Previous in Blog: Sledding: Newsletter Challenge (02/26/08)   Next in Blog: Green Flash: CR4 Challenge (03/11/08)
Falling Ladders: Newsletter Challenge (03/04/08)
Posted March 02, 2008 5:01 PM
User-tagged by 1 user
Welcome to March edition of Monthly Challenge Question from Specs & Techs by GlobalSpec:
Three identical ladders standing squarely on a plane are simultaneously released, starting thirty degrees to vertical. One falls in an open frictionless area. The second falls, without friction, away from a wall that the base contacts initially. The third falls without slipping. In what order do they hit the ground?
Thanks to Physicist? for submitting this question!
(Update: March 18, 8:52 AM EST) And the Answer is...
The first is the earliest to hit the ground. The second takes the longest to fall.
For simplicity, consider the situation in the absence of air damping. As all situations are then lossless (at least until the ladders hit the ground), the total Kinetic Energy depends only on the height of the Centre of Gravity. The KE is the sum of three components: vertical, lateral, and inertial. Because the relation between the height of the CofG and the angle of the ladders is the same for all three ladders, they all display the same relation between vertical and inertial KEs, so the only effective difference is the amount of KE that is required for lateral movement. The CofG of the first ladder falls vertically, so all the available energy is available for falling-and-rotation. The second and third arrangements are identical while the CofG is accelerating horizontally away from the base of the ladder. However, once the angle becomes flat enough, the horizontal component of the CofG's velocity will need to reduce if the base is to remain stationary; for the non-slipping ladder, that is indeed what happens, but there is nothing to restrain movement of the second ladder away from the wall, so it departs with the CofG maintaining constant lateral velocity. Thus, once the lateral velocity of the second and third ladders reaches their peaks, the vertical KE of the non-slipping ladder can outstrip that of the second ladder, so the third ladder goes ahead of the second. Neither viscous damping nor turbulence would change this order.
Can't wait til the end of the month for a new Challenge Question? Check out these weekly challenges from CR4:
On A Forgotten Island: CR4 Challenge (03/18/08)
Reverse Engineering Dinner: CR4 Challenge (03/25/08)
Re: Falling Ladders: Newsletter Challenge (03/04/08)
03/05/2008 5:23 AM
I can't really see the intended difference between ladders 2 and 3. They both have a vertical component of reaction, and also a horizontal one (albeit stated as friction/lack of room to move sideways). For now, I'll just play pick-up sticks. I think 1 is first, then 2 & 3 at the same time (based on path of travel). Since they are ladders, they should follow the Order of the Garter (at least I didn't say the 'b' word )
#81
In reply to #73
03/05/2008 9:11 AM
They are the same until the base of ladder2 parts company with the wall. See post #79.
03/05/2008 7:15 PM
The dumbbell and the slipp'ry floor
Fought for the crown,
And ladders three did climb, afore
They all tumbled down.
...Oh what a fall.... How come no limericks yet?? Or have I missed something?
Some janitor (human or inhuman) will surely have a tough job clearing away all the bouncing/sliding debris of the dumb belles and ladders from that frictionless floor! But let that challenge appear following a decent interlude in the frictional rather than the fictional world.
But for the present I would imagine that the third ladder is constrained by some sort of frictionless hinge at the bottom (by way of not being entirely off-topic).
=TeeSquare=
03/07/2008 12:37 AM
Let's see if I've learnt my lesson.
Ladder 1 will be the first to hit the floor. (It seems to be agreed that it's centre of Gravity falls straight down, there is no resistance to sideways movement of the base of the ladder and so that ladder base slides gracefully out of the way.)
Ladder 3 would seem to be next. Pivoting about a single point (without sliding) on the plane there is no other resistance to movement. That point of rotation will be the "bottom extreme corner" of the ladder rail rather than the centre line.
Ladder 2 will be last since for all of its rotation, the action of the centre of gravity and that ladder being on a frictionless (horizontal) plane will force the ladder against the wall and thus it experiences the restriction of movement (slowness) that this would create. (Wall was not stated to be of the same "magical" frictionless material as the plane.) Friction in the wall material providing a torque opposing rotation.
Again it seems that I'm running slightly against the mob.
By the way, where can I get some of that frictionless plain stuff? Want it for another project.
Good Answers: 37
#94
In reply to #93
03/07/2008 1:01 AM
"Ladder 2 will be last since for all of its rotation, the action of the centre of gravity and that ladder being on a frictionless (horizontal) plane will force the ladder against the wall and thus it experiences the restriction of movement (slowness) that this would create. (Wall was not stated to be of the same "magical" frictionless material as the plane.) Friction in the wall material providing a torque opposing rotation."
I'm reading the situation for ladder #2 differently, I think. You are seeing it initially leaning against the wall with 30 degrees interior angle, correct? But the question says "The second falls, without friction, away from a wall that the base contacts initially." (my emphasis throughout) I cannot fault your sequence for the condition that you are analyzing, but I don't think it matches the original question. I would think that there is an implicit similarity to the previous "dumbbell-almost-against-a-wall" thread on this forum because that question led to this one, I believe.
In reply to #94
03/07/2008 1:13 AM
Thanks for the feedback, some clarification (I hope)
I also see the ladder top falling away from the wall. What the frictionless plane allows though is the bottom of the ladder will try to slide (like the free standing condition) but be impeded by the wall.
Thus, the extreme bottom corner of the bottom of the ladder will remain in contact with the plane (sliding ever colser as the ladder falls.) and the upper corner of the bottom of the ladder will remain in constant contact with the wall. (and thus experience resistance to movement.)
#97
In reply to #95
03/07/2008 5:30 AM
The phrase "The second falls, without friction" was meant to mean that there was no friction anywhere - i.e. no friction from the wall. The intention was that all cases would be lossless** (at least until the ladders hit the ground, at which point all bets are off). Sorry if this was not clear.
**In practice air losses would not affect the result - but I didn't want to introduce yet another variable.
Fyz
#98
In reply to #94
03/07/2008 5:31 AM
Indeed it did.
Fyz
#102
03/08/2008 12:25 AM
Here is my angle (Excuse the pun) on the maths of the sliding ladders:-
Let us first look at ladder 1 and ladder 3.
Ladder 1 will experience a rotational torque about it's centre of gravity whereas ladder 3 is experiencing a rotational torque about it's base point. The torque is provided by the mass of the ladder acting vertically downwards through the COG and the opposing normal Reaction provided by the plane. Thus the torque is the same on all ladders for any given angle theta. What is different however, is the rotational Inertia I. As you will see from the calculations below the angular acceleration on ladder 1 is 4 times larger than the angular acceleration on ladder 3 thus ladder 1 must reach a theta of 90 degrees before ladder 3.
Finally ladder 2 will behave like ladder 3 until it reaches that critical angle (As in the barbell challenge) when it's base parts company with the wall. From then on it will behave like ladder 1 because it is no longer rotating around it's base but now rotates around it's COG just like ladder 1. It's angular acceleration should quadruple and again it will rotate faster than ladder 3 and hence hit the ground before ladder 3, but after ladder 1.
Thus my prediction on the sequence for hitting the ground is :-
ladder 1 first, followed by ladder 2 and finally ladder 3
#104
In reply to #102
03/08/2008 11:32 PM
Does the ladder in case 2 leave contact with the wall first or the floor first?
-Sully
#105
In reply to #104
03/09/2008 10:08 AM
The foot of the ladder does not leave the ground while the ladder is falling. This is true for all three cases.
If we performed the same procedure with a light-handled sledgehammer (head at top), case 3 would leave the ground - but I can't honestly say it would then meet the "non-sliding" constraint.
In reply to #102
03/11/2008 3:07 AM
Try swinging a racket or a club. During the period after ladder 2 leaves the wall: some of the horizontal energy of ladder 3 is converted into rotational (and CoG downward) energy. Hence 3 gets there slightly before 2.
#126
In reply to #109
03/11/2008 6:07 PM
Hi Randall,
I did have the same thought as you when I first started to think about the motion of ladder 3, however that would mean that ladder 3's angular acceleration would suddenly increase at that critical angle when the COG's horizontal velocity reaches a maximum and unfortunately for that to happen some extra force would have to appear to make this so. I believe that the horizontal Force of friction, although it changes direction at the "Critical angle" is present at all times to ensure that the COG of ladder 3 is travelling in a circular path. Thus it is providing for the centripetal acceleration needed to keep the COG of the ladder moving in a circular orbit.
Again, try and imagine ladder 3 as being hinged to the ground ( No slip). The torque force which is causing this ladder to rotate about it's base is simply mg.SinΘ . L/2 as I have shown in post #103
This torque is certainly varying with the angle Θ, but it does not suddenly jump at the critical angle when COG horizontal velocity reaches it's maximum.
The only factor that "jumps" or has an instantaneous change at this critical angle is the rotational inertia, I, of ladder 2. Ladder 2's Rotational inertia has an instantaneous change from mL2/3 to mL2/12 when it's base looses contact with the wall and as Torque = Rotational Inertia X Angular acceleration, this essentially means that as the Rotational Inertia is instantaneously reduced by a factor of 4, the angular acceleration must instantaneously be increased by a factor of 4. I.E. The Torque must keep changing smoothly as per the sinusoidal function which defines it.
I do hope this makes sense.
#127
In reply to #126
03/11/2008 6:23 PM
High time for another hint, I think:
What is the horizontal velocity of the Centre of Gravity of ladder 1 when it hits the ground?
Ditto ladder 3.
Now what about ladder 2?
What does that imply about the relationship between the vertical velocities of the three ladders as they hit the ground?
#128
In reply to #127
03/11/2008 8:51 PM
Horizontal velocity of ladder 1 and ladder 3 is zero when it hits the ground.
Horizontal velocity of ladder 2 is whatever max velocity it had when it parted company with the wall....
Now you have put me thinking deeply about the significance of this.....Hmmmmm.....
Good Answers: 22
#139
In reply to #128
03/12/2008 3:23 PM
Horizontal velocity of ladder 1... is zero when it hits the ground.
I don't think so. As ladder 1 falls, the pull of gravity on the top will push the bottom to one side.
I conducted a quick experiment to confirm this. I have a six-inch steel ruler that a keep on my desk (it doubles quite well as a back scratcher!) that I held at an angle and released. I also had the tip of my index finger on the other hand marking the point where the base was at the beginning of its fall. Twice the base end stopped about 1 1/2 inches away.
#141
In reply to #139
03/12/2008 4:38 PM
Yes, 3Doug,
The base of ladder 1 will have an initial horizontal velocity and the top of the ladder will have an equal an opposite horizontal velocity but the COG will have zero horizontal velocity. Hence when ladder 1 hits the ground at 90 degrees to the vertical the base and top will also have decelerated to a zero horizontal velocity at this point.
That is what I meant in my reply to Fyz.
#143
In reply to #141
03/12/2008 5:02 PM
Thanks MPM - I think I understood you. I'm pretty certain from your diagrams that you are using the correct conditions. For simplicity of analysis (though it is not strictly necessary to arrive at correct answers) I've defined all three so that there are no losses until the ladders have struck the ground. So everything can be seen in terms of conservation of energy.
Fyz
Good Answers: 22
#149
In reply to #141
03/12/2008 7:11 PM
MPM, I did another experiment where I held the ruler at its C/G and marked a point under the C/G. The ruler lands with the C/G to one side of the mark.
JF, the friction in my experiments is neglible. The ruler is very thin, and the surface of the desk is very smooth.
#150
In reply to #149
03/12/2008 8:19 PM
Well 3Doug,
What can I say, other than it is very difficult to sometimes recreate these idyllic environments in the real world. Perhaps, you may be imparting a slight horizontal velocity as you let go of the ruler - I don't know.
However, I think you will agree, if you think about it, ladder 1's COG must fall vertically downwards because in order for it to move horizontally there would have to be force horizontally applied at some stage during it's fall and as it is falling on a frictionless floor this horizontal force can never exist.
I do, however, agree that it's base and top points will move horizontally but in opposite directions to each other, hence cancelling out any horizontal movement of the ladders centre-point.
#151
In reply to #149
03/13/2008 5:08 AM
If you lay the ruler flat on the desk, and gently spin it, does it rotate for as long as it would if you then put a drawing-pin through the C of G and spin it in the same way?
[I thought not].
Unless your ruler is so thin that it cuts into the desk, its thickness will have negligible effect on the level of friction.
It is almost impossible to release a ruler (or anything else] by hand without imparting an impulse at the instant of release.
[Don't try the following at home, but (before health-and-safety) the standard method to approximate impulse-free release was to support the object by a thread tied to an unmoving object and burn through the thread. BTW, once you have watched the effect of holding the end of such a thread in your hand, you will never again rely on hold anything truly stationary by hand].
In reply to #151
03/13/2008 5:55 AM
I'm not sure that cotton thread is made in a non-twisting fashion. Surely some kind of electro-magnetic thing could be devised ?
#154
In reply to #153
03/13/2008 10:25 AM
You are right that normal cotton thread exerts a torque - but it's still a great deal better than releasing anything by hand, and the amount of energy that a thin thread imparts when severed through burning is relatively small. Traditionally, I believe that the thread would have been built from a just-strong-enough assemblage of untwisted silk strands.
_________________________
In my experience, the only perfect things in life are one past tense and the awful mess my wife finds whenever I try to do anything.
United States - Member - New Member Fans of Old Computers - Apple II - New Member Hobbies - Musician - New Member Engineering Fields - Systems Engineering - New Member Engineering Fields - Software Engineering - New Member
#142
In reply to #139
03/12/2008 4:50 PM
Did you run that experiment on a true zero-friction surface?
The friction will bias the test towards the #2 & #3 cases. The horizontal motion should be null in absence of any friction.
#132
In reply to #127
03/12/2008 9:51 AM
I still feel my initial prediction was correct; ladder 1 hits the surface first, with ladders 2 & 3 hitting second at the same time. All 3 ladders are identical and will act identically in identical situations, but we're given 3 situations with different conditions. I also feel that the conditions imposed for ladders 2 & 3 are very similar and have the same influence on the ladder movement. I think we all agree that ladder 1 on the frictionless surface will fall such that its COG will drop straight to the ground while the base of the ladder slides without resistance along the plane. This means all the ladders would do the same thing if they did not have their other influences.
Ladder 2 has its base against a frictionless wall. The wall can only offer resistive force in one horizontal direction, but the ladders base will only want to slide in one direction. The ladders COG path will thus follow an arc because the base can not slide along the floor as with ladder 1 because the wall prevents the horizontal movement with exact and opposite force equal to the ladders force to slide the base. Therefore, the base does not move.
I feel that ladder 3 is similar to ladder 2, except the non-slip surface provides the resistance. The non-slip surface offers resistance to horizontal movement in any direction. Since, we know that ladder 1 wants to fall by allowing the base to slide in one direction, that's all that ladder 3 would do if it weren't for the non-slip surface. So, I feel that the non-slip surface acts the same way as the wall by providing forces equal and opposite to the sliding motion of ladder one, and resulting in ladder 3's COG following the arc of ladder 2. Horizontal forces and velocities from centripetal influences would be the same for ladder 2 & 3, thus causing them to fall at the same rate and path. You can run the numbers to find out what that path would be, but for this question, I feel it's not important. We are asked for the order in which they hit the ground. I think the answer to the question posed is ladder 1 hits the surface first, with ladders 2 & 3 hitting second at the same time.
#133
In reply to #132
03/12/2008 10:13 AM
Please let me appologize for not reading post #79. I'd like to revise my last post with the following.
Based on the info in post 79, think I can see what would happen. I think what your telling us is ladder 1 hitting the surface first, followed by #3, then #2. All 3 ladders are identical and will act identically in identical situations, but we're given 3 situations with different conditions. I also feel that the conditions imposed for ladders 2 & 3 are very similar and have the same influence on the ladder movement. I think we all agree that ladder 1 on the frictionless surface will fall such that its COG will drop straight to the ground while the base of the ladder slides without resistance along the plane. This means all the ladders would do the same thing if they did not have their other influences.
Ladder 2 has its base against a frictionless wall. The wall can only offer resistive force in one horizontal direction, but the ladders base will only want to slide in one direction. The ladders COG path will thus follow an arc because the base can not slide along the floor as with ladder 1 because the wall prevents the horizontal movement with exact and opposite force equal to the ladders force to slide the base. If the centripetal forces cause the base to part company with the wall due to a horizontal force influence away from the wall, the COG would follow an arc of radius L/2 until the horizontal force away from the wall exceeds the force to press the base against the wall. Then the COG would follow a curved path the ground. Since this would be a longer arc than in ladder 3, ladder 2 would be the last ladder to hit the surface.
I feel that ladder 3 is similar to ladder 2, except the non-slip surface provides the resistance. The non-slip surface offers resistance to horizontal movement in any direction. Ladder 3 would then follow the same path as ladder 2 if it weren't for the ability of the non-slip floor to prevent movement away from the initial location of the base, and this causes the COG to fall in an arc with radius L/2.
Sorry for not reading post 79 earlier. My mistake
#140
In reply to #133
03/12/2008 3:45 PM
Hi TL21043,
You say:-
Yes, you are correct that ladder 2 follows a curved path to ground, and that curved path is outside the circular arc and hence the path is longer, but that does not necessarily mean that it takes a longer time. Remember that ladder 2 will leave the wall with some horizontal velocity Vh and on a frictionless surface this Vh will remain constant unless acted on by a force (Once it leaves the wall, there is no horizontal force now for ladder 2). Remember this Vh will in no way affect how ladder 2 will now fall vertically. If you throw a ball 1 horizontally from a tower with an initially velocity gretaer than zero and drop a similar ball 2 from the same tower, then ignoring drag/losses etc they will both hit the ground at the same time although ball 2 travels a longer path!!!
Now, please don't think that I am advcocating that ladder 2 and ladder 3 hit the ground together, you will need to read my previous posts to discover my thoughts on the landing sequence of the 3 ladders...
#146
In reply to #140
03/12/2008 5:42 PM
Thank you, MPM, for pointing out that oversight I had in the longer arc for ladder 2. I should have remembered that. However, that makes me think since the vertical velocities are constant due to gravity, only a force acting in the vertical direction would influence the ladders velocity. Since none of the situations has any other influence in the vertical direction, wouldn't they all hit at the same time? Horizontal velocities due to rotation, etc., would have no influence on the fall. If that's true, then aren't all the discussions about horizontal velocities, although interesting, irrelavent to the answer?
#147
In reply to #146
03/12/2008 5:52 PM
It so happens that you are right but not so much for the reason of a longer path length.
See my post 146 just before you where I eat humble pie.
You may need to read previous posts to see the complications that rotational motion brings to horizontal and vertical velocities...
#148
In reply to #146
03/12/2008 6:25 PM
You can balance a long stick upright by moving horizontally only. Or you can accelerate its rotation. Of course that is quite obvious when the stick is upright, because the vertical motion is negligible. But what you are doing directly is to influence the rotation, and in principle you can continue to do that whatever angle the stick is at (other than horizontal). If the stick (or in our case ladder) is to remain in contact with the ground, the vertical movement of the Cof G must also change with the rate of rotation. The force that allows this change to the vertical velocity is due to upward pressure from the ground; this is self-adjusting just so long as the rotation allows the ladders to provide any downward pressure.
That's quite a mouthful, but I hope it helps.
Fyz
#144
In reply to #127
03/12/2008 5:07 PM
Aha, The light has dawned...Randall is right...
#145
In reply to #109
03/12/2008 5:42 PM
Hi Randall,
You have my humble admiration. I now believe you are correct and the order of hits is in fact 1, 3 and finally 2 and you actually stated this in post 26.
I think I now see the error of my earlier predictions regarding ladder 2:-
Once ladder 2 starts rotating about it's end point, it continues to rotate about it's end point even after it leaves the wall at an angle of 54.74 degrees (Please tell me your calculations agree with this ). It doesn't suddenly change to rotation about it's centre as I was predicting earlier. (Question for Fyz :-Does the rotation point start to move from the base towards the COG at all before ladder 2 hits the ground? )
Up to this angle of 54.74 degrees, ladder 2 and ladder 3 will be tracking each other exactly.
Now, immediately after this angle, the friction force on ladder 3 will start to decelerate it's COG horizontal velocity and of course this energy must get transferred to the COG vertical velocity ( Thanks for the final velocity hint Fyz and the swinging club analogy Randall ). Hence from 54.74 degrees until 90 degrees, the vertical velocity of ladder 3 will increase more rapidly than the vertical velocity of ladder 2 which has no frictional force to convert that parting horizontal velocity to a vertical component. Hence ladder 3 beats ladder 2 between the 54.74 and 90 degrees when it hits the ground.
Finally I thought this pop-up quote to be most appropriate and worthy of repeat:-
"The greatest thing in this world is not so much where we stand as in what direction we are moving." -- Johann Wolfgang von Goethe (1749-1832), playwright
#152
In reply to #145
Re: Falling Ladders: Centre of Rotation?
03/13/2008 5:30 AM
I'm not certain where this might be leading, but...
Because the base of the ladder only moves horizontally, the centre of rotation must always be vertically in line with it (i.e. vertically above, below, or coincident with, the base).
In the first case, the CofG falls vertically - so the centre of rotation must be at the same height as the CofG. That means the centre of rotation moves on a circle that is centred on an axis that is in the plain and is located immediately below the CofG. The radius of the circle is the distance between the base of the ladder and the CofG (i.e. half the total length of an ideal ladder)
In the third case, the centre of rotation is always coincident with the base of the ladder.
For the second case, the centre of rotation is coincident with the base of the ladder until the ladder parts company with the wall, after which it sinks vertically below the base of the ladder. I think its vertical movement is monotonic, but I wouldn't swear to this.
#106
03/10/2008 6:25 PM
To finally clarify the happenings of ladder 2, if we revisit the barbell challenge we will see that the barbell which started at an angle of zero degrees to the vertical left the wall at an angle whose cosine equalled 2/3 or 48.1897 degrees. This happens because when you balance out the loss of potential energy to the gain in kinetic and rotational energy, there comes a point when the horizontal velocity reaches a maximum and at this point the falling and rotating object must leave the wall.
Now the barbell challenge had the barbell leaving the wall at y = 2/3.r
If we were to revisit the equations of the barbell challenge and start with an initial angle Θ we would find that y now becomes 2/3 .r.CosΘ. and hence the angle at which the ladder of barbell parts company with the wall is Inverse Cosine(2/3.CosΘ).
I have listed below the contents of an excel spreadsheet that shows how the parting angle varies with the initial release angle. As you will see, when the initial release angle is 30 degrees to the vertical (As in this case), ladder 2 will part company with the wall at an angle of 54.7356 degrees to the vertical.
Furthermore, it is interesting to note that no matter what angle one releases ladder 2 it will always loose contact with the wall before it hits the floor at 90 degrees to the vertical E.G. Releasing at 85 degrees it looses contact at 86.669 degrees
Column 1 = Starting Angle to the vertical in degrees
Column 2 = Cosine of this angle
Column 3 = 2/3 Cosine of this angle
Column 4 = Inverse Cosine of result in column 3 = Departing angle
Column 5 = Angle difference (Departure angle - Initial release angle)
Theta cos(Theta) 2/3 cos(Th) Inv Cos(2/3Cos(Th)) Angle Difference
0 1.0000 0.6667 48.1897 48.1897
1 0.9998 0.6666 48.1975 47.1975
2 0.9994 0.6663 48.2209 46.2209
3 0.9986 0.6658 48.2599 45.2599
4 0.9976 0.6650 48.3144 44.3144
5 0.9962 0.6641 48.3844 43.3844
6 0.9945 0.6630 48.4698 42.4698
7 0.9925 0.6617 48.5705 41.5705
8 0.9903 0.6602 48.6865 40.6865
9 0.9877 0.6585 48.8176 39.8176
10 0.9848 0.6565 48.9636 38.9636
11 0.9816 0.6544 49.1245 38.1245
12 0.9781 0.6521 49.3000 37.3000
13 0.9744 0.6496 49.4901 36.4901
14 0.9703 0.6469 49.6944 35.6944
15 0.9659 0.6440 49.9130 34.9130
16 0.9613 0.6408 50.1454 34.1454
17 0.9563 0.6375 50.3916 33.3916
18 0.9511 0.6340 50.6514 32.6514
19 0.9455 0.6303 50.9244 31.9244
20 0.9397 0.6265 51.2104 31.2104
21 0.9336 0.6224 51.5093 30.5093
22 0.9272 0.6181 51.8208 29.8208
23 0.9205 0.6137 52.1447 29.1447
24 0.9135 0.6090 52.4806 28.4806
25 0.9063 0.6042 52.8283 27.8283
26 0.8988 0.5992 53.1877 27.1877
27 0.8910 0.5940 53.5583 26.5583
28 0.8829 0.5886 53.9400 25.9400
29 0.8746 0.5831 54.3325 25.3325
30 0.8660 0.5774 54.7356 24.7356
31 0.8572 0.5714 55.1490 24.1490
32 0.8480 0.5654 55.5723 23.5723
33 0.8387 0.5591 56.0055 23.0055
34 0.8290 0.5527 56.4481 22.4481
35 0.8192 0.5461 56.9000 21.9000
36 0.8090 0.5393 57.3610 21.3610
37 0.7986 0.5324 57.8306 20.8306
38 0.7880 0.5253 58.3088 20.3088
39 0.7771 0.5181 58.7953 19.7953
40 0.7660 0.5107 59.2898 19.2898
41 0.7547 0.5031 59.7921 18.7921
42 0.7431 0.4954 60.3019 18.3019
43 0.7314 0.4876 60.8191 17.8191
44 0.7193 0.4796 61.3433 17.3433
45 0.7071 0.4714 61.8745 16.8745
46 0.6947 0.4631 62.4123 16.4123
47 0.6820 0.4547 62.9566 15.9566
48 0.6691 0.4461 63.5071 15.5071
49 0.6561 0.4374 64.0636 15.0636
50 0.6428 0.4285 64.6260 14.6260
51 0.6293 0.4195 65.1940 14.1940
52 0.6157 0.4104 65.7675 13.7675
53 0.6018 0.4012 66.3462 13.3462
54 0.5878 0.3919 66.9299 12.9299
55 0.5736 0.3824 67.5186 12.5186
56 0.5592 0.3728 68.1119 12.1119
57 0.5446 0.3631 68.7097 11.7097
58 0.5299 0.3533 69.3120 11.3120
59 0.5150 0.3434 69.9184 10.9184
60 0.5000 0.3333 70.5288 10.5288
61 0.4848 0.3232 71.1431 10.1431
62 0.4695 0.3130 71.7610 9.7610
63 0.4540 0.3027 72.3825 9.3825
64 0.4384 0.2922 73.0074 9.0074
65 0.4226 0.2817 73.6356 8.6356
66 0.4067 0.2712 74.2668 8.2668
67 0.3907 0.2605 74.9010 7.9010
68 0.3746 0.2497 75.5380 7.5380
69 0.3584 0.2389 76.1777 7.1777
70 0.3420 0.2280 76.8199 6.8199
71 0.3256 0.2170 77.4644 6.4644
72 0.3090 0.2060 78.1113 6.1113
73 0.2924 0.1949 78.7603 5.7603
74 0.2756 0.1838 79.4113 5.4113
75 0.2588 0.1725 80.0641 5.0641
76 0.2419 0.1613 80.7187 4.7187
77 0.2250 0.1500 81.3750 4.3750
78 0.2079 0.1386 82.0327 4.0327
79 0.1908 0.1272 82.6918 3.6918
80 0.1736 0.1158 83.3522 3.3522
81 0.1564 0.1043 84.0138 3.0138
82 0.1392 0.0928 84.6763 2.6763
83 0.1219 0.0812 85.3398 2.3398
84 0.1045 0.0697 86.0041 2.0041
85 0.0872 0.0581 86.6690 1.6690
86 0.0698 0.0465 87.3345 1.3345
87 0.0523 0.0349 88.0005 1.0005
88 0.0349 0.0233 88.6668 0.6668
89 0.0175 0.0116 89.3334 0.3334
90 0.0000 0.0000 90.0000 0.0000
Good Answers: 22
#107
In reply to #106
03/10/2008 9:05 PM
I don't think that ladder #2 and the dumbell can be compared. The base of the ladder is in contact with the wall at the beginning of its fall, and has no reason to move from that position until the momentum of the top end pulls it away. The rotation of the ladder around its CG will push the bottom into the wall unitil the motion of the top away from the wall pulls the entire ladder that direction.
With the duimbell, the top stays in contact with the wall until the momentum of the bottom pulls it away.
#108
In reply to #107
03/10/2008 10:01 PM
Hi 3Doug,
OK, let me try and convince you that we can compare ladder2 and the dumbell:-
Randall drew a nice graph in the dumbell challenge which clearly shows that the COG of the dumbell traces an arc of a circle while the contact with the wall is present. See below:
Now surely you will agree that if that same dumbell fell so that it's top moved away from the wall instead of the base( Just like ladder 2) then the COG will trace precisely the same arc of circle as shown above. Hence the maths and physics exhibit a symmetry that causes the dumbell to leave the wall at the same angle regardless of whether the bottom or the top moves away from the wall.
03/11/2008 5:32 AM
The Top of the ladders 2 and 3 rotate about their bases, the resultant direction of the COG is a product of three forces, centripetal, centrifugal and gravity, the resultant direction progressing from towards the wall, graduating to a direction away from the wall, the rotation of the ladder about it s COG is the reaction with the plane, this is brought about by the force of gravity which is evenly spread over the full length of the ladder, this being true for both ladder 2 and 3. it then becomes a matter of whether ladder 2's rotation about its base varies from that of ladder 3, when ladder 2 leaves the wall?
In the case of ladder 2 some of the energy becomes kinetic moving the ladder away from the wall, it then becomes a question of whether that same force in ladder 2 that became kinetic, acts to retard ladder 3's acceleration, when ladder 3 is restricted from moving away from the wall a new force is introduced into the resultant? Where as ladder 2's resultant is down and away from the wall, ladder 3's new resultant is up (restricted force) and away from the wall, and as it cannot move away from the wall the upward resultant retards its fall. thereby allowing ladder 2 and 3 to land at the same time.
Answer 1 first 2&3 together.
Regards JD.
03/11/2008 6:57 AM
The answer to this challenge will be posted on April 2nd, right here on CR4. Can't wait til then? Then check out these weekly CR4 Challenge Questions:
Is there something happening that I've missed ?
Good Answers: 37
#112
In reply to #111
03/11/2008 7:10 AM
The answer to this challenge will be posted on April 2nd, right here on CR4. Is there something happening that I've missed ?
Yeah - wouldn't the day after March 21st be the next "twos"day?
In reply to #112
03/11/2008 7:13 AM
LOL. I just don't trust them after they printed the question as the answer recently.
#114
In reply to #113
03/11/2008 9:03 AM
"Many's the slip 'tween cup and lip"
(To which the cynical might add "particularly when you're in your cups)
Fyz
In reply to #111
03/21/2008 6:33 AM
Yep, the time warp correction is functional.
#162
In reply to #161
03/21/2008 11:44 AM
Hi Kris
Apparently there is a scheme afoot to give a longer time for one challenge each month (I found out when I wrote to Chris). In this case that turned out to be a pretty good idea - as post-normal contributions were significant. The "solution" was brought forward following my query. Hopefully, there will be a fuller explanation next time it is tried.
Fyz
In reply to #162
03/21/2008 6:00 PM
Thanks Fyz.
I was wondering what had occurred, especially given that recent faux-pas over the 'answer that was a question'. The idea of a longer time to discuss question has merit, though I don't see how that can be thought of in advance it's hard to predict how any given question will run. Most people bail out when an answer is given, which is a bit of a mistake IMHO since good discussion often continues. However, many people view it as a competition and clearly don't read though any comments before posting. There are 2 possibilities that come to mind ;
A - Questions are published in GlobalSpec, so continue to publish answers as normal there, but give an extension when deemed fit to the CR4 answer date. Some people might post a 'spoiler', but that would probably not interfere with those who enjoy debating the detail.
B - Have a standing policy that question not answered will be left so (officially) for a stated period. ( One month was a bit ambitious for a first try !)
For what it's worth, I generally stay subscribed to a challenge question for about a month. There was some recent discussion about a desire to know about replies when a thread had seemingly died-off. The general meaning was that 'subscribed' lists can get too long, yet people don't like to think a direct reply to them would be missed and construed as rudeness etc. By way of example, I probably have many responses to post I made long ago, but I've since un-subscribed because the thread was dormant for > 1 month.
On a slightly different tack - CR4 have/are introducing new forums. It would be good to have a dedicated 'challenge' type forum. Many people post conundrums/puzzles which are often fun to take part in. I may go back to the relevant spot and suggest a CR4 'puzzle-corner' type place. I have an annoyingly difficult maths-crossword that would be fun to post. It require a bit of programming to solve, but the type of people who read the Challenge Question would probably enjoy it.
Kris
#115
03/11/2008 10:39 AM
Ladder 1 hits the ground first, falling straight down.
Ladder 2 hits the ground second, falling on an arc.
Ladder 3 never hits the ground. The wall keeps it from falling past its 30 degree angle and there is no slip. This is how a ladder is used. Remember, common sense.
#117
In reply to #115
03/11/2008 10:48 AM
What wall?
Neither of the other two is set up to be usable, so why do you assume this one should be?
#118
In reply to #117
03/11/2008 11:03 AM
could be the wall stated in condition 2.
but then again, how else would you use a free standing ladder?
Good Answers: 37
#119
In reply to #118
03/11/2008 11:14 AM
Haven't you ever seen the circus performers who climb a free-standing ladder, straddle the top, and "walk" it across the floor?
#120
In reply to #118
03/11/2008 11:19 AM
Since the purpose of the challenge is to determine their rates of fall, the question posed tells you that the wall is in contact with the base of the ladder. Since all 3 ladders start at a 30 degree angle, it would be impossible to have the ladder leaning against the wall while the wall was in contact with the base. Also, the question tells you all three are falling.
#122
In reply to #120
03/11/2008 12:48 PM
Agreed - and the safe angle for using a ladder is appreciably smaller than 30o.
#123
In reply to #120
03/11/2008 12:57 PM
The question is not the rates of fall. The question is "In what order do they hit the ground?"
Nothing says ladder 3 actually has to hit the ground, it could be supported in a position which is its intended use.
If hits the ground means when do the ladders contact the ground, well that could be at the initial condition (t=0).
As to the falling part, it could start at a 30 degree angle @ t=0 and end at say a 32 degree angle @ t=1.
In a follow up reply Physicist stated
"This type of question is to be answered according to the usual "common sense" rule - i.e.: If there is an interpretation that allows a reasonable answer without additional information, that is the correct one."
What is the intended use of a ladder? How are ladders normally used? Sometimes the simplest answer can be the correct answer.
#124
In reply to #123
03/11/2008 5:15 PM
Hmm. The question says "the third one falls without slipping".
And hopefully common sense would also preclude using a ladder at an angle so far from the vertical. (See this safety guide).
It is beyond me why every engineering challenge has to be converted to a children's riddle, and so often in ways that neither the wording nor practicality would support.
CR4 Admin: Replaced broken link (http://www.hse.gov.uk/pubns/indg402.pdf) with link to updated brochure
http://www.hse.gov.uk/pubns/indg455.pdf
#121
In reply to #115
03/11/2008 11:21 AM
I made a similar assumption first but if you read the question it says for #2 "away from a wall that the base contacts initially", and mentions nothing else for #3.
One should assume it is also leaning away from the wall.
Furthermore the question states "The third falls [...]" which would be incorrect with your assumption (it does not fall).
The question leaves to interpretation, but I think the above makes sense.
#125
03/11/2008 6:04 PM
The ladder in the frictionless environment has a direct path to the ground for its CG therefore striking the ground first.
The other two ladders' CG's fall through a complete arch (same distance) only because the one ladder "falls without slipping"...if that ladder's base slipped then it would hit prior to the ladder with the wall at the base because its CG would arc to a 'point of no return' and then the base would slip and its CG would then travel straight down toward the plane (or much closer to 'straight down toward the plane'). The only way these two ladders dont strike the plane at the same time is if there is some kind of friction applied because the base is against a wall...any thoughts on that aspect?
#129
03/12/2008 3:21 AM
Errr, one, then another, and then the last?
03/12/2008 12:40 PM
First of all, I see the initial statement as contradictory - how can a ladder be standing squarely on a plane if it is at 30 degrees to vertical? Regardless, I will first state my assumptions:
1. The ladders do not have non-slip feet but rather have four points of contact (two per 'leg').
2. The first and second ladders slip (only the third ladder is identified as not slipping which would lead one to presume that slippage IS a factor with ladders 1 and 2.)
3. The ladders are non-adjustable - i.o.w. no second ladder on top of the first which can be raised and lowered.
4. All three ladders are affected equally by the pull of gravity.
5. The friction of air, the friction of the wall surface and the friction of the floor surface are all equal in magnitude.
Now for the answer:
Ladder 1 will hit the ground first - no friction of air opposing the pull of gravity, and no friction opposing the slippage.
Ladder 2 will hit the ground second - the ladder will experience only the force of friction of the floor and the wall against it. However the wall will impose resistance only for 15 degrees (vertical) on two surfaces of minimal area (the ladder feet), and the floor will impose resistance only for a short distance (horizontal) on two surfaces of minimal area (the ladder feet.)
Ladder 3 will hit the ground last - the pull of gravity is opposed only by the force of friction of the air against the ladder. However, the force of friction is on the entire surface area of the ladder.
As a side note, if you picture a 30, 60, 90 triangle, the two short legs belong to ladder 2 and the hypotenuse belongs to ladder 3. Therefore, clearly ladder 3 has a greater force against it than ladder 2 since the hypotenuse of a triangle is greater than the two legs combined.
#137
In reply to #136
03/12/2008 1:23 PM
If (colloquially) I ask someone to place a real ladder squarely (say) against a wall, they will ensure that both legs contact the ground. That may be a regional interpretation, but it is what was meant here.
1 & 3 - for economy of presentation, the questions are posed so that the simplest possible interpretation is the one intended. Thus, you rightly assume single section ladders, and just as for real ladders on a flat surface there is a line along which the contact points of both legs runs. Not that this last is essential when the ladders start from 30-degrees.
2. Both the first and second ladders are expressly stated not only to fall, but without friction.
4. Yes.
5. explicitly zero (1 and 2) or enough to prevent any slipping occuring (3).
6. If you include air resistance, the properties of the air should be the same for all three ladders. Or you can assume it to be zero (no air resistance specified). So long as the atmosphere has the same properties for all three ladders, the level of resistance makes no difference to the order in which the ladders hit the ground.
7. I can't see where 15-degrees comes from - the ladders all start at 30-degrees to the vertical.
In case it helps, Randall has created a dynamic illustration (using phun) that corresponds to my intentions.
#155
03/18/2008 4:35 PM
The 'official' answer is very disappointing. It's what my Classical Mechanics professor would have called 'hand waving'. Where are the equations that prove these statements? And frankly, I'm not convinced that the logic is correct in distinguishing the actions of ladders 2 and 3.
The statement is made: The KE is the sum of three components: vertical, lateral, and inertial. Excuse me, inertial? What the heck is inertial kinetic energy? Do you mean Potential Energy? In actuality, the situation here is that gravitational potential energy is being converted into sideways KE, downward KE and rotational KE.
Another statement is: However, once the angle becomes flat enough, the horizontal component of the CofG's velocity will need to reduce if the base is to remain stationary; for the non-slipping ladder, that is indeed what happens, but there is nothing to restrain movement of the second ladder away from the wall, so it departs with the CofG maintaining constant lateral velocity. Thus, once the lateral velocity of the second and third ladders reaches their peaks, the vertical KE of the non-slipping ladder can outstrip that of the second ladder, so the third ladder goes ahead of the second.
The second ladder has one initial constraint (the base of the wall). Once the second ladder it released it free-falls away from the wall. The third ladder has a constant constraint (some type of pivot point that prevents the bottom from moving). For the third ladder to strike the ground before the second ladder does, it must have a greater downward acceleration (achieve a faster velocity downward) than the second ladder. I don't see anywhere in your argument that the pivot point will cause the third ladder to accelerate faster than the second ladder. The fact that the second ladder continues its lateral movement does not necessarily mean that it will fall slower, since (as we all know in the classic fired-bullet vs dropped-bullet experiment) lateral velocity does not affect downward acceleration during free-fall. Given two objects that start in similar initial conditions, if one is in free-fall the other must be accelerated downward if it is to fall faster than the one in free-fall.
Also, the path of the COG of the ladders does not predict which one will land first. An obvious comparion here is a small ball bearing that rolls down a straight inclined plane vs the same ball bearing rolling down a hypercycloid curve. The path along the hypercycloid curve is much longer, but the ball bearing gets to the bottom much faster than the ball bearing rolling down the straight inclined plane. (You may remember this from sophomore year Physics).
Guest March 18, 4:30 PM
#156
In reply to #155
03/18/2008 5:43 PM
Well, I am a little disappointed in the answer too, although I do believe the final answer vis-a-vis the order is indeed correct, I would have liked to have seen the full mathematical analysis for all three ladders which should be able to show the times, t1, t2 and t3 , in terms of acceleration due to gravity, g , and ladder length L (It would be independent of the mass of the ladder).
I also argue that the following statement in the answer, although not affecting the result, is incorrect:-
"Because the relation between the height of the CofG and the angle of the ladders is the same for all three ladders, they all display the same relation between vertical and inertial KEs"
I would argue that because ladder 1 is rotating around it's centre of gravity and ladders 2 and 3 are rotating about their base points, ladder 1 has only a quarter of the "Rotational Inertia" which ladders 2 and 3 have, hence even in the simulation given by Randall for the PHUN software program, we see that ladder 1 hits the ground way ahead of ladder 3.
Fyz, I would welcome your comments...
#158
In reply to #156
03/18/2008 6:26 PM
With regard to ladder three, you are within your rights to consider it as a purely rotating about the base - which would give the MofI you propose. But I don't find this helpful when comparing the three ladders. What makes the ladder2/ladder3 part of the problem tractable is that
1) you can in all cases consider the motion in terms of two components of linear motion of the centre of gravity and the angular motion about the centre of gravity
2) the relationship between the angular velocity and the vertical velocity is the same for all three ladders at any given height (ditto the equivalent components of kinetic energy).
N.B. The difference in presentation is equivalent to the theorem that the moment of inertia of an object about a remote point is the sum of the moment of inertia of a point object of equal mass located at the centre of gravity and the moment of inertia of the object about its centre of gravity.
If you still need equations, they are not difficult - but what I thought was interesting about this problem (as an ancillary to the dumbbells) was that everything (other than the horizontal velocity itself) was in the concept - the equations are simply a formalisation.
#157
In reply to #155
03/18/2008 6:06 PM
It's not just arm waving, but it does suffer from poor editing (my fault - I used a word processor for a substitution and didn't check sufficiently).
So we agree that the kinetic energy of a rigid body moving in two dimensions can be split into three orthogonal parts - those due to linear motion of the centre of gravity in the horizontal and vertical directions respectively, and that due to rotational motion. Because we are considering situations without loss, the sum of these three components depends only on the height of the centre of gravity (and the properties of the ladders, of course - but we can neglect these for this part of the argument, because the ladders have identical properties).
Now, as shown in the dumbbell challenge, for any given angle the relationship between vertical velocity of the CofG and the angular velocity is fixed. That means that the component of KE due to vertical movement reduces as the proportion of KE due to horizontal movement increases. So it is sufficient to show that the horizontal component of KE is in the order {1}<={3}<={2} at all times, which I believe you already accepted.
I believe that your professor would have regarded the addition of the equations as an exercise for the student. If not, let me know where the problems lie.
BTW, I certainly wouldn't rely on the path length alone.
Fyz
In reply to #155
03/19/2008 3:32 AM
Where do you think the horizontal energy is going?
I liked this challenge because it could be solved conclusively by "hand waving".
#160
In reply to #159
03/19/2008 6:10 AM
Although I believe that you an I are in complete agreement as to the substance, I think we have a linguistic issue here.
To my mind, hand-waving means non-rigorous and therefore inconclusive. Solutions involving equations can be completely non-rigorous, even when the manipulation of the equations is immaculate (they can indeed be wrong, as we have sometimes seen in various attempts at solution on CR4). The contrast here is that we have a situation where the logic requires to set up the equations leads to a rigorous solution - and without any need for the equations to be made explicit.
I personally believe that the ability to handle this type of problem lies at the heart of good engineering and physics. Unfortunately, because such the solutions to such problems are expressed in language that can be variable, they are hard to examine (and even harder to demonstrate that the examinations have been properly marked); as a result, these problems are woefully under-represented in many of the places they should gain the highest regard - the educational institutions. My hope is that guest's ex-professor would appreciate the solution (once correctly reworded); sad as it may be, I also fear he would find him/her-self unable to mark a solution expressed in those terms.
Fyz
In reply to #160
03/22/2008 8:12 PM
Hi Fyz,
The Ladders discussion has indeed been very informative, and I regret I haven't been able to participate or even read through all of it carefully. I too liked the hand-waving approach to the solution. Here I wish to digress on your remarks about the nature of engineering/physics problems and how we perceive them. My comments are based on a reading of some CR4 challenges during the past few months, and my own experiences as a design engineer. I do find it amazing that many of the contributors to CR4, who are obviously quite competent and presumably responsible for crucial (possibly life-and-death) decisions in their professional work based on their knowledge of science and engineering, can hold such diverse and even contradictory opinions regarding applying the basic principles of physics. I make no claim however of being better informed than anyone else in this forum (I only manage to look in here now and then, and occasionally put in my tuppence worth). I can vouch for the truth of what you said about solving the 'wrong' equations rigorously -- happens so often, even to me.
I have sometimes speculated on the 'problem' addressed in your remark, and even wondered if there is some fundamental flaw in human understanding of what our supposed civilisation refers to as 'science', considering the prevalence of misconceptions or contrary positions taken by technical experts all the time. I had come across an interesting book "Understanding Force" by J W Warren (Physics Dept., Brunel U, London. Publ: 1970 John Murrray). It was aimed at teachers but I found it quite an eye-opener regarding some of my own misconceptions. I'm told the author was not very popular, particularly at conferences, because he would point out some of the basic errors which others were making! His book quotes examples of loose statements from some well-known texts relating to force, motion, inertia, etc.
At a more fundamental level, here is a quotation from Bertrand Russell's "The Principles of Mathematics" published in 1903 (!): "... The first thing to remember is -- what physicists now-a-days will scarcely deny -- that force is a mathematical fiction, not a physical entity...." This appears in chapter LVII on Newton's Laws of Motion **. I can only wonder what the statement implies, as the contents of the book are more in the realm of metaphysics and mostly beyond my comprehension. But it does seem to me that all kinds of apparently unconnected things are referred to by us as force (say from surface tension to friction to gravity to electrostatic attraction), and I'm told that today scientists prefer to talk (euphemistically?) of interactions.
It is not only in mechanics, but in other areas of science as well that our understanding is found wanting. For instance in the CR4 challenge on concave mirrors (Funny Reflection, Nov 2007) to which I ventured some contributions, I am still unable to understand why there is no change in my perception of my face as image when my eye traverses the focal point and the image changes from real to virtual. However I just can't articulate any objection to the explanation given by MPM, so I guess I'll just live with the contradiction (like I do with so many other unresolved issues). But my kind of doubt regarding curved mirrors is perhaps more widely prevalent, as at one point I seem to have been accused of reporting an imagined observation without actually trying it out.
Perhaps all this rightfully belongs in some other more appropriate forum, but it got triggered in the current context, and I am much too inept at dealing with computers and the internet to attempt initiating something elsewhere.
**[I am not referring to the three-volume "Principia Mathematica" by Whitehead & Russell, which I believe is completely unintelligible except to a few weird greyheads on this planet].
=TeeSquare=
#165
In reply to #164
On force and inertia
03/23/2008 5:14 PM
I don't believe that Russell's view of force purely as a mathematical fiction is entirely helpful. Einstein, for example, regards a force due to an accelerating inertial frame as entirely equivalent to gravity, the inverse of which is that gravitational force is equivalent to an inertial acceleration. But the existence of different types of field** acting on different materials in different proportions means that the intermediate concept of force must indeed have physical validity (in so far as any model does). That is not to say that I reject everything in W&R.
BTW, I don't believe that 'Principia Mathematica' is mainly for greybeards*** - for the most part people grasp the main features before middle life or not at all (though I have no doubt there will be exceptions who take a late-life opportunity to do this).
**E.g. electric fields are still best described as generating a field that generates a force. I know that string-theorists use other models, but string-theory remains so stretchy that (at least to date) you can model almost any behaviour you choose. In my book, that precludes it from providing useful physical models (that is until some meaningful constraint allows it to successfully predict a new feature - or at least the size of one not otherwise understood)
***I'm in no position to judge the 'weird' bit - being brought up with them, my old colleagues seem relatively normal...
In reply to #165
Re: On force and inertia
03/26/2008 8:10 PM
My apologies for the uncharitable remarks about academics. My 'weird' opinion goes back to a time when out of curiosity I opened a couple of pages in W&R, and told myself it was humanly impossible for any normal person to meaningfully grasp all that mass of concentrated hieroglyphics. Perhaps it is about as difficult as learning say Chinese, but I have no intention of attempting either. My work experience has been altogether in industry with little need for mathematics beyond conventional geometry and trigonometry. My encounters with academia (in engineering disciplines) have not in general been particularly fruitful. No doubt conditions could be quite different in western nations, so I shouldn't generalise.
The point I was trying to make in the earlier post seems to have got side-tracked by my auxiliary comments. I was mainly curious about why there is so much disparity in the understanding of problems involving basic principles of physics or mechanics, even among experienced professionals. I suspect there may be some inherent 'flaw' in science itself **. There is much in science which is not intuitive, and hence liable to different perceptions unless a common logic is followed systematically. For instance an energy approach could lead one to a different result from that based on the equations of motion, and only someone with a deep understanding may be able to find where the error lies. I clearly don't belong in that category, but I'm generally wary of proofs or results which I cannot verify to my own satisfaction (though I could still be wrong!).
One area which has always intrigued me has been the persistent confusion between weight and mass. Defining mass as a fundamental unit was no doubt necessary for scientists to get around certain practical difficulties in dealing with force, but even engineers (let alone lay people) continue to be bewildered by the distinction. I've actually come across one bloke who believed that the newton was the metric ton as opposed to the long ton of 2240 lb. The need for separately defining the mole which is also a quantity of matter, is another grey area for me, but I'll leave that to the chemists to sort out.
Now if anybody on this thread would care to comment on any of this.... ?
** [For instance now there is a point of view that science is not value-neutral, but socially loaded in certain insidious ways, but I don't have access to sufficient material to form an independent opinion. It also raises questions about the boundaries between science, applied science, and technology.]
TeeSquare
In reply to #170
03/27/2008 4:20 AM
I really should wait for the more qualified to answer, but mass, like moles, is just the amount of stuff you have. Weight is the 'force'* between two lumps of 'stuff'. It depend upon how much stuff you have and how far apart they are. Hence you would weigh less on the top of Everest than you would at sea level, even though the amount of stuff is the same. With moles, chemists want to know how many bits of stuff there are to interact with each other, a bit like pairing people up at a dance. You might do better to wait for a good explanation !
* rendered gibberish by Kg.g = Newtons force !
#172
In reply to #170
03/27/2008 8:37 AM
TeeSquare,
I am new to this forum and like you, not someone who works with physics in my day-to-day work. My most recent encounters with physics are helping my son with his homework and this forum. However, I must have had something stick when I was in college learning physics and chemistry as part of the basic mandatory courses you take for mechanical engineering curriculum. I'll think I may be able to help you with your struggle with mass and moles. If I don't quite word this properly, I hope someone corrects me so it doesn't lead you astray.
I remember that it was eady for me to grasp that mass is the resistance of an object to be accelerated, not much different from the definition of inertia. In fact I found one definition on the internet that stated mass is the characteristic of matter that gives it inertia, which I remember being defined as the force of resistance to acceleration. An example would better clarify this. If you had a large object that, on earth weighed 20 tons and was floating in the weightlessness of space, the object has no weight because there is no gravitational force acting on it. However, if you were next to the object in space and tried to push it away from you in the weightless environment, you would apply a force against the object that would cause you to move away from the object's original location faster than the object would move. If that is still difficult to grasp, think of trying to push a large ship while you are floating in the water. You will move more easily than the larger object because the larger object has a much greater mass. Gravity pulls the object toward earth, but because the ground stops you from falling to the center of the earth, you feel the resistance against the ground. That resistance is measured with scales in units of weight that are dependent completely on the gravitational acceleration. That's why on the moon you would weigh less than on earth but not have less mass.
Moles in chemistry have to do with determining a specific characteristic of the material. The mole is defined as 6.022 x 10^22 of molecules (Avogadro's number, if I recall correctly, but I can't remember why that was determined to be THE number to use.) The concept is that if you had the same number of molecules of any substance, its properties would be unique from other substance with the same number of molecules. For example, A mole of iron weighs more than a mole of Styrofoam. That's because even though you have the same number of molecules, their mass per molecule is different. It's sort of like asking someone what weighs more, 10 tennis balls or 10 cannon balls. This fixed quantity gives chemists the ability to evaluate properties of substances with the consistency of them having the same number of molecules. Another example would be that a mole of carbon dioxide gas has greater volume than a mole of dry ice, but it's still the same number of molecules.
I hope I have at least helped.
#173
In reply to #170
03/27/2008 5:37 PM
Hieroglyphics: undergraduate (specialist) mathematicians soon learn to cope with hieroglyphics. The reason for using them is that they are preferable to the alternatives - using the same symbol with different meanings in several places, and/or repeatedly using long descriptors to retain precision. Over the years, conventions have built up as to how and where these are used, which makes life relatively easy once you are used to them. Some of that may be in danger of getting even worse now that Andrew Wiles has brought together previously disparate branches of mathematics (as part of his truly scary proof of Fermat). Far from only being followed by a rarefied group of potential greybeards, at my university there were over 200 students in each year following this course - and I believe numbers have increased since then.
Practically useless academics: the essentials in academia are interest and rigour - though not necessarily simultaneously. That unfortunately means that not all academics are suited to providing work that is useful in the day-to-day world. And just like other professions, there will even be those who are duffers within their own environments. On the other hand, I have received significant help in my more practical work from academics over the years (but you do need to know what to ask of whom).
Rigour: this is at the heart of the general difficulties. The sort of rigour that is needed to communicate scientifically is not a 'natural' function - it needs to be developed deliberately. The communications themselves also need a specialised use of language - which is not helped by the fact that we often appropriate terms (potentially each having a wide range of meanings) from common language. The downside is that the alternative (specialist terms that are not used in day-to-day language) is even worse; in addition, the terms would probably survive less than a generation before acquiring additional less precisely-defined meanings.
Mass vs Weight: At least part of the confusion between mass and weight arises from the fact that we commonly use the effects of gravity (weight) to assess mass - and this is even true when it comes to measurement methods.
Spring scales measure weight directly - they will weigh lighter at the top of a mountain than at ground level.
Some balances measure mass by comparing the weight of the mass of interest with the weight of standard (reference) masses. Ignoring the effects of buoyancy, they will measure approximately the same at the top of a mountain as at ground level.
Just to further confuse matters, spring scales are called balances because they work by balancing forces.
The above confusion would probably be resolved by experience if our normal range of environments included living in places where the gravity is very different (factor of two or more?)
"Value-neutral" partly that depends what you mean by the phrase. If we are referring to moral values, that is probably correct (except possibly for physical sciences concern with demonstrable and repeatable truth, which you may regard as having some moral force). Science is unlikely to provide any insight into morality - other than at the most basic level of the moral contribution to the survival of societies. But what scientists do is not necessarily morally neutral - whether it be Dr. Menghele in Nazi Germany, or Lister or Pasteur at other extremes; nor (in my opinion) should scientists hold demonstrable truth above basic morality... But we are a long way beyond my expertise
In reply to #173
03/30/2008 8:25 PM
Thanks, Fyz, for your meticulous response to my ill-considered remarks. I can only admire your patience and tolerance in reading through and replying to all the points which are raised by so many people, as it must be taking up an enormous amount of your time even if you are super-efficient at it.
I am indeed sorry that my remarks on mass and weight led three of you (including Kris and TL21043) to conclude that I was seeking enlightenment in that area, whereas I was essentially remarking on the prevailing situation in engineering practice. Obviously I must choose my words a lot more carefully in future.
I had not intended to run down academics either generally or specifically, when I made a limited statement about my experience in dealing with engineering faculty in India. Actually I have a soft corner for the teaching profession and should have been in it myself, considering that both my parents were school teachers and the majority in my circle of relatives have been in school or college jobs, albeit mainly in the humanities. My liking for science eventually led to a career as a mechanical design engineer, but I kept in touch with theory and concepts as far as possible. After fifteen years in industry I went back and got a post graduate degree with the hope of moving to an academic career. But I realised soon enough that I would be a misfit. Since I was an even greater misfit in the corporate world, I've been floating around happily for two decades doing whatever peculiar assignments take my fancy! I have indeed studied some engineering subjects under remarkably knowledgeable professors, and also encountered comparable theoretical knowledge outside of a university. Anyway I'm not qualified to throw stones in either direction.
I generally agree with your views on rigour and interest, and quite appreciate the difficulties in defining industrial problems suitably for an academic framework. It's certainly true that rigour does not come to most of us naturally -- we are invariably glad to take a shortcut.
I fully understand the need for using symbols in any profession, the technical ones certainly. For me all the lines and hieroglyphics in an engineering drawing or hydraulic circuit diagram hold a world of meaning which no words can convey. In my opinion, the current trend of representing engineering objects as 3-D 'drawings' is a retrograde exercise which might make sense to people with no imagination. But the software industry is laughing all the way to the bank because of fools who cannot hold pencil to paper.
I'm afraid I was deliberately somewhat vague about "value-neutral". Apart from a moral factor I was also implying a perhaps unintentional bias in ignoring information from say tribal or 'primitive' sources when it does not fit into any of the artificial classifications of objects and ideas in the western tradition. That is probably changing though, but possibly too late as much would have been destroyed already. Prof Needham's work on Science and Civilisation in China is a fantastic effort, but that too relates to an 'advanced' culture.
In later posts 176 and 177, Kris and you have referred to bluff. I've encountered plenty of it, even the brazen variety. I don't think I've deliberately done it myself, but I must have been guilty at times of ignorance or over-confidence or self-delusion in my technical communication -- which to someone else would be nothing but bluff! For me it is always a game searching for essential substance amidst all the sales talk and glossy brochures. My feeling is that the internet has drastically reduced the reliability of available information, as there are strong commercial and strategic grounds for propagating false information of all kinds by organisations and governments. Apart from deliberate misinformation, a lot of careless work can be dressed up to look impressive, because it's so cheap and easy.
I can't help being bewildered by all the Towers of Babel which surround me, as various technical and other interest groups ascend towards their respective heavens. No doubt my hut will get choked out of existence by all the high-rise structures, but I remain resigned to my fate.
Ultimately it appears that nobody (in this thread at least) has a good explanation for why there was so much variation in the approaches to the dumbbell and ladder problems. There are some obvious goofs like considering centripetal and centrifugal forces -- a topic worthy of a separate discussion perhaps. So my conclusion is that a lot of us apparently honest practitioners of science or engineering may actually be dangerous to society because of the way we take decisions. I have found that it is easy to make conceptual mistakes when dealing with forces (action, reaction, external, internal) in even simple mechanisms. Maybe many of my errors went undetected because the equipment worked satisfactorily anyway. But many disasters could possibly be traced to inadequate rigour on the part of people like us. Perhaps that's one of the myriad reasons why the world is in such a mess, and only getting worse as far as I can make out.
I am indeed pleased that many aspects of the problem of communication in science have been aired in this thread, and from the nature of the official answer I feel this wider discussion beyond the ladder problem per se is not really off-topic.
=TeeSquare=
In reply to #189
03/31/2008 2:26 AM
I once had to give a daily sit-rep to a senior guy. Having handed over the graph of data, he studied it for several seconds before I reached over and turned it the right way up ! My wink saved his embarrassment, and from then on he was more than happy to just listen to my verbal summary. 'Bluff' probably happens for a lot of reasons, and I'm sure I've done it many times (certainly by omission of saying anything) when I've thought to myself I'd better read up on something PDQ. I once heard a lecturer say that passing the exam was the most important thing, we could get to understand the subject when we were let loose on the world. In a way, I think his philosophy was right.
#191
In reply to #190
03/31/2008 5:39 AM
My inexpert opinion:
Your lecturer was demonstrably right in terms of your employment prospects!
He would also have been right in terms of utility iff
a) the exam was structured to check that you had assimilated enough to know where to look whenever you found the appropriate problem, and
b) some aspect of your course had developed your problem-solving capabilities.
I've always had my doubts about the latter (and perhaps university is many years too late?). Unfortunately, based on graduate interviews conducted over the last ten years, I now strongly doubt the former.
In reply to #191
03/31/2008 6:09 AM
LOL. If only they could foresee the consequence of their wisdom. One of my triumphs was getting the highest mark for a particular course, even though I never went to a single lecture ! I figured that lectures that were no more than a verbatim rendition of a hand-out given afterwards were a waste of time. Such study is better down without distraction in the small hours. The conflict with opening hours down the pub was pure coincidence. I confess that a goodly amount of my time was spent studying past papers, then allocating time in proportion to the seeming importance of topics. Facts in themselves are no more than a parlour game, it's knowing where to find them and how to apply them that counts. I'm a fervent believer in the value of cryptic crosswords, and seemingly idiot tasks like trying to trisect angles. Those types of coffee-time antics exercise the brain.
#193
In reply to #192
03/31/2008 6:20 AM
Maybe methods for trisecting angles (using only pencil, ruler and compass) to some specified degree of accuracy would make a good CR4 challenge?
In reply to #193
03/31/2008 7:07 AM
That would be interesting, though it could run and run. Even if somebody met the required accuracy, we'd never know how much it could be improved on (?). Also, a thread filled with diagrams might be annoying to some. Some of my wilder excursions have gone as far as using wall-paper ! It would certainly bring out a lot of geometric trivia, Morley, Napolean etc.
#195
In reply to #194
03/31/2008 10:29 AM
Nothing wrong with things that can be improved. Clearly, you can go as close as you wish with alternate bisections (1/2-1/4+1/8-1/16+...), but that's obviously not optimum.
I'd be inclined to specify the required theoretical accuracy**, and see how few of moves*** it can take to achieve this
***There are several definitions for a move that probably lead to different optimal solutions -
one possibility is to define a move as either a placement of the needle of the compasses or the drawing of a straight line,
another possibility is the creation of a cross on the paper or the drawing of a straight line
**Maybe 0.1% of resulting angle, on the basis that this probably exceeds most practical drawing precision.
In reply to #195
04/01/2008 5:17 AM
I still can't see how to frame such a question well. My musings last night led me to see that I can draw a 36o angle, armed with nothing more than a piece of paper and pencil. I'm sure you can see how many strokes of the pencil that would take, but is it obvious ?
In reply to #164
Re: Falling Ladders: Newsletter Challenge (03/04/08)
03/24/2008 3:40 AM
It's off-tack a bit, but you may enjoy vermins thread about understanding of quantum physics. It's looking at misconceptions, and how things are described etc.
#167
03/25/2008 10:19 AM
Before I accept this solution I must be shown that the ladder first contacts the ground in a horizontal position. Since the ladders are rotating as they fall, we must consider the possibility that the top of the ladder overtakes the rest of the ladder and contacts the ground first. If so, the height of the fall is reduced by the distance of the center of gravity from the ground when the top hits.
In reply to #167
03/25/2008 6:52 PM
You could be right. Guidlines for safe use of ladders suggest using a suitably heavy person to steady the foot of a ladder. If the person at the top of the ladder is a lot heavier, there's a danger that the assistant could be launched skyward.
#169
In reply to #167
03/26/2008 6:24 AM
A stronger constraint is that the base does not leave the ground.
=> all we need to show is that the force applied at the base is upwards whenever the ladders are contacting the ground.
We don't need to do this for the first case, as rotation can only make these ladders hit the ground earlier.
The second ladder will not leave the ground if the third one doesn't.
So we only need to show that the third ladder does not leave the ground. This will depend on its mass distribution. A simple analysis shows that if we release a ladder with uniform mass distribution from the vertical position the vertical force on the base will just reach zero and then increase again - it will not change sign. We are starting 30-degrees from the vertical, so we would need a very non-uniform distribution of the ladders were to lift - and all ladders I have seen are close (enough) to uniform.
03/27/2008 8:29 PM
Thanks to Kris for the link to vermin's thread in post 167. It was interesting all right, but way beyond my competence for any meaningful comment.
My grouse is that even before addressing the problems relating to language or interpretation of conventional Newtonian mechanics, all the experts have moved into the rarefied territory of quantums and quarks and strings and what-not. I suppose there is no excitement (or money) involved in dealing with mundane problems, or maybe we just pretend that they don't exist.
Thanks to those who have responded to my comments in post 171. Actually I don't have much difficulty in dealing with the concepts of mass, weight, etc. myself, but communicating ideas without ambiguity is sometimes a nightmare. And maybe it would be worthwhile to investigate why there is so much confusion among professionals. Or are these monsters only in my own imagination?
=TeeSquare=
In reply to #174
03/28/2008 4:56 AM
Maybe part of the problem is that as people rise up the tree of knowledge, they forget basic principles. It's also possible to get by using equations without understanding where they come from. As a (probably poor) example, many people could quote the formula for solving a quadratic equation but couldn't give it's derivation, either because they never learned it or have forgotten it. Knowing how to use the formula is arguably of greater practical use, but the ability to understand where it comes from is what enables someone to progress to more difficult things.
I'm sure a lot of people bluff the appearance of knowledge, it's easy enough to garner key-words with the internet. The UK tendency toward course work rather than exams leaves me skeptical. Taking my cynical hat off, it's probably difficult to go back from a higher plane and explain something fundamental. Understanding something in ones own head is a lot different to being able to explain it, though being able to explain is probably a truer measure of understanding than ability to use knowledge.
If it's any consolation, I don't understand quantum physics but by reading here and there I may one day start to comprehend. CR4 has a lot of people who are fantastic at breaking down complex subjects.
#176
In reply to #175
03/28/2008 6:31 AM
"a lot of people bluff the appearance of knowledge"
Even more important, bluff the appearance of understanding? I plead guilty. I manipulate the equations of QP (more truthfully, the subset known as QED), and come up with answers that seem to match measurements. Some people think I understand it; I got tired of explaining that I don't.
In reply to #176
03/28/2008 7:23 AM
On the occasions I read about QP, I get the impression it's like shoring up a wobbly house with ever more inventive blends of plaster. It probably works, but becomes increasingly odd to new prospective buyers.
#178
In reply to #177
03/28/2008 8:50 AM
Er - definitely not possible if you're plastered - so no.
It's highly consistent, superbly tightly structured - and utterly inimical to (my version of) human understanding.
But you couldn't live in a logical house...
In reply to #178
03/28/2008 5:16 PM
....the Borg do, but that's not really living. There was an old woman who lived in a shoe, but I doubt she had planning permission. I was once much amused by my local council writing to advice me that I lived in a "Housing in Multiple Occupation Area Action Zone". There was I thinking it was a 2-bedroom terrace !
#180
In reply to #179
03/29/2008 7:26 AM
Surely the Borg was an apparently emotionless tennis player whose silences (should that be one long singular) were actually the result of "determination to suppress a suspect temperament"?
In reply to #180
03/29/2008 9:35 AM
It's a bit of a paradox, given the reported Sweedish lack of inhibition about jumping naked into icy lakes. They had much more 'style' in the days of Perry.
Good Answers: 22
#182
In reply to #179
03/29/2008 1:53 PM
Apparently there is some disagreement about how the Borg were bjorn, err, born.
In reply to #182
03/29/2008 4:15 PM
I just know this will eventually lead to someone posting a gratuitous picture of seven of nine ! Oh well, it's a dirty job, but someones got to do it
#184
In reply to #183
03/29/2008 5:03 PM
this posting exploits men
Good Answers: 22
#185
In reply to #184
03/30/2008 2:34 AM
I'd definitely let her assimilate me! Resistance not even considered!
In reply to #184
03/30/2008 2:59 AM
True enough, but men and women are symbiotic. Even a smiling baby is just using a softly-softly approach to get what it wants (with the exception of being about to burp), it's the nature of our species. As someone once said, " humans are the only creatures that blushes, or need to."
Good Answers: 37
#187
In reply to #186
03/30/2008 12:45 PM
"As someone once said, ' humans are the only creatures that blushes, or need to.' "
Mark Twain
In reply to #187
03/30/2008 3:29 PM
Thanks Ron.
3Doug (10); Abdel Halim Galala (1); AccuDave (1); Anonymous Hero (3); Anonymous Poster (30); BobD (1); Cowboyss (2); cuznmonkey (2); Janissaries (1); jdretired (9); jfcayron (4); Johnjohn (8); Just an Engineer (2); Kris (25); Maths_Physics_Maniac (17); mrmikeb (1); Nigh (2); Odessey2001 (1); pc (1); Physicist? (38); Randall (8); RickLee (2); Ron (9); saran369 (1); TeeSquare (5); Tina (1); tkot (2); TL21043 (6); TVP45 (1); user-deleted-1105 (2)
Previous in Blog: Sledding: Newsletter Challenge (02/26/08)   Next in Blog: Green Flash: CR4 Challenge (03/11/08)
