-
In reply to #90
03/06/2008 10:45 AM
It's a real gas ! I was having a hard time positioning my 'ladder' with no friction, but didn't spend a lot of time on it. I'm fairly sure this question can be emulated on the thing, but that depends on how it was programmed to behave. It's worth a quick play with. Live dangerous and try it.
In reply to #91
03/06/2008 12:31 PM
Hey, Really easy to do the bouncing ball simulation. One minute to do it half an hour to create this composite pic. Don't know why all the small balls are different colours.
In reply to #92
03/07/2008 2:24 AM
Cool ! I didn't get the significance of the colour change either. I shall definately play with this prog some more when I have time. A whole bunch of previous challenge questions can be simulated on it.
#99
In reply to #92
03/07/2008 5:44 AM
I suppose that is the basketball-baseball challenge? Can you tell us what your input parameters were (masses & coefficients of restitution of baseball & basketball, air resistance).
The reason for asking is that it looks as if the top ball has risen to six times the original height in less than twice the time (plus the lower ball scarcely bounced)
In reply to #99
03/07/2008 12:13 PM
This program is more like a game than a real physics simulation. So in particular it's hard to give things specific dimensions and placement (or I haven't found out how to yet). However the two balls were originally the same density, coefficients of restitution were 1, and, no air resistance. Also the frames are not equally spaced in time: I just repeatedly: started stopped and did a screen capture. However, when I reduced the small balls density to 0.5 (from 100: don't know what that means) I did get about 9 times drop distance. The "measuring squares" are cloned, the bottom one is supposed to represent the drop height and the second one starts from about the top of the large ball when its on the "floor" (actually I've "lost" the floor, so I had to fix a beam to replace it). This time I just did a screen capture before starting and again when the small ball reached about its maximum height.
#101
In reply to #100
03/07/2008 3:28 PM
Thanks. I imagine that 100 means percent (for this particular problem it shouldn't matter of what, so long as everything is on the same basis).
On the basis that this is truly a two-dimensional world, I'm beginning to believe the modelling- at least for these simple cases [because making the lower mass 4-times the upper one would give a bounce height of 2.22 or 4.84 times the start height - and your lower ball looks just a touch over twice the diameter of the upper one] .
Regards
Fyz
In reply to #89
03/12/2008 4:21 AM
For anyone interested:- this scene for phun seems to reasonably accurately simulate the situation. You have to mess about a lot with details like corners (in high resolution), and exact positioning. I didn't bother to set the original angle of the ladders accurately. I think the third ladder still slips a bit: using hinges seems to make really weird things happen. Cut and paste the text below into a file called Ladders.phn and save it in the sub directory scenes (under phun); then you can load it from the file menu.
version = 1;
angle = -0.3673485815525055;
body = 3;
collide = true;
color = [0.7097859978675842, 0.4268820881843567, 0.4682828187942505];
density = 100.0;
friction = 0.0;
id = 6;
pos = [-45.16016006469727, -22.0022144317627];
restitution = 0.5;
type = "polygon";
vecs = [[0.122528076171875, 20.03328895568848], [0.1148719787597656, 20.03328895568848], [0.0, 20.03328895568848], [-0.1148719787597656, 20.03328895568848], [-0.122528076171875, 20.03328895568848], [-0.122528076171875, 18.78120803833008], [-0.122528076171875, -9.27355756630277e-07], [-0.122528076171875, -18.78120613098145], [-0.122528076171875, -20.03328704833984], [-0.1148719787597656, -20.03328704833984], [0.0, -20.03328704833984], [0.1148719787597656, -20.03328704833984], [0.122528076171875, -20.03328704833984], [0.122528076171875, -18.78120613098145], [0.122528076171875, -9.27355756630277e-07], [0.122528076171875, 18.78120803833008]]
angle = -0.00432773120701313;
body = 0;
collide = true;
color = [0.9704574346542358, 0.117519736289978, 0.7122856378555298];
density = 100.0;
friction = 2.0;
id = 7;
pos = [8.935851097106934, -42.70936584472656];
restitution = 0.0;
type = "polygon";
vecs = [[-83.87024688720703, 1.895349502563477], [-83.87024688720703, 1.910241280711489e-06], [-83.87024688720703, -1.895349502563477], [-83.87024688720703, -2.021707534790039], [-78.62835693359375, -2.021707534790039], [-1.955558094336686e-15, -2.021707534790039], [78.62835693359375, -2.021707534790039], [83.87024688720703, -2.021707534790039], [83.87024688720703, -1.895349502563477], [83.87024688720703, 1.910241280711489e-06], [83.87024688720703, 1.895349502563477], [83.87024688720703, 2.021707534790039], [78.62835693359375, 2.021707534790039], [-1.955558094336686e-15, 2.021707534790039], [-78.62835693359375, 2.021707534790039], [-83.87024688720703, 2.021707534790039]]
angle = 0.0;
body = 6;
collide = true;
color = [0.920330286026001, 0.5471211075782776, 0.1760539710521698];
density = 2.0;
friction = 0.5;
id = 8;
pos = [-46.07910919189453, -46.26280212402344];
restitution = 0.5;
type = "polygon";
vecs = [[-0.1837921142578125, 1.206132888793945], [-0.1837921142578125, -1.911444314828259e-06], [-0.1837921142578125, -1.206132888793945], [-0.1837921142578125, -1.286542892456055], [-0.1723060607910156, -1.286542892456055], [0.0, -1.286542892456055], [0.1723060607910156, -1.286542892456055], [0.1837921142578125, -1.286542892456055], [0.1837921142578125, -1.206132888793945], [0.1837921142578125, -1.911444314828259e-06], [0.1837921142578125, 1.206132888793945], [0.1837921142578125, 1.286542892456055], [0.1723060607910156, 1.286542892456055], [0.0, 1.286542892456055], [-0.1723060607910156, 1.286542892456055], [-0.1837921142578125, 1.286542892456055]]
body = 4;
collide = true;
density = 100.0;
friction = 0.0;
id = 5;
pos = [7.878161430358887, -21.94937896728516];
restitution = 0.0;
type = "polygon";
angle = 0.0;
body = 0;
collide = true;
color = [0.8521677255630493, 0.7599371671676636, 0.5793073177337646];
density = 100.0;
friction = 0.0;
id = 91;
pos = [-0.03340736031532288, -40.16891479492188];
restitution = 0.0;
type = "polygon";
vecs = [[-0.653759241104126, 0.4236183166503906], [-0.653759241104126, -3.814697265625e-06], [-0.653759241104126, -0.4236259460449219], [-0.653759241104126, -0.4518661499023438], [-0.6128993034362793, -0.4518661499023438], [0.0, -0.4518661499023438], [0.6128993034362793, -0.4518661499023438], [0.653759241104126, -0.4518661499023438], [0.653759241104126, -0.4236259460449219], [0.653759241104126, -3.814697265625e-06], [0.653759241104126, 0.4236183166503906], [0.653759241104126, 0.4518585205078125], [0.6128993034362793, 0.4518585205078125], [0.0, 0.4518585205078125], [-0.6128993034362793, 0.4518585205078125], [-0.653759241104126, 0.4518585205078125]]
body = 9;
collide = true;
density = 100.0;
friction = 2.0;
id = 9;
pos = [53.99565505981445, -22.14850425720215];
restitution = 0.0;
type = "polygon";
color = [1.0, 1.0, 1.0];
geom0 = 7;
geom0pos = [-81.29721069335938, 0.1837895661592484];
geom1 = 0;
geom1pos = [-72.35978698730469, -42.17374801635742];
size = 4.148577690124512;
type = "fixjoint"
geom0 = 91;
geom0pos = [-0.05648288130760193, 0.01562118530273438];
geom1 = 0;
geom1pos = [-0.0898902416229248, -40.15329360961914];
size = 0.0406896248459816;
type = "fixjoint"
Reply Off Topic (Score 4)
#131
In reply to #130
03/12/2008 8:51 AM
That looks almost more effort than setting up the equations!
I haven't done that for a 30-degree start, but I can confirm that a 0-degree start** for case 3 and with an "ideal" ladder (thin, and with uniform mass distribution along the length) there would be an instant when the foot would almost (but not quite) lift - i.e. the vertical component of the force on the foot would instantaneously reach zero. That would require an infinite coefficient of friction to stop it slipping.
So I would not be surprised if a 30-degee start still slips when the coefficient of friction is 2 (will phun accept anything higher?).
However, whatever non-zero coefficient of friction we use for case 3, the order of impact will be unchanged. I'm don't know, however, whether the falling time varies monotonically with μ.
**The time to fall would be infinite, but the dynamics versus angle are relatively straightforward
[As friction-free is already non-practical, I didn't feel that using infinite μ was taking a significant additional liberty - and I felt that lossless conditions would be less troublesome to work with and/or explain]
In reply to #131
03/12/2008 10:50 AM
True, but, it's quick and almost effortless to set up the original trial, and then just progressive fine tuning when trying to figure out why it's not doing exactly what you expect.
Friction, coefficient of restitution density etc. are set with sliders so it looks like 2 is the max for friction. Hum? I suppose I could try editing the text file.
#135
In reply to #134
03/12/2008 10:54 AM
Not knowing the complexities of the package: maybe attach a narrow spike (at a suitable angle to the ladder) stuck into a v-groove?
In reply to #130
03/12/2008 1:35 PM
That's really neat Randall ! The prog is a good way on conveying info on this type of question. Here's a screen capture for anyone interested;
3Doug (10); Abdel Halim Galala (1); AccuDave (1); Anonymous Hero (3); Anonymous Poster (30); BobD (1); Cowboyss (2); cuznmonkey (2); Janissaries (1); jdretired (9); jfcayron (4); Johnjohn (8); Just an Engineer (2); Kris (25); Maths_Physics_Maniac (17); mrmikeb (1); Nigh (2); Odessey2001 (1); pc (1); Physicist? (38); Randall (8); RickLee (2); Ron (9); saran369 (1); TeeSquare (5); Tina (1); tkot (2); TL21043 (6); TVP45 (1); user-deleted-1105 (2)
